Mathe Funktion
Begonnen von stefantaust1, 09 Februar 2018, 22:23:29
stefantaust1
   DEF        0 5
   HeatPumpServer_MSGCNT 97
   HeatPumpServer_TIME 2018-02-10 17:05:14
   IODev      HeatPumpServer
   LASTInputDev HeatPumpServer
   MSGCNT     97
   ModbusRegister_lastRcv 2018-02-10 17:05:14
   NAME       dim_flow_temperature
   NR         45
   NTFY_ORDER 50-dim_flow_temperature
   STATE      25.6
   TYPE       ModbusRegister
   lastUpdate Sat Feb 10 17:05:14 2018
   nextUpdate Sat Feb 10 17:06:14 2018
     2018-02-10 17:05:14   RAW             0100
     2018-02-10 17:05:14   statTemperature Hour: -0.1 Day: 3.6 Month: 3.6 Year: 3.6 (since: 2018-01-25_20:08:10 )
     2018-01-26 20:09:53   statTemperatureDay Min: 18.1 Avg: 27.8 Max: 52.4 (since: 2018-01-25_20:45:46 )
     2018-01-26 20:09:53   statTemperatureHour Min: 30.6 Avg: 36.3 Max: 36.8
     2018-01-26 19:59:55   statTemperatureHourLast Min: 20.4 Avg: 32.9 Max: 36.7
     2018-02-10 16:59:55   statTemperatureLast Hour: -0.9 Day: - Month: - Year: -
     2018-01-26 20:09:53   statTemperatureMonth Min: 18.1 Avg: 27.8 Max: 52.4 (since: 2018-01-25_20:45:46 )
     2018-01-28 13:59:55   statTemperatureTendency 1h: +4.3 2h: +3.5 3h: +2.3 6h: +2.3
     2018-01-26 20:09:53   statTemperatureYear Min: 18.1 Avg: 27.8 Max: 52.4 (since: 2018-01-25_20:45:46 )
     2018-02-10 17:05:14   state           25.6
     2018-02-10 17:05:14   tempDiff        -0.100000000000001
     2018-02-10 17:05:14   temperature     25.6
   helper:
     _98_statistics dim_statistics
     addr       3 0 5
     address    5
     disableRegisterMapping 0
     lastUpdate 0
     nextUpdate 1518278774.31805
     nread      1
     readCmd
     register   5
     registerType 3
     unitId     0
     updateIntervall 60
     cnv:
       a          0.1
       b          0
       max        3276.7
       min        -3276.8
       pr         -1
       step       10
   alias      Vorlauftemperatur
   conversion 0.1:0
   event-min-interval .*:1
   event-on-change-reading temperature:0.1
   fp_Dimplex 625,604,1,Vorlauftemperatur,
   group      Temperaturen
   plcDataType INT
   registerType Holding
   room       Dimplex
   stateAlias temperature
   stateFormat {sprintf("%0.1f", ReadingsVal($name,"state",0))}
   updateInterval 00:01:00
   userReadings tempDiff {ReadingsVal("$name","temperature","0") - ReadingsVal("dim_return_temperature","temperature","0")}
Naja damit ist alles in Ordnung. Ich glaube Dir nicht, dass der im Wizard nicht auftaucht   :D
Du musst in der ersten Klappleiste hinter dem set in regexp parts dim_flow_temperature auswählen. Dann sollte in der zweiten Klappleiste eine Liste mit den Werten zur Auswahl stehen.
stefantaust1
da habe ich dann nur    .*    und    temperature:.*     zur Auswahl
hinzugefügt schaut das dann so aus:
dim_flow_temperature:.*
dim_flow_temperature:temperature:.*
ins Log wird nix geschrieben
ok Du hast -> event-on-change-reading temperature:0.1
Zitat Doku
Zitatevent-on-change-reading
Dieses Attribut enthält eine durch Kommata getrennte Liste von "readings". Wenn gesetzt, erzeugen nur Veränderungen der gelisteten "readings" ein Ereignis. Wenn die aktualiserten Werte der gelisteten "readings" identisch sind, wird kein Ereignis generiert.
Du musst Dein attr <> event-on-change-reading entsprechend anpassen.   :-[ ;)
stefantaust1
jetzt funktioniert es.  ;D Vielen Dank  :)
der-Lolo
Ich habe mitgelesen und auch meine Spreizung ausgerechnet...
Spreizung {ReadingsVal("WMZ","Vorlauftemperatur","0") - ReadingsVal("WMZ","Ruecklauftemperatur","0")}
Die Temperaturen kommen zwar sauber auf einer nachkommastelle aus dem Modbus Wärmemengenzähler, gelegentlich habe ich aber beim UserReading trotzdem viele Nachkommastellen - hat jemand einen tip wie ich das verhindere..?
#21
Kurz und nicht ausformuliert und getestet:
mit sprintf("%.2f",ReadingsVal("WMZ","Vorlauftemperatur","0") - ReadingsVal("WMZ","Ruecklauftemperatur","0"))
http://perldoc.perl.org/functions/sprintf.html
Edit im Code fehlte ne Klammer - korrigiert.
der-Lolo
So ganz trifft das den Nagel nicht auf den Kopf... Mit der Zeile wird nicht mehr aktualisiert.
Ich würde auch gerne noch die aktuelle AZ bestimmen ( abgegebene Leistung / aufgenommene Leistung )
Problem ist, das eine sind kW - das andere W
#23
Verstehe ich nicht. Also Du musst es komplett so machen:
Spreizung {sprintf("%.2f",ReadingsVal("WMZ","Vorlauftemperatur","0") - ReadingsVal("WMZ","Ruecklauftemperatur","0"))}
ZitatProblem ist, das eine sind kW - das andere W
Umrechnungsfaktor 1000 ?  :D oder welches Problem siehst Du?
der-Lolo
Hehe, komma getrennt - dazu brauchte ich auch die ComandRef... Habs nun, rechnen ging doch einfacher als ich gedacht hatte....
Spreizung {sprintf("%.1f",ReadingsVal("WMZ","Vorlauftemperatur","0") - ReadingsVal("WMZ","Ruecklauftemperatur","0"))},
aktAZ {sprintf("%.2f",ReadingsVal("WMZ","aktWaermeleistung","0")*1000 / ReadingsVal("SDM630","Power_L2__W","0"))}
Ich frag mich schon ob ich mit den Temperaturen und dem Durchfluss die Wärmeleistung mal selber rechne ;-)
Deckoffizier
Hallo der-Lolo,
ZitatIch frag mich schon ob ich mit den Temperaturen und dem Durchfluss die Wärmeleistung mal selber rechne ;-)
Deine Idee für meinen Holzvergaser geht auch gerade schwanger mit mir  ;D
1 wire Anlegefühler sind eh bestellt, dann frisch ans Werk.
Danke für die Vorarbeit an Alle.
Hans-Jürgen
FHEM 5.8 auf "yakkaroo Emu A1FL.1" mit CUL 868MHz, SIGNALduino,2 1Wire USB Busmaster, diverse 1 Wire Sensoren,Landroid,Aeotec USB Dongle Z-Wave Plus
stefantaust1
ich muss das Thama nochmal aufgreifen
Ich erhalte ja unter der Vorlauftemperatur das Reading der Spreizung
Wie bekomme ich das Reading tempDiff als extra Dummy oder Device angezeigt?
Stefan
Kannst Du genauer werden? Was ist der Vorteil eines extra Devices gegenüber einem Reading aus Deiner Sicht? Wo willst Du den Wert in dem Device haben?
stefantaust1
Hallo Otto123,
schön du du mir wieder unter die Arme greifst  :D
Ich will den Wert einem Raum und Gruppe zuordnen und dann im Floorplan anzeigen lassen.
Jetzt ist der Wert tempDiff ja nur als reading bei der Vorlauftemperatur zu finden
Stefan
Hallo Stefan,
und wie lässt Du andere Temperaturen im Floorplan anzeigen? Ich meine klar Du kannst das Reading in den state eines Dummy kopieren, aber das erscheint mir überflüssig.
Du kannst es auch in den state Deines Devices HeatPumpServer schreiben.
