eq3: Read callback: Error: read from http://www.eq-3.de:80 timed out
Begonnen von Burny4600, 31 Dezember 2017, 10:46:22
Burny4600
Was muss ich bei dieser Fehlermeldung eq3: Read callback: Error: read from http://www.eq-3.de:80 timed out ändern?
   BUSY       0
   CFGFN      /media/hdd/fhem/mycfg/HM/hm_rasp01.cfg
   DEF        http://www.eq-3.de/service/downloads.html 86400
   Interval   86400
   LASTSEND   1514712964.83361
   MainURL    http://www.eq-3.de/service/downloads.html
   MaxAgeEnabled 1
   ModuleVersion 3.4.0 - 9.9.2017
   NAME       eq3
   NR         2300
   STATE      <div style="text-align:left">last <a title="eq3-downloads" href="http://www.eq-3.de/downloads.html">homematic</a>-fw-check => 2017-12-31 10:11:28<br><br><pre>| device                  | model                   | old_fw | new_fw | release    |
| no fw-updates needed!                                                            |</pre></div>
   TRIGGERTIME 1514799364.83107
   TRIGGERTIME_FMT 2018-01-01 10:36:04
   TYPE       HTTPMOD
   addr       http://www.eq-3.de:80
   auth       0
   buf
   data       suchtext=&suche_in=2&downloadart=11
   displayurl http://www.eq-3.de/service/downloads.html
   header
   host       www.eq-3.de
   httpversion 1.0
   ignoreredirects 0
   loglevel   4
   path       /service/downloads.html
   protocol   http
   redirects  0
   timeout    2
   value      0
   QUEUE:
     2017-12-31 10:36:10   LAST_ERROR      connect to http://www.eq-3.de:80 timed out
     2017-12-31 10:36:10   LAST_REQUEST    update
     2017-12-31 10:11:28   MATCHED_READINGS fw_link-01 fw_link-02 fw_link-03 fw_link-04 fw_link-05 fw_link-06 fw_link-07 fw_link-08 fw_link-09 fw_link-10 fw_link-11 fw_link-12 fw_link-13 fw_link-14 fw_link-15 fw_link-16 fw_link-17 fw_link-18 fw_link-19 fw_link-20
     2017-12-31 10:11:28   UNMATCHED_READINGS
     2017-12-31 10:11:28   newFwForDevices no fw-updates needed!
   REQUEST:
     header
     ignoreredirects 0
     retryCount 0
     type       update
     value      0
   defptr:
     readingBase:
     readingNum:
     readingOutdated:
     readingSubNum:
     requestReadings:
       update:
   sslargs:
   alias      eq3
   enableControlSet 1
   event-on-change-reading .*
   event-on-update-reading LAST_ERROR,MATCHED_READINGS
   eventMap   reread:Neuanfrage
   group      .Firmware Updates
   reading01AutoNumLen 2
   reading01Format http://www.eq-3.de/%s
   reading01Name fw_link
   reading01RegOpt g
   reading01Regex <a.href="(Downloads\/Software\/Firmware\/[^"]+)
   readingMaxAge 10
   readingMaxAgeReplacementMode delete
   requestData.* suchtext=&suche_in=2&downloadart=11
   room       _HM
   showError  1
   showMatched 1
   stateFormat {eq3StateFormat}
   userReadings newFwForDevices:MATCHED_READINGS:.* {
  my $ret = "";
  my @data;
  my @eq3FwList = map{@data = ReadingsVal("eq3","fw_link-".$_,"?") =~ m/Firmware\/(.*?)_update_V([\d_]+)_(\d\d)(\d\d)(\d\d)/;
            $data[0] =~ s/_/-/g;
            sprintf("%s:%s:%s.%s.%s:%s",$data[0],$data[1],$data[4],$data[3],"20".$data[2],$_);
            } ReadingsVal("eq3","MATCHED_READINGS","?") =~ m/fw_link-(\d\d)/g;
  foreach my $dev (devspec2array("TYPE=CUL_HM:FILTER=DEF=......:FILTER=subType!=(virtual|)")) {
    my $md = AttrVal($dev,"model","?");
    my $v = AttrVal($dev,"firmware","0.0");
    my ($h,$l) = split('\.',$v);
    foreach my $newFw (grep m/^${md}:/i,@eq3FwList) {
      my ($nh,$nl,$no,$date,$idx) = $newFw =~ m/^[^:]+:(\d+)_(\d+)_?(\d*):([^:]+):(\d\d)$/;
      if(($nh > $h) || (($nh == $h) && ($nl > $l))) {
        $ret .= "," if($ret ne "");
        $ret .= $dev." (".$md." | fw_".$v." => fw".$idx."_".$nh.".".$nl.($no?sprintf(".%d",$no):"")." | ".$date.")";
  return ($ret eq "")?"no fw-updates needed!":$ret;
   userattr   enableControlSet event-on-change-reading event-on-update-reading reading01AutoNumLen reading01Format reading01Name reading01RegOpt reading01RegOpt:s,i,g reading01Regex readingMaxAge readingMaxAgeReplacementMode readingMaxAgeReplacementMode:text,expression,delete readingMaxAgeReplacementMode:text,reading,internal,expression,delete requestData.* showError showMatched stateFormat userReadings webCmd
   webCmd     Neuanfrage
LG Chris
Devices: APC, Eastron, FS20, IT, Homematic, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, S.USV, TEK603, WMR200, YouLess
Man sollte einen Downloadserver nicht mit automatischen requests befeuern, solange man nicht das OK des Serverbetreibers dazu hat.
Burny4600
LG Chris
Klartext? Ok, Du hast es so gewollt: Das was Du da tun willst, ist absoluter bullshit. Lass es.
Burny4600
LG Chris
Ich bin nicht unfreundlich. Du wolltest Klartext und hast Klartext bekommen.
Übrigens: wir hatten vor kurzem schonmal Streß mit einem Dienstanbieter im Internet, bei dem FHEM Anwender kurz davor waren, den Server mit HTTPMOD Abfragen lahmzulegen. Sowas muss einfach nicht sein.
Burny4600
Habe auch nicht vor irgendwelche Server lam zu legen.
Diese Form der Firmware Updateüberprüfung ist eine gute Idee die ich übernommen habe, nur habe ich noch einen Fehler in der Überprüfung wo ich leider mit meiner Weisheit anstehe.
LG Chris
CoolTux
Das solltest Du denjenigen Fragen von dem Du es übernommen hast.
Das TuxNet Wiki:
https://www.cooltux.net
frank
hallo chris,
nach deinem list hat das tool um 10:11:28 erfolgreich einen check durchgeführt, mit 20 gefundenen dateien.
für dich war nichts dabei.
warum hast du kurz danach erneut versucht?
da eq3 ziehmlich sparsam mit neuen updates ist, habe ich ein interval von 10 tagen eingestellt.
mit dem attr alignTime lege ich den check zudem auf die nachtzeit, um timeouts möglichst aus dem weg zugehen. war sicherlich gerade viel betrieb auf dem server.
FHEM: 6.0(SVN) => Pi3(buster)
Burny4600
@frank
Danke für die Infos.
Habe jetzt die Suche auf 20 Tage und der Abfrage auf 00:15 geändert.
Läst sich auch die Meldung eq3: Read callback: Error: read from http://www.eq-3.de:80 timed out beinflussen?
LG Chris
frank
meinst du LAST_ERROR?
da bleibt immer der letzte fehler, siehe timestamp.
Burny4600
LG Chris
