No I/O device found for.... nach Update von "fhem.pl"
Begonnen von Tom111, 20 Juli 2018, 15:09:01
Tom111
Hier mal ein Auszug des LOG.
2018.07.20 15:04:48 1: Including fhem.cfg
2018.07.20 15:04:48 3: telnetPort: port xxxx opened
2018.07.20 15:04:49 3: WEB: port xxxx opened
2018.07.20 15:04:49 2: eventTypes: loaded 1939 events from ./log/eventTypes.txt
2018.07.20 15:04:49 3: Opening CUL_0 device /dev/ttyACM0
2018.07.20 15:04:49 3: Setting CUL_0 serial parameters to 9600,8,N,1
2018.07.20 15:04:50 3: CUL_0: Possible commands: BbCFiAZNkGMKUYRTVWXefmLltux
2018.07.20 15:04:50 3: CUL_0 device opened
2018.07.20 15:04:58 1: MiLamp_1_Define: no I/O device
2018.07.20 15:04:58 1: MiLamp_2_Define: no I/O device
2018.07.20 15:04:58 1: Including ./log/fhem.save
2018.07.20 15:04:58 3: No I/O device found for Sleep_Fan_light2
2018.07.20 15:04:58 3: No I/O device found for Tuer_Wohnen
2018.07.20 15:04:58 3: No I/O device found for Sleep_Group_Lights
2018.07.20 15:04:58 3: No I/O device found for Sleep_SchrankLicht3
2018.07.20 15:04:58 3: No I/O device found for UTG_heizen
2018.07.20 15:04:58 3: No I/O device found for Window_Sleep
2018.07.20 15:04:58 3: No I/O device found for Living_SchrankLicht
2018.07.20 15:04:58 3: No I/O device found for Sleep_Stehlampe
2018.07.20 15:04:58 3: No I/O device found for Kitchen_Leuchtstoff
2018.07.20 15:04:58 3: No I/O device found for HMS100TF_Sleep
2018.07.20 15:04:58 3: No I/O device found for Kitchen_UTG
2018.07.20 15:04:58 3: No I/O device found for Sleep_SchrankLicht2
2018.07.20 15:04:58 3: No I/O device found for Xoro_Tablet
2018.07.20 15:04:58 3: No I/O device found for Kitchen_UTG_Status
2018.07.20 15:04:58 3: No I/O device found for Wohnen_TV
2018.07.20 15:04:58 3: No I/O device found for Home_Group_Lights
2018.07.20 15:04:58 3: No I/O device found for DECT_546e_Wohnen
2018.07.20 15:04:58 3: No I/O device found for MiLamp_2
2018.07.20 15:04:58 3: No I/O device found for Sleep_DVBT
2018.07.20 15:04:58 3: No I/O device found for Tuer_TFK_zu
2018.07.20 15:04:58 3: No I/O device found for Tuer_Wohnen_short2
2018.07.20 15:04:58 3: No I/O device found for Ladegeraet_kitchen
2018.07.20 15:04:58 3: No I/O device found for Window_Kitchen
2018.07.20 15:04:58 3: No I/O device found for Window_Wohnen
2018.07.20 15:04:58 3: No I/O device found for Bath_Licht
2018.07.20 15:04:58 3: No I/O device found for Sleep_Tucher
2018.07.20 15:04:58 3: No I/O device found for Sleep_Fan2
2018.07.20 15:04:58 3: No I/O device found for MiLamp_1
2018.07.20 15:04:58 3: No I/O device found for ASH2200_Kueche
2018.07.20 15:04:58 3: No I/O device found for DECT_Group_CAM
2018.07.20 15:04:58 3: No I/O device found for Keller_Timer
2018.07.20 15:04:58 3: No I/O device found for Steckdose_Laptop
2018.07.20 15:04:58 3: No I/O device found for DECT_546e_Keller
2018.07.20 15:04:58 3: No I/O device found for HMS100TF_Wohnen
2018.07.20 15:04:58 3: No I/O device found for HMS100WD_kitchen
2018.07.20 15:04:58 3: No I/O device found for ASH2200_outdoor
2018.07.20 15:04:58 3: No I/O device found for Sleep_tablet
2018.07.20 15:04:58 3: No I/O device found for Kitchen_Dunstabzug
2018.07.20 15:04:58 3: No I/O device found for HMS100TF_Bad
2018.07.20 15:04:58 0: Featurelevel: 5.8
2018.07.20 15:04:58 0: Server started with 340 defined entities (fhem.pl:17003/2018-07-19 perl:5.014002 os:linux user:fhem pid:19380)
2018.07.20 15:04:59 3: telnetForBlockingFn_1532091899: port 34523 opened
FHEM 5.9 auf Raspberry Pi - 3B+ - Stretch-5.10.88+ | Perl v5.24.1 | CUL868 CC1101 - USB - Lite module - V3 FW 1.67
Fritz!Box 7490 OS 07.29 / Fritz!Dect200 / Fritz!Powerline 546E
FS20ST-4/ FS20 DI-5/ FS20LS/ FS20 PIRI-2-KU/ FS20 TFK/ FS20S4A/FS20 SU-3/FS20 S20-3
HMS100TF/FHT80TF-2/ASH2200/S300TH
Tom111
#4
Zitat von: betateilchen am 20 Juli 2018, 15:30:39
schöner Logauszug :)
Verstehe ich nicht,... bitte kläre mich auf!
rischbiter123
4*Raspi, Max Thermostate und Fensterkontakte, FB7590, Mysensors und NanoCUL, IT und Sonoff, zigbee2mqtt2
Rudi hat den Fehler behoben, die Korrektur kommt mit dem morgigen Update.
(Oder man holt sich die aktuelle fhem.pl bereits jetzt aus dem svn repository)
Tom111
Zitat von: rischbiter123 am 20 Juli 2018, 17:25:30
Keine konkrete Frage?  ::)
Nein, eine Feststellung, wie im Titel zu lesen ist!!!
(d.h. eine Frage erübrigt sich wenn ich direkt auf einen Fehler aufmerksam mache!)
