10_CUL_HM.pm trotz restore (16086) Probleme
Begonnen von ffdec, 11 Februar 2018, 17:34:50
ffdec
Hallo, scheinbar gibt es in der Datei noch weitere Fehler. Ich kann nicht mehr AES  ...
2018.02.11 17:29:22 0: Server shutdown
2018.02.11 17:29:24 1: Including fhem.cfg
2018.02.11 17:29:24 3: telnetPort: port 7072 opened
2018.02.11 17:29:25 3: WEB: port 8083 opened
2018.02.11 17:29:25 3: WEBphone: port 8084 opened
2018.02.11 17:29:25 3: WEBtablet: port 8085 opened
2018.02.11 17:29:25 2: eventTypes: loaded 479 events from ./log/eventTypes.txt
2018.02.11 17:29:26 1: [Alarm_Define] data hash restored from save file with date Sun Feb 11 16:21:35 2018
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 287.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 304.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 322.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 366.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 382.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 398.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 414.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 430.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 446.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 463.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 476.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 489.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 505.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 521.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 536.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 552.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 569.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 587.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 616.
2018.02.11 17:29:26 1: PERL WARNING: Use of uninitialized value $newIODev in string ne at ./FHEM/10_CUL_HM.pm line 9069, <$fh> line 644.
HMUARTLGW HMLAN Alarmanlage ZPumpe VCONTROL Viessmann 333-F MySensors CO2 Floorplan IT Raspberry 3 CC1101 Firmata Arduino nanoCUL868
ffdec
Can't use string ("-") as a HASH ref while "strict refs" in use at ./FHEM/10_CUL_HM.pm line 9059.
das auch noch, neustart notwendig
martinp876
du machst mich ratlos.
diese Zeilen gibt es nicht. Welche Version von CUL_HM hast du?
was sagt "version"?
Martin, die von Dir heute morgen eingecheckte Version ist ebenfalls fehlerhaft.
Nachzulesen ab hier: https://forum.fhem.de/index.php/topic,84181.msg764507.html#msg764507
Bitte korrigiere das bis zum morgigen Update!
ffdec
#4
hab kein cul_hm, habe HMUARTLGW und vccu, von daher keine version, nur type ist cul_hm
ich glaube ich habe die fehler schon eine Woche, falls es hilft.... ich mache täglich die updates
ähm ich hab die version von gestern oder so wieder drauf gemacht ...  Revision 16086
ich kann auch erst mal noch warten, wenn es morgen eine neue version gibt, wenn es immer noch hakt melde ich mich
Wenn Du eine vccu hast, hast Du auch eine Version von CUL_HM in Deinem System ;)
Gib einfach mal "version CUL_HM" oben in die FHEM Befehlszeile ein.
ffdec
ups
File         Rev   Last Change
10_CUL_HM.pm 16086 2018-02-04 19:48:36Z martinp876
doif.js                    15546 2017-12-03 09:57:42Z Ellert
fhemweb.js                 16075 2018-02-03 22:27:04Z rudolfkoenig
Die eben von Martin in SVN bereitgestellte Version
10_CUL_HM.pm 16155 2018-02-11 21:01:30Z martinp876
läßt in meinen Installationen zumindest keine devices mehr verschwinden.
ffdec
No Id found for 10_CUL_HM.pm
jo läuft: weniger Fehler auch beim Start:
2018.02.11 22:28:14.298 1: PERL WARNING: Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 2033, <$fh> line 666.
2018.02.11 22:28:14.303 1: PERL WARNING: Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 2033, <$fh> line 673.
2018.02.11 22:28:14.307 1: PERL WARNING: Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 2033, <$fh> line 680.
2018.02.11 22:28:14.312 1: PERL WARNING: Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 2033, <$fh> line 687.
2018.02.11 22:28:14.316 1: PERL WARNING: Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 2033, <$fh> line 694.
2018.02.11 22:28:14.325 1: PERL WARNING: Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 2033, <$fh> line 701.
2018.02.11 22:28:14.332 1: PERL WARNING: Use of uninitialized value in numeric comparison (<=>) at fhem.pl line 2033, <$fh> line 703.
Wenn Du stacktrace einschaltest, kommt man der Ursache vielleicht auf die Spur. Aber ich vermute, das hat wenig mit CUL_HM zu tun.
da musst Du suchen:
2018.02.11 22:36:28.285 1:     main::AssignIoPort                  called by ./FHEM/21_OWTHERM.pm (205)
2018.02.11 22:36:28.285 1:     main::OWTHERM_Define                called by fhem.pl (3510)
Der Fehler passiert beim define Deiner OWTHERM devices.
Hat nix mit Homematic zu tun.
ffdec
ja danke hab es auch gesehen ...
okay geb mich geschlagen liegt bei den firmata ds18b20 owx devices demnach...
jetzt hab ich nur noch das problem mit meinen switches, die zb kein assignhmkey mehr machen.... der zeigt aesCommToDev pending
ich kann die alarmsteuerung nicht mehr pairen, unpäiren, reseten, assignhmkeyen...
YellowBall
Kann das Problem bestätigen:
Mein Log zeigt: Cannot load module CUL_HM
Ich habe das Vorgängermodul aus dem RestoreDir wieder hergestellt und nun läuft es (erstmal) wieder.
Raspi 0,1,2,3,4 | HMUART | Broadlink | Harmony | Xiaomi | Milight | Homematic | Somfy | Sonos | Meross  | Sonoff  | Shelly | Comet DECT  | ioBroker
greenBelt
Hab es wie YellowBall gemacht. Backup restore und gut ist.
Hatte Anfangs mein include in Verdacht. Aber hier scheint es etwas tiefer zu sitzen
ffdec
2018.02.12 08:22:27.515 1 : UPD ./CHANGED
2018.02.12 08:22:27.581 1 : UPD ./MAINTAINER.txt
2018.02.12 08:22:27.625 1 : UPD FHEM/01_FHEMWEB.pm
2018.02.12 08:22:27.699 1 : UPD FHEM/10_CUL_HM.pm
2018.02.12 08:22:27.817 1 : open ./FHEM/10_CUL_HM.pm failed: Permission denied, trying to restore the previous version and aborting the update
