Hallo!
Ist jetzt gerade wieder passiert, hier die letzten Einträge im FHEM-Log:
2018.01.01 13:16:08 5: HS658GXS6 event channel data: {"items":[{"timestamp":1514808634,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active","key":"BSH.Common.Root.ActiveProgram","value":"Cooking.Oven.Program.HeatingMode.HotAir","level":"hint"},{"timestamp":1514808634,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.Duration","key":"BSH.Common.Option.Duration","unit":"seconds","value":600,"level":"hint"},{"timestamp":1514808634,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/Cooking.Oven.Option.SetpointTemperature","key":"Cooking.Oven.Option.SetpointTemperature","unit":"°C","value":180,"level":"hint"},{"timestamp":1514808634,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.StartInRelative","key":"BSH.Common.Option.StartInRelative","unit":"seconds","value":0,"level":"hint"},{"timestamp":1514808634,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.RemainingProgramTime","key":"BSH.Common.Option.RemainingProgramTime","unit":"seconds","value":225,"level":"hint"},{"timestamp":1514808634,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.ElapsedProgramTime","key":"BSH.Common.Option.ElapsedProgramTime","unit":"seconds","value":375,"level":"hint"},{"timestamp":1514808634,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.ProgramProgress","key":"BSH.Common.Option.ProgramProgress","unit":"%","value":63,"level":"hint"}]}
2018.01.01 13:16:08 4: BSH.Common.Root.ActiveProgram = Cooking.Oven.Program.HeatingMode.HotAir
2018.01.01 13:16:08 4: BSH.Common.Option.Duration = 600 seconds
2018.01.01 13:16:08 4: Cooking.Oven.Option.SetpointTemperature = 180 °C
2018.01.01 13:16:08 4: BSH.Common.Option.StartInRelative = 0 seconds
2018.01.01 13:16:08 4: BSH.Common.Option.RemainingProgramTime = 225 seconds
2018.01.01 13:16:08 4: BSH.Common.Option.ElapsedProgramTime = 375 seconds
2018.01.01 13:16:08 4: BSH.Common.Option.ProgramProgress = 63 %
2018.01.01 13:16:18 5: HS658GXS6 event channel searching for data
2018.01.01 13:16:18 5: HS658GXS6 event channel received event:NOTIFY
data:{"items":[{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active","key":"BSH.Common.Root.ActiveProgram","value":"Cooking.Oven.Program.HeatingMode.HotAir","level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.Duration","key":"BSH.Common.Option.Duration","unit":"seconds","value":600,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/Cooking.Oven.Option.SetpointTemperature","key":"Cooking.Oven.Option.SetpointTemperature","unit":"°C","value":180,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.StartInRelative","key":"BSH.Common.Option.StartInRelative","unit":"seconds","value":0,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.RemainingProgramTime","key":"BSH.Common.Option.RemainingProgramTime","unit":"seconds","value":219,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.ElapsedProgramTime","key":"BSH.Common.Option.ElapsedProgramTime","unit":"seconds","value":381,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.ProgramProgress","key":"BSH.Common.Option.ProgramProgress","unit":"%","value":64,"level":"hint"}]}
2018.01.01 13:16:18 5: HS658GXS6 event channel data: {"items":[{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active","key":"BSH.Common.Root.ActiveProgram","value":"Cooking.Oven.Program.HeatingMode.HotAir","level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.Duration","key":"BSH.Common.Option.Duration","unit":"seconds","value":600,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/Cooking.Oven.Option.SetpointTemperature","key":"Cooking.Oven.Option.SetpointTemperature","unit":"°C","value":180,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.StartInRelative","key":"BSH.Common.Option.StartInRelative","unit":"seconds","value":0,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.RemainingProgramTime","key":"BSH.Common.Option.RemainingProgramTime","unit":"seconds","value":219,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.ElapsedProgramTime","key":"BSH.Common.Option.ElapsedProgramTime","unit":"seconds","value":381,"level":"hint"},{"timestamp":1514808640,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.ProgramProgress","key":"BSH.Common.Option.ProgramProgress","unit":"%","value":64,"level":"hint"}]}
2018.01.01 13:16:18 4: BSH.Common.Root.ActiveProgram = Cooking.Oven.Program.HeatingMode.HotAir
2018.01.01 13:16:18 4: BSH.Common.Option.Duration = 600 seconds
2018.01.01 13:16:18 4: Cooking.Oven.Option.SetpointTemperature = 180 °C
2018.01.01 13:16:18 4: BSH.Common.Option.StartInRelative = 0 seconds
2018.01.01 13:16:18 4: BSH.Common.Option.RemainingProgramTime = 219 seconds
2018.01.01 13:16:18 4: BSH.Common.Option.ElapsedProgramTime = 381 seconds
2018.01.01 13:16:18 4: BSH.Common.Option.ProgramProgress = 64 %
2018.01.01 13:16:28 5: HS658GXS6 event channel searching for data
2018.01.01 13:16:28 5: HS658GXS6 event channel received event:NOTIFY
data:{"items":[{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active","key":"BSH.Common.Root.ActiveProgram","value":"Cooking.Oven.Program.HeatingMode.HotAir","level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.Duration","key":"BSH.Common.Option.Duration","unit":"seconds","value":600,"level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/Cooking.Oven.Option.SetpointTemperature","key":"Cooking.Oven.Option.SetpointTemperature","unit":"°C","value":180,"level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.StartInRelative","key":"BSH.Common.Option.StartInRelative","unit":"seconds","value":0,"level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.RemainingProgramTime","key":"BSH.Common.Option.RemainingProgramTime","unit":"seconds","value":213,"level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.ElapsedProgramTime","key":"BSH.Common.Option.ElapsedProgramTime","unit":"seconds","value":387,"level":"hint"},{
2018.01.01 13:16:28 5: HS658GXS6 event channel data: {"items":[{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active","key":"BSH.Common.Root.ActiveProgram","value":"Cooking.Oven.Program.HeatingMode.HotAir","level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.Duration","key":"BSH.Common.Option.Duration","unit":"seconds","value":600,"level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/Cooking.Oven.Option.SetpointTemperature","key":"Cooking.Oven.Option.SetpointTemperature","unit":"°C","value":180,"level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.StartInRelative","key":"BSH.Common.Option.StartInRelative","unit":"seconds","value":0,"level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.RemainingProgramTime","key":"BSH.Common.Option.RemainingProgramTime","unit":"seconds","value":213,"level":"hint"},{"timestamp":1514808646,"handling":"none","uri":"/api/homeappliances/SIEMENS-HS658GXS6-68A40E04C5C6/programs/active/BSH.Common.Option.ElapsedProgramTime","key":"BSH.Common.Option.ElapsedProgramTime","unit":"seconds","value":387,"level":"hint"},{
'"' expected, at character offset 1430 (before "(end of string)") at ./FHEM/48_HomeConnect.pm line 760.
Es ist nicht passiert, als als das Programm beendet war, sondern als sich der Ofen nach einer gewissen Idle-Zeit selbst abgeschalten hat...
FHEM-Prozess ist definitiv nicht mehr da....
Ciao,
Andy
