Beleuchtung einschalten wenn ich nach Hause komme
Begonnen von reimundko, 16 Dezember 2017, 14:50:56
CoolTux
Wie Otto schon sagt, es geht nicht darum ins Log zu schreiben sondern wann wie ein Event erzeugt werden soll auf das Dein DOIF am Ende triggert (anspricht)
Das TuxNet Wiki:
https://www.cooltux.net
Caleus
OK ich danke euch
also am besten unter PRESENCE absencetimeout setzen.
Caleus
Kenne ich (noch) nicht, aber wenn ich die Doku lese:
Zitatevent - A presence check by listening to FHEM events of other definitions.
absenceTimeout
(only in mode "event" applicable)
The timeout after receiving an "absent" event, before the state of the PRESENCE definition is switched to "absent". This can be used to verify the permanent absence by waiting a specific time frame to not receive an "present" event. If this timeout is reached with no "present" event received in the meantime, the presence state will finally be set to "absent". The timeout is given in HH:MM:SS format, where hours and minutes are optional. If this attribute is set to a valid value, the reading state and presence will be set to "maybe absent" during the absence verification.
Default Value is 0 (no absence verification)
Bist Du im event Mode?
Caleus
Tja du da bin ich überfragt. Ich wüste nicht mal wo man das einstellt ?
Caleus
"eingestellt" wird das nicht, das ist eine Frage Deiner Definition / des Modus:
ZitatThe PRESENCE module provides several possibilities to check the presence of mobile phones or similar mobile devices such as tablets.
This module provides several operational modes to serve your needs. These are:
lan-ping - A presence check of a device via network ping in your LAN/WLAN.
fritzbox - A presence check by requesting the device state from the FritzBox internals (only available when running FHEM on a FritzBox!).
local-bluetooth - A presence check by searching directly for a given bluetooth device nearby.
function - A presence check by using your own perl function which returns a presence state.
shellscript - A presence check by using an self-written script or binary which returns a presence state.
lan-bluetooth - A presence check of a bluetooth device via LAN network by connecting to a presenced or collectord instance.
Each mode can be optionally configured with a specific check interval and a present check interval.
check-interval - The interval in seconds between each presence check. Default value: 30 seconds
present-check-interval - The interval in seconds between each presence check in case the device is present. Otherwise the normal check-interval will be used.
Define
Mode: lan-ping
define <name> PRESENCE lan-ping <ip-address> [ <check-interval> [ <present-check-interval> ] ]
Checks for a network device via PING requests and reports its presence state.
Example
define iPhone PRESENCE lan-ping 192.168.179.21
Caleus
Ich habe keine Ahnung sorry.
Aber hier mal die RAW Definition
defmod PBT PRESENCE local-bluetooth 1C:23:2C:xx:xx:xx
attr PBT userattr presence presence_map structexclude
attr PBT event-on-change-reading state
attr PBT presence Anwesenheit
setstate PBT present
setstate PBT 2018-10-16 21:02:46 .absenceThresholdCounter 0
setstate PBT 2018-10-16 21:02:46 .presenceThresholdCounter 0
setstate PBT 2018-10-16 21:02:46 device_name Samsung Galaxy S7 P
setstate PBT 2018-10-13 15:21:44 model local-bluetooth
setstate PBT 2018-10-16 21:02:46 presence present
setstate PBT 2018-10-16 21:02:46 state present
und 2 Bilder im Anhang.
Caleus
Ich habe auch keine Ahnung aber
Zitatdefmod PBT PRESENCE local-bluetooth 1C:23:2C:xx:xx:xx
Du verwendest local-bluetooth und nicht event.
Zumindest verstehe ich die Doku so  8)
CoolTux
Mach mal so
defmod PBT PRESENCE local-bluetooth 1C:23:2C:xx:xx:xx 10 60
attr PBT absenceThreshold 24
Bei Abwesenheit prüft er alle 10s auf Anwesenheit und bei Anwesenheit alle 60s ob Du Abwesend bist.
Ausserdem wechselt er erst nach 24x10s Abwesenheit tatsächlich in den absent, vorher bist Du maybe absent
Das TuxNet Wiki:
Caleus
Leider klapt es bis jetzt nicht, es triggert auch wenn wir zu hause sind.
CoolTux
Ein list aller presence Device und des DOIF bitte.
Das TuxNet Wiki:
