Offizielles FHEM Docker Basis Image für verschiedene Plattformen
Begonnen von Loredo, 28 Juli 2018, 21:24:57
Reinschki
Hm, der Versuch von Docker fhem/fhem:latest zu pullen, sowie mit deinen letzten Änderungen in der docker-compose.yml erzeugt das hier:
root@fhem:/docker# docker compose up -d
[+] Building 0.0s (1/1) FINISHED        docker:default
 => [fhem internal] load build definition from Dockerfile        0.0s
 => => transferring dockerfile: 860B        0.0s
failed to solve: unterminated heredoc
passibe
Zeig nochmal deine ganze compose file bitte. Bei mir funktioniert das mit
services:
  fhemtest:
    container_name: fhemtest
    restart: unless-stopped
    hostname: fhemtest
    environment:
      TZ: Europe/Berlin
    build:
      context: .
      dockerfile_inline: |
        FROM fhem/fhem:latest
        RUN <<EOF
          LC_ALL=C DEBIAN_FRONTEND=noninteractive apt-get update
          LC_ALL=C DEBIAN_FRONTEND=noninteractive apt-get install -qqy --no-install-recommends build-essential libxml-bare-perl libpath-class-perl libhtml-tableextract-perl libemail-simple-perl libnet-imap-simple-perl libnet-imap-simple-ssl-perl libmail-imapclient-perl libmime-tools-perl libemail-mime-perl libemail-mime-attachment-stripper-perl less mosquitto-clients libreadonly-perl libai-decisiontree-perl mc
          LC_ALL=C apt-get autoremove -qqy && LC_ALL=C apt-get clean
        EOF
        RUN <<EOF
          cpm install --show-build-log-on-failure --configure-timeout=360 --workers=$(nproc) --local-lib-contained /usr/src/app/3rdparty/ Date::Calc
        EOF
        RUN <<EOF
          npm install -g --unsafe-perm --production gassistant-fhem
          npm cache clean --force
        EOF
    pull_policy: build
    volumes:
      - ./fhem:/opt/fhem
    privileged: true
    ports:
      - "8083:8083"
Reinschki
services:
  fhem:
    build:
      context: .
        RUN <<EOF
        EOF
        RUN <<EOF
        EOF
        RUN <<EOF
        EOF
    pull_policy: build
    restart: always
    network_mode: "host"
    volumes:
      - "./fhem/core/:/opt/fhem/"
      - "./fhem/config/pre-start.sh:/pre-start.sh"
      - "./fhem/config/collectord.conf:/etc/collectord.conf"
      - "/mnt/SonosSpeak:/mnt/SonosSpeak"
      - "/mnt/SoundFiles:/mnt/SoundFiles"
      - "/mnt/backup:/mnt/backup"
      - "/mnt/Tauschordner:/mnt/Tauschordner"
      - "/mnt/surveillance:/mnt/surveillance"
    environment:
      LANG: de_DE.UTF-8
      FHEM_UID: 1000
      FHEM_GID: 1000
      UMASK: 0022
      TIMEOUT: 10
      RESTART: 1
      TELNETPORT: 7072
      TZ: Europe/Berlin
    labels:
      - "com.centurylinklabs.watchtower.enable=true"
passibe
Ah, bei deinem letzten EOF (das hinter npm cache clean --force) sind Leerzeichen dahinter. Das ist das Problem. Lösch die mal, sodass die Zeile nur mit EOF endet, dann geht es.
Reinschki
Wer hätte gedacht, dass die Lösung für mein Problem in 4 kleinen Leerzeichen steckt? Vielen Dank für deine Detektivarbeit!
no_Legend
Guten morgen Zusammen,
ich hab gestern auf das neue 4bullseye umgestellt.
Nun bekomme ich beim Start in FHEM folgende zwei Meldungen:
Messages collected while initializing FHEM:configfile: logfile is readonly, it is set in the FHEM_GLOBALATTR environment
pidfilename is readonly, it is set in the FHEM_GLOBALATTR environment
Leider hab ich auf die schnelle im Thread nix gefunden.
Kann mich jemand in die richtige Richtung Schubsen?
Danke und Grüße Robert
Docker FHEM immer aktuell,4x HMLAN, CUL443, CUL868 -homekit/siri -tablet ui -homebridge
Device, diverse:
Homematic, Shelly, Tasmota, MQTT, Unifi Network usw.
Flachzange
Hmm, ist es vielleicht einfach das, was die Fehlermeldung sagt? Dein FHEM-User hat keine Schreibrechte auf das Logfile?
no_Legend
Zitat von: Flachzange am 09 Dezember 2024, 07:30:08Hmm, ist es vielleicht einfach das, was die Fehlermeldung sagt? Dein FHEM-User hat keine Schreibrechte auf das Logfile?
Gute Ansatz.
Bis ich auf die Version 4 umgestellt habe, also gestern, kam diese Meldung nicht.
Dazu hat auch der fhem user auf den Ordner "740" rechte.
Also FHEM user Vollzugriff und die Gruppe nur Leserechte.
Sollte das nicht reichen?
Grüße Robert
Device, diverse:
passibe
Geh mal bitte mit
docker exec -it <FHEM CONTAINER ID/NAME> /bin/bashin den Container und gib uns die Ausgabe von
ls -la /opt/fhem/log | grep -E "fhem-|\.\."
Poste bitte auch mal dein compose file, oder das docker-run-Kommando, mit dem du den Container startest.
Danke!
no_Legend
Danke!
Sorry hat ein wenig gedauert, eben erst Feierband.
-rw-r-----  1 fhem fhem     560749 Sep  6 09:12 fhem-2024-09-01.log
-rw-r-----  1 fhem fhem     464985 Sep  6 09:12 fhem-2024-09-02.log
-rw-r-----  1 fhem fhem     501998 Sep  6 09:12 fhem-2024-09-03.log
-rw-r-----  1 fhem fhem     472139 Sep  6 09:12 fhem-2024-09-04.log
-rw-r-----  1 fhem fhem     483336 Sep  6 09:12 fhem-2024-09-05.log
-rw-r-----  1 fhem fhem     587576 Sep  6 23:59 fhem-2024-09-06.log
-rw-r-----  1 fhem fhem     460868 Sep  7 23:59 fhem-2024-09-07.log
-rw-r-----  1 fhem fhem     470418 Sep  8 23:59 fhem-2024-09-08.log
-rw-r-----  1 fhem fhem     568957 Sep  9 23:59 fhem-2024-09-09.log
-rw-r-----  1 fhem fhem     549618 Sep 10 23:59 fhem-2024-09-10.log
-rw-r-----  1 fhem fhem     794592 Sep 11 23:59 fhem-2024-09-11.log
-rw-r-----  1 fhem fhem    2983087 Sep 12 23:59 fhem-2024-09-12.log
-rw-r-----  1 fhem fhem     895309 Sep 13 23:59 fhem-2024-09-13.log
-rw-r-----  1 fhem fhem     873778 Sep 14 23:59 fhem-2024-09-14.log
-rw-r-----  1 fhem fhem    1944889 Sep 15 23:59 fhem-2024-09-15.log
-rw-r-----  1 fhem fhem     668010 Sep 16 23:59 fhem-2024-09-16.log
-rw-r-----  1 fhem fhem     557085 Sep 17 23:59 fhem-2024-09-17.log
-rw-r-----  1 fhem fhem    1799402 Sep 18 23:59 fhem-2024-09-18.log
-rw-r-----  1 fhem fhem    2991307 Sep 19 23:59 fhem-2024-09-19.log
-rw-r-----  1 fhem fhem    3572267 Sep 20 23:59 fhem-2024-09-20.log
-rw-r-----  1 fhem fhem     464174 Sep 21 23:59 fhem-2024-09-21.log
-rw-r-----  1 fhem fhem     474282 Sep 22 23:59 fhem-2024-09-22.log
-rw-r-----  1 fhem fhem     480205 Sep 23 23:59 fhem-2024-09-23.log
-rw-r-----  1 fhem fhem     467797 Sep 24 23:59 fhem-2024-09-24.log
-rw-r-----  1 fhem fhem     457338 Sep 25 23:59 fhem-2024-09-25.log
-rw-r-----  1 fhem fhem     459711 Sep 26 23:59 fhem-2024-09-26.log
-rw-r-----  1 fhem fhem     529680 Sep 27 23:59 fhem-2024-09-27.log
-rw-r-----  1 fhem fhem     469232 Sep 28 23:59 fhem-2024-09-28.log
-rw-r-----  1 fhem fhem     449673 Sep 29 23:59 fhem-2024-09-29.log
-rw-r-----  1 fhem fhem     464222 Sep 30 23:59 fhem-2024-09-30.log
-rw-r-----  1 fhem fhem     454764 Okt  1 23:59 fhem-2024-10-01.log
-rw-r-----  1 fhem fhem     461322 Okt  2 23:59 fhem-2024-10-02.log
-rw-r-----  1 fhem fhem     464398 Okt  3 23:59 fhem-2024-10-03.log
-rw-r-----  1 fhem fhem     569569 Okt  4 23:59 fhem-2024-10-04.log
-rw-r-----  1 fhem fhem     450164 Okt  5 23:59 fhem-2024-10-05.log
-rw-r-----  1 fhem fhem     435878 Okt  6 23:59 fhem-2024-10-06.log
-rw-r-----  1 fhem fhem     421754 Okt  7 23:59 fhem-2024-10-07.log
-rw-r-----  1 fhem fhem    2628654 Okt  8 23:59 fhem-2024-10-08.log
-rw-r-----  1 fhem fhem    6187898 Okt  9 23:59 fhem-2024-10-09.log
-rw-r-----  1 fhem fhem    4261084 Okt 10 23:59 fhem-2024-10-10.log
-rw-r-----  1 fhem fhem    4018640 Okt 11 23:59 fhem-2024-10-11.log
-rw-r-----  1 fhem fhem     538125 Okt 12 23:59 fhem-2024-10-12.log
-rw-r-----  1 fhem fhem     499712 Okt 13 17:51 fhem-2024-10-13.log
-rw-r-----  1 fhem fhem    2673343 Okt 14 23:59 fhem-2024-10-14.log
-rw-r-----  1 fhem fhem    6471541 Okt 15 23:59 fhem-2024-10-15.log
-rw-r-----  1 fhem fhem    6475943 Okt 16 23:59 fhem-2024-10-16.log
-rw-r-----  1 fhem fhem    6342969 Okt 17 23:59 fhem-2024-10-17.log
-rw-r-----  1 fhem fhem    6331034 Okt 18 23:59 fhem-2024-10-18.log
-rw-r-----  1 fhem fhem    6534525 Okt 19 23:59 fhem-2024-10-19.log
-rw-r-----  1 fhem fhem    6754261 Okt 20 23:59 fhem-2024-10-20.log
-rw-r-----  1 fhem fhem    4595915 Okt 21 23:59 fhem-2024-10-21.log
-rw-r-----  1 fhem fhem     465663 Okt 22 23:59 fhem-2024-10-22.log
-rw-r-----  1 fhem fhem     523128 Okt 23 23:59 fhem-2024-10-23.log
-rw-r-----  1 fhem fhem     467465 Okt 24 23:59 fhem-2024-10-24.log
-rw-r-----  1 fhem fhem     482222 Okt 25 23:59 fhem-2024-10-25.log
-rw-r-----  1 fhem fhem     466049 Okt 26 23:59 fhem-2024-10-26.log
-rw-r-----  1 fhem fhem     476819 Okt 27 23:59 fhem-2024-10-27.log
-rw-r-----  1 fhem fhem     453229 Okt 28 23:59 fhem-2024-10-28.log
-rw-r-----  1 fhem fhem     432611 Okt 29 23:59 fhem-2024-10-29.log
-rw-r-----  1 fhem fhem     434456 Okt 30 23:59 fhem-2024-10-30.log
-rw-r-----  1 fhem fhem     538212 Okt 31 23:59 fhem-2024-10-31.log
-rw-r-----  1 fhem fhem     459341 Nov  1 23:59 fhem-2024-11-01.log
-rw-r-----  1 fhem fhem     427585 Nov  2 23:59 fhem-2024-11-02.log
-rw-r-----  1 fhem fhem     422018 Nov  3 23:59 fhem-2024-11-03.log
-rw-r-----  1 fhem fhem     428588 Nov  4 23:59 fhem-2024-11-04.log
-rw-r-----  1 fhem fhem     464213 Nov  5 23:59 fhem-2024-11-05.log
-rw-r-----  1 fhem fhem     467128 Nov  6 23:59 fhem-2024-11-06.log
-rw-r-----  1 fhem fhem     507811 Nov  7 23:59 fhem-2024-11-07.log
-rw-r-----  1 fhem fhem     446458 Nov  8 23:59 fhem-2024-11-08.log
-rw-r-----  1 fhem fhem     509032 Nov  9 23:59 fhem-2024-11-09.log
-rw-r-----  1 fhem fhem     458394 Nov 10 23:59 fhem-2024-11-10.log
-rw-r-----  1 fhem fhem     461182 Nov 11 23:59 fhem-2024-11-11.log
-rw-r-----  1 fhem fhem     563573 Nov 12 23:59 fhem-2024-11-12.log
-rw-r-----  1 fhem fhem     508792 Nov 13 23:59 fhem-2024-11-13.log
-rw-r-----  1 fhem fhem     469089 Nov 14 23:59 fhem-2024-11-14.log
-rw-r-----  1 fhem fhem     449933 Nov 15 23:59 fhem-2024-11-15.log
-rw-r-----  1 fhem fhem     514151 Nov 16 23:59 fhem-2024-11-16.log
-rw-r-----  1 fhem fhem     427403 Nov 17 23:59 fhem-2024-11-17.log
-rw-r-----  1 fhem fhem     719567 Nov 18 23:59 fhem-2024-11-18.log
-rw-r-----  1 fhem fhem     494765 Nov 19 23:59 fhem-2024-11-19.log
-rw-r-----  1 fhem fhem     472956 Nov 20 23:59 fhem-2024-11-20.log
-rw-r-----  1 fhem fhem     463962 Nov 21 23:59 fhem-2024-11-21.log
-rw-r-----  1 fhem fhem     451388 Nov 22 23:59 fhem-2024-11-22.log
-rw-r-----  1 fhem fhem     480609 Nov 23 23:59 fhem-2024-11-23.log
-rw-r-----  1 fhem fhem     462581 Nov 24 23:59 fhem-2024-11-24.log
-rw-r-----  1 fhem fhem     466763 Nov 25 23:59 fhem-2024-11-25.log
-rw-r-----  1 fhem fhem     668085 Nov 26 23:59 fhem-2024-11-26.log
-rw-r-----  1 fhem fhem    1437865 Nov 27 23:59 fhem-2024-11-27.log
-rw-r-----  1 fhem fhem    1153077 Nov 28 23:59 fhem-2024-11-28.log
-rw-r-----  1 fhem fhem    1324029 Nov 29 23:59 fhem-2024-11-29.log
-rw-r-----  1 fhem fhem    1385322 Nov 30 23:59 fhem-2024-11-30.log
-rw-r-----  1 fhem fhem    1260153 Dez  1 23:59 fhem-2024-12-01.log
-rw-r-----  1 fhem fhem    1332070 Dez  2 23:59 fhem-2024-12-02.log
-rw-r-----  1 fhem fhem    1377235 Dez  3 23:59 fhem-2024-12-03.log
-rw-r-----  1 fhem fhem    1247543 Dez  4 23:59 fhem-2024-12-04.log
-rw-r-----  1 fhem fhem    1229540 Dez  5 23:59 fhem-2024-12-05.log
-rw-r-----  1 fhem fhem    1326570 Dez  6 23:59 fhem-2024-12-06.log
-rw-r-----  1 fhem fhem    1274284 Dez  7 23:59 fhem-2024-12-07.log
-rw-r-----  1 fhem fhem    1260485 Dez  8 23:59 fhem-2024-12-08.log
-rw-r-----  1 fhem fhem    1109011 Dez  9 17:09 fhem-2024-12-09.log
hier das compose aus portanier raus:
version: "3.2"
#Network Configuration
networks:
    macvlan_bond0:
        external: true
    backend:
        #internal: true
        external: true
services:
#Database MYSQL Container
    db:
        image: mysql
        deploy:
          resources:
             limits:
                memory: 8096M
        networks:
          backend:
            ipv4_address: 172.22.0.3
        volumes:
            - "/var/lib/docker/volumes/fhem/_mysql:/var/lib/mysql"
        environment:
            MYSQL_ROOT_PASSWORD: "HS:iwmen3k;!"
#FHEM Container
    app:
#        image: ghcr.io/fhem/fhem-docker:3-bullseye
        image: ghcr.io/fhem/fhem-docker:4-bullseye
        links:
            - db
        restart: always
        privileged: true
        networks:
          macvlan_bond0:
            ipv4_address: 172.16.3.10
          backend:
            ipv4_address: 172.22.0.2
        ports:
            - 8083:8083
        volumes:
            - "/var/lib/docker/volumes/fhem/_fhem:/opt/fhem/"
#       devices:
#           - "/dev/serial/by-id/usb-busware.de_CUL433-if00:/dev/serial/by-id/usb-busware.de_CUL433-if00"
#           - "/dev/serial/by-id/usb-busware.de_CUL868-if00:/dev/serial/by-id/usb-busware.de_CUL868-if00"
        environment:
            APT_PKGS: "libswitch-perl librpc-xml-perl"
            FHEM_UID: 1013
            FHEM_GID: 1007
            TIMEOUT: 10
            RESTART: 1
            TELNETPORT: 7072
            TZ: Europe/Berlin
#           CONFIGTYPE: configDB
Device, diverse:
Wernieman
Kann es sein, das Du die Zeile mit ".." rausgeschnitten hast? Die wäre wichtig gewesen um zu Wissen, ob der User überhaupt in das Verzeichnis schreiben kann ....
- Bitte um Input für Output
no_Legend
Zitat von: Wernieman am 09 Dezember 2024, 18:11:54Kann es sein, das Du die Zeile mit ".." rausgeschnitten hast? Die wäre wichtig gewesen um zu Wissen, ob der User überhaupt in das Verzeichnis schreiben kann ....
Sorry kann passiert sein.
Hier gerade noch mal frisch.
Was mich aber wundert, wenn man auf den Zeitstempel beim letzten Daylog von heute schaut.
Dann sieht man ja, dass das Log geschrieben werden kann.
drwxr-x--- 22 fhem fhem       4096 Dez  9 06:49 ..
-rw-r-----  1 fhem fhem    1171604 Dez  9 18:34 fhem-2024-12-09.log
Device, diverse:
passibe
Ok, hab es selbst gerade getestet und konnte es (jedenfalls hinsichtlich des logfiles) reproduzieren.
Wenn man eine non-default FHEM_UID oder FHEM_GID einträgt, dann kommt die Fehlermeldung.
Die Fehlermeldung ist aber falsch, weil die Berechtigungen stimmen und das Logfile unproblematisch beschrieben werden kann und ja auch beschrieben wird. Kannst du aktuell also einfach ignorieren.
Habe dazu mal ein GitHub-Issue aufgemacht: https://github.com/fhem/fhem-docker/issues/283
Sidey
Zitat von: no_Legend am 09 Dezember 2024, 07:01:16Nun bekomme ich beim Start in FHEM folgende zwei Meldungen:
Die Meldung kommt von FHEM und besagt lediglich, dass das Attribut logfile und pidfilename durch den Container kontrolliert werden und nicht über das configfile verändert werden können.
Grüße Sidey
Maintainer von: SIGNALduino, SD_WS*, fhem-docker, alexa-fhem-docker, fhempy-docker, WebAuth, fhem-mcp, midea-mqtt, whatsmeow-mqtt
no_Legend
Ah interessant. Danke. Das beruhigt mich.
Mich wundert aber, dass die Meldung erst bei 4 bullseye auftaucht.
Device, diverse:
