WifiLight schaltet alle 5 min?
Begonnen von stoniii, 20 Februar 2018, 10:42:24
stoniii
Hallo :)
habe folgendes in meinen Logfiles gefunden:
2018.02.20 10:13:45 3: ledStripe01 RGB LD382A set off 0
2018.02.20 10:13:45 3: ledStripe01 RGB LD382A dim 0 0
2018.02.20 10:13:45 3: ledStripe01 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:13:45 3: ledStripe03 RGBW LD382A set off 0
2018.02.20 10:13:45 3: ledStripe03 RGBW LD382A dim 0 0
2018.02.20 10:13:45 3: ledStripe03 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:13:45 3: ledStripe04 RGB LD382A set off 0
2018.02.20 10:13:45 3: ledStripe04 RGB LD382A dim 0 0
2018.02.20 10:13:45 3: ledStripe04 set HSV 189, 81, 0 with ramp: 0, flags:
2018.02.20 10:18:45 3: ledStripe01 RGB LD382A set off 0
2018.02.20 10:18:45 3: ledStripe01 RGB LD382A dim 0 0
2018.02.20 10:18:45 3: ledStripe01 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:18:45 3: ledStripe03 RGBW LD382A set off 0
2018.02.20 10:18:45 3: ledStripe03 RGBW LD382A dim 0 0
2018.02.20 10:18:45 3: ledStripe03 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:18:45 3: ledStripe04 RGB LD382A set off 0
2018.02.20 10:18:45 3: ledStripe04 RGB LD382A dim 0 0
2018.02.20 10:18:45 3: ledStripe04 set HSV 189, 81, 0 with ramp: 0, flags:
2018.02.20 10:19:16 3: ledStripe01 RGB LD382A set off 0
2018.02.20 10:19:16 3: ledStripe01 RGB LD382A dim 0 0
2018.02.20 10:19:16 3: ledStripe01 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:19:16 3: ledStripe03 RGBW LD382A set off 0
2018.02.20 10:19:16 3: ledStripe03 RGBW LD382A dim 0 0
2018.02.20 10:19:16 3: ledStripe03 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:21:14 3: ledStripe01 RGB LD382A set off 0
2018.02.20 10:21:14 3: ledStripe01 RGB LD382A dim 0 0
2018.02.20 10:21:14 3: ledStripe01 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:21:14 3: ledStripe03 RGBW LD382A set off 0
2018.02.20 10:21:14 3: ledStripe03 RGBW LD382A dim 0 0
2018.02.20 10:21:14 3: ledStripe03 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:21:14 3: ledStripe01 set HSV 220, 0, 98 with ramp: 0, flags:
2018.02.20 10:21:14 3: ledStripe03 set HSV 220, 0, 98 with ramp: 0, flags:
2018.02.20 10:22:56 3: ledStripe01 set HSV 220, 0, 98 with ramp: 0, flags:
2018.02.20 10:22:56 3: ledStripe03 set HSV 220, 0, 98 with ramp: 0, flags:
2018.02.20 10:22:56 3: ledStripe01 RGB LD382A set off 0
2018.02.20 10:22:56 3: ledStripe01 RGB LD382A dim 0 0
2018.02.20 10:22:56 3: ledStripe01 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:22:56 3: ledStripe03 RGBW LD382A set off 0
2018.02.20 10:22:56 3: ledStripe03 RGBW LD382A dim 0 0
2018.02.20 10:22:56 3: ledStripe03 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:23:45 3: ledStripe01 RGB LD382A set off 0
2018.02.20 10:23:45 3: ledStripe01 RGB LD382A dim 0 0
2018.02.20 10:23:45 3: ledStripe01 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:23:45 3: ledStripe03 RGBW LD382A set off 0
2018.02.20 10:23:45 3: ledStripe03 RGBW LD382A dim 0 0
2018.02.20 10:23:45 3: ledStripe03 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:23:45 3: ledStripe04 RGB LD382A set off 0
2018.02.20 10:23:45 3: ledStripe04 RGB LD382A dim 0 0
2018.02.20 10:23:45 3: ledStripe04 set HSV 189, 81, 0 with ramp: 0, flags:
2018.02.20 10:28:45 3: ledStripe01 RGB LD382A set off 0
2018.02.20 10:28:45 3: ledStripe01 RGB LD382A dim 0 0
2018.02.20 10:28:45 3: ledStripe01 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:28:45 3: ledStripe03 RGBW LD382A set off 0
2018.02.20 10:28:45 3: ledStripe03 RGBW LD382A dim 0 0
2018.02.20 10:28:45 3: ledStripe03 set HSV 220, 0, 0 with ramp: 0, flags:
2018.02.20 10:28:45 3: ledStripe04 RGB LD382A set off 0
2018.02.20 10:28:45 3: ledStripe04 RGB LD382A dim 0 0
2018.02.20 10:28:45 3: ledStripe04 set HSV 189, 81, 0 with ramp: 0, flags:
die LEDStripes welche über WIFIlight angesteuert werden schalten alle 5 min immer und immer wieder die gleichen Werte. Ich würde meinen dies ist so nicht ganz richtig.
Könnte mir vorstellen, dass dadurch FHEM auch ein wenig ausgebremst wird?
anbei noch meine DOIF´s welche die LEDStripes schalten
LEDStripe01 & 03
   DEF        ([ZWave_SENSOR_NOTIFICATION_10:motion] eq "on" and [00:00-5:30]) (set ledStripe01 RGB 696969)
DOELSEIF ([ZWave_SENSOR_NOTIFICATION_10:motion] eq "on" and [05:30-8:30]) (set ledStripe01 RGB FAFAFA, set ledStripe03 RGB FAFAFA)
DOELSEIF ([ZWave_SENSOR_NOTIFICATION_10:motion] eq "off" and [Anwesenheit] >0 and [05:30-8:30] and [LichtWetter:twilight_weather] <99) (set ledStripe01 RGB 1661F7, set ledStripe03 RGB 1661F7)
DOELSEIF ([ZWave_SENSOR_NOTIFICATION_10:motion] eq "on" and [08:30-18:30]) (set ledStripe01 RGB FAFAFA, set ledStripe03 RGB FAFAFA)
DOELSEIF ([ZWave_SENSOR_NOTIFICATION_10:motion] eq "off" and [Anwesenheit] >0 and [08:30-18:30] and [LichtWetter:twilight_weather] <99) (set ledStripe01 RGB 1661F7, set ledStripe03 RGB 1661F7)
DOELSEIF ([ZWave_SENSOR_NOTIFICATION_10:motion] eq "on" and [18:30-23:59]) (set ledStripe01 off, set ledStripe03 RGB FAFAFA)
DOELSEIF ([ZWave_SENSOR_NOTIFICATION_10:motion] eq "off" and [Anwesenheit] >0 and [18:30-22:30] and [LichtWetter:twilight_weather] <99) (set ledStripe01 RGB 05173B, set ledStripe03 RGB 05173B)
DOELSE
  (set ledStripe01 off, set ledStripe03 off)
   NAME       Ankleide
   NR         188
   NTFY_ORDER 50-Ankleide
   STATE      cmd_8
   TYPE       DOIF
     2018-02-20 10:33:45   Device          LichtWetter
     2018-02-20 10:33:45   cmd             8
     2018-02-20 10:33:45   cmd_event       LichtWetter
     2018-02-20 10:33:45   cmd_nr          8
     2018-02-19 18:18:14   e_Anwesenheit_STATE 1
     2018-02-20 10:33:45   e_LichtWetter_twilight_weather 100
     2018-02-20 10:22:56   e_ZWave_SENSOR_NOTIFICATION_10_motion off
     2018-02-17 17:06:19   mode            enabled
     2018-02-20 10:33:45   state           cmd_8
     2018-02-20 05:30:00   timer_01_c01    21.02.2018 00:00:00
     2018-02-20 05:30:00   timer_02_c01    21.02.2018 05:30:00
     2018-02-20 08:30:00   timer_03_c02    21.02.2018 05:30:00
     2018-02-20 08:30:00   timer_04_c02    21.02.2018 08:30:00
     2018-02-20 08:30:00   timer_05_c03    21.02.2018 05:30:00
     2018-02-20 08:30:00   timer_06_c03    21.02.2018 08:30:00
     2018-02-19 20:47:50   timer_07_c04    20.02.2018 08:30:00
     2018-02-19 20:47:50   timer_08_c04    20.02.2018 18:30:00
     2018-02-19 20:47:50   timer_09_c05    20.02.2018 08:30:00
     2018-02-19 20:47:50   timer_10_c05    20.02.2018 18:30:00
     2018-02-19 23:59:00   timer_11_c06    20.02.2018 18:30:00
     2018-02-19 23:59:00   timer_12_c06    20.02.2018 23:59:00
     2018-02-19 22:30:00   timer_13_c07    20.02.2018 18:30:00
     2018-02-19 22:30:00   timer_14_c07    20.02.2018 22:30:00
   Regex:
   condition:
     0          ReadingValDoIf($hash,'ZWave_SENSOR_NOTIFICATION_10','motion') eq "on" and DOIF_time($hash,0,1,$wday,$hms)
     1          ReadingValDoIf($hash,'ZWave_SENSOR_NOTIFICATION_10','motion') eq "on" and DOIF_time($hash,2,3,$wday,$hms)
     2          ReadingValDoIf($hash,'ZWave_SENSOR_NOTIFICATION_10','motion') eq "off" and InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,4,5,$wday,$hms) and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     3          ReadingValDoIf($hash,'ZWave_SENSOR_NOTIFICATION_10','motion') eq "on" and DOIF_time($hash,6,7,$wday,$hms)
     4          ReadingValDoIf($hash,'ZWave_SENSOR_NOTIFICATION_10','motion') eq "off" and InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,8,9,$wday,$hms) and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     5          ReadingValDoIf($hash,'ZWave_SENSOR_NOTIFICATION_10','motion') eq "on" and DOIF_time($hash,10,11,$wday,$hms)
     6          ReadingValDoIf($hash,'ZWave_SENSOR_NOTIFICATION_10','motion') eq "off" and InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,12,13,$wday,$hms) and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
   days:
   devices:
     0           ZWave_SENSOR_NOTIFICATION_10
     1           ZWave_SENSOR_NOTIFICATION_10
     2           ZWave_SENSOR_NOTIFICATION_10 Anwesenheit LichtWetter
     3           ZWave_SENSOR_NOTIFICATION_10
     4           ZWave_SENSOR_NOTIFICATION_10 Anwesenheit LichtWetter
     5           ZWave_SENSOR_NOTIFICATION_10
     6           ZWave_SENSOR_NOTIFICATION_10 Anwesenheit LichtWetter
     all         ZWave_SENSOR_NOTIFICATION_10 Anwesenheit LichtWetter
   do:
     0:
       0          set ledStripe01 RGB 696969
     1:
       0          set ledStripe01 RGB FAFAFA, set ledStripe03 RGB FAFAFA
     2:
       0          set ledStripe01 RGB 1661F7, set ledStripe03 RGB 1661F7
     3:
     4:
     5:
       0          set ledStripe01 off, set ledStripe03 RGB FAFAFA
     6:
       0          set ledStripe01 RGB 05173B, set ledStripe03 RGB 05173B
     7:
       0          set ledStripe01 off, set ledStripe03 off
   helper:
     DOIF_Readings_events
     DOIF_eventas
     event      azimuth: 149.42,elevation: 25.81,twilight: 100,twilight_weather: 100,compasspoint: southeast
     globalinit 1
     last_timer 14
     sleeptimer -1
     timerdev   LichtWetter
     timerevent azimuth: 149.42,elevation: 25.81,twilight: 100,twilight_weather: 100,compasspoint: southeast
     triggerDev LichtWetter
     timerevents:
       azimuth: 149.42
       elevation: 25.81
       twilight: 100
     timereventsState:
       azimuth: 149.42
       elevation: 25.81
       twilight: 100
     triggerEvents:
       azimuth: 149.42
       elevation: 25.81
       twilight: 100
     triggerEventsState:
       azimuth: 149.42
       elevation: 25.81
       twilight: 100
   internals:
     2           Anwesenheit:STATE
     4           Anwesenheit:STATE
     6           Anwesenheit:STATE
     all         Anwesenheit:STATE
   interval:
     0          -1
     1          0
     10         -1
     11         10
     12         -1
     13         12
     2          -1
     3          2
     4          -1
     5          4
     6          -1
     7          6
     8          -1
     9          8
   itimer:
   localtime:
     0          1519167600
     1          1519187400
     10         1519147800
     11         1519167540
     12         1519147800
     13         1519162200
     2          1519187400
     3          1519198200
     4          1519187400
     5          1519198200
     6          1519111800
     7          1519147800
     8          1519111800
     9          1519147800
   readings:
     0           ZWave_SENSOR_NOTIFICATION_10:motion
     1           ZWave_SENSOR_NOTIFICATION_10:motion
     2           ZWave_SENSOR_NOTIFICATION_10:motion LichtWetter:twilight_weather
     3           ZWave_SENSOR_NOTIFICATION_10:motion
     4           ZWave_SENSOR_NOTIFICATION_10:motion LichtWetter:twilight_weather
     5           ZWave_SENSOR_NOTIFICATION_10:motion
     6           ZWave_SENSOR_NOTIFICATION_10:motion LichtWetter:twilight_weather
     all         ZWave_SENSOR_NOTIFICATION_10:motion LichtWetter:twilight_weather
   realtime:
     0          00:00:00
     1          05:30:00
     10         18:30:00
     11         23:59:00
     12         18:30:00
     13         22:30:00
     2          05:30:00
     3          08:30:00
     4          05:30:00
     5          08:30:00
     6          08:30:00
     7          18:30:00
     8          08:30:00
     9          18:30:00
   time:
     0          00:00:00
     1          5:30
     10         18:30:00
     11         23:59:00
     12         18:30:00
     13         22:30:00
     2          05:30:00
     3          8:30
     4          05:30:00
     5          8:30
     6          08:30:00
     7          18:30:00
     8          08:30:00
     9          18:30:00
   timeCond:
     0          0
     1          0
     10         5
     11         5
     12         6
     13         6
     2          1
     3          1
     4          2
     5          2
     6          3
     7          3
     8          4
     9          4
   timer:
     0          0
     1          0
     10         0
     11         0
     12         0
     13         0
     2          0
     3          0
     4          0
     5          0
     6          0
     7          0
     8          0
     9          0
   timers:
     0           0  1
     1           2  3
     2           4  5
     3           6  7
     4           8  9
     5           10  11
     6           12  13
   trigger:
   triggertime:
     1519147800:
       localtime  1519147800
       hash:
     1519162200:
       localtime  1519162200
       hash:
     1519167540:
       localtime  1519167540
       hash:
     1519167600:
       localtime  1519167600
       hash:
     1519187400:
       localtime  1519187400
       hash:
     1519198200:
       localtime  1519198200
       hash:
   uiState:
   uiTable:
   alias      Lichtsteuerung LED Stripe Ankleide
   do         always
   group      Flur Logik
   room       1.5.0 Ankleide,9.1.0 LOGIKCENTER
LEDStripe04
   DEF        ([Anwesenheit] >0 and [5:30-8:30|Mo Di Mi Do Fr Sa So] and [LichtWetter:twilight_weather] <99) (set ledStripe04 RGB 05171A)
DOELSEIF([Anwesenheit] >0 and [16:00-20:00|Mo Di Mi Do Fr] and [LichtWetter:twilight_weather] <99) (set ledStripe04 RGB 30E0FF)
DOELSEIF([Anwesenheit] >0 and [20:00-22:00|Mo Di Mi Do] and [LichtWetter:twilight_weather] <99) (set ledStripe04 RGB 05171A)
DOELSEIF([Anwesenheit] >0 and [20:00-22:00|Fr] and [LichtWetter:twilight_weather] <99) (set ledStripe04 RGB 104A54)
DOELSEIF([Anwesenheit] >0 and [22:00-23:59|Fr] and [LichtWetter:twilight_weather] <99) (set ledStripe04 RGB 05171A)
DOELSEIF([Anwesenheit] >0 and [8:30-11:30|Sa So] and [LichtWetter:twilight_weather] <99) (set ledStripe04 RGB 30E0FF)
DOELSEIF([Anwesenheit] >0 and [16:00-22:00|Sa So] and [LichtWetter:twilight_weather] <99) (set ledStripe04 RGB 30E0FF)
DOELSEIF([Anwesenheit] >0 and [22:00-03:00|Sa So] and [LichtWetter:twilight_weather] <99) (set ledStripe04 RGB 05171A)
DOELSE(set ledStripe04 off)
   NAME       Zeitschaltung_Nachttischbeleuchtung
   NR         159
   NTFY_ORDER 50-Zeitschaltung_Nachttischbeleuchtung
   STATE      cmd_9
   TYPE       DOIF
     2018-02-20 10:33:45   cmd             9
     2018-02-20 10:33:45   cmd_nr          9
     2018-02-19 07:18:20   mode            enabled
     2018-02-20 10:33:45   state           cmd_9
     2018-02-20 08:30:00   timer_01_c01    21.02.2018 05:30:00|MoDiMiDoFrSaSo
     2018-02-20 08:30:00   timer_02_c01    21.02.2018 08:30:00|MoDiMiDoFrSaSo
     2018-02-19 20:47:50   timer_03_c02    20.02.2018 16:00:00|MoDiMiDoFr
     2018-02-19 20:47:50   timer_04_c02    20.02.2018 20:00:00|MoDiMiDoFr
     2018-02-19 22:00:00   timer_05_c03    20.02.2018 20:00:00|MoDiMiDo
     2018-02-19 22:00:00   timer_06_c03    20.02.2018 22:00:00|MoDiMiDo
     2018-02-19 22:00:00   timer_07_c04    20.02.2018 20:00:00|Fr
     2018-02-19 22:00:00   timer_08_c04    20.02.2018 22:00:00|Fr
     2018-02-19 23:59:00   timer_09_c05    20.02.2018 22:00:00|Fr
     2018-02-19 23:59:00   timer_10_c05    20.02.2018 23:59:00|Fr
     2018-02-19 20:47:50   timer_11_c06    20.02.2018 08:30:00|SaSo
     2018-02-19 20:47:50   timer_12_c06    20.02.2018 11:30:00|SaSo
     2018-02-19 22:00:00   timer_13_c07    20.02.2018 16:00:00|SaSo
     2018-02-19 22:00:00   timer_14_c07    20.02.2018 22:00:00|SaSo
     2018-02-20 03:00:00   timer_15_c08    20.02.2018 22:00:00|SaSo
     2018-02-20 03:00:00   timer_16_c08    21.02.2018 03:00:00|SaSo
   Regex:
   condition:
     0          InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,0,1,$wday,$hms,"MoDiMiDoFrSaSo") and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     1          InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,2,3,$wday,$hms,"MoDiMiDoFr") and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     2          InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,4,5,$wday,$hms,"MoDiMiDo") and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     3          InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,6,7,$wday,$hms,"Fr") and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     4          InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,8,9,$wday,$hms,"Fr") and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     5          InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,10,11,$wday,$hms,"SaSo") and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     6          InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,12,13,$wday,$hms,"SaSo") and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
     7          InternalDoIf($hash,'Anwesenheit','STATE') >0 and DOIF_time($hash,14,15,$wday,$hms,"SaSo") and ReadingValDoIf($hash,'LichtWetter','twilight_weather') <99
   days:
     0          MoDiMiDoFrSaSo
     1          MoDiMiDoFrSaSo
     10         SaSo
     11         SaSo
     12         SaSo
     13         SaSo
     14         SaSo
     15         SaSo
     2          MoDiMiDoFr
     3          MoDiMiDoFr
     4          MoDiMiDo
     5          MoDiMiDo
     6          Fr
     7          Fr
     8          Fr
     9          Fr
   devices:
     1           Anwesenheit LichtWetter
     2           Anwesenheit LichtWetter
     3           Anwesenheit LichtWetter
     4           Anwesenheit LichtWetter
     5           Anwesenheit LichtWetter
     6           Anwesenheit LichtWetter
     7           Anwesenheit LichtWetter
     all         Anwesenheit LichtWetter
   do:
     0:
       0          set ledStripe04 RGB 05171A
     1:
       0          set ledStripe04 RGB 30E0FF
     2:
     3:
       0          set ledStripe04 RGB 104A54
     4:
     5:
     6:
     7:
     8:
       0          set ledStripe04 off
   helper:
     DOIF_eventas
     globalinit 1
     last_timer 16
     sleeptimer -1
     timerevents:
       azimuth: 149.42
       elevation: 25.81
       twilight: 100
     timereventsState:
       azimuth: 149.42
       elevation: 25.81
       twilight: 100
     triggerEvents:
       azimuth: 149.42
       elevation: 25.81
       twilight: 100
     triggerEventsState:
       azimuth: 149.42
       elevation: 25.81
       twilight: 100
   internals:
     0           Anwesenheit:STATE
     1           Anwesenheit:STATE
     2           Anwesenheit:STATE
     3           Anwesenheit:STATE
     4           Anwesenheit:STATE
     5           Anwesenheit:STATE
     6           Anwesenheit:STATE
     7           Anwesenheit:STATE
   interval:
     0          -1
     1          0
     10         -1
     11         10
     12         -1
     13         12
     14         -1
     15         14
     2          -1
     3          2
     4          -1
     5          4
     6          -1
     7          6
     8          -1
     9          8
   itimer:
   localtime:
     0          1519187400
     1          1519198200
     10         1519111800
     11         1519122600
     12         1519138800
     13         1519160400
     14         1519160400
     15         1519178400
     2          1519138800
     3          1519153200
     4          1519153200
     5          1519160400
     6          1519153200
     7          1519160400
     8          1519160400
     9          1519167540
   readings:
     0           LichtWetter:twilight_weather
     1           LichtWetter:twilight_weather
     2           LichtWetter:twilight_weather
     3           LichtWetter:twilight_weather
     4           LichtWetter:twilight_weather
     5           LichtWetter:twilight_weather
     6           LichtWetter:twilight_weather
     7           LichtWetter:twilight_weather
     all         LichtWetter:twilight_weather
   realtime:
     0          05:30:00
     1          08:30:00
     10         08:30:00
     11         11:30:00
     12         16:00:00
     13         22:00:00
     14         22:00:00
     15         03:00:00
     2          16:00:00
     3          20:00:00
     4          20:00:00
     5          22:00:00
     6          20:00:00
     7          22:00:00
     8          22:00:00
     9          23:59:00
   time:
     0          5:30
     1          8:30
     10         8:30
     11         11:30:00
     12         16:00:00
     13         22:00:00
     14         22:00:00
     15         03:00:00
     2          16:00:00
     3          20:00:00
     4          20:00:00
     5          22:00:00
     6          20:00:00
     7          22:00:00
     8          22:00:00
     9          23:59:00
   timeCond:
     0          0
     1          0
     10         5
     11         5
     12         6
     13         6
     14         7
     15         7
     2          1
     3          1
     4          2
     5          2
     6          3
     7          3
     8          4
     9          4
   timer:
     0          0
     1          0
     10         0
     11         0
     12         0
     13         0
     14         0
     15         0
     2          0
     3          0
     4          0
     5          0
     6          0
     7          0
     8          0
     9          0
   timers:
     0           0  1
     1           2  3
     2           4  5
     3           6  7
     4           8  9
     5           10  11
     6           12  13
     7           14  15
   trigger:
   triggertime:
     1519122600:
       localtime  1519122600
       hash:
     1519138800:
       localtime  1519138800
       hash:
     1519153200:
       localtime  1519153200
       hash:
     1519160400:
       localtime  1519160400
       hash:
     1519167540:
       hash:
     1519178400:
       localtime  1519178400
       hash:
     1519187400:
       hash:
     1519198200:
       hash:
   uiState:
   uiTable:
   do         always
   group      Wohnzimmer Logik
   room       1.4.0 Schlafzimmer,9.1.0 LOGIKCENTER
Kann & sollte ich hier etwas ändern? Bis auf die vielen Logeinträge funktioniert sonst soweit alles.
Dankeschön schonmal vorab  ;D
herrmannj
nö, gebremst wird da nicht aber ist natürlich Unsinn so eine Logik zu betreiben.
Ich habe mir jetzt die DOIF Konstruktion nicht durchgelesen - die (oder eine andere Quelle) musst Du aber reparieren so dass nur geschaltet wird wenn es auch etwas zu schalten gibt.
da es offenbar im set off Bereich passiert würde ich mal tippen, dass einer Deiner Sensoren in diesem DOIF Zweig in diesem Abstand einen Event generiert und das DOIF triggert.
Da Du do always gesetzt hast wird es auch immer ausgewertet und kommt zu dem Schluss es muss was tun.
nils_
ich würde auch mal die _trigger_ überarbeiten bzw. mit ? ergänzen.
so wie es scheint ist für dich die hauptbedingung der bewegungsmelder, d.h. die anderen bedingungen (uhrzeit, helligkeit,....) müssen das DOIF nicht anschmeißen, sondern werden dann nur mitgeprüft!
viele Wege in FHEM es gibt!
