define CUL erzeugt nur och Fehlermeldungen in SerialPort.pm :-(
Begonnen von Guest, 10 September 2012, 23:18:52
Guest
Hallo Leute,
sorry, ich weis nicht mehr weiter. Seit dem letzten Reboot meiner FB 7390
geht nichts mehr. Sobald ich versuche, den CUL zu definieren gibt es nur
noch Perl Fehlermeldungen :-(
define CUL CUL /dev/ttyACM0@38400 1234
ergibt:
syntax error at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 495, near "print cF "$self"
syntax error at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 496, near "# used!to ""
Global symbol "$self" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 497.
Global symbol "$item" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 501.
Global symbol "$self" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 502.
Global symbol "$item" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 504.
Global symbol "%c_cs_fields" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 504.
Global symbol "$got_match" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1638.
Global symbol "$mpos" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1639.
Global symbol "$before" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1639.
Global symbol "$mpos" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1640.
Global symbol "$best_pos" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1641.
Global symbol "$mpos" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1641.
Global symbol "$best_pos" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1642.
Global symbol "$mpos" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1642.
Global symbol "$best_pat" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1643.
Global symbol "$self" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1643.
Global symbol "$count_in" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1643.
Global symbol "$best_match" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1644.
Global symbol "$match" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1644.
Global symbol "$best_before" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1645.
Global symbol "$before" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1645.
Global symbol "$best_after" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1646.
Global symbol "$after" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1646.
Global symbol "$self" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1649.
Global symbol "$count_in" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1649.
Global symbol "$self" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1650.
Global symbol "$match" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1650.
Global symbol "$self" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1651.
Global symbol "$after" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1651.
Global symbol "$self" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1652.
Global symbol "$before" requires explicit package name at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1653.
syntax error at /var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm line 1656, near "}"
/var/InternerSpeicher/fhem/lib/perl5/site_perl/5.12.2/mips-linux/Device/SerialPort.pm has too many errors.
Compilation failed in require at /var/InternerSpeicher/Verbatim-STORENGO-00/fhem/FHEM/DevIo.pm line 168.
Was ist bei mir kaputt?
version
Fhem 5.2 (DEVELOPMENT), $Id: fhem.pl 1764 2012-07-28 06:27:09Z rudolfkoenig $
Danke für Eure Hilfe!!!
Elmar
UliM
Hilft evtl das runtersetzen der Baudrate?
Guest
nope, ergibt identische Fehlermeldungen.
Elmar
Am Montag, 10. September 2012 23:42:52 UTC+2 schrieb UliM:
UliM
kannst Du SerialPort.pm aus einem backup zurückspielen?
Sieht ja irgendwie eher nach nem Problem der perl-Installation aus...
Dazu sollte besser einer der cracks was sagen :)
=8-)
Guest
Das war es! Anscheinend war die Datei beschädigt.
Danke!
Entschuldigung, dass ich so blind war!
Gruss
Elmar
Am Dienstag, 11. September 2012 00:18:14 UTC+2 schrieb UliM:
> =8-)
