Fremde Hardware ballert Log voll
Begonnen von accessburn, 22 März 2018, 11:37:00
accessburn
ich hab einen SignalESP mit Wlan laufen und werde seit dem gestrigen Umzug mit fremder Hardware zugeballert:
Zitat2018.03.22 10:47:46 2: SIGNALESP433: CUL_TCM97001 Unknown device Unknown, please define it
2018.03.22 10:51:57 2: SIGNALESP433: CUL_TCM97001 Unknown device Unknown, please define it
2018.03.22 10:59:01 2: SIGNALESP433: CUL_TCM97001 Unknown device Unknown, please define it
2018.03.22 11:00:47 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
2018.03.22 11:06:06 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 11:10:37 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
2018.03.22 11:12:30 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
2018.03.22 11:14:55 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_73, please define it
2018.03.22 11:15:05 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
2018.03.22 11:15:08 2: SIGNALESP433: CUL_TCM97001 Unknown device Unknown, please define it
2018.03.22 11:19:33 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 11:21:17 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
2018.03.22 11:24:50 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
2018.03.22 11:25:43 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 11:25:47 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 11:25:50 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 11:25:50 1: SD_WS: UNDEFINED sensor SD_WS_51_TH detected, code SD_WS_51_TH_11
2018.03.22 11:26:37 2: SIGNALESP433: CUL_TCM97001 Unknown device Unknown, please define it
2018.03.22 11:31:01 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 11:31:57 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 11:31:57 1: SD_WS: UNDEFINED sensor SD_WS_51_TH detected, code SD_WS_51_TH_11
2018.03.22 11:31:59 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 11:31:59 1: SD_WS: UNDEFINED sensor SD_WS_51_TH detected, code SD_WS_51_TH_11
Laut Wiki hab ich autocreate abgeschaltet:
defmod autocreate autocreate
attr autocreate autosave 0
attr autocreate disable 1
setstate autocreate disabled
Ändert aber nix.
Was kann ich noch tun?
Wezzy Rpi2b> FHEM, Elro, Intenso, FTUI, Jeelink v3, Max!Cube, Fire5, Foscam, NAS, Fritz!Box + Fon, Max!Wandthermostat, Amazon Echo
Wezzy Rp3b> OctoPi
Jessie Rp3b> UPNP, NAS, Pi-Hole
frank
jeweils definieren und attr ignore setzen.
FHEM: 6.0(SVN) => Pi3(buster)
CBSnake
autocreate wieder anschalten und die Attribute
attr autocreate autocreateThreshold CUL_TCM97001:6:60,SD_WS:6:60,
setzen. Dadurch müssen 6 Events vom Device innerhalb 60 Sekunden ankommen um das Autocreate zu aktivieren.
Autocreate braucht man auch für andere Module das würde ich nicht ganz abschalten.
Gegen:
Hab ich auch noch keine schönere Lösung als dieses DOIF:
defmod doif_ignore DOIF ##schnelles ignore von signalduino devices\
(["$SELF:ignore"]) ##trigger durch set reading im doif\
(defmod [$DEVICE:ignore] CUL_TCM97001 [$DEVICE:ignore], ## erzeuge DEVICE\
attr [$DEVICE:ignore] ignore 1) ##ignoriere DEVICE
attr doif_ignore do always
mit
setreading doif_ignore ignore CUL_TCM97001_20
legt dir das DOIF dieses Device an und setzt es danach auf ignore.
Die meisten Browser speichern ja Eingaben in Eingabefelder ab und die musst später nur noch die Zahl am Schluss ändern.
Nach ein paar Tagen und den dann angelegten und ignorierten Devices wird es deutlich ruhiger im Log.
Achim
FHEM auf Debian 10, HM-Wlan, JeeLink-Wlan, Wlanduino, ConBee, TP-Link Steckdose, GHoma Steckdosen, Shelly Steckdosen
accessburn
Danke für deinen ausführlichen Post. Werd das mal abarbeiten und im Auge behalten.
Danke schön :-)
Wezzy Rp3b> OctoPi
Brice
Bei aktiviertem autocreate sollte
attr autocreate ignoreTypes CUL_TCM.*|SD_WS_33.*
reichen.
FHEM auf RPi 4 4GB (Buster) | produktiv) CUL 868 für FS20 | S300TH | KS300 | Max!Cube als CUN 868 für TechemWZ | HM-MOD-RPI-PCB für HM | Z-Wave ZME_UZB1 | FRITZ!DECT 200 | HUE | Lightify | Echo Dot | WS3080
accessburn
reichen.
Leider nein:
Zitat2018.03.22 17:28:10 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
2018.03.22 17:38:47 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 17:42:19 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
2018.03.22 17:46:44 1: SD_WS: UNDEFINED sensor SD_WS_33_TH detected, code SD_WS_33_TH_2
2018.03.22 17:49:23 2: SIGNALESP433: CUL_TCM97001 Unknown device CUL_TCM97001_20, please define it
Geht fröhlich weiter  :D
Wezzy Rp3b> OctoPi
CBSnake
schlussendlich verhindert das attr nur das anlegen von "wilden" Device.
Du kannst am Signal ESP das Attribut Verbose auf 0 stellen. Den Rest musst du mit dem DOIF auf "ignore" setzen.
Ralf9
ZitatIch hab einen SignalESP mit Wlan laufen und werde seit dem gestrigen Umzug mit fremder Hardware zugeballert:
Welche Sensoren und protocolIDs möchstet Du empfangen?
Mit "get  protocolIDs" bekommt Du eine Übersicht der z.Zt. unterstützten Sensoren und protocolIDs angezeigt.
Gruß Ralf
Gisbert
bei Homematicgeräten funktioniert auch:
  • eine VCCU anlegen
  • set VCCU devIgnUnknown
Dadurch werden diese Geräte ignoriert und nicht mehr geloggt.
Ein Nachbar bei mir hat aufgerüstet und ca. 50 neue Geröte in Betrieb. Um die cfg nicht unübersichtlich  zu bekommen, hab ich diese Geräte in eine separate cfg ausgelagert.
Ja ich bin bekennender cfg-Editierer, und ja, ich weiß, was ich tue - dennoch nicht zur Nachahmung empfohlen.
Hoffentlich werde ich jetzt nicht auf die schwarze Liste gesetzt.
Viele​ Grüße​ Gisbert​
accessburn
Gruß Ralf
ZitatprotocolIDs:
ID    modulname       protocolname # comment
  0 MS CUL_TCM97001    weather1 # Logilink, NC, WS, TCM97001 etc
  1 MS SD_RSL          ConradRSL
  2 MS SD_AS           AS, Self build arduino sensor # developModule. SD_AS module is only in github available
  3 MS IT              itv1
3.1 MS IT              itv1_sync40 # IT remote Control PAR 1000
  4 MS IT              arctech2
  5 MU IT              unitec6899
  6 MS                 weatherID6
  7 MS SD_WS07         weatherID7 # EAS800z, FreeTec NC-7344
  8 MU CUL_TX          TX3 Protocol
  9 MU SD_WS09         CTW 600 # FunkWS WH1080/WH3080/CTW600
10 MC OREGON          OSV2o3
11 MC SD_AS           AS
12 MC hideki          Hideki protocol
12.1 MC hideki          Hideki protocol not invert # only for test of the firmware dev-r33_fixmc
13 MS FLAMINGO        FLAMINGO FA21
13.1 MU FLAMINGO        FLAMINGO FA21 b
14 MS                 Heidemann HX
15 MS                 TCM Bell
16 MU Dooya           Dooya shutter
17 MS IT              arctech
18 MC OREGON          OSV1
20 MU                 livolo
21 MU                 einhell garagedoor
22 MS                 TX-EZ6
23 MS                 perl unknown
24 MU                 visivon remote
25 MS                 les led remote
26 MU                 remote26
27 MU                 remote27
28 MU                 IC Ledspot
29 MU                 HT12e remote
30 MU SD_UT           unitec47031 # developModule. SD_UT module is only in github available
31 MU                 pollin isotronic
32 MS                 freetec 6946
33 MS SD_WS           weather33
35 MS                 socket35
36 MU                 socket36
37 MU SD_WS           Bresser 7009994
38 MS CUL_TCM97001    weather38
39 MU RFXX10REC       X10 Protocol
40 MU                 romotec
41 MS                 elro doorbell # Elro (Smartwares) Doorbell DB200
43 MC SOMFY           Somfy RTS
44 MU SD_WS           BresserTemeo
44.1 MU SD_WS           BresserTemeo
45 MU Revolt          Revolt
46 MU                 EKX1BE
47 MC SD_WS_Maverick  Maverick protocol
48 MU                 TFA Dostmann
49 MU                 quigg_gt9000
50 MU SD_WS           optus_XT300
51 MS SD_WS           weather51 # IAN 275901 Wetterstation Lidl
52 MC OREGON          OS_PIR
55 MS IT              quigg_gt1000
56 MU                 Celexon
57 MC                 m-e
58 MC                 tfa 30.3208.0
59 MU                 AK-HD-4
60 MU CUL_WS          WS2000
61 MU FS10            FS10
62 MU IT              Clarus_Switch
63 MU                 Warema # developId, is still experimental
64 MU SD_WS           WH2
65 MU                 Homeeasy
66 MU CUL_TX          WS7035
67 MU CUL_TX          WS7053
68 MS CUL_TCM97001    PFR-130
69 MU                 Hoermann
70 MU CUL_FHTTK       FHT80TF # Door/Window switch (868Mhz)
71 MU SD_WS           PV-8644 # infactory Poolthermometer
72 MU Siro            Siro shutter # developModule. Siro is not in github or SVN available
72.1 MS Siro            Siro shutter # developModule. Siro is not in github or SVN available
73 MU FHT             FHT80 # Roomthermostat (868Mhz only receive)
74 MU FS20            FS20 # Remote Control (868Mhz only receive)
75 MU SD_RSL          ConradRSL2
76 MU                 xm21 # reserviert, LED Lichtrekette on
76.1 MU                 xm21 # reserviert, LED Lichtrekette off
Wezzy Rp3b> OctoPi
Ralf9
möchstet Du demnach die Möglichkeit haben alle Sensoren und protocolIDs zu empfangen?
Wenn Du auch den sensor SD_WS_33 empfangen möchstest, dann wird es schwierig.
Ansonsten gibt es das sduino Attribut blacklist_IDs, da kannst Du die protocolIDs eintragen, die Du nicht empfangen möchstest.
Für Sensoren mit ausreichend Wiederholungen gibt es das sduino Attribut doubleMsgCheck_IDs
z.B.
attr SIGNALESP433 doubleMsgCheck_IDs 0,3,7
siehe auch
https://fhem.de/commandref.html#SIGNALduinoattr
Gruß Ralf
CBSnake
Blacklist 0,7 hab ich schon länger aktiv, trotzdem hab ich im Log noch CUL_TCM97001 Unknown device CUL_TCM97001_, please define it
Achim
Ralf9
#12
Die Blacklist wirkt nur, wenn keine Whitelist definiert ist.
Wie Du mit get protocolIDs siehst, gibt es außer der ID 0 noch andere IDs die das CUL_TCM97001 aufrufen
Nachtrag:
mit "list sduino" kannst Du Dir die verwendeten IDs anzeigen lassen.
z.B.:
   mcIdList:
     12
   msIdList:
     0
     3
     7
   muIdList:
     9
Gruß Ralf
CBSnake
Whitelist habe ich keine aber z.b. Protokoll 38 hab ich tatsächlich übersehen. Das werde ich mal anpassen ;-)
