Raspberry PI: unable to telnet to FHEM
Begonnen von Guest, 03 November 2012, 23:37:20
Guest
I am using FHEM and it runs perfectly on my Raspberry.
But since some days (I think it was already before upgrading to 5.3) I am
no more able to connect to FHEM using telnet from my RPI.
FHEM is running by "perl fhem.pl fhem.cfg" and I can connect to
telnet 192.168.2.118 7072
from my iMac via local network, but when I try to connect directly from my
RPI using
telnet localhost 7072
my RPI responds:
Trying 127.0.0.1...
telnet: Unable to connect to remote host: Connection timed out
So I am no more able to e.g shutdown my FHEM using
perl fhem.pl 7072 "shutdown"
or any other command.
Any ideas?
Thanks in advance
Guest
the syntax for telnet configuration in fhem.cfg has changed in 5.3:
e.g. define tPort telnet 7072 global
> But since some days (I think it was already before upgrading to 5.3) I am no
> RPI using
> my RPI responds:
> Trying 127.0.0.1...
> Any ideas?
> Thanks in advance
This is correct, but still does not explain, why he cannot connect via
localhost, only from remote. I propose to check how fhem opened the ports via
lsof by executing the following as root:
  lsof -p | grep TCP
The result should look like:
  # lsof -p 7294 | grep TCP
  perl    7294 fhem    5u  IPv4  10226      0t0    TCP *:7072 (LISTEN)
  perl    7294 fhem    6u  IPv4  10227      0t0    TCP *:8083 (LISTEN)
  perl    7294 fhem    7u  IPv4  10228      0t0    TCP *:8084 (LISTEN)
  perl    7294 fhem    8u  IPv4  10229      0t0    TCP *:8085 (LISTEN)
The * is telling us that fhem opened the 7072 port on all available interfaces.
Btw. you did checked the fhem log for errors, didn't you?
Guest
Thanks very much for your feedback.
Unfortunately it doesn't yet help me.
The log file logs:
2012.11.04 13:05:18 3: telnetPort: port 7072 opened
2012.11.04 13:05:18 3: WEB: port 8083 opened
2012.11.04 13:05:19 3: WEBphone: port 8084 opened
2012.11.04 13:05:19 3: WEBtablet: port 8085 opened
and lsof -p 9817 | grep TCP returns
perl    9817 root    6u  IPv4 284166      0t0    TCP *:7072 (LISTEN)
perl    9817 root    8u  IPv4 284167      0t0    TCP *:8083 (LISTEN)
perl    9817 root    9u  IPv4 284168      0t0    TCP *:8084 (LISTEN)
perl    9817 root   10w  IPv4 284169      0t0    TCP *:8085 (LISTEN)
the fhem.cfg simply looks like
define telnetPort telnet 7072 global
This means that fhem can be reached from localhost (if there is one :)
Guest
> Thanks to you all, I got it!
> I forgot to add
> auto lo
> iface lo inet loopback
> to
/etc/networking/interfaces
