mqtt publish with extra timestamp
Begonnen von kroonen, 09 Juli 2018, 18:42:47
kroonen
I have an smoke device, and I want to publish the state and time with mqtt
I have this
fhem> l Rookzolder
   IODev      mqtt
   NAME       Rookzolder
   NR         102
   STATE      Clear
   TYPE       MQTT_DEVICE
     2018-07-09 17:54:49   battery         100.00
     2018-07-09 17:54:49   rook            {"battery":"100.00","voltage":3185,"smoke":false}
     2018-07-09 17:54:49   smoke           0
     2018-07-09 17:54:49   transmission-state incoming publish received
     2018-07-09 17:54:49   voltage         3185
   message_ids:
   sets:
   subscribe:
     zigbee2mqtt/smokezolder
   subscribeExpr:
     ^zigbee2mqtt\/smokezolder$
   subscribeQos:
     zigbee2mqtt/smokezolder 0
   subscribeReadings:
     zigbee2mqtt/smokezolder:
       cmd
       name       rook
   IODev      mqtt
   eventMap   0:Clear 1:Fire
   room       Zolder
   stateFormat smoke
   subscribeReading_rook zigbee2mqtt/smokezolder
and a publish
fhem> l rookzolder_mqtt
   DEF        Rookzolder
   IODev      mqtt
   NAME       rookzolder_mqtt
   NOTIFYDEV  Rookzolder
   NR         106
   NTFY_ORDER 50-rookzolder_mqtt
   STATE      outgoing publish sent
   TYPE       MQTT_BRIDGE
     2018-07-09 17:54:49   transmission-state outgoing publish sent
   message_ids:
   publishReadings:
     smoke      /zigbee2mqtt/smoke1
   subscribe:
   subscribeExpr:
   subscribeQos:
   IODev      mqtt
   publishReading_smoke /zigbee2mqtt/smoke1
   stateFormat transmission-state
I now get a publish at /zigbee2mqtt/smoke1 the value : Clear
What I want is the value: Clear at 17:54:49
So with the timestamp.
Is this possible, and how?
regards Richard
Imo it's not clear what you want to achieve.
Do you want to change the STATE of the device from "Clear" to "Clear at 17:54:49" or do you really want to publish the combined info towards somewhere else?
If It's the first approach, you may use a different Perl-function in stateFormat transforming the '"smoke":false"' to the desired format. As a general remark: If you are looking for an option to have a "one look" how recent your values are, better use other ways like readingsGroup or readingsProxy. If you want to check a device for regular updates, use a watchdog.
In general imo it's better to keep both elements separated (clear and timestamp).
If you want to publish the combined info to a different place/topic, use an event-handler like notify to react on any new "smoke" update. But for this, further info would be required.
