HMCCU: Version 4.3 verfügbar
Begonnen von zap, 11 September 2018, 10:40:03
zap
poste mal bitte die Log Einträge beim Start der RPC Server.
FHEM baut immer nur kurzzeitig eine Verbindung zur CCU auf, eben beim Start der RPC Server oder auch beim Ausführen eines Set Befehls.
SW7
#166
hier das Log für die eine CCU:
2019.01.21 18:35:34 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:34 2: HMCCURPCPROC: [d_rpcBidCos_RF] RPC server process started for interface BidCos-RF with PID=32635
2019.01.21 18:35:34 2: CCURPC: [d_rpcBidCos_RF] Initializing RPC server CB2001010013 for interface BidCos-RF
2019.01.21 18:35:34 2: HMCCURPCPROC: [d_rpcBidCos_RF] Callback server CB2001010013 created. Listening on port 7411
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Adding callback for events for server CB2001010013
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Adding callback for new devices for server CB2001010013
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Adding callback for deleted devices for server CB2001010013
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Adding callback for modified devices for server CB2001010013
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Adding callback for replaced devices for server CB2001010013
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Adding callback for readded devices for server CB2001010013
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Adding callback for list devices for server CB2001010013
2019.01.21 18:35:34 2: CCURPC: [d_rpcBidCos_RF] event = SL|CB2001010013|32635
2019.01.21 18:35:34 2: CCURPC: [d_rpcBidCos_RF] CB2001010013 accepting connections. PID=32635
2019.01.21 18:35:34 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Set state to busy
2019.01.21 18:35:34 1: HMCCURPCPROC: [d_rpcBidCos_RF] RPC server starting
2019.01.21 18:35:34 4: HMCCURPCPROC: [d_rpcBidCos_RF] Set rpcstate to starting
2019.01.21 18:35:35 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:35 2: HMCCURPCPROC: [d_rpcHmIP_RF] RPC server process started for interface HmIP-RF with PID=32636
2019.01.21 18:35:35 2: CCURPC: [d_rpcHmIP_RF] Initializing RPC server CB2010010013 for interface HmIP-RF
2019.01.21 18:35:35 2: HMCCURPCPROC: [d_rpcHmIP_RF] Callback server CB2010010013 created. Listening on port 7420
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Adding callback for events for server CB2010010013
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Adding callback for new devices for server CB2010010013
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Adding callback for deleted devices for server CB2010010013
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Adding callback for modified devices for server CB2010010013
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Adding callback for replaced devices for server CB2010010013
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Adding callback for readded devices for server CB2010010013
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Adding callback for list devices for server CB2010010013
2019.01.21 18:35:35 2: CCURPC: [d_rpcHmIP_RF] event = SL|CB2010010013|32636
2019.01.21 18:35:35 2: CCURPC: [d_rpcHmIP_RF] CB2010010013 accepting connections. PID=32636
2019.01.21 18:35:35 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:35 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Set state to busy
2019.01.21 18:35:35 1: HMCCURPCPROC: [d_rpcHmIP_RF] RPC server starting
2019.01.21 18:35:35 4: HMCCURPCPROC: [d_rpcHmIP_RF] Set rpcstate to starting
2019.01.21 18:35:36 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:36 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:36 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:36 4: HMCCURPCPROC: [d_rpcHmIP_RF] Read called
2019.01.21 18:35:36 4: HMCCURPCPROC: [d_rpcHmIP_RF] read SL|CB2010010013|32636 from queue
2019.01.21 18:35:36 2: HMCCURPCPROC: [d_rpcHmIP_RF] CCUEvent = SL|CB2010010013|32636
2019.01.21 18:35:36 2: HMCCURPCPROC: [d_rpcHmIP_RF] RPC server CB2010010013 enters server loop
2019.01.21 18:35:36 4: HMCCURPCPROC: [d_rpcHmIP_RF] Set rpcstate to working
2019.01.21 18:35:37 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:37 2: HMCCURPCPROC: [d_rpcHmIP_RF] Registering callback http://192.168.10.14:7420/fh2010 of type A with ID CB2010010013 at http://192.168.10.14:2010
2019.01.21 18:35:37 4: HMCCURPCPROC: [d_rpcHmIP_RF] Send ASCII RPC request init to http://192.168.10.14:2010
2019.01.21 18:35:37 1: HMCCURPCPROC: [d_rpcHmIP_RF] RPC server CB2010010013 running
2019.01.21 18:35:37 4: HMCCURPCPROC: [d_rpcHmIP_RF] Set rpcstate to running
2019.01.21 18:35:37 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:37 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:38 4: HMCCURPCPROC: [d_rpcHmIP_RF] Set state to OK
2019.01.21 18:35:38 4: HMCCURPCPROC: [d_rpcHmIP_RF] Read stopped after 1 events read: no data
2019.01.21 18:35:38 4: HMCCURPCPROC: [d_rpcHmIP_RF] Read finished
2019.01.21 18:35:38 4: HMCCURPCPROC: [d_rpcBidCos_RF] Read called
2019.01.21 18:35:38 4: HMCCURPCPROC: [d_rpcBidCos_RF] read SL|CB2001010013|32635 from queue
2019.01.21 18:35:38 2: HMCCURPCPROC: [d_rpcBidCos_RF] CCUEvent = SL|CB2001010013|32635
2019.01.21 18:35:38 2: HMCCURPCPROC: [d_rpcBidCos_RF] RPC server CB2001010013 enters server loop
2019.01.21 18:35:38 4: HMCCURPCPROC: [d_rpcBidCos_RF] Set rpcstate to working
2019.01.21 18:35:38 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:38 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:38 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:38 2: HMCCURPCPROC: [d_rpcBidCos_RF] Registering callback http://192.168.10.14:7411/fh2001 of type A with ID CB2001010013 at http://192.168.10.14:2001
2019.01.21 18:35:38 4: HMCCURPCPROC: [d_rpcBidCos_RF] Send ASCII RPC request init to http://192.168.10.14:2001
2019.01.21 18:35:38 1: HMCCURPCPROC: [d_rpcBidCos_RF] RPC server CB2001010013 running
2019.01.21 18:35:38 4: HMCCURPCPROC: [d_rpcBidCos_RF] Set rpcstate to running
2019.01.21 18:35:38 1: HMCCU: [ccu2_14] All RPC servers running
2019.01.21 18:35:38 2: HMCCUDEV: GetUpdate: Addr=xxxxxxxxxxxxxx Name=HmIP-PSM-Andre-Schreibtisch Script=!GetDatapointsByDevice
2019.01.21 18:35:38 2: HMCCUDEV: GetUpdate: Script response =
HmIP-PSM-Andre-Schreibtisch:0=HmIP-RF.xxxxxxxxxxxxxx:0.ACTUAL_TEMPERATURE=0.000000
HmIP-PSM-Andre-Schreibtisch:0=HmIP-RF.xxxxxxxxxxxxxx:0.ACTUAL_TEMPERATURE_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:8=HmIP-RF.xxxxxxxxxxxxxx:8.WEEK_PROGRAM_CHANNEL_LOCKS=0
40
2019.01.21 18:35:38 2: HMCCUDEV: GetAttrSubstitute: subst = STATE!(true|1):on,(false|0):off;AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: HmIP_PSM_Andre_Schreibtisch Objects = xxxxxxxxxxxxxx
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: Processing object xxxxxxxxxxxxxx
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:4, dpt=SECTION, key=4.SECTION, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HMIP-PSM xxxxxxxxxxxxxx:4 chnnum=4 dpt=SECTION, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV:     check rm=1 f=.* cn= c=
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=4.SECTION, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:4, dpt=SECTION_STATUS, key=4.SECTION_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HMIP-PSM xxxxxxxxxxxxxx:4 chnnum=4 dpt=SECTION_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=4.SECTION_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:4, dpt=PROCESS, key=4.PROCESS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HMIP-PSM xxxxxxxxxxxxxx:4 chnnum=4 dpt=PROCESS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=4.PROCESS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:4, dpt=STATE, key=4.STATE, value=false
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HMIP-PSM xxxxxxxxxxxxxx:4 chnnum=4 dpt=STATE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=4.STATE, orgvalue=false value=off peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE, key=0.OPERATING_VOLTAGE, value=0.000000
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=OPERATING_VOLTAGE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.OPERATING_VOLTAGE, orgvalue=0.000000 value=0.0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UPDATE_PENDING, key=0.UPDATE_PENDING, value=false
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=UPDATE_PENDING, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.UPDATE_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_PEER, key=0.RSSI_PEER, value=179
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=RSSI_PEER, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.RSSI_PEER, orgvalue=179 value=179 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UNREACH, key=0.UNREACH, value=false
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=UNREACH, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.UNREACH, orgvalue=false value=alive peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=CONFIG_PENDING, key=0.CONFIG_PENDING, value=false
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=CONFIG_PENDING, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.CONFIG_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=ACTUAL_TEMPERATURE, key=0.ACTUAL_TEMPERATURE, value=0.000000
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=ACTUAL_TEMPERATURE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.ACTUAL_TEMPERATURE, orgvalue=0.000000 value=0.0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_DEVICE, key=0.RSSI_DEVICE, value=177
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=RSSI_DEVICE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.RSSI_DEVICE, orgvalue=177 value=177 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE_STATUS, key=0.OPERATING_VOLTAGE_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=OPERATING_VOLTAGE_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.OPERATING_VOLTAGE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=DUTY_CYCLE, key=0.DUTY_CYCLE, value=false
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=DUTY_CYCLE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.DUTY_CYCLE, orgvalue=false value=false peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=INSTALL_TEST, key=0.INSTALL_TEST, value=true
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=INSTALL_TEST, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.INSTALL_TEST, orgvalue=true value=true peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=ERROR_OVERHEAT, key=0.ERROR_OVERHEAT, value=false
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=ERROR_OVERHEAT, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.ERROR_OVERHEAT, orgvalue=false value=false peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=ERROR_CODE, key=0.ERROR_CODE, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=ERROR_CODE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.ERROR_CODE, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:0, dpt=ACTUAL_TEMPERATURE_STATUS, key=0.ACTUAL_TEMPERATURE_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Schreibtisch:0 chnnum=0 dpt=ACTUAL_TEMPERATURE_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=0.ACTUAL_TEMPERATURE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:3, dpt=PROCESS, key=3.PROCESS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HMIP-PSM xxxxxxxxxxxxxx:3 chnnum=3 dpt=PROCESS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=3.PROCESS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:3, dpt=STATE, key=3.STATE, value=true
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HMIP-PSM xxxxxxxxxxxxxx:3 chnnum=3 dpt=STATE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=3.STATE, orgvalue=true value=on peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:3, dpt=SECTION, key=3.SECTION, value=2
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HMIP-PSM xxxxxxxxxxxxxx:3 chnnum=3 dpt=SECTION, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=3.SECTION, orgvalue=2 value=2 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:3, dpt=SECTION_STATUS, key=3.SECTION_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HMIP-PSM xxxxxxxxxxxxxx:3 chnnum=3 dpt=SECTION_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=3.SECTION_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:2, dpt=SECTION_STATUS, key=2.SECTION_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HMIP-PSM xxxxxxxxxxxxxx:2 chnnum=2 dpt=SECTION_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=2.SECTION_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:2, dpt=SECTION, key=2.SECTION, value=2
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HMIP-PSM xxxxxxxxxxxxxx:2 chnnum=2 dpt=SECTION, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=2.SECTION, orgvalue=2 value=2 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:2, dpt=STATE, key=2.STATE, value=true
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HMIP-PSM xxxxxxxxxxxxxx:2 chnnum=2 dpt=STATE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=2.STATE, orgvalue=true value=on peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:2, dpt=PROCESS, key=2.PROCESS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HMIP-PSM xxxxxxxxxxxxxx:2 chnnum=2 dpt=PROCESS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=2.PROCESS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:5, dpt=STATE, key=5.STATE, value=false
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:5, chnnam=HMIP-PSM xxxxxxxxxxxxxx:5 chnnum=5 dpt=STATE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=5.STATE, orgvalue=false value=off peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:5, dpt=PROCESS, key=5.PROCESS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:5, chnnam=HMIP-PSM xxxxxxxxxxxxxx:5 chnnum=5 dpt=PROCESS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=5.PROCESS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:5, dpt=SECTION_STATUS, key=5.SECTION_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:5, chnnam=HMIP-PSM xxxxxxxxxxxxxx:5 chnnum=5 dpt=SECTION_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=5.SECTION_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:5, dpt=SECTION, key=5.SECTION, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:5, chnnam=HMIP-PSM xxxxxxxxxxxxxx:5 chnnum=5 dpt=SECTION, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=5.SECTION, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=POWER, key=6.POWER, value=1.620000
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=POWER, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.POWER, orgvalue=1.620000 value=1.6 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=VOLTAGE, key=6.VOLTAGE, value=235.300000
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=VOLTAGE, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.VOLTAGE, orgvalue=235.300000 value=235.3 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=ENERGY_COUNTER_OVERFLOW, key=6.ENERGY_COUNTER_OVERFLOW, value=false
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=ENERGY_COUNTER_OVERFLOW, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.ENERGY_COUNTER_OVERFLOW, orgvalue=false value=false peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=CURRENT, key=6.CURRENT, value=165.000000
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=CURRENT, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.CURRENT, orgvalue=165.000000 value=165.0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=POWER_STATUS, key=6.POWER_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=POWER_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.POWER_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=VOLTAGE_STATUS, key=6.VOLTAGE_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=VOLTAGE_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.VOLTAGE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=CURRENT_STATUS, key=6.CURRENT_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=CURRENT_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.CURRENT_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=FREQUENCY_STATUS, key=6.FREQUENCY_STATUS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=FREQUENCY_STATUS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.FREQUENCY_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=FREQUENCY, key=6.FREQUENCY, value=49.990000
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=FREQUENCY, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.FREQUENCY, orgvalue=49.990000 value=50.0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:6, dpt=ENERGY_COUNTER, key=6.ENERGY_COUNTER, value=398.000000
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=ENERGY_COUNTER, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=6.ENERGY_COUNTER, orgvalue=398.000000 value=398.0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Schreibtisch, chnadd/object=xxxxxxxxxxxxxx:8, dpt=WEEK_PROGRAM_CHANNEL_LOCKS, key=8.WEEK_PROGRAM_CHANNEL_LOCKS, value=0
2019.01.21 18:35:38 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:8, chnnam=HMIP-PSM xxxxxxxxxxxxxx:8 chnnum=8 dpt=WEEK_PROGRAM_CHANNEL_LOCKS, rules=.*
2019.01.21 18:35:38 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Schreibtisch, readings=8.WEEK_PROGRAM_CHANNEL_LOCKS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: text=^0\.UNREACH!(1|true):unreachable;^[0-9]\.LOW_?BAT!(1|true):warn_battery
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=5.SECTION
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.INSTALL_TEST
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UNREACH
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=3.SECTION_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.OPERATING_VOLTAGE_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_PEER
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=6.FREQUENCY_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=4.STATE
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=6.ENERGY_COUNTER_OVERFLOW
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=3.PROCESS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.CONFIG_PENDING
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=6.VOLTAGE_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=5.PROCESS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=5.STATE
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=2.SECTION
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=2.SECTION_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.ERROR_CODE
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=2.PROCESS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=6.POWER
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=5.SECTION_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UPDATE_PENDING
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.ERROR_OVERHEAT
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=6.CURRENT_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=3.STATE
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.ACTUAL_TEMPERATURE_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=2.STATE
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=4.SECTION
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=8.WEEK_PROGRAM_CHANNEL_LOCKS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=4.PROCESS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=4.SECTION_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.DUTY_CYCLE
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=6.POWER_STATUS
2019.01.21 18:35:38 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_DEVICE
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: rule=^0\.UNREACH!(1|true):unreachable, dptexpr=^0\.UNREACH, subst=(1|true):unreachable
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 5.SECTION match ^0\.UNREACH
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^0\.UNREACH
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^0\.UNREACH
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: rule=^[0-9]\.LOW_?BAT!(1|true):warn_battery, dptexpr=^[0-9]\.LOW_?BAT, subst=(1|true):warn_battery
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 5.SECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 3.SECTION_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 3.SECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.RSSI_PEER match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.FREQUENCY_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 4.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.ENERGY_COUNTER_OVERFLOW match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 3.PROCESS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.CONFIG_PENDING match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.VOLTAGE_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 5.PROCESS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 5.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 2.SECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 2.SECTION_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.ERROR_CODE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 2.PROCESS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.POWER match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 5.SECTION_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.FREQUENCY match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.UPDATE_PENDING match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.ERROR_OVERHEAT match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.CURRENT_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.VOLTAGE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 3.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.CURRENT match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.ACTUAL_TEMPERATURE_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 2.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 4.SECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 8.WEEK_PROGRAM_CHANNEL_LOCKS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 4.PROCESS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.ACTUAL_TEMPERATURE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 4.SECTION_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.ENERGY_COUNTER match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.DUTY_CYCLE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 6.POWER_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:38 2: HMCCUDEV: GetHMState: Check 0.RSSI_DEVICE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:39 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:39 2: HMCCUDEV: IsValidDatapoint: devtype=HMIP-PSM, chnno=3, dpt=ON_TIME, valid=1
2019.01.21 18:35:39 2: HMCCUDEV: IsValidDatapoint: devtype=HMIP-PSM, chnno=3, dpt=LEVEL, valid=0
2019.01.21 18:35:39 2: HMCCUDEV: GetUpdate: Addr=xxxxxxxxxxxxxx Name=HmIP-FAL230-C6-EG Script=!GetDatapointsByDevice
2019.01.21 18:35:39 2: HMCCUDEV: GetUpdate: Script response =
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.CONFIG_PENDING=false
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.DATE_TIME_UNKNOWN=false
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.DUTY_CYCLE=false
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.HEATING_COOLING=0
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.HUMIDITY_ALARM=false
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.INSTALL_TEST=true
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.OPERATING_VOLTAGE=0.000000
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.OPERATING_VOLTAGE_STATUS=0
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.RSSI_DEVICE=190
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.RSSI_PEER=189
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.TEMPERATURE_LIMITER=false
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.UNREACH=false
HmIP-FAL230-C6-EG:0=HmIP-RF.xxxxxxxxxxxxxx:0.UPDATE_PENDING=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.STATE=false
49
2019.01.21 18:35:39 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:39 2: HMCCUDEV: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: HmIP_FAL230_C6_EG Objects = xxxxxxxxxxxxxx
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: Processing object xxxxxxxxxxxxxx
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:3, dpt=HUMIDITY_LIMITER, key=3.HUMIDITY_LIMITER, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:3 chnnum=3 dpt=HUMIDITY_LIMITER, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV:     check rm=1 f=.* cn= c=
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=3.HUMIDITY_LIMITER, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:3, dpt=FROST_PROTECTION, key=3.FROST_PROTECTION, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:3 chnnum=3 dpt=FROST_PROTECTION, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=3.FROST_PROTECTION, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:3, dpt=EXTERNAL_CLOCK, key=3.EXTERNAL_CLOCK, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:3 chnnum=3 dpt=EXTERNAL_CLOCK, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=3.EXTERNAL_CLOCK, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:3, dpt=DEW_POINT_ALARM, key=3.DEW_POINT_ALARM, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:3 chnnum=3 dpt=DEW_POINT_ALARM, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=3.DEW_POINT_ALARM, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:3, dpt=EMERGENCY_OPERATION, key=3.EMERGENCY_OPERATION, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:3 chnnum=3 dpt=EMERGENCY_OPERATION, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=3.EMERGENCY_OPERATION, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:3, dpt=STATE, key=3.STATE, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:3 chnnum=3 dpt=STATE, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=3.STATE, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:2, dpt=EXTERNAL_CLOCK, key=2.EXTERNAL_CLOCK, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:2 chnnum=2 dpt=EXTERNAL_CLOCK, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=2.EXTERNAL_CLOCK, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:2, dpt=FROST_PROTECTION, key=2.FROST_PROTECTION, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:2 chnnum=2 dpt=FROST_PROTECTION, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=2.FROST_PROTECTION, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:2, dpt=HUMIDITY_LIMITER, key=2.HUMIDITY_LIMITER, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:2 chnnum=2 dpt=HUMIDITY_LIMITER, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=2.HUMIDITY_LIMITER, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:2, dpt=STATE, key=2.STATE, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:2 chnnum=2 dpt=STATE, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=2.STATE, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:2, dpt=EMERGENCY_OPERATION, key=2.EMERGENCY_OPERATION, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:2 chnnum=2 dpt=EMERGENCY_OPERATION, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=2.EMERGENCY_OPERATION, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:2, dpt=DEW_POINT_ALARM, key=2.DEW_POINT_ALARM, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:2 chnnum=2 dpt=DEW_POINT_ALARM, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=2.DEW_POINT_ALARM, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:4, dpt=EXTERNAL_CLOCK, key=4.EXTERNAL_CLOCK, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:4 chnnum=4 dpt=EXTERNAL_CLOCK, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=4.EXTERNAL_CLOCK, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:4, dpt=FROST_PROTECTION, key=4.FROST_PROTECTION, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:4 chnnum=4 dpt=FROST_PROTECTION, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=4.FROST_PROTECTION, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:4, dpt=HUMIDITY_LIMITER, key=4.HUMIDITY_LIMITER, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:4 chnnum=4 dpt=HUMIDITY_LIMITER, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=4.HUMIDITY_LIMITER, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:4, dpt=STATE, key=4.STATE, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:4 chnnum=4 dpt=STATE, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=4.STATE, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:4, dpt=EMERGENCY_OPERATION, key=4.EMERGENCY_OPERATION, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:4 chnnum=4 dpt=EMERGENCY_OPERATION, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=4.EMERGENCY_OPERATION, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:4, dpt=DEW_POINT_ALARM, key=4.DEW_POINT_ALARM, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:4 chnnum=4 dpt=DEW_POINT_ALARM, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=4.DEW_POINT_ALARM, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UNREACH, key=0.UNREACH, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=UNREACH, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.UNREACH, orgvalue=false value=alive peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=CONFIG_PENDING, key=0.CONFIG_PENDING, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=CONFIG_PENDING, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.CONFIG_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE, key=0.OPERATING_VOLTAGE, value=0.000000
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=OPERATING_VOLTAGE, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.OPERATING_VOLTAGE, orgvalue=0.000000 value=0.000000 peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UPDATE_PENDING, key=0.UPDATE_PENDING, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=UPDATE_PENDING, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.UPDATE_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_PEER, key=0.RSSI_PEER, value=189
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=RSSI_PEER, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.RSSI_PEER, orgvalue=189 value=189 peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=DATE_TIME_UNKNOWN, key=0.DATE_TIME_UNKNOWN, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=DATE_TIME_UNKNOWN, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.DATE_TIME_UNKNOWN, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=DUTY_CYCLE, key=0.DUTY_CYCLE, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=DUTY_CYCLE, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.DUTY_CYCLE, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=INSTALL_TEST, key=0.INSTALL_TEST, value=true
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=INSTALL_TEST, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.INSTALL_TEST, orgvalue=true value=true peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_DEVICE, key=0.RSSI_DEVICE, value=190
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=RSSI_DEVICE, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.RSSI_DEVICE, orgvalue=190 value=190 peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=HUMIDITY_ALARM, key=0.HUMIDITY_ALARM, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=HUMIDITY_ALARM, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.HUMIDITY_ALARM, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=TEMPERATURE_LIMITER, key=0.TEMPERATURE_LIMITER, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=TEMPERATURE_LIMITER, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.TEMPERATURE_LIMITER, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=HEATING_COOLING, key=0.HEATING_COOLING, value=0
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=HEATING_COOLING, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.HEATING_COOLING, orgvalue=0 value=0 peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE_STATUS, key=0.OPERATING_VOLTAGE_STATUS, value=0
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-FAL230-C6-EG:0 chnnum=0 dpt=OPERATING_VOLTAGE_STATUS, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=0.OPERATING_VOLTAGE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:6, dpt=DEW_POINT_ALARM, key=6.DEW_POINT_ALARM, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:6 chnnum=6 dpt=DEW_POINT_ALARM, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=6.DEW_POINT_ALARM, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:6, dpt=EMERGENCY_OPERATION, key=6.EMERGENCY_OPERATION, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:6 chnnum=6 dpt=EMERGENCY_OPERATION, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=6.EMERGENCY_OPERATION, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:6, dpt=STATE, key=6.STATE, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:6 chnnum=6 dpt=STATE, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=6.STATE, orgvalue=false value=false peer=null
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_FAL230_C6_EG, chnadd/object=xxxxxxxxxxxxxx:6, dpt=HUMIDITY_LIMITER, key=6.HUMIDITY_LIMITER, value=false
2019.01.21 18:35:39 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HmIP-FAL230-C6 xxxxxxxxxxxxxx:6 chnnum=6 dpt=HUMIDITY_LIMITER, rules=.*
2019.01.21 18:35:39 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_FAL230_C6_EG, readings=6.HUMIDITY_LIMITER, orgvalue=false value=false peer=null
SW7
Hier noch das Log für CCU die zweite:
2019.01.21 18:51:10 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:10 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:11 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:11 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:12 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:12 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:13 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:13 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:14 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:14 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:15 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:15 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:16 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:16 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:17 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:17 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:18 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:18 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:19 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:19 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:20 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:20 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:21 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:21 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:22 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:22 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:23 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:23 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:24 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:24 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:25 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:25 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:26 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:26 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:26 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:26 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] RPC server process started for interface BidCos-RF with PID=679
2019.01.21 18:51:26 2: CCURPC: [d_rpcBidCos_RF_15] Initializing RPC server CB2001010013 for interface BidCos-RF
2019.01.21 18:51:26 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] Callback server CB2001010013 created. Listening on port 7421
2019.01.21 18:51:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Adding callback for events for server CB2001010013
2019.01.21 18:51:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Adding callback for new devices for server CB2001010013
2019.01.21 18:51:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Adding callback for deleted devices for server CB2001010013
2019.01.21 18:51:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Adding callback for modified devices for server CB2001010013
2019.01.21 18:51:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Adding callback for replaced devices for server CB2001010013
2019.01.21 18:51:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Adding callback for readded devices for server CB2001010013
2019.01.21 18:51:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Adding callback for list devices for server CB2001010013
2019.01.21 18:51:26 2: CCURPC: [d_rpcBidCos_RF_15] event = SL|CB2001010013|679
2019.01.21 18:51:26 2: CCURPC: [d_rpcBidCos_RF_15] CB2001010013 accepting connections. PID=679
2019.01.21 18:51:26 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Set state to busy
2019.01.21 18:51:27 1: HMCCURPCPROC: [d_rpcBidCos_RF_15] RPC server starting
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Set rpcstate to starting
2019.01.21 18:51:27 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:27 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:27 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:27 2: HMCCURPCPROC: [d_rpcHmIP_RF_15] RPC server process started for interface HmIP-RF with PID=680
2019.01.21 18:51:27 2: CCURPC: [d_rpcHmIP_RF_15] Initializing RPC server CB2010010013 for interface HmIP-RF
2019.01.21 18:51:27 2: HMCCURPCPROC: [d_rpcHmIP_RF_15] Callback server CB2010010013 created. Listening on port 7430
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Adding callback for events for server CB2010010013
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Adding callback for new devices for server CB2010010013
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Adding callback for deleted devices for server CB2010010013
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Adding callback for modified devices for server CB2010010013
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Adding callback for replaced devices for server CB2010010013
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Adding callback for readded devices for server CB2010010013
2019.01.21 18:51:27 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Adding callback for list devices for server CB2010010013
2019.01.21 18:51:27 2: CCURPC: [d_rpcHmIP_RF_15] event = SL|CB2010010013|680
2019.01.21 18:51:27 2: CCURPC: [d_rpcHmIP_RF_15] CB2010010013 accepting connections. PID=680
2019.01.21 18:51:27 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:27 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:28 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Set state to busy
2019.01.21 18:51:28 1: HMCCURPCPROC: [d_rpcHmIP_RF_15] RPC server starting
2019.01.21 18:51:28 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Set rpcstate to starting
2019.01.21 18:51:28 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:28 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:28 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:28 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:28 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:28 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:29 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Read called
2019.01.21 18:51:29 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] read SL|CB2010010013|680 from queue
2019.01.21 18:51:29 2: HMCCURPCPROC: [d_rpcHmIP_RF_15] CCUEvent = SL|CB2010010013|680
2019.01.21 18:51:29 2: HMCCURPCPROC: [d_rpcHmIP_RF_15] RPC server CB2010010013 enters server loop
2019.01.21 18:51:29 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Set rpcstate to working
2019.01.21 18:51:29 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:29 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:29 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:29 2: HMCCURPCPROC: [d_rpcHmIP_RF_15] Registering callback http://192.168.10.15:7430/fh2010 of type A with ID CB2010010013 at http://192.168.10.15:2010
2019.01.21 18:51:29 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Send ASCII RPC request init to http://192.168.10.15:2010
2019.01.21 18:51:29 1: HMCCURPCPROC: [d_rpcHmIP_RF_15] RPC server CB2010010013 running
2019.01.21 18:51:29 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Set rpcstate to running
2019.01.21 18:51:29 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:29 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:30 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:30 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:30 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:30 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Set state to OK
2019.01.21 18:51:30 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:30 4: HMCCURPCPROC: [d_rpcHmIP_RF_15] Read finished
2019.01.21 18:51:30 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:30 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read SL|CB2001010013|679 from queue
2019.01.21 18:51:30 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = SL|CB2001010013|679
2019.01.21 18:51:30 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] RPC server CB2001010013 enters server loop
2019.01.21 18:51:30 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Set rpcstate to working
2019.01.21 18:51:30 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:30 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:30 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:31 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:31 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] Registering callback http://192.168.10.15:7421/fh2001 of type A with ID CB2001010013 at http://192.168.10.15:2001
2019.01.21 18:51:31 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request init to http://192.168.10.15:2001
2019.01.21 18:51:31 1: HMCCURPCPROC: [d_rpcBidCos_RF_15] RPC server CB2001010013 running
2019.01.21 18:51:31 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Set rpcstate to running
2019.01.21 18:51:31 1: HMCCU: [ccu2_15] All RPC servers running
2019.01.21 18:51:31 2: HMCCUDEV: GetUpdate: Addr=xxxxxxxxxxxxxx Name=HmIP-SWDM-B2-Bad Script=!GetDatapointsByDevice
2019.01.21 18:51:31 2: HMCCUDEV: GetUpdate: Script response =
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.CONFIG_PENDING=false
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.DUTY_CYCLE=false
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.INSTALL_TEST=true
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.LOW_BAT=false
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.OPERATING_VOLTAGE=3.100000
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.OPERATING_VOLTAGE_STATUS=0
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.RSSI_DEVICE=184
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.RSSI_PEER=0
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.UNREACH=false
HmIP-SWDM-B2-Bad:0=HmIP-RF.xxxxxxxxxxxxxx:0.UPDATE_PENDING=false
HmIP-SWDM-B2 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.STATE=0
11
2019.01.21 18:51:31 2: HMCCUDEV: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: HmIP_SWDM_B2_Bad Objects = xxxxxxxxxxxxxx
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: Processing object xxxxxxxxxxxxxx
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:1, dpt=STATE, key=1.STATE, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-SWDM-B2 xxxxxxxxxxxxxx:1 chnnum=1 dpt=STATE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV:     check rm=1 f=.* cn= c=
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=1.STATE, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UNREACH, key=0.UNREACH, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=UNREACH, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.UNREACH, orgvalue=false value=alive peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=CONFIG_PENDING, key=0.CONFIG_PENDING, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=CONFIG_PENDING, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.CONFIG_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_PEER, key=0.RSSI_PEER, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=RSSI_PEER, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.RSSI_PEER, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE, key=0.OPERATING_VOLTAGE, value=3.100000
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=OPERATING_VOLTAGE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.OPERATING_VOLTAGE, orgvalue=3.100000 value=3.100000 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UPDATE_PENDING, key=0.UPDATE_PENDING, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=UPDATE_PENDING, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.UPDATE_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=DUTY_CYCLE, key=0.DUTY_CYCLE, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=DUTY_CYCLE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.DUTY_CYCLE, orgvalue=false value=false peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=INSTALL_TEST, key=0.INSTALL_TEST, value=true
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=INSTALL_TEST, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.INSTALL_TEST, orgvalue=true value=true peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE_STATUS, key=0.OPERATING_VOLTAGE_STATUS, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=OPERATING_VOLTAGE_STATUS, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.OPERATING_VOLTAGE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_DEVICE, key=0.RSSI_DEVICE, value=184
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=RSSI_DEVICE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.RSSI_DEVICE, orgvalue=184 value=184 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_SWDM_B2_Bad, chnadd/object=xxxxxxxxxxxxxx:0, dpt=LOW_BAT, key=0.LOW_BAT, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-SWDM-B2-Bad:0 chnnum=0 dpt=LOW_BAT, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_SWDM_B2_Bad, readings=0.LOW_BAT, orgvalue=false value=ok peer=null
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: text=^0\.UNREACH!(1|true):unreachable;^[0-9]\.LOW_?BAT!(1|true):warn_battery
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.OPERATING_VOLTAGE
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=1.STATE
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UPDATE_PENDING
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.INSTALL_TEST
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UNREACH
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.CONFIG_PENDING
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.OPERATING_VOLTAGE_STATUS
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_DEVICE
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_PEER
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.DUTY_CYCLE
2019.01.21 18:51:31 2: HMCCUDEV: HMCCU_SubstVariables: var=0.LOW_BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: rule=^0\.UNREACH!(1|true):unreachable, dptexpr=^0\.UNREACH, subst=(1|true):unreachable
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE match ^0\.UNREACH
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 1.STATE match ^0\.UNREACH
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.UPDATE_PENDING match ^0\.UNREACH
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^0\.UNREACH
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^0\.UNREACH
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: rule=^[0-9]\.LOW_?BAT!(1|true):warn_battery, dptexpr=^[0-9]\.LOW_?BAT, subst=(1|true):warn_battery
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 1.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.UPDATE_PENDING match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.CONFIG_PENDING match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.RSSI_DEVICE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.RSSI_PEER match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.DUTY_CYCLE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 2: HMCCUDEV: GetHMState: Check 0.LOW_BAT match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:31 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:31 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:31 2: HMCCUDEV: IsValidDatapoint: devtype=HmIP-SWDM-B2, chnno=1, dpt=ON_TIME, valid=0
2019.01.21 18:51:31 2: HMCCUDEV: IsValidDatapoint: devtype=HmIP-SWDM-B2, chnno=1, dpt=LEVEL, valid=0
2019.01.21 18:51:31 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:31 2: HMCCUDEV: GetUpdate: Addr=xxxxxxxxxxxxxx Name=HmIP-PSM-Andre-Musik Script=!GetDatapointsByDevice
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.ACTUAL_TEMPERATURE=0.000000
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.ACTUAL_TEMPERATURE_STATUS=0
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.CONFIG_PENDING=false
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.DUTY_CYCLE=false
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.ERROR_CODE=0
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.ERROR_OVERHEAT=false
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.INSTALL_TEST=false
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.OPERATING_VOLTAGE=0.000000
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.OPERATING_VOLTAGE_STATUS=0
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.RSSI_DEVICE=187
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.RSSI_PEER=187
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.UNREACH=false
HmIP-PSM-Andre-Musik:0=HmIP-RF.xxxxxxxxxxxxxx:0.UPDATE_PENDING=false
HMIP-PSM xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.PROCESS=0
HMIP-PSM xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.SECTION=2
HMIP-PSM xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.SECTION_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.STATE=true
HMIP-PSM xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.PROCESS=0
HMIP-PSM xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.SECTION=2
HMIP-PSM xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.SECTION_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.STATE=true
HMIP-PSM xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.PROCESS=0
HMIP-PSM xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.SECTION=0
HMIP-PSM xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.SECTION_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.STATE=false
HMIP-PSM xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.PROCESS=0
HMIP-PSM xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.SECTION=0
HMIP-PSM xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.SECTION_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.STATE=false
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.CURRENT=142.000000
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.CURRENT_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.ENERGY_COUNTER=674.400000
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.ENERGY_COUNTER_OVERFLOW=false
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.FREQUENCY=49.980000
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.FREQUENCY_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.POWER=5.830000
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.POWER_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.VOLTAGE=235.400000
HMIP-PSM xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.VOLTAGE_STATUS=0
HMIP-PSM xxxxxxxxxxxxxx:8=HmIP-RF.xxxxxxxxxxxxxx:8.WEEK_PROGRAM_CHANNEL_LOCKS=0
40
2019.01.21 18:51:31 2: HMCCUDEV: GetAttrSubstitute: subst = STATE!(true|1):on,(false|0):off;AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: HmIP_PSM_Andre_Musik Objects = xxxxxxxxxxxxxx
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:4, dpt=SECTION_STATUS, key=4.SECTION_STATUS, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HMIP-PSM xxxxxxxxxxxxxx:4 chnnum=4 dpt=SECTION_STATUS, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=4.SECTION_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:4, dpt=SECTION, key=4.SECTION, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HMIP-PSM xxxxxxxxxxxxxx:4 chnnum=4 dpt=SECTION, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=4.SECTION, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:4, dpt=STATE, key=4.STATE, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HMIP-PSM xxxxxxxxxxxxxx:4 chnnum=4 dpt=STATE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=4.STATE, orgvalue=false value=off peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:4, dpt=PROCESS, key=4.PROCESS, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:4, chnnam=HMIP-PSM xxxxxxxxxxxxxx:4 chnnum=4 dpt=PROCESS, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=4.PROCESS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UNREACH, key=0.UNREACH, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=UNREACH, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.UNREACH, orgvalue=false value=alive peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=CONFIG_PENDING, key=0.CONFIG_PENDING, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=CONFIG_PENDING, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.CONFIG_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=ACTUAL_TEMPERATURE, key=0.ACTUAL_TEMPERATURE, value=0.000000
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=ACTUAL_TEMPERATURE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.ACTUAL_TEMPERATURE, orgvalue=0.000000 value=0.0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE, key=0.OPERATING_VOLTAGE, value=0.000000
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=OPERATING_VOLTAGE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.OPERATING_VOLTAGE, orgvalue=0.000000 value=0.0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UPDATE_PENDING, key=0.UPDATE_PENDING, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=UPDATE_PENDING, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.UPDATE_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_PEER, key=0.RSSI_PEER, value=187
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=RSSI_PEER, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.RSSI_PEER, orgvalue=187 value=187 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=DUTY_CYCLE, key=0.DUTY_CYCLE, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=DUTY_CYCLE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.DUTY_CYCLE, orgvalue=false value=false peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=ERROR_OVERHEAT, key=0.ERROR_OVERHEAT, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=ERROR_OVERHEAT, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.ERROR_OVERHEAT, orgvalue=false value=false peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=INSTALL_TEST, key=0.INSTALL_TEST, value=false
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=INSTALL_TEST, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.INSTALL_TEST, orgvalue=false value=false peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=ERROR_CODE, key=0.ERROR_CODE, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=ERROR_CODE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.ERROR_CODE, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=ACTUAL_TEMPERATURE_STATUS, key=0.ACTUAL_TEMPERATURE_STATUS, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=ACTUAL_TEMPERATURE_STATUS, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.ACTUAL_TEMPERATURE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_DEVICE, key=0.RSSI_DEVICE, value=187
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=RSSI_DEVICE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.RSSI_DEVICE, orgvalue=187 value=187 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE_STATUS, key=0.OPERATING_VOLTAGE_STATUS, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-PSM-Andre-Musik:0 chnnum=0 dpt=OPERATING_VOLTAGE_STATUS, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=0.OPERATING_VOLTAGE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:2, dpt=PROCESS, key=2.PROCESS, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HMIP-PSM xxxxxxxxxxxxxx:2 chnnum=2 dpt=PROCESS, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=2.PROCESS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:2, dpt=STATE, key=2.STATE, value=true
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HMIP-PSM xxxxxxxxxxxxxx:2 chnnum=2 dpt=STATE, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=2.STATE, orgvalue=true value=on peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:2, dpt=SECTION, key=2.SECTION, value=2
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HMIP-PSM xxxxxxxxxxxxxx:2 chnnum=2 dpt=SECTION, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=2.SECTION, orgvalue=2 value=2 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:2, dpt=SECTION_STATUS, key=2.SECTION_STATUS, value=0
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:2, chnnam=HMIP-PSM xxxxxxxxxxxxxx:2 chnnum=2 dpt=SECTION_STATUS, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=2.SECTION_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:3, dpt=SECTION_STATUS, key=3.SECTION_STATUS, value=0
2019.01.21 18:51:31 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HMIP-PSM xxxxxxxxxxxxxx:3 chnnum=3 dpt=SECTION_STATUS, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=3.SECTION_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:3, dpt=SECTION, key=3.SECTION, value=2
2019.01.21 18:51:31 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HMIP-PSM xxxxxxxxxxxxxx:3 chnnum=3 dpt=SECTION, rules=.*
2019.01.21 18:51:31 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=3.SECTION, orgvalue=2 value=2 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:3, dpt=STATE, key=3.STATE, value=true
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HMIP-PSM xxxxxxxxxxxxxx:3 chnnum=3 dpt=STATE, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV:     check rm=1 f=.* cn= c=
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=3.STATE, orgvalue=true value=on peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:3, dpt=PROCESS, key=3.PROCESS, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:3, chnnam=HMIP-PSM xxxxxxxxxxxxxx:3 chnnum=3 dpt=PROCESS, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=3.PROCESS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=POWER, key=6.POWER, value=5.830000
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=POWER, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.POWER, orgvalue=5.830000 value=5.8 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=VOLTAGE, key=6.VOLTAGE, value=235.400000
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=VOLTAGE, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.VOLTAGE, orgvalue=235.400000 value=235.4 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=POWER_STATUS, key=6.POWER_STATUS, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=POWER_STATUS, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.POWER_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=VOLTAGE_STATUS, key=6.VOLTAGE_STATUS, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=VOLTAGE_STATUS, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.VOLTAGE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=FREQUENCY_STATUS, key=6.FREQUENCY_STATUS, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=FREQUENCY_STATUS, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.FREQUENCY_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=CURRENT_STATUS, key=6.CURRENT_STATUS, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=CURRENT_STATUS, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.CURRENT_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=ENERGY_COUNTER_OVERFLOW, key=6.ENERGY_COUNTER_OVERFLOW, value=false
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=ENERGY_COUNTER_OVERFLOW, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.ENERGY_COUNTER_OVERFLOW, orgvalue=false value=false peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=CURRENT, key=6.CURRENT, value=142.000000
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=CURRENT, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.CURRENT, orgvalue=142.000000 value=142.0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=FREQUENCY, key=6.FREQUENCY, value=49.980000
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=FREQUENCY, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.FREQUENCY, orgvalue=49.980000 value=50.0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:6, dpt=ENERGY_COUNTER, key=6.ENERGY_COUNTER, value=674.400000
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:6, chnnam=HMIP-PSM xxxxxxxxxxxxxx:6 chnnum=6 dpt=ENERGY_COUNTER, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=6.ENERGY_COUNTER, orgvalue=674.400000 value=674.4 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:5, dpt=SECTION_STATUS, key=5.SECTION_STATUS, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:5, chnnam=HMIP-PSM xxxxxxxxxxxxxx:5 chnnum=5 dpt=SECTION_STATUS, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=5.SECTION_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:5, dpt=SECTION, key=5.SECTION, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:5, chnnam=HMIP-PSM xxxxxxxxxxxxxx:5 chnnum=5 dpt=SECTION, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=5.SECTION, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:5, dpt=STATE, key=5.STATE, value=false
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:5, chnnam=HMIP-PSM xxxxxxxxxxxxxx:5 chnnum=5 dpt=STATE, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=5.STATE, orgvalue=false value=off peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:5, dpt=PROCESS, key=5.PROCESS, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:5, chnnam=HMIP-PSM xxxxxxxxxxxxxx:5 chnnum=5 dpt=PROCESS, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=5.PROCESS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_PSM_Andre_Musik, chnadd/object=xxxxxxxxxxxxxx:8, dpt=WEEK_PROGRAM_CHANNEL_LOCKS, key=8.WEEK_PROGRAM_CHANNEL_LOCKS, value=0
2019.01.21 18:51:32 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:8, chnnam=HMIP-PSM xxxxxxxxxxxxxx:8 chnnum=8 dpt=WEEK_PROGRAM_CHANNEL_LOCKS, rules=.*
2019.01.21 18:51:32 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_PSM_Andre_Musik, readings=8.WEEK_PROGRAM_CHANNEL_LOCKS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: text=^0\.UNREACH!(1|true):unreachable;^[0-9]\.LOW_?BAT!(1|true):warn_battery
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.CURRENT_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.ERROR_OVERHEAT
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UPDATE_PENDING
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=5.SECTION_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.FREQUENCY
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.POWER
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.OPERATING_VOLTAGE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=2.PROCESS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=2.SECTION_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.ERROR_CODE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_DEVICE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.POWER_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.DUTY_CYCLE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.ENERGY_COUNTER
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.ACTUAL_TEMPERATURE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=4.SECTION_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=4.PROCESS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=8.WEEK_PROGRAM_CHANNEL_LOCKS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=2.STATE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.ACTUAL_TEMPERATURE_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=3.STATE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.VOLTAGE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_PEER
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=3.SECTION
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.OPERATING_VOLTAGE_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=3.SECTION_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.INSTALL_TEST
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=5.STATE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=5.PROCESS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.VOLTAGE_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=3.PROCESS
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=0.CONFIG_PENDING
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.ENERGY_COUNTER_OVERFLOW
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=4.STATE
2019.01.21 18:51:32 2: HMCCUDEV: HMCCU_SubstVariables: var=6.FREQUENCY_STATUS
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: rule=^0\.UNREACH!(1|true):unreachable, dptexpr=^0\.UNREACH, subst=(1|true):unreachable
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.CURRENT_STATUS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.ERROR_OVERHEAT match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.UPDATE_PENDING match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 5.SECTION_STATUS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.FREQUENCY match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.POWER match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 2.PROCESS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 2.SECTION_STATUS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.ERROR_CODE match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.RSSI_DEVICE match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.POWER_STATUS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.DUTY_CYCLE match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.ENERGY_COUNTER match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.ACTUAL_TEMPERATURE match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 4.SECTION_STATUS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 4.PROCESS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 8.WEEK_PROGRAM_CHANNEL_LOCKS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 4.SECTION match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 2.STATE match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.ACTUAL_TEMPERATURE_STATUS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.CURRENT match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 3.STATE match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.VOLTAGE match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.RSSI_PEER match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 3.SECTION match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE_STATUS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 3.SECTION_STATUS match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^0\.UNREACH
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: rule=^[0-9]\.LOW_?BAT!(1|true):warn_battery, dptexpr=^[0-9]\.LOW_?BAT, subst=(1|true):warn_battery
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.CURRENT_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.ERROR_OVERHEAT match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.UPDATE_PENDING match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 5.SECTION_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.FREQUENCY match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.POWER match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 2.PROCESS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 2.SECTION_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.ERROR_CODE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.RSSI_DEVICE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.POWER_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.DUTY_CYCLE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.ENERGY_COUNTER match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.ACTUAL_TEMPERATURE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 4.SECTION_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 4.PROCESS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 8.WEEK_PROGRAM_CHANNEL_LOCKS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 4.SECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 2.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.ACTUAL_TEMPERATURE_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.CURRENT match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 3.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.VOLTAGE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.RSSI_PEER match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 3.SECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 3.SECTION_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 5.SECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 2.SECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 5.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 5.PROCESS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.VOLTAGE_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 3.PROCESS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 0.CONFIG_PENDING match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.ENERGY_COUNTER_OVERFLOW match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 4.STATE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: GetHMState: Check 6.FREQUENCY_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:32 2: HMCCUDEV: IsValidDatapoint: devtype=HMIP-PSM, chnno=3, dpt=ON_TIME, valid=1
2019.01.21 18:51:32 2: HMCCUDEV: IsValidDatapoint: devtype=HMIP-PSM, chnno=3, dpt=LEVEL, valid=0
2019.01.21 18:51:32 2: HMCCUDEV: GetUpdate: Addr=xxxxxxxxxxxxxx Name=HmIP-FAL230-C6-OG Script=!GetDatapointsByDevice
2019.01.21 18:51:32 2: HMCCUDEV: GetUpdate: Script response =
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.CONFIG_PENDING=false
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.DATE_TIME_UNKNOWN=false
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.DUTY_CYCLE=false
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.HEATING_COOLING=0
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.HUMIDITY_ALARM=false
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.INSTALL_TEST=true
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.OPERATING_VOLTAGE=0.000000
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.OPERATING_VOLTAGE_STATUS=0
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.RSSI_DEVICE=184
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.RSSI_PEER=191
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.TEMPERATURE_LIMITER=false
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.UNREACH=false
HmIP-FAL230-C6-OG:0=HmIP-RF.xxxxxxxxxxxxxx:0.UPDATE_PENDING=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:1=HmIP-RF.xxxxxxxxxxxxxx:1.STATE=true
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:2=HmIP-RF.xxxxxxxxxxxxxx:2.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:3=HmIP-RF.xxxxxxxxxxxxxx:3.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:4=HmIP-RF.xxxxxxxxxxxxxx:4.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:5=HmIP-RF.xxxxxxxxxxxxxx:5.STATE=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.DEW_POINT_ALARM=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.EMERGENCY_OPERATION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.EXTERNAL_CLOCK=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.FROST_PROTECTION=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.HUMIDITY_LIMITER=false
HmIP-FAL230-C6 xxxxxxxxxxxxxx:6=HmIP-RF.xxxxxxxxxxxxxx:6.STATE=false
49
SW7
Hier das ende von Log2:
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Janine:0 chnnum=0 dpt=UPDATE_PENDING, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV:     check rm=1 f=.* cn= c=
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=0.UPDATE_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:0, dpt=OPERATING_VOLTAGE, key=0.OPERATING_VOLTAGE, value=2.400000
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Janine:0 chnnum=0 dpt=OPERATING_VOLTAGE, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=0.OPERATING_VOLTAGE, orgvalue=2.400000 value=2.4 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:0, dpt=CONFIG_PENDING, key=0.CONFIG_PENDING, value=false
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Janine:0 chnnum=0 dpt=CONFIG_PENDING, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=0.CONFIG_PENDING, orgvalue=false value=false peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:0, dpt=UNREACH, key=0.UNREACH, value=false
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Janine:0 chnnum=0 dpt=UNREACH, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=0.UNREACH, orgvalue=false value=alive peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=PARTY_TIME_END, key=1.PARTY_TIME_END, value=
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=PARTY_TIME_END, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.PARTY_TIME_END, orgvalue= value= peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=HUMIDITY, key=1.HUMIDITY, value=53
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=HUMIDITY, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.HUMIDITY, orgvalue=53 value=53 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=PARTY_SET_POINT_TEMPERATURE, key=1.PARTY_SET_POINT_TEMPERATURE, value=0.000000
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=PARTY_SET_POINT_TEMPERATURE, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.PARTY_SET_POINT_TEMPERATURE, orgvalue=0.000000 value=0.0 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=ACTUAL_TEMPERATURE_STATUS, key=1.ACTUAL_TEMPERATURE_STATUS, value=0
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=ACTUAL_TEMPERATURE_STATUS, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.ACTUAL_TEMPERATURE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=ACTIVE_PROFILE, key=1.ACTIVE_PROFILE, value=1
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=ACTIVE_PROFILE, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.ACTIVE_PROFILE, orgvalue=1 value=1 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=WINDOW_STATE, key=1.WINDOW_STATE, value=0
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=WINDOW_STATE, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.WINDOW_STATE, orgvalue=0 value=closed peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=HUMIDITY_STATUS, key=1.HUMIDITY_STATUS, value=0
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=HUMIDITY_STATUS, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.HUMIDITY_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=HEATING_COOLING, key=1.HEATING_COOLING, value=0
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=HEATING_COOLING, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.HEATING_COOLING, orgvalue=0 value=0 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=BOOST_TIME, key=1.BOOST_TIME, value=0
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=BOOST_TIME, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.BOOST_TIME, orgvalue=0 value=0 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=SWITCH_POINT_OCCURED, key=1.SWITCH_POINT_OCCURED, value=false
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=SWITCH_POINT_OCCURED, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.SWITCH_POINT_OCCURED, orgvalue=false value=false peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=QUICK_VETO_TIME, key=1.QUICK_VETO_TIME, value=0
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=QUICK_VETO_TIME, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.QUICK_VETO_TIME, orgvalue=0 value=0 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=SET_POINT_TEMPERATURE, key=1.SET_POINT_TEMPERATURE, value=17.000000
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=SET_POINT_TEMPERATURE, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.SET_POINT_TEMPERATURE, orgvalue=17.000000 value=17.0 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=FROST_PROTECTION, key=1.FROST_PROTECTION, value=false
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=FROST_PROTECTION, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.FROST_PROTECTION, orgvalue=false value=false peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=PARTY_TIME_START, key=1.PARTY_TIME_START, value=
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=PARTY_TIME_START, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.PARTY_TIME_START, orgvalue= value= peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=ACTUAL_TEMPERATURE, key=1.ACTUAL_TEMPERATURE, value=19.600000
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=ACTUAL_TEMPERATURE, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.ACTUAL_TEMPERATURE, orgvalue=19.600000 value=19.6 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=SET_POINT_MODE, key=1.SET_POINT_MODE, value=0
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=SET_POINT_MODE, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.SET_POINT_MODE, orgvalue=0 value=0 peer=null
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Janine, chnadd/object=xxxxxxxxxxxxxx:1, dpt=PARTY_MODE, key=1.PARTY_MODE, value=false
2019.01.21 18:51:41 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:1, chnnam=HmIP-STH xxxxxxxxxxxxxx:1 chnnum=1 dpt=PARTY_MODE, rules=.*
2019.01.21 18:51:41 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Janine, readings=1.PARTY_MODE, orgvalue=false value=false peer=null
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: text=^0\.UNREACH!(1|true):unreachable;^[0-9]\.LOW_?BAT!(1|true):warn_battery
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.OPERATING_VOLTAGE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UPDATE_PENDING
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.INSTALL_TEST
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UNREACH
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.SWITCH_POINT_OCCURED
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.PARTY_TIME_END
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.SET_POINT_MODE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.OPERATING_VOLTAGE_STATUS
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.FROST_PROTECTION
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_PEER
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.ACTUAL_TEMPERATURE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.LOW_BAT
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.HEATING_COOLING
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.WINDOW_STATE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.SET_POINT_TEMPERATURE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.BOOST_TIME
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.PARTY_SET_POINT_TEMPERATURE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.PARTY_MODE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.HUMIDITY_STATUS
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.QUICK_VETO_TIME
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.ACTUAL_TEMPERATURE_STATUS
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.PARTY_TIME_START
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.CONFIG_PENDING
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=1.ACTIVE_PROFILE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_DEVICE
2019.01.21 18:51:41 2: HMCCUDEV: HMCCU_SubstVariables: var=0.DUTY_CYCLE
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: rule=^0\.UNREACH!(1|true):unreachable, dptexpr=^0\.UNREACH, subst=(1|true):unreachable
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE match ^0\.UNREACH
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.UPDATE_PENDING match ^0\.UNREACH
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^0\.UNREACH
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^0\.UNREACH
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: rule=^[0-9]\.LOW_?BAT!(1|true):warn_battery, dptexpr=^[0-9]\.LOW_?BAT, subst=(1|true):warn_battery
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.UPDATE_PENDING match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 1.SWITCH_POINT_OCCURED match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 1.PARTY_TIME_END match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 1.SET_POINT_MODE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE_STATUS match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 1.FROST_PROTECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.RSSI_PEER match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 1.ACTUAL_TEMPERATURE match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 2: HMCCUDEV: GetHMState: Check 0.LOW_BAT match ^[0-9]\.LOW_?BAT
2019.01.21 18:51:41 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:42 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:42 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:42 2: HMCCUDEV: IsValidDatapoint: devtype=HmIP-STH, chnno=1, dpt=ON_TIME, valid=0
2019.01.21 18:51:42 2: HMCCUDEV: IsValidDatapoint: devtype=HmIP-STH, chnno=1, dpt=LEVEL, valid=0
2019.01.21 18:51:42 2: HMCCU: [ccu2_15] Updated devices. Success=9 Failed=0
2019.01.21 18:51:42 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:42 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:42 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:42 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:43 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:43 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Set state to OK
2019.01.21 18:51:43 1: HMCCURPCPROC: [d_rpcBidCos_RF_15] Scheduled CCU ping every 1 seconds
2019.01.21 18:51:43 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:43 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:43 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 9 events read: no data
2019.01.21 18:51:43 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:43 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:43 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:43 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:44 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:44 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:44 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:44 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:44 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:51:44 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:45 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:45 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:45 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:45 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:45 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:45 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:45 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:45 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:45 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:45 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:46 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:46 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:46 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:46 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:46 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:46 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:46 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:46 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:46 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:46 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:46 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:47 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:47 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:47 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:47 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:47 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:48 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:48 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:48 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:48 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:48 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:48 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:48 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:48 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:48 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:48 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:49 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:49 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:49 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:49 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:50 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:50 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:50 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:50 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:50 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:51 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:51 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:51 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:51 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:51 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:51 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:51 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:51 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:51 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:51 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:52 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:52 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:52 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:52 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:52 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:52 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:52 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:52 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:52 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:52 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:52 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:53 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:53 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:53 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:53 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:53 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:54 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:54 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:54 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:54 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:54 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:54 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:54 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:54 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:54 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:54 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:54 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:55 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:55 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:55 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:55 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:55 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:56 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:56 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:56 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:56 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:56 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:56 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:56 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:56 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:56 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:56 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:56 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:57 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:57 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:57 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:57 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:57 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:58 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:51:58 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:58 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:51:58 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:51:58 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:51:58 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:51:58 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:51:58 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:51:58 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:58 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:58 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:51:59 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:51:59 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:51:59 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:51:59 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:00 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:00 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:00 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:00 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:00 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:00 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:00 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:00 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:00 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:00 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:00 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:01 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:01 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:01 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:01 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:01 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:02 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:02 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:02 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:02 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:02 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:02 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:02 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:02 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:02 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:02 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:03 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:03 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:03 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:03 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:03 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:04 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:04 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:04 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:04 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:04 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:04 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:04 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:04 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:04 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:04 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:04 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:05 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:05 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:05 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:05 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:05 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:06 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:06 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:06 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:06 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:06 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:06 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:06 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:06 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:06 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:06 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:06 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:07 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:07 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:07 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:07 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:07 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:08 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:08 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:08 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:08 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:08 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:08 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:08 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:08 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:08 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:08 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:08 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:09 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:09 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:09 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:09 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:09 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:10 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:10 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:10 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:10 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:10 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:10 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:10 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:10 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:10 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:10 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:10 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:11 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:11 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:11 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:11 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:11 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:12 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:12 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:12 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:12 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:12 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:12 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:12 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:12 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:12 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:12 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:12 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:13 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:13 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:13 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:13 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:13 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:14 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:14 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:14 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:14 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:14 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:14 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:14 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:14 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:14 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:14 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:14 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:15 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:15 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:15 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:15 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:15 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:16 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:16 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:16 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:16 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:16 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:16 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:16 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:16 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:16 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:16 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:16 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:17 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:17 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:17 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:17 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:17 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:18 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:18 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:18 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:18 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:18 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:18 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:18 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:18 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:18 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:18 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:18 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:19 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:19 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:19 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:19 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:19 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:20 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:20 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:20 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:20 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:20 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:20 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:20 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:20 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:20 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:20 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:20 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:21 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:21 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:21 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:21 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:21 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:22 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:22 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:22 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:22 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:22 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:22 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:22 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:22 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:22 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:22 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:22 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:23 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:23 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:23 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:23 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:23 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:24 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:24 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:24 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:24 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:24 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:24 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:24 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:24 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:24 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:24 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:24 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:25 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:25 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:25 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:25 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:25 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:26 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:26 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:26 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:26 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:26 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:26 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:26 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:27 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:27 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:27 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:27 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:27 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:28 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:28 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:28 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:28 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:28 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:28 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:28 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:28 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:28 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:28 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:28 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:29 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:29 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:29 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:29 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:29 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:30 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:30 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:30 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:30 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:30 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:30 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:30 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:30 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:30 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:30 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:31 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:31 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:31 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:31 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:31 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:32 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:32 2: CCURPC: [d_rpcBidCos_RF_15] event = TO|CB2001010013|2
2019.01.21 18:52:32 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:32 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read called
2019.01.21 18:52:32 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] read TO|CB2001010013|2 from queue
2019.01.21 18:52:32 2: HMCCURPCPROC: [d_rpcBidCos_RF_15] CCUEvent = TO|CB2001010013|2
2019.01.21 18:52:32 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read stopped after 1 events read: no data
2019.01.21 18:52:32 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Read finished
2019.01.21 18:52:32 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
2019.01.21 18:52:32 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:52:32 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:52:33 5: CCURPC: [d_rpcHmIP_RF_15] RPC server CB2010010013 accepting connections
2019.01.21 18:52:33 5: CCURPC: [d_rpcBidCos_RF_15] RPC server CB2001010013 accepting connections
2019.01.21 18:52:33 4: HMCCURPCPROC: [d_rpcBidCos_RF_15] Send ASCII RPC request ping to http://192.168.10.15:2001
SW7
Und noch das Ende von Log1:
2019.01.21 18:35:42 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Wohnzimmer:0 chnnum=0 dpt=OPERATING_VOLTAGE_STATUS, rules=.*
2019.01.21 18:35:42 2: HMCCUDEV:     check rm=1 f=.* cn= c=
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Wohnzimmer, readings=0.OPERATING_VOLTAGE_STATUS, orgvalue=0 value=0 peer=null
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Wohnzimmer, chnadd/object=xxxxxxxxxxxxxx:0, dpt=LOW_BAT, key=0.LOW_BAT, value=false
2019.01.21 18:35:42 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Wohnzimmer:0 chnnum=0 dpt=LOW_BAT, rules=.*
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Wohnzimmer, readings=0.LOW_BAT, orgvalue=false value=ok peer=null
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Wohnzimmer, chnadd/object=xxxxxxxxxxxxxx:0, dpt=RSSI_DEVICE, key=0.RSSI_DEVICE, value=183
2019.01.21 18:35:42 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Wohnzimmer:0 chnnum=0 dpt=RSSI_DEVICE, rules=.*
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Wohnzimmer, readings=0.RSSI_DEVICE, orgvalue=183 value=183 peer=null
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Wohnzimmer, chnadd/object=xxxxxxxxxxxxxx:0, dpt=DUTY_CYCLE, key=0.DUTY_CYCLE, value=false
2019.01.21 18:35:42 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Wohnzimmer:0 chnnum=0 dpt=DUTY_CYCLE, rules=.*
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Wohnzimmer, readings=0.DUTY_CYCLE, orgvalue=false value=false peer=null
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: dev=HmIP_STH_Wohnzimmer, chnadd/object=xxxxxxxxxxxxxx:0, dpt=INSTALL_TEST, key=0.INSTALL_TEST, value=false
2019.01.21 18:35:42 2: HMCCUDEV: FilterReading: chn=xxxxxxxxxxxxxx:0, chnnam=HmIP-STH-Wohnzimmer:0 chnnum=0 dpt=INSTALL_TEST, rules=.*
2019.01.21 18:35:42 2: HMCCUDEV: UpdateSingleDevice: device=HmIP_STH_Wohnzimmer, readings=0.INSTALL_TEST, orgvalue=false value=false peer=null
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: text=^0\.UNREACH!(1|true):unreachable;^[0-9]\.LOW_?BAT!(1|true):warn_battery
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.FROST_PROTECTION
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.ACTUAL_TEMPERATURE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_PEER
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.LOW_BAT
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.HEATING_COOLING
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.SET_POINT_MODE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.OPERATING_VOLTAGE_STATUS
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UPDATE_PENDING
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.INSTALL_TEST
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.SWITCH_POINT_OCCURED
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.PARTY_TIME_END
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.RSSI_DEVICE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.DUTY_CYCLE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=0.CONFIG_PENDING
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.HUMIDITY
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.ACTIVE_PROFILE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.QUICK_VETO_TIME
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.PARTY_TIME_START
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.ACTUAL_TEMPERATURE_STATUS
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.SET_POINT_TEMPERATURE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.BOOST_TIME
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.WINDOW_STATE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.PARTY_SET_POINT_TEMPERATURE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.PARTY_MODE
2019.01.21 18:35:42 2: HMCCUDEV: HMCCU_SubstVariables: var=1.HUMIDITY_STATUS
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: rule=^0\.UNREACH!(1|true):unreachable, dptexpr=^0\.UNREACH, subst=(1|true):unreachable
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 1.FROST_PROTECTION match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 1.ACTUAL_TEMPERATURE match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 0.RSSI_PEER match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 0.LOW_BAT match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 1.HEATING_COOLING match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 1.SET_POINT_MODE match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 0.OPERATING_VOLTAGE_STATUS match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 0.UPDATE_PENDING match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 0.INSTALL_TEST match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 0.UNREACH match ^0\.UNREACH
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: rule=^[0-9]\.LOW_?BAT!(1|true):warn_battery, dptexpr=^[0-9]\.LOW_?BAT, subst=(1|true):warn_battery
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 1.FROST_PROTECTION match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 1.ACTUAL_TEMPERATURE match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 0.RSSI_PEER match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:42 2: HMCCUDEV: GetHMState: Check 0.LOW_BAT match ^[0-9]\.LOW_?BAT
2019.01.21 18:35:43 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:43 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:43 2: HMCCUDEV: IsValidDatapoint: devtype=HmIP-STH, chnno=1, dpt=ON_TIME, valid=0
2019.01.21 18:35:43 2: HMCCUDEV: IsValidDatapoint: devtype=HmIP-STH, chnno=1, dpt=LEVEL, valid=0
2019.01.21 18:35:43 2: HMCCU: [ccu2_14] Updated devices. Success=8 Failed=0
2019.01.21 18:35:43 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:44 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:44 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:44 4: HMCCURPCPROC: [d_rpcBidCos_RF] Set state to OK
2019.01.21 18:35:44 1: HMCCURPCPROC: [d_rpcBidCos_RF] Scheduled CCU ping every 300 seconds
2019.01.21 18:35:44 4: HMCCURPCPROC: [d_rpcBidCos_RF] Read stopped after 1 events read: no data
2019.01.21 18:35:44 4: HMCCURPCPROC: [d_rpcBidCos_RF] Read finished
2019.01.21 18:35:44 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:45 2: HMCCU: GetAttrSubstitute: subst = AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
2019.01.21 18:35:45 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:45 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:46 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:46 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:47 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:47 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:48 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:48 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:49 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:49 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
2019.01.21 18:35:50 5: CCURPC: [d_rpcHmIP_RF] RPC server CB2010010013 accepting connections
2019.01.21 18:35:50 5: CCURPC: [d_rpcBidCos_RF] RPC server CB2001010013 accepting connections
SW7
habe ich die wichtigen Stellen erwischt?
zap
Beide CCUs melden "All RPC servers running". Sieht für mich erst mal OK aus.
Beim Start kommen auch einige Events durch. Sonst würden die RPC Server gar nicht starten.
Warte nach dem Start mal 30 Minuten. Dann führe für die I/O Devices ein "get rpcevents" aus. Das zeigt an, wie viele Events von der CCU geschickt wurden.
SW7
Ich habe mir auf meinem 2. Raspi noch ein HMCCU Device angelegt, welches auch auf eine der beiden CCU verweist.
Damit hat dann der Datensync (RPCPush) funktioniert. Daraufhin habe ich mal die Devices verglichen.
Auf meinem FHEM Server, wo es (für mich) nicht sauber funktionierte, hatte ich folgendes im CCU Device konfiguriert:
ccudef-readingfilter=^(LOW_?BAT|UNREACH)\$
ccudef-readingformat=datapoint
ccudef-readingname=^(.+\.)?AES_KEY\$:sign;^(.+\.)?LOW_?BAT\$:battery;^(.+\.)?BATTERY_STATE\$:batteryLevel;^(.+\.)?UNREACH\$:Activity;^(.+\.)?TEMPERATURE\$:+temperature;^(.+\.)?SET_TEMPERATURE\$:+desired-temp;^(.+\.)?HUMIDITY\$:+humidity;^(.+\.)?LEVEL\$:+pct;^(.+\.)?CONTROL_MODE\$:+controlMode
ccudef-substitute=AES_KEY!(0|false):off,(1|true):on;LOWBAT,LOW_BAT!(0|false):ok,(1|true):low;UNREACH!(0|false):alive,(1|true):dead;MOTION!(0|false):noMotion,(1|true):motion;DIRECTION!0:stop,1:up,2:down,3:undefined;WORKING!0:false,1:true;INHIBIT!(0|false):unlocked,(1|true):locked
Das kam aus der HM Defaults Datei.
Nachdem ich die Attribute in den zwei Devices entfernt hatte, lief die Geschichte sauber.
Den Readingsfilter hatte ich schon früher entfernt, doch der alleine hatte nicht gereicht um die Events anzuzeigen.
Zum Verständnis:
    - ist ccudef-readingname auch ein Filter?
    - ccudef-substitute ist doch nur für Ersetzungen da, richtig? Dürfte somit keine Auswirkung auf die Anzeige/Empfang von Readings haben. Korrekt?
Mein List vom Device schaut jetzt erst einmal ganz simpel so aus:
   CCUNum     1
   Clients    :HMCCUDEV:HMCCUCHN:HMCCURPC:HMCCURPCPROC:
   DEF        192.168.10.14
   FUUID      5c43c0ea-f33f-2430-fc33-8d59cf94f0f8165b
   NAME       ccu2_14
   NOTIFYDEV  global,TYPE=(HMCCU|HMCCUDEV|HMCCUCHN)
   NR         335
   NTFY_ORDER 50-ccu2_14
   RPCState   running
   STATE      running/OK
   TYPE       HMCCU
   ccuaddr    BidCoS-RF
   ccuchannels 115
   ccudevices 9
   ccuif      BidCos-RF
   ccuinterfaces VirtualDevices,HmIP-RF,BidCos-RF
   ccuip      192.168.10.14
   ccuname    HM-RCV-50 BidCoS-RF
   ccustate   active
   ccutype    CCU2/3
   host       192.168.10.14
   version    4.3.010
   .attraggr:
   .attrminint:
   Helper:
     DBLOG:
       CCUDuty:
         mySQLLog:
           TIME       1548195027.13385
           VALUE      5.000000
       state:
         mySQLLog:
           TIME       1548098773.77067
           VALUE      OK
     2019-01-22 23:10:27   CCUDuty         5.000000
     2019-01-21 20:25:29   count_channels  115
     2019-01-21 20:25:29   count_devices   9
     2019-01-21 20:25:29   count_groups    0
     2019-01-21 20:25:29   count_interfaces 3
     2019-01-21 20:25:29   count_programs  4
     2019-01-17 21:50:23   dutycycle       0.0
     2019-01-21 20:26:09   rpcstate        running
     2019-01-21 20:26:13   state           OK
   hmccu:
     defInterface BidCos-RF
     defPort    2001
     evtime     0
     evtimeout  0
     rpccount   0
     rpcports   2001,2010
     updatetime 0
     adr:
     agg:
     ccu:
       chncount   115
       delay      180
       delayed    0
       devcount   9
       gcount     0
       ifcount    3
       prgcount   4
       timeout    1
     dev:
       0001Dxxxxxxxxx:
     grp:
     ifports:
       2001       BidCos-RF
       2010       HmIP-RF
       9292       VirtualDevices
     interfaces:
       BidCos-RF:
         device     d_rpcBidCos_RF
         flags      forceASCII
         host       192.168.10.14
         manager    HMCCU
         port       2001
         prot       http
         state      running
         type       A
         url        http://192.168.10.14:2001
       HmIP-RF:
         device     d_rpcHmIP_RF
         flags      _
         host       192.168.10.14
         manager    HMCCU
         port       2010
         prot       http
         state      running
         type       A
         url        http://192.168.10.14:2010
       VirtualDevices:
         flags      _
         host       192.168.10.14
         manager    null
         port       9292
         prot       http
         state      inactive
         type       A
         url        http://192.168.10.14:9292/groups
     prg:
       GetDutyCycle:
         active     true
         internal   false
       GetPSM_Andre_Desk:
         active     true
         internal   false
       prgEnergyCounter_1321_0001D3C99CBA6A:6:
         active     true
         internal   true
       prgEnergyCounter_1874_0001D709900E3C:6:
         active     true
         internal   true
     rpc:
   ccuflags   procrpc
   room       Homematic
   rpcinterfaces BidCos-RF,HmIP-RF
   rpcport    2001,2010
   rpcserver  on
   stateFormat rpcstate/state
Ich habe mal die ganzen CCU Devices inkl. der 50 virtuellen Schalter weggelassen. ;-)
zap
#173
ccudef-readingname ist eine globale Einstellung, die entsprechende readingname Attribute in den einzelnen Device erspart. Hat aber keine Filterfunktion.
Verschiedene User scheinen mit ccudef-readingfilter Probleme zu haben. Leider konnte ich diese Probleme bisher nicht nachstellen. Wenn Du sichergehen willst, lass ccudef-readingfilter weg und setzte ccureadingfilter in den einzelnen Devices.
Noch eine Info:
- Wenn ccudef-readingfilter gesetzt ist, ccureadingfilter in einem Device aber nicht, werden nur die Datenpunkte in Readings geschrieben, die in ccudef-readingfilter angegeben sind.
- Ist hingegen ccudef-readingfilter nicht gesetzt und auch ccureadingfilter in einem Device nicht gesetzt, werden alle Datenpunkte in Readings geschrieben.
- Sind sowohl ccudef-readingfilter als auch ccureadingfilter gesetzt, werden sie quasi addiert bzw. gelten beide.
SW7
vielen Dank für Deine Erklärungen.
Das hat mir noch einmal ein Stück geholfen und die Sache klarer gemacht.
Aktuell läuft alles wie ich es mir vorgestellt habe.Vielen Dank für Deine Unterstützung.
Ich habe aktuell keine readingsfilter konfiguriert. Weder im CCU Device, noch im RPC Device.
Vielleicht führe ich das später mal ein, aber zur Zeit mag ich es, wenn alle Readings angezeigt werden können.
Liebe Grüße
tndx
Guten Morgen,
ich hatte mal vor 2-3 Monaten HMCCU zum Testen eingerichtet, habe mich aber längere Zeit nicht darum gekümmert. Ich habe in der Zwischenzeit die SW auf der piVCCU auf CCU3 aktualisiert und irgendwann mal festgestellt dass HMCCU nicht lief. Ließ sich auch nicht durch FHEM Updates, HMCCU an/aus, "shutdown restart" zum Laufen überreden.
Ich habe gestern den ganzen Abend der Fehlersuche gewidmet, und am Ende festgestellt, dass es wohl an der Einstellung "Authentifizierung aktiv" gelegen hat. Die Einstellung scheint relativ neu zu sein und die breite Masse nicht zu stören, denn ich habe dazu nur was in einem kleinen FHEM-Thread gefunden, aber weder in diesem Thread noch in Wiki etc. Sollte dieser Hinweis nicht irgendwo ergänzt werden? Ich würde es auch übernehmen, habe nur relativ wenig Ahnung von der Materie.
Eine weitere Frage hätte ich noch bzgl. CCU3 Firewall Einstellungen:
Bis jetzt habe ich folgendes als funktionsfähig befunden, s. Screenshot. Was ich aber nicht weiß, ob ich auf Dauer Probleme damit bekommen kann, weil z.B. noch weitere Ports dazu kommen können etc. Gibt es dazu irgendwo genauere Beschreibung? Mir ist klar, dass ich mit "Vollzugriff" keine Probleme zu erwarten habe, aber das ist ja nicht der Sinn einer Firewall  ;)
zap
Die Firewall Richtlinie würde ich auf "Ports offen" setzen. Dann musst Du nicht immer daran denken, wenn Du ein neues Interface hinzufügst (z.B. virtuelle Gruppen oder CUxD,
Ich habe bei mir alles auf Vollzugriff stehen, da ich den Geräten in meinem lokalen Netz vertraue und keinerlei Port Freigabe ins Internet habe. Mein Router ist meine Firewall. Wer den schafft, schafft im Zweifel auch die CCU Firewall.
HMCCU unterstützt noch keine Authentifizierung. Steht aber auf der Todo-Liste, genauso wie SSL Verschlüsselung => Da ändern sich dann auch die Ports wieder ...
tndx
#177
OK, das leuchtet ein. Da ich auch keine Portfreigaben ins Internet habe, werde ich es wohl ähnlich handhaben.
Wie gesagt, ein Hinweis wäre nicht verkehrt, die Einstellung scheint ab einer bestimmten CCU-SW-Version Standardeinstellung zu sein. Ich habe jedenfalls die Authentifizierung nicht bewusst eingeschaltet... Und dann lief es plötzlich nicht mehr  :(
BadenPower
Eigentlich mehr oder weniger schon, denn bei der Installation der Firmware 3.41.11 wird der Sicherheitsassistent eingeblendet, der Dich fragt, welche Einstellung Du wählen möchtest. Hättest Du dort "Relaxed" gewählt, dann wäre alles so geblieben, wie auf der CCU2 und den "älteren" CCU3-Firmwares.
BadenPower
Zitat eines Users per PN:
Die Dummheit eines Forums, vor allem deren Nutzer, läßt sich daran ablesen, wie oft Personen als Troll bezeichnet werden, wenn sie offenkundige Fehlverhalten von anderen Benutzern öffentlich machen.
zap
#179
Neue Version 4.3.011 im SVN verfügbar
Neue Funktionen:
  • HMCCU: Neuer Befehl set authentication zum Aktivieren der Authentifizierung mit Username/Password bei der Kommunikation mit der CCU (Hinweise s.u.)
  • HMCCU: Neuer Befehl set clear zum Löschen von Readings
  • HMCCU: Neuer Befehl set initialize zum nachträglichen Initialisieren des I/O Device, wenn die CCU beim Start nicht erreichbar war
  • HMCCU: Neuer Befehl get ccumsg zum Auslesen von Alarm- und Service-Meldungen aus der CCU
  • HMCCU/HMCCURPCPROC: Nutzung der neuen DelayedShutdown Funktion von FHEM, um die RPC Server bei shutdown oder shutdown restart korrekt zu beenden
  • HMCCURPCPROC: Der Befehl get rpcstate zeigt nun die lokale IP-Adresse sowie den Callback-Port an, an den die CCU Events schickt. Hilfreich für Docker-Umgebungen
  • HMCCU/HMCCURPCPROC: Unterstützung für SSL-Verschlüsselung beim Zugriff auf die CCU (Hinweise s.u.)
Behobene Fehler:
  • Bei der automatischen Definition von RPC-Devices wurden bei Einsatz mehrerer CCUs keine eindeutigen Device-Namen vergeben
  • Das I/O Device wurde bei RPC- und Client-Devices u.U. nicht richtig zugeordnet
  • Die automatisch vergebene ID eines RPC-Servers war bei Einsatz mehrerer CCUs nicht eindeutig
  • Events bei CCU Timeouts wurden nicht getriggert
Authentifizierung und SSL-Verschlüsselung
Authentifizierung und SSL-Verschlüsselung können kombiniert oder einzeln verwendet werden. Eine Authentifizierung ohne SSL-Verschlüsselung macht jedoch eigentlich keinen Sinn, da Username und Passwort dann unverschlüsselt übertragen werden.
Um die SSL-Verschlüsselung zu aktivieren, muss bei der Definition von Devices vom Typ HMCCU und HMCCURPCPROC dem Namen oder der IP-Adresse der CCU ein "https://" vorangestellt werden. Dazu einfach in der Detailansicht der Devices "DEF" anklicken. Die RPC-Server müssen danach neu gestartet werden. Wenn in der CCU Firewall Ports explizit freigegeben sind, müssen in der Liste folgende Ports ergänzt werden: 42000, 42001, 42010, 49292, 48181. CUxD unterstützt keine SSL-Verschlüsselung!
Für die Aktivierung der Authentifizierung sollte man wie folgt vorgehen:
  • RPC Server stoppen
  • Im WebUI der CCU unter "Einstellungen / Benutzer" einen separaten Nutzer für FHEM anlegen (Admin Rechte zuweisen)
  • Im WebUI der CCU unter "Einstellungen / Systemsteuerung / Sicherheit" die Authentifizierung aktivieren
  • In FHEM für das I/O Device (Typ HMCCU) den Befehl "set authentication Username Password" ausführen
Um die Authentifizierung wieder abzuschalten, wie folgt vorgehen:
  • Im WebUI der CCU unter "Einstellungen / Systemsteuerung / Sicherheit" die Authentifizierung deaktivieren
  • In FHEM für das I/O Device (Typ HMCCU) den Befehl "set authentication" ohne weitere Parameter ausführen
