how to detect switching on 230 volt
Begonnen von Guest, 28 Juli 2012, 22:05:16
Guest
A question
I would like to get a signal to my FHEM software when 230 volt power is
switched on with a regular switch. I googled a lot on this but didn´t find
a good way to do this.
I use a FB7390 and a TrxFrx433 of RFXCOM.
Thanks for any suggestion.
UliM
Have you considered FS20-FMS yet?
Guest
Use FS20 KSE - Bell Ringing Detector - plus some external components.
pah
Guest
Yes but that wouldn't function.
I would like to use it in a situation where pir sensors switch the light.
If I can send a signal to the  FHEM software when the light is on, it can
be used for some kind of security  too.
I now think the KlikAanKlikUit AWMT-230 does this, but it uses a battery as
a power supply. I don't like the idea of having to open the ceiling every
year to change batteries. I know they say about 5 years. But pir sensors
will switch more often as a wall switch and so the batteries will go empty
much earlier.
{HT}
Op zaterdag 28 juli 2012 22:15:31 UTC+2 schreef UliM het volgende:
Guest
Yes it would. Think twice, please.
pah
