ELV ASH 500 mit CUL
Begonnen von Guest, 30 August 2012, 02:48:15
Guest
habe hier noch einen alten
ELV ASH 500 Funk-Temperatur-/Luftfeuchtesensor
http://www.elv.de/controller.aspx?cid=683&detail=10&detail2=93854
liegen.
Habe diesem Sensor Strom gegeben.
Wie bringe ich nun dem CUL bei das er den Sensor einlesen soll,
gibt es sowas wie ein rescan commando?!
Bin leider aus
http://culfw.de/commandref.html
nicht schlau geworden.
root@fhem:~# egrep CUL /var/log/fhem/fhem-2012-08.log|egrep \.08\.30
2012.08.30 02:33:50 3: Opening CUL device /dev/ttyACM0
2012.08.30 02:33:50 3: Setting CUL baudrate to 9600
2012.08.30 02:33:50 3: CUL device opened
2012.08.30 02:34:52 3: Opening CUL device /dev/ttyACM0
2012.08.30 02:34:53 3: Setting CUL baudrate to 9600
2012.08.30 02:34:53 3: CUL device opened
2012.08.30 02:35:33 5: Cmd: >define CUL CUL /dev/ttyACM0@9600 1234<
2012.08.30 02:35:33 3: Opening CUL device /dev/ttyACM0
2012.08.30 02:35:33 3: Setting CUL baudrate to 9600
2012.08.30 02:35:33 3: CUL device opened
2012.08.30 02:35:33 5: CUL/RAW (ReadAnswer): V 1.46 CUL868
2012.08.30 02:35:33 5: CUL/RAW (ReadAnswer): 1234
2012.08.30 02:35:33 5: GOT CUL fhtid: 1234
2012.08.30 02:35:33 5: Cmd: >define Wohnzimmer CUL_WS 1<
2012.08.30 02:35:33 5: Cmd: >define Schlafzimmer CUL_WS 2<
2012.08.30 02:35:34 5: Cmd: >setstate CUL 2012-08-30 02:21:50 ccconf
freq:868.300MHz bWidth:325KHz rAmpl:42dB sens:4dB<
2012.08.30 02:35:34 5: Cmd: >setstate CUL 2012-08-30 02:22:44 fhtbuf
AE<
2012.08.30 02:35:34 5: Cmd: >setstate CUL 2012-08-30 02:27:26 raw V
1.46 CUL868<
2012.08.30 02:35:34 5: Cmd: >setstate CUL 2012-08-30 02:22:27 uptime 19
03:36:12<
2012.08.30 02:35:34 5: Cmd: >setstate CUL 2012-08-30 02:27:14 version V
1.46 CUL868<
2012.08.30 02:35:55 5: CUL/RAW: /K0161325702
2012.08.30 02:35:55 5: CUL: K01613257 -73
2012.08.30 02:35:55 5: CUL dispatch K01613257
2012.08.30 02:35:55 4: CUL_WS S300TH Wohnzimmer: T: 26.1  H: 57.3
2012.08.30 02:42:01 4: ### ttyACM0: checking if it is a CUL
2012.08.30 02:42:01 4: already used by the CUL fhem device
2012.08.30 02:44:46 5: CUL/RAW: /K0161325701
2012.08.30 02:44:46 5: CUL: K01613257 -73.5
2012.08.30 02:44:46 5: CUL dispatch K01613257
2012.08.30 02:44:46 4: CUL_WS S300TH Wohnzimmer: T: 26.1  H: 57.3
Danke & LG
Aleks
