Raspberry 1 Wire GPIO4 Adafruit Thermocouple MAX31850K
Begonnen von AlexA., 15 Dezember 2017, 12:47:07
AlexA.
ich möchte dieses Modul parallel zu den vorhandenen DS1820 Fühlern auslesen.
Muß ich hierfür nur die Einträge in der 58_GPIO4.pm hinzufügen? (siehe beide Abschnitte mit "$family eq "3B"")
#  $Id$
#  Copyright notice
#  (c) 2012 Copyright: Peter J. Flathmann (peter dot flathmann at web dot de)
#  All rights reserved
#  This script free software; you can redistribute it and/or modify
#  it under the terms of the GNU General Public License as published by
#  the Free Software Foundation; either version 2 of the License, or
#  (at your option) any later version.
#  The GNU General Public License can be found at
#  http://www.gnu.org/copyleft/gpl.html.
#  A copy is found in the textfile GPL.txt and important notices to the license
#  from the author is found in LICENSE.txt distributed with these scripts.
#  This script is distributed in the hope that it will be useful,
#  but WITHOUT ANY WARRANTY; without even the implied warranty of
#  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
#  GNU General Public License for more details.
package main;
use strict;
use warnings;
use POSIX;
use vars qw{%attr %defs};
sub GPIO4_Initialize($) {
my ($hash) = @_;
$hash->{DefFn} = "GPIO4_Define";
$hash->{UndefFn} = "GPIO4_Undef";
$hash->{NotifyFn} = "GPIO4_Notify";
$hash->{GetFn} = "GPIO4_Get";
$hash->{AttrList} = "tempOffset pollingInterval model loglevel:0,1,2,3,4,5,6 ".$readingFnAttributes;
sub GPIO4_Notify($$) {
my ($hash, $dev) = @_;
return if($hash->{DEF} ne "BUSMASTER" || $dev->{NAME} ne "global" || !grep(m/^INITIALIZED$/, @{$dev->{CHANGED}}));
# check bus for new devices not before fhem.cfg completely loaded to avoid duplicates
GPIO4_GetSlaves($hash);
delete $modules{GPIO4}{NotifyFn};
return;
sub GPIO4_Define($$) {
my ($hash, $def) = @_;
Log 4, "GPIO4: GPIO4_Define($hash->{NAME})";
my @a = split("[ \t][ \t]*", $def);
return "syntax: define <name> GPIO4 <id>|BUSMASTER" if (int(@a) != 3);
$hash->{NAME} = $a[0];
$hash->{TYPE} = 'GPIO4';
if ($a[2] eq "BUSMASTER") {
$hash->{STATE} = "Initialized";
else {
my ($family, $id) = split('-',$a[2]);
if ($family eq "28" || $family eq "10" || $family eq "3B") {
# reset failures counter
setReadingsVal($hash,'failures',0,TimeNow());
$hash->{fhem}{interfaces} = "temperature";
GPIO4_DeviceUpdateLoop($hash);
else {
return "GPIO4: device family $family not supported";
return;
sub GPIO4_GetSlaves($) {
my ($hash) = @_;
Log 4, "GPIO4: GPIO4_GetSlaves()";
open SLAVES, "/sys/bus/w1/devices/w1_bus_master1/w1_master_slaves";
my @slaves = <SLAVES>;
chomp(@slaves);
close(SLAVES);
$hash->{SLAVES} = join(',',@slaves);
foreach my $slave (@slaves) {
GPIO_GetSlave($hash,$slave);
return;
sub GPIO_GetSlave($$) {
my ($hash,$slave) = @_;
Log 4, "GPIO4: GPIO4_GetSlave($slave)";
my ($family, $id) = split("-", $slave);
# return if device exists
foreach my $devicename (keys %defs) {
return if (exists $defs{$devicename}{DEF} && $defs{$devicename}{DEF} eq $slave);
# device does not exist, let autocreate create it
my $model;
if ($family eq "28") {
$model = "DS18B20";
elsif ($family eq "10") {
$model = "DS1820";
        elsif ($family eq "3B") {
$model = "MAX31850";
DoTrigger("global", "UNDEFINED GPIO4_${model}_${id} GPIO4 $slave");
$attr{"GPIO4_${model}_${id}"}{model} = $model;
return;
sub GPIO4_DeviceUpdateLoop($) {
my ($hash) = @_;
    my $pollingInterval = $attr{$hash->{NAME}}{pollingInterval} || 60;
Log 6, "GPIO4: GPIO4_DeviceUpdateLoop($hash->{NAME}), pollingInterval:$pollingInterval";
GPIO4_Get($hash);
InternalTimer(gettimeofday()+$pollingInterval, "GPIO4_DeviceUpdateLoop", $hash, 0);
return;
sub GPIO4_Get($) {
my ($hash) = @_;
Log 6, "GPIO4: GPIO4_Get($hash->{NAME})";
open DATA, "/sys/bus/w1/devices/$hash->{DEF}/w1_slave";
if (<DATA> =~ /YES/) {
<DATA> =~ /t=(-?\d+)/;
my $temp = $1/1000.0;
if ($attr{$hash->{NAME}}{tempOffset}) {
$temp+=$attr{$hash->{NAME}}{tempOffset};
readingsBeginUpdate($hash);
readingsBulkUpdate($hash,"state","T: $temp");
readingsBulkUpdate($hash,"temperature",$temp);
readingsEndUpdate($hash,1);
else {
readingsSingleUpdate($hash,'failures',ReadingsVal($hash->{NAME},"failures",0)+1,1);
close(DATA);
return;
sub GPIO4_Undef($) {
my ($hash) = @_;
Log 4, "GPIO4: GPIO4_Undef($hash->{NAME})";
RemoveInternalTimer($hash);
return;
1;
=pod
=begin html
<a name="GPIO4"></a>
<h3>GPIO4</h3>
<ul>
  1-wire temperature sensors connected to Raspberry Pi's GPIO port 4.
  <br><br>
  <a name="GPIO4define"></a>
  <b>Define</b>
  <ul>
    <code>define &lt;name&gt; GPIO4 ('BUSMASTER'|&lt;id&gt;)</code>
    <br><br>
    Defines the BUSMASTER or one of the slave devices. The BUSMASTER is necessary
    to get the slaves automatically created by autocreate.pm.
<br><br>
    Examples:
    <ul>
      <code>
    define RPi GPIO4 BUSMASTER<br>
define mysSensor GPIO4 28-000004715a10<br>
  </code>
    </ul>
  </ul>
  <br>
  <a name="GPIO4attr"></a>
  <b>Attributes</b>
  <ul>
    <li><a href="#pollingInterval">pollingInterval</a></li>
    <li><a href="#tempOffest">tempOffset</a></li>
    <li><a href="#readingFnAttributes">readingFnAttributes</a></li>
  </ul>
  <br>
</ul>
=end html
=begin html_DE
<h3>GPIO4</h3>
<ul>
  1-wire Temperatursensoren an GPIO Port 4 des Raspberry Pi.
  <br><br>
  <b>Define</b>
  <ul>
    <br><br>
    Definiert den BUSMASTER oder die Slave-Devices. Der BUSMASTER ist notwendig,
    um die Slave-Devices automatisch via autocreate.pm zu erzeugen.
    <br><br>
    Examples:
    <ul>
      <code>
      </code>
    </ul>
  </ul>
  <br>
  <b>Attributes</b>
  <ul>
  </ul>
  <br>
</ul>
=end html_DE
=cut
Danke, Gruß Alex
KölnSolar
Hi Alex,
vermutlich nicht.  :'(
Wenn ich es richtig in Erinnerung hab, basiert das Modul ja auf w1-therm/w1-gpio und da wird Dein Sensor nicht enthalten sein.
Grüße Markus
AlexA.
#2
Ich komme nicht wirklich weiter. Ich hänge mal die Geänderten Dateien an.
Ich bekomme noch immer die Meldung:
Zitat2017.12.16 12:14:10 0: Server shutdown
2017.12.16 12:14:13 1: Including fhem.cfg
2017.12.16 12:14:13 3: telnetPort: port 7072 opened
2017.12.16 12:14:13 3: WEB: port 8083 opened
2017.12.16 12:14:13 3: WEBphone: port 8084 opened
2017.12.16 12:14:13 3: WEBtablet: port 8085 opened
2017.12.16 12:14:13 2: eventTypes: loaded 12 events from ./log/eventTypes.txt
2017.12.16 12:14:17 1: Including ./log/fhem.save
2017.12.16 12:14:17 1: PERL WARNING: Use of uninitialized value $model in concatenation (.) or string at ./FHEM/58_GPIO4.pm line 116.
2017.12.16 12:14:17 1: PERL WARNING: Use of uninitialized value $model in concatenation (.) or string at ./FHEM/58_GPIO4.pm line 117.
2017.12.16 12:14:17 2: autocreate: define GPIO4__6c98073dab74 GPIO4 3b-6c98073dab74
2017.12.16 12:14:17 1: define GPIO4__6c98073dab74 GPIO4 3b-6c98073dab74: GPIO4: device family 3b not supported
2017.12.16 12:14:17 1: ERROR: GPIO4: device family 3b not supported
2017.12.16 12:14:17 1: usb create starting
2017.12.16 12:14:17 3: Probing CUL device /dev/ttyAMA0
2017.12.16 12:14:17 3: Probing TCM_ESP3 device /dev/ttyAMA0
2017.12.16 12:14:18 3: Probing ZWDongle device /dev/ttyAMA0
2017.12.16 12:14:18 3: Probing FRM device /dev/ttyAMA0
2017.12.16 12:14:23 1: usb create end
2017.12.16 12:14:23 0: Featurelevel: 5.8
2017.12.16 12:14:23 0: Server started with 23 defined entities (fhem.pl:15564/2017-12-07 perl:5.020002 os:linux user:fhem pid:12415)
Bitte helft mir.
Danke, Gruß Alex
AlexA.
Es wird der Ordner für den MAX angelegt und nach einem Neustart auch die w1-slave Datei aktualisiert.
24 03 e0 11 f0 ff ff ff 75 : crc=75 YES
24 03 e0 11 f0 ff ff ff 75 t=50250
AlexA.
Tja, Klein- und Großschreibung beachten. ;)
58_GPIO4.pm
#  $Id$
#  Copyright notice
package main;
use strict;
use warnings;
use POSIX;
my ($hash) = @_;
return;
else {
if ($family eq "28" || $family eq "10" || $family eq "3b") {
else {
return;
my ($hash) = @_;
chomp(@slaves);
close(SLAVES);
return;
my $model;
$model = "DS18B20";
$model = "DS1820";
elsif ($family eq "3b") {
return;
my ($hash) = @_;
GPIO4_Get($hash);
return;
sub GPIO4_Get($) {
my ($hash) = @_;
else {
close(DATA);
return;
my ($hash) = @_;
return;
1;
=pod
=begin html
<h3>GPIO4</h3>
<ul>
  <br><br>
  <b>Define</b>
  <ul>
    <br><br>
<br><br>
    Examples:
    <ul>
      <code>
  </code>
    </ul>
  </ul>
  <br>
  <b>Attributes</b>
  <ul>
  </ul>
  <br>
</ul>
=end html
=begin html_DE
<h3>GPIO4</h3>
<ul>
  <br><br>
  <b>Define</b>
  <ul>
    <br><br>
    <br><br>
    Examples:
    <ul>
      <code>
      </code>
    </ul>
  </ul>
  <br>
  <b>Attributes</b>
  <ul>
  </ul>
  <br>
</ul>
=end html_DE
=cut
AlexA.
Kann das Jemand ins Git-Hub übernehmen!?
Gruß Alex
KölnSolar
Prima, dass es klappt u. der Sensor doch v. w1.. unterstützt wird.
Github ? Is nicht, da es weder ein "offizielles" Modul ist, noch einen maintainer gibt. Du könntest das ja übernehmen .... ;)
AlexA.
Ich!? Ich kann nur bissl an den Codes rumpfuschen. Verstehen tu ich's nicht wirklich.
Gruß Alex
