VCCU/CUL_HM - Problem mit ignored Devices
Begonnen von DeeSPe, 17 Dezember 2017, 22:33:54
DeeSPe
Nach "set VCCU defIgnUnknown" habe ich folgende Meldungen im Log:
2017.12.17 11:59:40 1: PERL WARNING: Use of uninitialized value $mh{"devN"} in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 1182.
2017.12.17 11:59:40 1: stacktrace:
2017.12.17 11:59:40 1:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (1182)
2017.12.17 11:59:40 1:     main::CUL_HM_Parse                  called by fhem.pl (3696)
2017.12.17 11:59:40 1:     main::Dispatch                      called by ./FHEM/00_HMUARTLGW.pm (1388)
2017.12.17 11:59:40 1:     main::HMUARTLGW_Parse               called by ./FHEM/00_HMUARTLGW.pm (1491)
2017.12.17 11:59:40 1:     main::HMUARTLGW_Read                called by fhem.pl (3500)
2017.12.17 11:59:40 1:     main::CallFn                        called by fhem.pl (702)
2017.12.17 11:59:40 1: CUL_HM  error: no IO deviced!!! correkt it
2017.12.17 12:06:01 1: PERL WARNING: Use of uninitialized value $mh{"devN"} in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 1182.
2017.12.17 12:06:01 1: stacktrace:
2017.12.17 12:06:01 1:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (1182)
2017.12.17 12:06:01 1:     main::CUL_HM_Parse                  called by fhem.pl (3696)
2017.12.17 12:06:01 1:     main::Dispatch                      called by ./FHEM/00_HMUARTLGW.pm (1388)
2017.12.17 12:06:01 1:     main::HMUARTLGW_Parse               called by ./FHEM/00_HMUARTLGW.pm (1491)
2017.12.17 12:06:01 1:     main::HMUARTLGW_Read                called by fhem.pl (3500)
2017.12.17 12:06:01 1:     main::CallFn                        called by fhem.pl (702)
2017.12.17 12:06:01 1: CUL_HM  error: no IO deviced!!! correkt it
2017.12.17 12:08:29 1: PERL WARNING: Use of uninitialized value $mh{"devN"} in concatenation (.) or string at ./FHEM/10_CUL_HM.pm line 1182.
2017.12.17 12:08:29 1: stacktrace:
2017.12.17 12:08:29 1:     main::__ANON__                      called by ./FHEM/10_CUL_HM.pm (1182)
2017.12.17 12:08:29 1:     main::CUL_HM_Parse                  called by fhem.pl (3696)
2017.12.17 12:08:29 1:     main::Dispatch                      called by ./FHEM/00_HMUARTLGW.pm (1388)
2017.12.17 12:08:29 1:     main::HMUARTLGW_Parse               called by ./FHEM/00_HMUARTLGW.pm (1491)
2017.12.17 12:08:29 1:     main::HMUARTLGW_Read                called by fhem.pl (3500)
2017.12.17 12:08:29 1:     main::CallFn                        called by fhem.pl (702)
2017.12.17 12:08:29 1: CUL_HM  error: no IO deviced!!! correkt it
Bei den ignored Devices wird der Set-Befehl auch fehlerhaft angezeigt (siehe Screenshot).
Wäre es nicht sinnvoller bei ignored die Set-Befehle ganz auszublenden?
Dan
DeeSPe
martinp876
DeeSPe
Die im Screenshot von mir gezeigten "komischen" set Befehle sind leider immer noch da.
Dan
martinp876
Culhm liefert keine.... Das macht die zentral FW.
Welche Kommandos wären sinnvoll? Ich kenne keine...
Vielleicht fällt mir was ein.
DeeSPe
Dan
DeeSPe
Vielen Dank Martin, jetzt passt's!!!
Dan
