Läuft: zigbee2mqtt mit MQTT2_SERVER und MQTT2_DEVICE
Begonnen von supernova1963, 23 September 2018, 19:17:21
OdfFhem
@rudolfkoenig
Ein Satz an Inputdaten zum Testen ...
MQTT-Antwort für zigbee2mqtt/bridge/config/devices
{"type":"devices",
"message":[{"ieeeAddr":"0x00124b0018321aed","type":"Coordinator"},
{"ieeeAddr":"0x7cb03eaa00845fad","type":"Router","model":"AB3257001NJ","friendly_name":"smartPlug1","nwkAddr":4571,"manufId":48042,"manufName":"OSRAM","powerSource":"Mains (single phase)","modelId":"Plug 01","hwVersion":1,"swBuildId":"V1.04.12","dateCode":"20140331DEOS****"},
{"ieeeAddr":"0xccccccfffea32ef2","type":"EndDevice","model":"E1743","friendly_name":"onoffSwitch1","nwkAddr":44063,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Battery","modelId":"TRADFRI on/off switch","hwVersion":1,"swBuildId":"2.2.008","dateCode":"20190410"},
{"ieeeAddr":"0x0017880104ef74e4","type":"EndDevice","model":"324131092621","friendly_name":"dimmerSwitch5","nwkAddr":62963,"manufId":4107,"manufName":"Philips","powerSource":"Battery","modelId":"RWL021","hwVersion":1,"swBuildId":"5.45.1.17846","dateCode":"20160302"},
{"ieeeAddr":"0x00158d000319b828","type":"Router","model":"SP 120","friendly_name":"innrPlug2","nwkAddr":35300,"manufId":4454,"manufName":"innr","powerSource":"Mains (single phase)","modelId":"SP 120","hwVersion":1,"swBuildId":"2.0","dateCode":"20171027-100"},
{"ieeeAddr":"0x00158d00033e6826","type":"Router","model":"SP 120","friendly_name":"innrPlug1","nwkAddr":18066,"manufId":4454,"manufName":"innr","powerSource":"Mains (single phase)","modelId":"SP 120","hwVersion":1,"swBuildId":"2.0","dateCode":"20171027-100"},
{"ieeeAddr":"0x000d6ffffe7ff880","type":"EndDevice","model":"E1524/E1810","friendly_name":"remoteSwitch1","nwkAddr":11909,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Battery","modelId":"TRADFRI remote control","hwVersion":1,"swBuildId":"1.2.214","dateCode":"20170302"},
{"ieeeAddr":"0xccccccfffedb242f","type":"EndDevice","model":"E1743","friendly_name":"onoffSwitch2","nwkAddr":33661,"manufId":4476,"manufName":"IKEA of Sweden","powerSource":"Battery","modelId":"TRADFRI on/off switch","hwVersion":1,"swBuildId":"2.2.008","dateCode":"20190410"}]}
MQTT-Antwort für zigbee2mqtt/bridge/networkmap graphviz
digraph G {
node[shape=record];
  "0x00124b0018321aed" [style="bold, filled", fillcolor="#e04e5d", fontcolor="#ffffff", label="{0x00124b0018321aed|0x0 |No model information available|online (2019-11-06T11:52:41+00:00)}"];
  "0x00124b0018321aed" -> "0x7cb03eaa00845fad" [penwidth=0.5, weight=0, color="#994444", label="24"]
  "0x00124b0018321aed" -> "0x00158d000319b828" [penwidth=0.5, weight=0, color="#994444", label="59"]
  "0x00124b0018321aed" -> "0x00158d00033e6826" [penwidth=0.5, weight=0, color="#994444", label="42"]
  "0x7cb03eaa00845fad" [style="rounded, filled", fillcolor="#4ea3e0", fontcolor="#ffffff", label="{smartPlug1|0x11db |OSRAM Smart+ plug (AB3257001NJ)|offline (00:16:20s ago)}"];
  "0x7cb03eaa00845fad" -> "0x00124b0018321aed" [penwidth=0.5, weight=0, color="#994444", label="1"]
  "0xccccccfffea32ef2" [style="rounded, dashed, filled", fillcolor="#fff8ce", fontcolor="#000000", label="{onoffSwitch1|0xac1f |IKEA TRADFRI ON/OFF switch (E1743)|offline (00:50:42s ago)}"];
  "0xccccccfffea32ef2" -> "0x7cb03eaa00845fad" [penwidth=1, weight=0, color="#994444", label="88"]
  "0x0017880104ef74e4" [style="rounded, dashed, filled", fillcolor="#fff8ce", fontcolor="#000000", label="{dimmerSwitch5|0xf5f3 |Philips Hue dimmer switch (324131092621)|online (00:00:33s ago)}"];
  "0x0017880104ef74e4" -> "0x7cb03eaa00845fad" [penwidth=1, weight=0, color="#994444", label="82"]
  "0x00158d000319b828" [style="rounded, filled", fillcolor="#4ea3e0", fontcolor="#ffffff", label="{innrPlug2|0x89e4 |Innr Smart plug (SP 120)|offline (00:00:40s ago)}"];
  "0x00158d000319b828" -> "0x00124b0018321aed" [penwidth=0.5, weight=0, color="#994444", label="60"]
  "0x00158d000319b828" -> "0x7cb03eaa00845fad" [penwidth=0.5, weight=0, color="#994444", label="48"]
  "0x00158d000319b828" -> "0x00158d00033e6826" [penwidth=0.5, weight=0, color="#994444", label="192"]
  "0x00158d00033e6826" [style="rounded, filled", fillcolor="#4ea3e0", fontcolor="#ffffff", label="{innrPlug1|0x4692 |Innr Smart plug (SP 120)|offline (00:00:00s ago)}"];
  "0x00158d00033e6826" -> "0x00158d000319b828" [penwidth=0.5, weight=0, color="#994444", label="189"]
  "0x00158d00033e6826" -> "0x7cb03eaa00845fad" [penwidth=0.5, weight=0, color="#994444", label="46"]
  "0x00158d00033e6826" -> "0x00124b0018321aed" [penwidth=0.5, weight=0, color="#994444", label="43"]
  "0x000d6ffffe7ff880" [style="rounded, dashed, filled", fillcolor="#fff8ce", fontcolor="#000000", label="{remoteSwitch1|0x2e85 |IKEA TRADFRI remote control (E1524/E1810)|offline (03:48:18s ago)}"];
  "0x000d6ffffe7ff880" -> "0x7cb03eaa00845fad" [penwidth=1, weight=0, color="#994444", label="84"]
  "0xccccccfffedb242f" [style="rounded, dashed, filled", fillcolor="#fff8ce", fontcolor="#000000", label="{onoffSwitch2|0x837d |IKEA TRADFRI ON/OFF switch (E1743)|offline (15:44:11s ago)}"];
  "0xccccccfffedb242f" -> "0x7cb03eaa00845fad" [penwidth=1, weight=0, color="#994444", label="48"]
Danke, habs eingecheckt.
Warum ein regexp ohne Klammer $1/$2 zuruecksetzt (aber nur, wenn es matcht), bleibt mir allerdings ein Raetsel.
OdfFhem
@rudolfkoenig
Habe nach dem heutigen Update den neuen Stand getestet - funktioniert einwandfrei.
Vielen Dank für die prompte Reaktion.
Zur Info:
Habe grade eben die contact- und water-leak templates angepaßt, dass die das jeweilige Hauptreading direkt in "state" schreiben (via $JSONMAP, siehe dazu rund um diesen Beitrag: https://forum.fhem.de/index.php/topic,99980.msg991166.html#msg991166).
Finde das an diesen Stellen sehr passend und neige dazu, das (mindestens) auch für den einfachen Taster (zigbee2mqtt_Light_Switch) entsprechend anzupassen.
Eine kurze Rückmeldung wäre daher hilfreich, wie die allgemeine Meinung dazu ist (kann im Ergebnis heißen, dass alles bleibt, wie es ist, es auch da und ggf. weiteren vorgeschlagenen geändert wird oder beide Fassungen angeboten werden...).
OdfFhem
@rudolfkoenig
--- 1 ---
Bei der Ausführung von z.B. set MQTT2_zigbee3_bridge device_options <param1> <param2> <param3> taucht folgender Logeintrag auf:
2019.11.11 08:20:29 3: Bad line >< for MQTT2_zigbee3_bridge
Nach der weiteren Analyse könnte dieser Logeintrag (vermutlich) bei jedem Versuch auftreten, bei dem ein neues Reading angelegt werden soll ...
zusätzliche Codezeilen in MQTT2_DEVICE_addReading liefern folgende Logeinträge (gekürzte Fassung; readingList ist umfangreicher):
2019.11.11 09:03:14 3: name: MQTT2_zigbee3_bridge
2019.11.11 09:03:14 3: param: zigbee3mqtt/bridge/state:.* state
  zigbee3mqtt/bridge/config/devices:.* {}
zigbee3mqtt/bridge/config/device_options:.* { json2nameValue($EVENT) }
2019.11.11 09:03:14 3: line: zigbee3mqtt/bridge/state:.* state
2019.11.11 09:03:14 3: re: zigbee3mqtt/bridge/state:.*
2019.11.11 09:03:14 3: code: state
2019.11.11 09:03:14 3: line:   zigbee3mqtt/bridge/config/devices:.* {}
2019.11.11 09:03:14 3: re: zigbee3mqtt/bridge/config/devices:.*
2019.11.11 09:03:14 3: code: {}
2019.11.11 09:03:14 1: PERL WARNING: Use of uninitialized value $re in concatenation (.) or string at ./FHEM/10_MQTT2_DEVICE.pm line 535.
2019.11.11 09:03:14 1: PERL WARNING: Use of uninitialized value $code in concatenation (.) or string at ./FHEM/10_MQTT2_DEVICE.pm line 536.
2019.11.11 09:03:14 3: Bad line >< for MQTT2_zigbee3_bridge
Die zwei PERL WARNINGs werden durch meine zusätzlichen Codezeilen verursacht und können eigentlich ignoriert werden. Sie zeigen nur, dass das Attribut readingList wohl eine Leerzeile enthält, die dann zu undefinierten Variablen führt; die Routine wird in diesem Fall fehlerhaft beendet und es werden keine neuen Readings angelegt.
Da die Leerzeile in readingList nicht bewusst erfasst wurde und man es wohl auch nicht verhindern könnte, ist nun die Frage
  • kann man die Leerzeile in readingList beim Speichern automatisch entsorgen (bei Neuerfassung vermutlich die beste Variante)
  • kann man die Leerzeile in readingList beim Analysieren kontrolliert überlesen (bei Altlasten vermutlich notwendig)
  • oder gibt es noch andere Möglichkeiten ...
--- 2 ---
Ein leicht nerviges Verhalten wird beim reload von 10_MQTT2_DEVICE.pm "wachgeküsst". Scheinbar wird ab diesem Zeitpunkt mit jeder eintreffenden MQTT-Nachricht ein Logeintrag nach folgendem Muster erzeugt. In diesem Fall hilft zunächst einmal nur ein FHEM-Neustart. Kann man die Ursache abstellen?
2019.11.11 08:38:30 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:31 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:35 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:40 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:41 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:43 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:44 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:46 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:52 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:54 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:55 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:58 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:38:59 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:00 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:06 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:07 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:08 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:09 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:11 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:12 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:14 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:20 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:21 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:22 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:24 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:25 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:27 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:28 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:35 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:36 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:37 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:40 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:41 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:45 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:50 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:51 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:54 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:39:55 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:02 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:03 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:05 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:08 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:09 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:10 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:16 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:19 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:20 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:27 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:40 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:41 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:46 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:47 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:50 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:40:51 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:01 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:02 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:05 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:06 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:08 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:11 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:13 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:23 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:24 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:28 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:29 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:30 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:34 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:37 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:38 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:40 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:41 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:42 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:43 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:51 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:56 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:57 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:41:59 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:01 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:02 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:08 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:11 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:12 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:13 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:15 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:16 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:19 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:22 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:23 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:27 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:28 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:33 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:36 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:37 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:39 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:40 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:41 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:42 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:43 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:44 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:51 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:55 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:58 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:42:59 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:43:04 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:43:05 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:43:06 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:43:07 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:43:08 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:43:09 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
2019.11.11 08:43:11 2: autocreate: define FileLog_MQTT2_myMqttClient FileLog ./log/MQTT2_myMqttClient-%Y.log MQTT2_myMqttClient
--- 3 ---
Aktuell benutze ich mehrere ZigBee-Netze. Da für jedes der ZigBee-Netze eine eigene bridge existiert und auch als eigenes FHEM-Device erhalten bleiben muss, musste ich die einzelnen Netze unter Verwendung von unterschiedlichen base_topic eindeutig machen; für die eigentlichen ZigBee-Geräte wäre dies (aus meiner Sicht) nicht unbedingt notwendig gewesen. In FHEM werden die Topics der Netze durch die Verwendung eines vorgelagerten bridgeRegexp korrekt erkannt und abgelegt.  Bei der graphischen Darstellung funktioniert die aktuell verwendete Theorie für Name translation aber leider nicht mehr, so dass die zugehörigen Geräte nicht mehr gefunden/aufgelöst werden.
Meine genutzen ZigBee-Netze habe ich durchnummeriert und heißen: zigbee1mqtt, zigbee2mqtt, zigbee3mqtt; die jeweiligen FHEM-Devices heißen gemäß bridgeRegexp dann zigbee1_<name>, zigbee2_<name>, zigbee3_<name>.
Eine "minimale" Änderung im Code würde für die Normalfälle nichts ändern, aber auch den/meinen Mehrnetzfall abdecken. Ist die folgende Änderung integrierbar?
  # Name translation
  for my $n (devspec2array("TYPE=MQTT2_DEVICE")) {
    my $cid = $defs{$n}{CID};
    if($cid) {
-      $cid =~ s/zigbee_//;
+      $cid =~ s/zigbee[0-9]?_//;
      $n2n{$cid} = $n;
-    if(AttrVal($n, "readingList","") =~ m,zigbee2mqtt/(.*):,) {
+    if(AttrVal($n, "readingList","") =~ m,zigbee[0-9]?mqtt/(.*):,) {
      $n2n{$1} = $n;
ad 1)
ZitatDa die Leerzeile in readingList nicht bewusst erfasst wurde und man es wohl auch nicht verhindern könnte, ist nun die Frage
Dass es nicht bewusst war, mag sein, aber mein Stand ist, dass es manuell gemacht wurde, und kann auch auf diesem Weg einfach entfernt werden.
Wenn die leere Zeile deiner Ansicht nach generiert wird, dann will ich es erst nachstellen koennen (vulgo: haette gerne Anleitung dafuer).
ad 2)
ZitatKann man die Ursache abstellen?
Weiss nicht, leider kann ich es auch nicht reproduzieren, habe dazu folgende Konfiguration verwendet:attr global logfile -
attr global modpath .
attr global statefile log/fhem.save.m2s
define ac autocreate
define w FHEMWEB 8083 global
define m2s MQTT2_SERVER 1883 global
=> Bitte beschreiben, wie ich es reproduzieren soll.
ad 3)
ich habe [0-9]? durch \d* ausgetauscht und eingecheckt, ich hoffe das ist auch ok.
OdfFhem
@rudolfkoenig
zu 1)
Ich glaube nicht unbedingt, dass die Leerzeile automatisch generiert wurde. "Nicht bewusst" sollte eigentlich nur betonen, dass man einer evtl. vorhandenen/eingetippten Leerzeile keine negativen Seiteneffekte unterstellt. Von den Auswirkungen bekommt man ja auch erst einmal nichts mit; erst ein eher zufälliger Blick ins Logfile macht einen stutzig.
Komme aber auf jeden Fall auch mit dem aktuellen Ist-Zustand sehr gut zurecht; die Leerzeile im readingList-Attribut ist ja auch schnell entfernt - wenn man erst mal das Problem erkannt hat.
zu 2)
Bei jedem Reload von 10_MQTT2_DEVICE.pm tritt das besagte Phänomen auf - aktuell bei mir sicher reproduzierbar.
Ich verwende keinen MQTT2_SERVER, sondern den MQTT2_CLIENT; der lästige Logeintrag ist aber nicht direkt für den MQTT2_CLIENT, sondern für das bei der Definition von MQTT2_CLIENT (myMqttClient) automatisch angelegte Verwaltungs-MQTT2_DEVICE (MQTT2_myMqttClient).
Wie man die Ursache noch weiter eingrenzen kann, kann ich leider nicht sagen ...
zu 3)
Habe bei mir vorab jetzt auch [0-9]? durch \d* ausgetauscht und erwartungsgemäß scheint es einwandfrei zu laufen.
Auf jeden Fall schon mal schönen Dank fürs Einchecken.
ulli
welches ist denn das richtige Template für die Ikea E1524 Fernbedinung?
Fernbedienungen sind allg. noch ein Thema. Es gibt dazu schon erste Ansätze, siehe hier: https://forum.fhem.de/index.php/topic,103593.0.html.
Wäre nett, wenn das jemand finalisieren könnte, ein Hexenwerk dürfte das nicht sein...
kabanett
ich hoffe, ich bin hier richtig?!
Ich habe gestern zigbee2mqtt aktualisiert und danach wurde mir eine zweite, neue Bridge angelegt. Nach zweimaligen löschen und automatischen anlegen, habe ich das neue Reading in meiner Bridge/readingList übernommen. Seit dem ist Ruhe ;)
$DEVICETOPIC/bridge/logging:.* { json2nameValue($EVENT) }
Hardware: Fhem auf Raspi3 / selbtsbau CUL 433 und 868 MHz / MAX Thermostate / IT-Dosen nur noch Weihnachten / diverse ESP Aktoren/Sensoren / X10 Fernbedienung / Shelly 1, 1L, 2, 2.5, Dimmer, RGB2 / LaCrosseGateway / Zigbee2531 / diverse Zigbee Aktoren/Sensoren
87insane
Hallo zusammen.. Ich habe mich nun hier durch gewühlt und so richtig keine Antwort gefunden.
die Bridge erzeugt innerhalb der Geräte ja auch die Links zu den entsprechenden Bildern. -> Klappt!
Aber innerhalb des graphviz sollten doch für normal auch Bilder zu sehen sein oder?
Ich sehe nur den blanken graphiz und die Namen der Geräte. Diese lassen sich auch Layouten usw.
Ideen? :)
87Insane
HansDampfHH
Moin, ich hoffe ich bin mit meinem Problem hier richtig.
Der User chdrsto hatte in folgendem Thread https://forum.fhem.de/index.php?topic=120794.0 nach einem Update Probleme, da er das Xiaomi_MQTT_Device nutzt.
Das gleiche Modul nutze ich auch und hatte auch die entsprechenden Probleme. In dem Thread ist allerdings ein Fix, von daher läuft wieder alles.
Ich würde aber gerne den Hinweis von Beta-User umsetzen:
ZitatEs gibt auch die 'neue' Implementierung, wie unter https://wiki.fhem.de/wiki/Zigbee2mqtt beschrieben.
Leider komme ich da aber nicht vorwärts.
Ich habe zuerst zigbee2mqtt aktualisiert (nun mit Frontend, wow), musste allerdings noch einmal meine Devices pairen.
Der Versionssprung war wohl zu groß. Im zigbee2mqtt-Frontend sind alle Devices nun wieder vorhanden und können geschaltet werden.
Danach habe ich versucht mich an die Anleitung zu halten.
Hier mal Listings vom MQTT2_DEVICE und MQTT2_SERVER:
   CID        zigbee
   DEF        zigbee
   DEVICETOPIC zigbee2mqtt
   FUUID      609e170b-f33f-1920-ed25-549232c7f2cd9bc3
   IODev      MQTT2_Server
   NAME       MQTT2_zigbee
   NR         683
   STATE      ???
   TYPE       MQTT2_DEVICE
     2021-05-14 08:55:25   IODev           MQTT2_Server
     2021-05-14 08:23:03   attrTemplateVersion 20201215
     2021-05-14 09:23:36   permit_join     set true
   DbLogExclude .*
   IODev      MQTT2_Server
   alias      MQTT2 (Zigbee)
   bridgeRegexp zigbee2mqtt/([A-Za-z0-9._]+)[/]?.*:.* "zigbee_$1"
   comment    To check for new updates of the deamon software, you might want to use a separate HTTPMOD device. See HTTPMOD template zigbee2mqtt_daemon_updates for further details.
   devicetopic zigbee2mqtt
   getList    devicelist:noArg log $DEVICETOPIC/bridge/config/devices/get
  networkmap_raw:noArg raw $DEVICETOPIC/bridge/networkmap raw
  networkmap_graphviz:noArg graphviz $DEVICETOPIC/bridge/networkmap graphviz
   icon       mqtt
   model      zigbee2mqtt_bridge
   readingList $DEVICETOPIC/bridge/state:.* state
  $DEVICETOPIC/bridge/config/devices:.* {}
  $DEVICETOPIC/bridge/config/log_level:.* log_level
  $DEVICETOPIC/bridge/config/permit_join:.* permit_join
  $DEVICETOPIC/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }
  $DEVICETOPIC/bridge/log:.*\"type\".\"devices\".\"message\".* devices
  $DEVICETOPIC/bridge/log:.* log
  $DEVICETOPIC/bridge/networkmap:.* {}
  $DEVICETOPIC/bridge/networkmap/graphviz:.* graphviz
  $DEVICETOPIC/bridge/networkmap/raw:.* raw
  $DEVICETOPIC/bridge/config:.* { json2nameValue($EVENT) }
   room       Steuerung
   setList    log_level:debug,info,warn,error $DEVICETOPIC/bridge/config/log_level $EVTPART1
  permit_join:true,false $DEVICETOPIC/bridge/config/permit_join $EVTPART1
  remove:textField $DEVICETOPIC/bridge/config/remove $EVTPART1
  ota_update:textField $DEVICETOPIC/bridge/ota_update/update $EVTPART1
  ota_update_check:textField $DEVICETOPIC/bridge/ota_update/check $EVTPART1
  y_device_setting:textField $DEVICETOPIC/$EVTPART1/set {"$EVTPART2": "$EVTPART3"}
  x_bind:textField $DEVICETOPIC/bridge/bind/$EVTPART1 $EVTPART2
  x_bind_unbind:textField $DEVICETOPIC/bridge/unbind/$EVTPART1 $EVTPART2
  x_device_options:textField $DEVICETOPIC/bridge/config/device_options {"friendly_name":"$EVTPART1","options": {"$EVTPART2": "$EVTPART3"}}
  x_group_add_to:textField $DEVICETOPIC/bridge/group/$EVTPART1/add $EVTPART2
  x_group_rm_from:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove $EVTPART2
  x_group_rm_from_all:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove_all $EVTPART2
  x_group_add_group:textField $DEVICETOPIC/bridge/config/add_group $EVTPART1
  x_group_rm_group:textField $DEVICETOPIC/bridge/config/remove_group $EVTPART1
  z_elapsed:textField $DEVICETOPIC/bridge/config/elapsed $EVTPART1
  z_last_seen:disable,ISO_8601,epoch,ISO_8601_local $DEVICETOPIC/bridge/config/last_seen $EVTPART1
  z_ban:textField $DEVICETOPIC/bridge/config/ban $EVTPART1
  z_rename:textField $DEVICETOPIC/bridge/config/rename  {"old":"$EVTPART1","new":"$EVTPART2"}
  z_reset_CC:noArg $DEVICETOPIC/bridge/config/reset
   setStateList on off
   Clients    :MQTT2_DEVICE:MQTT_GENERIC_BRIDGE:
   ClientsKeepOrder 1
   DEF        1884 global
   FD         21
   FUUID      5f4de9f1-f33f-1920-c025-9e3ba70faf8d8a2f
   NAME       MQTT2_Server
   NR         658
   PORT       1884
   STATE      Initialized
   TYPE       MQTT2_SERVER
   MatchList:
     1:MQTT2_DEVICE ^.
     2:MQTT_GENERIC_BRIDGE ^.
     2021-05-13 18:53:40   RETAIN          {"co2/status":"offline","tele/tasmota/LWT":"Online","tele/tasmota1/LWT":"Offline","tele/tasmota2/LWT":"Offline","zigbee2mqtt/bridge/state":"offline"}
     2020-09-03 11:29:43   lastPublish     cmnd/tasmota2/Backlog:StateText1 off; StateText2 on; StateText3 toggle; StateText4 hold; SetOption26 1; SaveData 1
     2021-05-14 08:55:25   nrclients       0
     2021-05-14 08:55:25   state           Initialized
   clients:
   retain:
     co2/status:
       ts         1620975325.88595
       val        offline
     tele/tasmota/LWT:
       ts         1620975325.88595
       val        Online
     tele/tasmota1/LWT:
       ts         1620975325.88595
       val        Offline
     tele/tasmota2/LWT:
       ts         1620975325.88595
       val        Offline
     zigbee2mqtt/bridge/state:
       ts         1620975325.88595
       val        offline
Wenn ich die Anleitung richtig verstehe, setze ich set MQTT2_zigbee permit_join true und kann ein Gerät über das Frontend von zigbee2mqtt schalten, um das Device in FHEM damit automatisch anzulegen. Aber hier passiert scheinbar nichts bzw. was soll passieren!?
Auch ein get MQTT2_zigbee devicelist führt zu "Timeout reading answer for zigbee2mqtt/bridge/config/devices/get".
Was mach ich falsch?
FHEM Docker, CUL868, Zigbee, CCU2, Jeelink
LWT sagt, der zigbee2mqtt-Dienst sei Offline.
Bitte zuerst schauen, dass das Online wird.
HansDampfHH
Könnte mir dabei jemand unter die Arme greifen?
Ich habe nun erst mal alle alten XiaomiMQTTDevice und MQTT_DEVICEs entfernt.
Dann den PORT beim verbleibenden MQTT2_SERVER wieder auf 1883 geändert (gleicher Port eben wie zigbee2mqtt).
Fhem fährt jetzt zumindest mal wieder hoch.
Aber nun bekomme ich im Log leider folgende Meldung und habe noch keine Idee woher das kommt bzw. wie ich es abschalte?
2021.05.14 14:59:02 4: Connection accepted from MQTT2_Server_127.0.0.1_35502
2021.05.14 14:59:02 5: in:  CONNECT: (16)5(0)(4)MQTT(4)&(0)<(0)(6)zigbee(0)(24)zigbee2mqtt/bridge/state(0)(7)offline
2021.05.14 14:59:02 3: Login denied via MQTT2_Server_127.0.0.1_35502
2021.05.14 14:59:02 5: out: CONNACK:  (2)(0)(4)
2021.05.14 14:59:02 5: MQTT2_Server: dispatch autocreate=simple\000zigbee\000zigbee2mqtt/bridge/state\000offline
Hast du ein allowed-Device für den M2-Server definiert? (Würde es erst mal ohne versuchen).
