Läuft: zigbee2mqtt mit MQTT2_SERVER und MQTT2_DEVICE
Begonnen von supernova1963, 23 September 2018, 19:17:21
TomLee
Die Readings der zusätzlichen Bridge deren Topic in die eigentliche Bridge gehören sehen so aus:
[code]setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_date_code 20180404-42
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_description Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_1_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_1_description On/off state of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_1_name state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_1_property state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_1_type binary
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_1_value_off OFF
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_1_value_on ON
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_1_value_toggle TOGGLE
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_2_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_2_description Brightness of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_2_name brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_2_property brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_2_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_2_value_max 254
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_2_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_description Color temperature of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_name color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_property color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_3_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_description Color temperature after cold power on of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_name color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_5_description Restore previous color_temp on cold power on
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_5_name previous
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_presets_5_value 65535
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_property color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_features_4_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_1_type light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_access 2
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_description Triggers an effect on the light (e.g. make light blink for a few seconds)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_name effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_property effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_type enum
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_values_1 blink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_values_2 breathe
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_values_3 okay
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_values_4 channel_change
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_values_5 finish_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_2_values_6 stop_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_3_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_3_description Link quality (signal strength)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_3_name linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_3_property linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_3_unit lqi
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_3_value_max 255
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_exposes_3_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_model 404006/404008/404004
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_supports_ota false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_definition_vendor Müller Licht
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_input_1 genBasic
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_input_2 genIdentify
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_input_3 genGroups
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_input_4 genScenes
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_input_5 genOnOff
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_input_6 genLevelCtrl
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_input_7 lightingColorCtrl
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_input_8 touchlink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_1_clusters_output_1 genOta
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_242_clusters_input_1 greenPower
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_endpoints_242_clusters_output_1 greenPower
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_friendly_name 0x00158d0002fdc5d7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_ieee_address 0x00158d0002fdc5d7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_interview_completed true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_interviewing false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_model_id ZBT-ColorTemperature
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_network_address 17413
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_power_source Mains (single phase)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_software_build_id 2.0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_supported true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 10_type Router
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_description MiJia human body movement sensor
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_1_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_1_description Remaining battery in %
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_1_name battery
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_1_property battery
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_1_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_1_unit %
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_1_value_max 100
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_1_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_2_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_2_description Indicates whether the device detected occupancy
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_2_name occupancy
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_2_property occupancy
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_2_type binary
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_2_unit mV
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_2_value_off false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_2_value_on true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_3_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_3_description Voltage of the battery in millivolts
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_3_name voltage
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_3_property voltage
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_3_unit mV
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_3_value_max 360
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_3_value_min -360
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_4_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_4_description Link quality (signal strength)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_4_name linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_4_property linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_4_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_4_unit lqi
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_4_value_max 255
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_exposes_4_value_min 0
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_4_value_step 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_5_access 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_5_description Side of the cube
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_5_name action_side
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_5_property action_side
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_5_type numeric
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_5_value_max 6
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_5_value_min 0
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_5_value_step 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_6_access 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_6_description Side of the cube
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_6_name action_to_side
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_6_property action_to_side
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_6_type numeric
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_6_value_max 6
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_6_value_min 0
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_6_value_step 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_access 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_description Triggered action (e.g. a button click)
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_name action
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_property action
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_type enum
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_1 shake
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_2 wakeup
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_3 fall
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_4 tap
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_5 slide
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_6 flip180
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_7 flip90
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_8 rotate_left
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_7_values_9 rotate_right
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_8_access 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_8_description Link quality (signal strength)
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_8_name linkquality
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_8_property linkquality
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_8_type numeric
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_8_unit lqi
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_8_value_max 255
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 11_definition_exposes_8_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_model RTCGQ01LM
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_supports_ota false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_definition_vendor Xiaomi
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_friendly_name 0x00158d00032c6d54
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_ieee_address 0x00158d00032c6d54
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_interview_completed true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_interviewing false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_model_id lumi.sensor_motion
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_network_address 19125
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_power_source Battery
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_supported true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 11_type EndDevice
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_description MiJia human body movement sensor
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_1_access 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_1_description Remaining battery in %
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_1_name battery
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_1_property battery
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_1_type numeric
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_1_unit %
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_1_value_max 100
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_1_value_min 0
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_2_access 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_2_description Indicates whether the device detected occupancy
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_2_name occupancy
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_2_property occupancy
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_2_type binary
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_2_value_off false
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_2_value_on true
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_3_access 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_3_description Voltage of the battery in millivolts
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_3_name voltage
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_3_property voltage
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_3_type numeric
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_3_unit mV
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_4_access 1
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_4_description Link quality (signal strength)
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_4_name linkquality
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_4_property linkquality
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_4_type numeric
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_4_unit lqi
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_4_value_max 255
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_exposes_4_value_min 0
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_model RTCGQ01LM
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_supports_ota false
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_definition_vendor Xiaomi
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_friendly_name 0x00158d00031c22fa
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_ieee_address 0x00158d00031c22fa
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_interview_completed true
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_interviewing false
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_model_id lumi.sensor_motion
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_network_address 39353
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_power_source Battery
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_supported true
setstate MQTT2_zigbee_bridge 2021-05-31 22:41:46 12_type EndDevice
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_endpoints_11_clusters_input_1 ssIasAce
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_endpoints_11_clusters_output_1 ssIasZone
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_endpoints_11_clusters_output_2 ssIasWd
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_endpoints_13_clusters_input_1 genOta
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_friendly_name Coordinator
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_ieee_address 0x00124b0018ed284e
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_interview_completed true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_interviewing false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_network_address 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_supported false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 1_type Coordinator
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_date_code 20180404-42
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_description Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_1_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_1_description On/off state of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_1_name state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_1_property state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_1_type binary
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_1_value_off OFF
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_1_value_on ON
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_1_value_toggle TOGGLE
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_2_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_2_description Brightness of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_2_name brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_2_property brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_2_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_2_value_max 254
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_2_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_description Color temperature of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_name color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_property color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_3_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_description Color temperature after cold power on of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_name color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_5_description Restore previous color_temp on cold power on
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_5_name previous
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_presets_5_value 65535
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_property color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_features_4_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_1_type light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_access 2
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_description Triggers an effect on the light (e.g. make light blink for a few seconds)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_name effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_property effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_type enum
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_values_1 blink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_values_2 breathe
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_values_3 okay
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_values_4 channel_change
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_values_5 finish_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_2_values_6 stop_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_3_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_3_description Link quality (signal strength)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_3_name linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_3_property linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_3_unit lqi
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_3_value_max 255
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_exposes_3_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_model 404006/404008/404004
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_supports_ota false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_definition_vendor Müller Licht
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_input_1 genBasic
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_input_2 genIdentify
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_input_3 genGroups
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_input_4 genScenes
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_input_5 genOnOff
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_input_6 genLevelCtrl
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_input_7 lightingColorCtrl
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_input_8 touchlink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_1_clusters_output_1 genOta
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_242_clusters_input_1 greenPower
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_endpoints_242_clusters_output_1 greenPower
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_friendly_name 0x00158d0003278378
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_ieee_address 0x00158d0003278378
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_interview_completed true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_interviewing false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_model_id ZBT-ColorTemperature
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_network_address 30845
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_power_source Mains (single phase)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_software_build_id 2.0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_supported true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 2_type Router
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_date_code 20180404-42
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_description Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_1_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_1_description On/off state of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_1_name state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_1_property state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_1_type binary
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_1_value_off OFF
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_1_value_on ON
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_1_value_toggle TOGGLE
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_2_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_2_description Brightness of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_2_name brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_2_property brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_2_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_2_value_max 254
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_2_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_description Color temperature of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_name color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_property color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_3_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_description Color temperature after cold power on of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_name color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_5_description Restore previous color_temp on cold power on
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_5_name previous
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_presets_5_value 65535
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_property color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_features_4_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_1_type light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_access 2
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_description Triggers an effect on the light (e.g. make light blink for a few seconds)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_name effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_property effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_type enum
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_values_1 blink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_values_2 breathe
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_values_3 okay
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_values_4 channel_change
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_values_5 finish_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_2_values_6 stop_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_3_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_3_description Link quality (signal strength)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_3_name linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_3_property linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_3_unit lqi
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_3_value_max 255
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_exposes_3_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_model 404006/404008/404004
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_supports_ota false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_definition_vendor Müller Licht
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_input_1 genBasic
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_input_2 genIdentify
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_input_3 genGroups
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_input_4 genScenes
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_input_5 genOnOff
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_input_6 genLevelCtrl
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_input_7 lightingColorCtrl
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_input_8 touchlink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_1_clusters_output_1 genOta
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_242_clusters_input_1 greenPower
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_endpoints_242_clusters_output_1 greenPower
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_friendly_name 0x00158d000360ba24
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_ieee_address 0x00158d000360ba24
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_interview_completed true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_interviewing false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_model_id ZBT-ColorTemperature
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_network_address 40745
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_power_source Mains (single phase)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_software_build_id 2.0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_supported true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 3_type Router
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_date_code 20180404-42
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_description Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_1_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_1_description On/off state of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_1_name state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_1_property state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_1_type binary
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_1_value_off OFF
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_1_value_on ON
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_1_value_toggle TOGGLE
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_2_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_2_description Brightness of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_2_name brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_2_property brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_2_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_2_value_max 254
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_2_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_description Color temperature of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_name color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_property color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_3_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_description Color temperature after cold power on of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_name color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_5_description Restore previous color_temp on cold power on
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_5_name previous
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_presets_5_value 65535
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_property color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_features_4_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_1_type light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_access 2
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_description Triggers an effect on the light (e.g. make light blink for a few seconds)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_name effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_property effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_type enum
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_values_1 blink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_values_2 breathe
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_values_3 okay
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_values_4 channel_change
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_values_5 finish_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_2_values_6 stop_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_3_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_3_description Link quality (signal strength)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_3_name linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_3_property linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_3_unit lqi
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_3_value_max 255
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_exposes_3_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_model 404006/404008/404004
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_supports_ota false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_definition_vendor Müller Licht
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_input_1 genBasic
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_input_2 genIdentify
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_input_3 genGroups
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_input_4 genScenes
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_input_5 genOnOff
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_input_6 genLevelCtrl
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_input_7 lightingColorCtrl
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_input_8 touchlink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_1_clusters_output_1 genOta
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_242_clusters_input_1 greenPower
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_endpoints_242_clusters_output_1 greenPower
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_friendly_name 0x00158d0003602b8a
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_ieee_address 0x00158d0003602b8a
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_interview_completed true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_interviewing false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_model_id ZBT-ColorTemperature
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_network_address 35605
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_power_source Mains (single phase)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_software_build_id 2.0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_supported true
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 4_type Router
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_date_code 20180404-42
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_description Tint LED bulb GU10/E14/E27 350/470/806 lumen, dimmable, opal white
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_1_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_1_description On/off state of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_1_name state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_1_property state
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_1_type binary
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_1_value_off OFF
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_1_value_on ON
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_1_value_toggle TOGGLE
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_2_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_2_description Brightness of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_2_name brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_2_property brightness
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_2_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_2_value_max 254
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_2_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_description Color temperature of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_name color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_property color_temp
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_3_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_access 7
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_description Color temperature after cold power on of this light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_name color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_1_description Coolest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_1_name coolest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_1_value 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_2_description Cool temperature (250 mireds / 4000 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_2_name cool
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_2_value 250
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_3_description Neutral temperature (370 mireds / 2700 Kelvin)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_3_name neutral
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_3_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_4_description Warmest temperature supported
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_4_name warmest
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_4_value 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_5_description Restore previous color_temp on cold power on
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_5_name previous
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_presets_5_value 65535
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_property color_temp_startup
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_unit mired
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_value_max 370
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_features_4_value_min 153
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_1_type light
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_access 2
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_description Triggers an effect on the light (e.g. make light blink for a few seconds)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_name effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_property effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_type enum
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_values_1 blink
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_values_2 breathe
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_values_3 okay
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_values_4 channel_change
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_values_5 finish_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_2_values_6 stop_effect
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_3_access 1
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_3_description Link quality (signal strength)
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_3_name linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_3_property linkquality
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_3_type numeric
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_3_unit lqi
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_3_value_max 255
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_exposes_3_value_min 0
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_model 404006/404008/404004
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_supports_ota false
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_definition_vendor Müller Licht
setstate MQTT2_zigbee_bridge 2021-06-01 17:55:06 5_endpoints_1_clusters_inp
TomLee
Sry sind einfach zuviele Readings für den code-Tag.
Könnt sie anhängen.
Auf jedenfall weiß ich nicht was jetzt machen mit den Lampen ?
Kann aber problemlos wieder zurück zur alten Version, ist bloss ärgerlich.
Könnt sie anhängen.
Wäre eine Lösung für das Forumgs-SW-Problem. Die Frage ist aber, ob uns das weiterhilft?
Das Prinzip ist jedenfalls betr. die nicht abgeschnittenen Teile klar: Sind nähere Daten zu den Devices. Ob man die haben muss? Evtl. teilweise interessant, wenn es um die Setter-Grenzen geht?
Da habe ich im Moment auch keine Idee. Seltsam ist, dass das Problem auf der ZigBee-Ebene zu sein scheint. "no route" klingt für mich danach, als würde der MQTT-Befehl verarbeitet, aber die Bulb antwortet mangels Erreichbarkeit nicht - warum auch immer; würde ich eher mal im z2m-Forum adressieren, aber ggf. weiß hier einer der z2m-Experten näheres.
Einfach nochmal permit_join+Bulb resetten hast du vermutlich probiert?
TomLee
ZitatOb man die haben muss? Evtl. teilweise interessant, wenn es um die Setter-Grenzen geht?
Ich brauch die nicht, aber ich bin nicht der der das für andere beurteilen kann, bei mir würden die im Nirvana verschwinden, stehen doch im Log die Daten wenn man was wissen wollte.
ZitatEinfach nochmal permit_join+Bulb resetten hast du vermutlich probiert?
Nee, probier ich später.
TomLee
#454
ZitatKann aber problemlos wieder zurück zur alten Version, ist bloss ärgerlich.
Bei der Gelegenheit und der (einen, SD-Backup gibts auch noch, @Joachim mit dem "tar.gz-Backup" hab ich mich immer noch nicht beschäftigt) Option die ich jetzt hätte einfach wieder ein Backup einzuspielen trau ich mich einfach mal zu fragen (weil mich das beschäftigt und ich es einfach nicht weiß wie die korrekte Vorgehensweise ist).
Spricht was dagegen Programme wie z2m einfach nach opt/fhem zu installieren ? Weil das hab ich testweise zuletzt gemacht, das Backup ist dann halt um einiges größer, kann mir aber irgendwie nicht vorstellen dass das so der richtige Weg ist.
MadMax-FHEM
#455
Zitat von: TomLee am 01 Juni 2021, 18:41:52
Bei der Gelegenheit und der Option die ich jetzt hätte einfach wieder ein Backup einzuspielen trau ich mich einfach mal zu fragen (weil mich das beschäftigt und ich es einfach nicht weiß wie die korrekte Vorgehensweise ist).
Prinzipiell wohl nicht.
Allerdings musst du dann den User für zigbee2mqtt auf fhem ändern (bei meiner bzw. "Standardinstallation" ist das ja der User pi), weil sonst hast du entweder einen Ordner der dem User pi "gehört", somit dürfte dann fhem ein Problem bei Backup haben oder du änderst die "Besitzverhältnisse" auf User fhem und bekommst evtl. zigbee2mqtt nicht mehr zum Laufen...
Allerdings dann vermutlich nach: /opt/fhem/zigbee2mqtt ;)
Mit etwas Zeit kann ich das ja "gerne" mal auf einem meiner Testsysteme machen...
Aber heute wohl nicht mehr :-\
EDIT: ach egal. Ich mach ne Sicherung und los geht's ;)
EDIT: evtl. probiere ich dann gleich meinen Conbee II mal aus :)
Gruß, Joachim
FHEM PI3 Buster (Test)
TomLee
Ja, ich weiß, alles OT ...
siehe oben, meine Vorgehensweise ;) :P
Zitatsudo chown -R fhem:dialout /opt/zigbee2mqtt
su fhem
cd /opt/zigbee2mqtt
TomLee
ZitatEDIT: evtl. probiere ich dann gleich meinen Conbee II mal aus
Und da würd ich mich dann auf eine kurze Anleitung freuen, dann bestell ich mir nämlich auch einen.
MadMax-FHEM
Klar.
Aber ich denke genauso wie beim Raspbee...
Ah, ja klar aber mit anderm User ;)
Allerdings habe ich ja unter Buster etwas abweichend installiert und das würde ich hier wieder tun..
Was ich allerdings (erst mal) auslasse: FW-Update des Conbee II (ich hoffe die ist nicht zu "alt"), weil ich jetzt das deCONZ-Geschlumpe (erst mal) weglassen wollte.
Bzw. zu dem Zweck den Stick dann mal an meinem deCONZ-Testsystem anstecken würde... :)
Gruß, Joachim
MadMax-FHEM
#459
So hier die Anleitung:
sudo apt update
(sudo apt upgrade)
Anleitung hier:
https://www.zigbee2mqtt.io/getting_started/running_zigbee2mqtt.html
EDIT: daran habe ich mich "orientiert". Ich habe das mit der "speziellen" nodejs etc. Version weggelassen! Ich habe es mit den beim OS (Buster!) mitgelieferten Versionen installiert: läuft auch... :)
EDIT: und wenn mal sowas wie alexa-fhem, gassistant o.ä. auf dem fhem-Server nutzt, dann ist das so besser und man bekommt Updates etc. eben über die OS-Mechanismen (apt)...
sudo apt install -y nodejs git make g++ gcc
pi@MadMax-FHEM-RaspiOS:~ $ node --version
v10.24.0
sudo apt install -y npm
[code]
EDIT: sonst ist kein npm da... ;)
[code]
pi@MadMax-FHEM-RaspiOS:~ $ npm --version
5.8.0
Nicht "ideal" (recommended) aber funktioniert (zumindest auf dem anderen PI mit Raspbee)...
sudo git clone https://github.com/Koenkk/zigbee2mqtt.git /opt/fhem/zigbee2mqtt
sudo chown -R fhem: /opt/fhem/zigbee2mqtt
EDIT: hier halt abweichend der User fhem -> wir sind ja im fhem-Ordner... ;)
sudo nano /etc/passwd
bei fhem: /bin/false -> /bin/bash
EDIT: damit man die Installation als User fhem machen kann...
EDIT: das kann/sollte man wieder zurückbauen... Ist ja danach (außer für den ersten "Teststart" nicht mehr nötig, denke ich)
sudo su fhem
cd /opt/fhem/zigbee2mqtt
npm ci --production
nano /opt/fhem/zigbee2mqtt/data/configuration.yaml
EDIT: Inhalt der configuration.yaml (bzgl. Conbee II bzw. RaspBee halt beim Eintrag "serial" entsprechend angeben):
permit_join: false
mqtt:
  base_topic: zigbee2mqtt
  server: 'mqtt://192.168.1.121'
  client_id: zigbee_pi
serial:
# maybe better use /dev/serial/by-id/...
# for RaspBee:  port: /dev/ttyACM0
  port: /dev/ttyACM0
  adapter: deconz
advanced:
  report: true
  network_key: GENERATE
frontend:
  port: 8080
  host: 0.0.0.0
npm start -> fertig :)
EDIT: gut der Start als Service fehlt halt (hier auch) noch ;)
Ich werde noch ein klein wenig was kommentieren...
...aber jetzt muss erst mal die Pizza weg, bevor sie noch kälter wird ;)
Gruß, Joachim
TomLee
Sry, die Anleitung hab ich inne, wie das ganze mit dem Conbee2 umgesetzt wird hab ich einfach noch nicht verstanden.
MadMax-FHEM
#461
Auch nicht anders.
Der einzige Unterschied den ich denke, dass es gibt ist eben:
Conbee II stecken: rauskriegen wie der heißt (noch besser wäre /dev/serial/by-id/... mache ich vielleicht noch)
Und dann eben in der configuration.yaml den angeben:
serial:
  port: /dev/ttyACM0
  adapter: deconz
Und für den Raspbee-Aufsatz das hier (und vorher halt die "Vorbereitungsmassnahmen": serial nutzen und aus der cmdline.txt "rausnehmen" und dann noch BT deaktivieren oder "umlenken"):
EDIT: daher ist der Conbee II schon sehr angenehm. Anstecken angeben in der configuration.yaml und gut :)
serial:
  port: /dev/ttyAMA0
  adapter: deconz
Muss ich oben noch anpassen, da hab ich dummerweise noch die Angaben für den RaspBee drin ;)
EDIT: erledigt, jetzt stimmt es "oben" für den Conbee II (gut evtl. noch /dev/serial/by-id/... ;)  )
Mehr ist es nicht.
Zuerst dachte ich noch (weil in der configuration.yaml deconz steht, dass deCONZ laufen müsste: FALSCH! Wird gar nicht gebraucht)...
Gruß, Joachim
TomLee
ZitatMehr ist es nicht.
Wenn das wirklich so ist, nur den Port zu ändern, dann mach ich mir seit Monaten zu nix Gedanken.
MadMax-FHEM
#463
Naja, ob es wirklich nix anderes ist: keine Ahnung, ich kenne ja nur den Weg/Einstellungen MIT deCONZ-Adaptrn (Conbee II bzw. RaspBee) ;)
Also habe ich (von der anderen Seite kommend) keine Vergleichsmögichkeit ;)
Aber ich habe wirklich ALLE Schritte 1:1 hier gepostet...
...musst du halt "gegen-diffen"... ;)
Einzig für einen FW-Update des Conbee II bzw. RaspBee braucht man halt den Flasher von DE...
...also denke ich.
Der ist halt auf meinen deCONZ-Systemen schon drauf.
Da habe ich den RaspBee auch erst mal neu geflasht...
...beim Conbee II werde ich mal prüfen und evtl. auch mal updaten.
Gruß, Joachim
TomLee
ZitatEinzig für einen FW-Update des Conbee II bzw. RaspBee braucht man halt den Flasher von DE...
Ja, das war jetzt bisher schlussfolgernd meine Erkenntnis aus deinen Aussagen.
