Signalduino gelegentlich closed
Begonnen von maddinthebrain, 01 Oktober 2018, 12:36:36
maddinthebrain
ich verwende den Signalduino. Neuerdings geht dieser in Fhem öftermal in den Zustand closed. Das ist seit dem Update der Firmware auf 3.3.1-RC7 so. Vorher gab es das nicht.
list sduino1:
   Clients    :IT:CUL_TCM97001:SD_RSL:OREGON:CUL_TX:SD_AS:Hideki:SD_WS07:SD_WS09: :SD_WS:RFXX10REC:Dooya:SOMFY:SD_UT:SD_WS_Maverick:FLAMINGO:CUL_WS:Revolt: :FS10:CUL_FHTTK:Siro:FHT:FS20:SIGNALduino_un:
   DEF        /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0-port0@57600
   DMSG       500A4D100F701400002D00
   DevState   initialized
   DeviceName /dev/serial/by-path/platform-3f980000.usb-usb-0:1.2:1.0-port0@57600
   FD         17
   LASTDMSG   500A4D100F701400002D00
   MSGCNT     451
   NAME       sduino1
   NR         50
   PARTIAL
   RAWMSG     MC;LL=-2926;LH=2940;SL=-1450;SH=1483;D=031D7F1E;C=1466;L=31;R=242;
   RSSI       -81
   STATE      opened
   TIME       1538389978
   TYPE       SIGNALduino
   sendworking 0
   unknownmessages
   version    V 3.3.1-RC7 SIGNALduino cc1101  - compiled at May 11 2018 23:00:28
   DoubleMsgIDs:
   MatchList:
     10:SD_WS07 ^P7#[A-Fa-f0-9]{6}F[A-Fa-f0-9]{2}(#R[A-F0-9][A-F0-9]){0,1}$
     11:SD_WS09 ^P9#F[A-Fa-f0-9]+
     12:SD_WS   ^W\d+x{0,1}#.*
     13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
     14:Dooya   ^P16#[A-Fa-f0-9]+
     15:SOMFY   ^Ys[0-9A-F]+
     16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
     17:SD_UT   ^u30#.*
     18:FLAMINGO ^P13#[A-Fa-f0-9]+
     19:CUL_WS  ^K[A-Fa-f0-9]{5,}
     1:IT       ^i......
     20:Revolt  ^r[A-Fa-f0-9]{22}
     21:FS10    ^P61#[A-F0-9]+
     22:Siro    ^P72#[A-Fa-f0-9]+
     23:FHT     ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     24:FS20    ^81..(04|0c)..0101a001
     2:CUL_TCM97001 ^s[A-Fa-f0-9]+
     3:SD_RSL   ^P1#[A-Fa-f0-9]{8}
     4:OREGON   ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
     5:CUL_TX   ^TX..........
     6:SD_AS    ^P2#[A-Fa-f0-9]{7,8}
     7:Hideki   ^P12#75[A-F0-9]+
     9:CUL_FHTTK ^T[A-F0-9]{8}
     X:SIGNALduino_un ^[u]\d+#.*
   QUEUE:
     2017-10-08 19:41:34   ITParms         Unsupported command
     2018-08-22 02:52:42   ccconf          freq:433.920MHz bWidth:325KHz rAmpl:42dB sens:4dB  (DataRate:5603.79Baud)
     2017-10-08 19:39:35   config          MS=1;MU=1;MC=1
     2018-09-24 19:06:03   ping            OK
     2018-10-01 12:00:33   state           opened
     2018-10-01 12:00:33   version         V 3.3.1-RC7 SIGNALduino cc1101  - compiled at May 11 2018 23:00:28
   keepalive:
     ok         1
     retry      0
   mcIdList:
     10
     11
     12
     18
     43
     47
     52
     57
     58
   msIdList:
     0
     1
     13
     14
     15
     17
     2
     22
     23
     25
     3
     3.1
     32
     33
     35
     38
     4
     41
     51
     55
     6
     68
     7
     72.1
   muIdList:
     13.1
     16
     20
     21
     24
     26
     27
     28
     29
     30
     31
     36
     37
     39
     40
     44
     44.1
     45
     46
     48
     49
     5
     50
     56
     59
     60
     61
     62
     64
     65
     66
     67
     69
     70
     71
     72
     75
     8
     9
   DbLogExclude .*
   event-on-change-reading state
   event-on-update-reading state
   flashCommand avrdude -c arduino -b [BAUDRATE] -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
   hardware   nanoCC1101
   icon       cul_cul
   room       Funk & Kommunikation
   verbose    0
Wieder verbinden geht nur, mit Reboot des Raspi. Fhem mit shutdown restart neustarten reicht nicht! Dass das nervig ist, muss ich nicht formulieren. Wie kann ich die Situation verbessern?
Martin
Martin
Futro mit Proxmox und Debian: FHEM, Signalduino 433MHz & 868MHz, MAX!, WeeWX, FHEM2FHEM,
Raspi 4 mit ConBee mit deCONZ und Phoscon für ZigBee Aktoren und Sensoren
Sidey
Leider weiss ich aktuell noch keine richtige Lösung.
Ist es so, dass die LED auf dem Arduino blinkt wenn er nicht mehr reagiert?
Welche Version hattest Du vorher im Einsatz?
Grüße Sidey
Gesendet von meinem XT1650 mit Tapatalk
Nutze: SIGNALDuino, Homematic, Raspberry Pi, MQTT, Alexa, Docker, AlexaFhem,zigbee2mqtt, tasmota
Maintainer von: SIGNALduino, SD_WS*, fhem-docker, alexa-fhem-docker, fhempy-docker, WebAuth, fhem-mcp, midea-mqtt, whatsmeow-mqtt, alexa-cookie-service
https://github.com/sidey79?tab=repositories
maddinthebrain
Das mit dem Blinken weiß ich gar nicht, weil ich den Raspi, dann wenn ich das feststelle, direkt über SSH reboote. Zumal der Raspi nicht gleich einsehbar ist. Aber ich werde mal beim nächsten mal nachsehen. Welche LED? Die extra LED oder eine auf dem Arduino selber?
Ich habe festgestellt, dass der Fehler häufig dann auftritt, wenn er selber was sendet. In meinem Fall sendet er täglich zum Sonnenuntergang (sunset()) einmal den Schließen-Befehl an den SOMFY RTS Antrieb der Markise. Beholfen hatte ich mich damit, dass ich ein paar Minuten nach dem Sonnenuntergang per at (*{sunset("REAL",60)} set sduino1 reset) den Arduino resette. Das hat es besser gemacht, aber nicht vollständig behoben... Ist aber natürlich auch nicht die Lösung.
Die Firmware war V 3.3.1-dev SIGNALduino cc1101 - compiled at Mar 10 2017 22:54:50
GRüße Martin
Martin
Sidey
ich habe einen Fehler finden können. Probiere doch bitte mal die neue Version aus ob sich der SIGNALduino nach dem Senden noch aufhängt.
set sduino1 flash https://github.com/RFD-FHEM/SIGNALDuino/releases/download/3.3.1-RC8/SIGNALDuino_nanocc11013.3.1-RC8.hex
Grüße Sidey
maddinthebrain
So hab es nun mal auf den einen geflasht. Mal sehen. Ich werde berichten. Vor dem Flash ist er wieder mal abgekackt gewesen.
Schönen Abend
Martin
fervor
ich hänge mich mal hier dran.
Bei mir läuft seit ein paar Wochen ein ähnliches setup (Singnalduino mit cc1101 V.3.3.1 RC7 + Somfy + Intertechno Steckdosen) ich kann die Probleme mit gelegentlichen closed Zuständen bestätigen. Ein softwareseitiger Reset hat bei mir nicht geholfen, musste immer den Raspberry neu starten.
Habe nun den RC8 geflashed. Jetzt taucht das Problem bei mir auf, dass nach ca. 2 Tagen und diversen Rolllofahrten keine Schaltbefehle mehr gesendet werden. Dabei bleibt der Signalduino die ganze Zeit "open". Wenn ich nun einen software reset durchführe werden die Schaltbefehle wieder gesendet.
Gibt es einen Weg einen Hardwaredefekt auszuschließen? Wie gesagt, das setup läuft noch nicht so lange. Welche firmeware Version hatte denn mit Somfy keine Probleme?
schönen Abend ...
Sidey
Kannst Du den Problemfall noch etwas genauer schildern?
Was funktioniert in diesem Zustand noch und was nicht.
Geht nur das Senden von Schaltbefehlen nicht und alles andere funktioniert, dann frag doch bitte mal den freien ram zu diesem Zeitpunkt ab, also wenn es nicht mehr geht.
Ein Hadwaredefekt vermute ich aktuell nicht.
Grüße Sidey
fervor
#7
Hi, heute ist das Problem wieder aufgetaucht. Ich versuche mal die benötigen Infos zu liefern.
Schon mal besten Dank für die Mühe ;)
Es ist wohl in der Tat so, dass die Somfy Rollläden noch funktionieren, jedoch die Intertechno Steckdosen nicht mehr schaltbar sind - weder manuell noch via DOIF.
Free Ram beträgt: 690
SignalDuino bleibt immer im Status opened
hier ein Auszug aus dem Logfile:
hier wird zwar irgendwie etwas gesendet, aber die Lampe bleibt aus - Rollläden funktionieren noch
2018.10.22 20:31:40 3: sduino IT_set: Leselicht on
2018.10.22 20:31:40 4: sduino IT_set: sendMsg=P3#is0FFF00FFFF0F#R6#C300
2018.10.22 20:31:40 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304040423;
2018.10.22 20:31:40 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304040423;
2018.10.22 20:31:41 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304040423;
2018.10.22 20:31:41 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304040423;
2018.10.22 20:31:41 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:31:43 3: sduino IT_set: Leselicht off
2018.10.22 20:31:43 4: sduino IT_set: sendMsg=P3#is0FFF00FFFFF0#R6#C300
2018.10.22 20:31:43 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304230404;
2018.10.22 20:31:43 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304230404;
2018.10.22 20:31:43 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304230404;
2018.10.22 20:31:43 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304230404;
2018.10.22 20:31:43 4: sduino/HandleWriteQueue: nothing to send, stopping timer
nach einem Reset klappt es auch wieder mit den Steckdosen:
2018.10.22 20:38:08 3: sduino reset
2018.10.22 20:38:08 3: Opening sduino device /dev/serial/by-id/usb-SHK_SIGNALduino_433-if00-port0
2018.10.22 20:38:08 3: Setting sduino serial parameters to 57600,8,N,1
2018.10.22 20:38:08 1: sduino/define: /dev/serial/by-id/usb-SHK_SIGNALduino_433-if00-port0@57600
2018.10.22 20:38:08 1: sduino/init: /dev/serial/by-id/usb-SHK_SIGNALduino_433-if00-port0@57600
2018.10.22 20:38:08 3: sduino device opened
2018.10.22 20:38:09 3: sduino/init: disable receiver (XQ)
2018.10.22 20:38:10 3: sduino/init: get version, retry = 0
2018.10.22 20:38:10 4: sduino/msg READ: V 3.3.1-RC8 SIGNALduino cc1101  - compiled at Oct  4 2018 21:44:45
2018.10.22 20:38:10 2: sduino: initialized. v3.3.3-dev_15.09.
2018.10.22 20:38:10 3: sduino/init: enable receiver (XE)
2018.10.22 20:38:12 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304230404;
2018.10.22 20:38:12 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304230404;
2018.10.22 20:38:12 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304230404;
2018.10.22 20:38:12 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304230404;
2018.10.22 20:38:12 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:38:13 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304040423;
2018.10.22 20:38:13 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304040423;
2018.10.22 20:38:13 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304040423;
2018.10.22 20:38:13 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304040423;
2018.10.22 20:38:13 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:38:16 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304230404;
2018.10.22 20:38:16 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304230404;
2018.10.22 20:38:16 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304230404;
2018.10.22 20:38:16 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423040404230423042304230404;
2018.10.22 20:38:16 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:38:21 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304040423;
2018.10.22 20:38:21 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304040423;
2018.10.22 20:38:21 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304040423;
2018.10.22 20:38:21 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304040423;
2018.10.22 20:38:21 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:38:25 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304230404;
2018.10.22 20:38:25 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304230404;
2018.10.22 20:38:25 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304230404;
2018.10.22 20:38:25 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304230404;
2018.10.22 20:38:25 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:38:26 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304040423;
2018.10.22 20:38:26 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304040423;
2018.10.22 20:38:26 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304040423;
2018.10.22 20:38:26 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040423042304230404042304040423;
2018.10.22 20:38:26 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=-557;P1=140;P2=347;P3=-332;P4=691;P5=-964;P6=95;P7=184;D=0102323454545451023106060102323101060601010231010102323101023106023102323106010606060607010232;CP=1;R=218;
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 8 -> TX3 Protocol matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 16 -> Dooya shutter matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 20 -> livolo matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 24 -> visivon remote matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 27 -> remote27 matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 28 -> IC Ledspot matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 29 -> HT12e remote matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 31 -> pollin isotronic matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 37 -> Bresser 7009994 matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 59 -> AK-HD-4 matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 61 -> FS10 matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 69 -> Hoermann matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 70 -> FHT80TF matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 72 -> Siro shutter matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 74 -> FS20 matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 79 -> VTX-BELL_Funkklingel matches, trying to demodulate
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 80 -> EM (Energy-Monitor) matches, trying to demodulate
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=-351;P1=718;P2=-953;P3=111;P4=-572;P5=322;D=012121212345034343434505034343434343450343434505034;CP=3;R=221;
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=-566;P1=123;P2=160;P3=343;P4=-343;P5=708;P6=-955;P7=92;D=0101020103434565656561034101010103434201010101010347010103434701034101034103434;CP=1;R=220;
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=-555;P1=131;P2=348;P3=-338;P5=743;P6=-942;D=01023231010231010231023231010101010101010102323565656561023101010102323101010101010231010102323;CP=1;R=218;
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=-563;P1=117;P2=347;P3=-372;P5=708;P6=-944;D=0102310102310232310101010101010101023235656;CP=1;R=221;
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=-356;P1=339;P2=-928;P3=728;P4=110;P5=-563;P7=150;D=012324515454545101045454545454510754545101045751045;CP=4;R=218;
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=128;P2=-573;P3=354;P4=-364;P5=92;P6=260;D=02023402020234345202640202340234340202020202020202023434;CP=0;R=219;
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=730;P1=-945;P2=122;P3=-538;P4=342;P5=-365;P7=92;D=0101010123452323232345452323232323234573232345452323452323;CP=2;R=219;
2018.10.22 20:38:33 4: sduino/msg READ: MU;P0=119;P1=-335;P2=-582;P3=160;P4=332;P5=92;P6=-432;P7=740;D=0102324102024102414102020202020252020241467;CP=0;R=220;
2018.10.22 20:38:33 4: sduino: Fingerprint for MU Protocol id 45 -> Revolt matches, trying to demodulate
2018.10.22 20:38:55 4: sduino/msg READ: MS;P0=-1979;P1=467;P3=-3921;P6=-8724;D=1613101013101313131313101010101010101010101013101013131010101010131313101013;CP=1;SP=6;R=220;O;m2;
2018.10.22 20:38:55 4: sduino: Matched MS Protocol id 0 -> weather1
2018.10.22 20:38:55 4: sduino: Decoded MS Protocol id 0 dmsg s97C004C1C800 length 40 RSSI = -92
2018.10.22 20:38:55 4: sduino: CUL_TCM97001 using longid: 1 model: Prologue
2018.10.22 20:38:55 4: sduino: Matched MS Protocol id 68 -> PFR-130
2018.10.22 20:38:55 4: sduino: Decoded MS Protocol id 68 dmsg s97C004C1C800 length 40 RSSI = -92
2018.10.22 20:38:55 4: sduino Dispatch: s97C004C1C800, Dropped due to short time or equal msg
2018.10.22 20:38:55 4: sduino/msg READ: MS;P0=-1970;P1=482;P3=-3910;P6=-8718;D=1613101013101313131313101010101010101010101013101013131010101010131313101013;CP=1;SP=6;R=220;O;m1;
2018.10.22 20:38:55 4: sduino/msg READ: MS;P0=-1977;P1=478;P3=-3916;P6=-8717;D=1613101013101313131313101010101010101010101013101013131010101010131313101013;CP=1;SP=6;R=220;O;m0;
2018.10.22 20:38:55 4: sduino/msg READ: MS;P0=-1982;P1=480;P3=-3908;P6=-8717;D=1613101013101313131313101010101010101010101013101013131010101010131313101013;CP=1;SP=6;R=220;
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=-526;P1=162;P3=122;P4=389;P5=-331;P6=763;P7=-912;D=01010301045101045101010451045304510101045451010454510101045456767676730451045101045101010101010104510104510101045304510453010104545101045451010104545676767671045104510104;CP=1;R=221;
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 8 -> TX3 Protocol matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 20 -> livolo matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 24 -> visivon remote matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 27 -> remote27 matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 28 -> IC Ledspot matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 29 -> HT12e remote matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 31 -> pollin isotronic matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 37 -> Bresser 7009994 matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 49 -> quigg_gt9000 matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 59 -> AK-HD-4 matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 61 -> FS10 matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 62 -> Clarus_Switch matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 69 -> Hoermann matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 70 -> FHT80TF matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 72 -> Siro shutter matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 74 -> FS20 matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 79 -> VTX-BELL_Funkklingel matches, trying to demodulate
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 80 -> EM (Energy-Monitor) matches, trying to demodulate
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=-310;P1=166;P2=-529;P3=127;P4=379;D=012121232121212401212403212124012401240123212404012;CP=1;R=219;
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=-553;P1=148;P3=364;P4=-317;D=010101034101034101010341034103410101034341010343410;CP=1;R=221;
2018.10.22 20:39:00 4: sduino: Fingerprint for MU Protocol id 16 -> Dooya shutter matches, trying to demodulate
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=-522;P1=376;P2=-322;P3=750;P4=-928;P5=161;D=0121234343434501250125050125050505050505012505012505050125012501250505012125050121250505012123434343450125012505012;CP=5;R=219;
2018.10.22 20:39:00 4: sduino: decoded matched MU Protocol id 37 dmsg W37#5202454663 length 40 RSSI = -92.5
2018.10.22 20:39:00 4: sduino: SD_WS_Parse Protocol: 37, rawData: 5202454663
2018.10.22 20:39:00 4: sduino: SD_WS37 ERROR - checksum 223 != 99
2018.10.22 20:39:00 4: sduino: decoded matched MU Protocol id 61 dmsg P61#ADFDBAB99C length 40 RSSI = -92.5
2018.10.22 20:39:00 4: sduino FS10_Parse: Protocol: 61, rawData: ADFDBAB99C
2018.10.22 20:39:00 4: sduino FS10_Parse: rawBitData: 1010110111111101101110101011100110011100 (40)
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=158;P1=-524;P4=378;P5=-321;P6=-922;P7=748;D=0101010101010145010145010101450145014501010145450106767601450145010145010101010101014501014501010145014501450101014545010145;CP=0;R=220;
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=170;P1=-548;P3=373;P4=-320;P5=122;P7=700;D=010134010101010101513401340134013401010134340101343401510134347;CP=0;R=220;
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=-944;P1=731;P2=155;P3=-543;P4=367;P5=-332;P6=118;P7=208;D=010101023452345232345232323232323634523234523236345634523452323734545232345452323234545101010102345234;CP=2;R=220;
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=-358;P1=174;P2=-541;P3=357;P5=752;P6=-919;D=012123012121212121212301212301212123012301230121212565656561230123012123012121212121212301212301212123012301230121212303012123030121212303056565656123;CP=1;R=220;
2018.10.22 20:39:00 4: sduino/msg READ: MU;P0=-320;P1=167;P2=-513;P3=375;P5=112;D=012301212301212521212121230121230121212301230123012;CP=1;R=215;
2018.10.22 20:39:02 4: sduino/msg READ: MU;P0=-16028;P1=372;P2=-23426;P3=3255;P4=-6427;P5=1191;D=01234543434343434543454343454545434543454543434543454343454545454345434545434345454345432;CP=5;R=229;
2018.10.22 20:39:02 4: sduino: Fingerprint for MU Protocol id 66 -> WS7035 matches, trying to demodulate
2018.10.22 20:39:03 4: sduino/msg READ: MU;P0=-448;P1=1184;P2=-2852;P3=-6441;P4=3242;D=012134313434343434313431343431313134313431313434313431343431313131343134313134343131343134;CP=1;R=229;
2018.10.22 20:39:03 4: sduino: Fingerprint for MU Protocol id 66 -> WS7035 matches, trying to demodulate
2018.10.22 20:39:03 4: sduino/msg READ: MU;P0=-4316;P1=5004;P2=-2840;P3=1180;P4=-6443;P5=3240;D=012345434545454545434543454543434345434543434545434543454543434343454345434345454343454345;CP=3;R=228;
2018.10.22 20:39:10 4: sduino/keepalive ok, retry = 0
2018.10.22 20:39:18 4: sduino/msg READ: MS;P0=-3928;P2=498;P3=-966;P4=-1935;D=20232323242423242424232423232323232323242423242423242424242324232324242324;CP=2;SP=0;R=228;O;m2;
2018.10.22 20:39:18 4: sduino: Matched MS Protocol id 1 -> ConradRSL
2018.10.22 20:39:18 4: sduino: Matched MS Protocol id 7 -> weatherID7
2018.10.22 20:39:18 4: sduino: Decoded MS Protocol id 7 dmsg P7#1BA036F4D length 36 RSSI = -88
2018.10.22 20:39:18 4: sduino: SD_WS07_Parse SD_WS07 (P7#1BA036F4D) length: 9
2018.10.22 20:39:18 4: sduino: SD_WS07_Parse SD_WS07 converted to bits 00011011 1010 000000110110 1111 01001101
2018.10.22 20:39:18 4: sduino: SD_WS07_TH_3 id=1B, channel=3, temp=5.4, hum=77, bat=ok
2018.10.22 20:39:18 4: sduino/set: sending via SendMsg: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A1EACC8D88AAAA;F=10AB85550A;
2018.10.22 20:39:18 4: sduino/set: sending via SendMsg: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=ACE5C3BFBB9999;F=10AB85550A;
2018.10.22 20:39:18 4: sduino/set: sending via SendMsg: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A5EFECE9EECCCC;F=10AB85550A;
2018.10.22 20:39:18 4: sduino/set: sending via SendMsg: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=ABEEEDE6EECCCC;F=10AB85550A;
2018.10.22 20:39:18 4: SOMFY_set: PC.Rollo -> entering with mode :send: cmd :on:  arg1 ::  pos :200:
2018.10.22 20:39:18 4: SOMFY_set: handled command on --> move :on:  newState :closed:
2018.10.22 20:39:18 4: SOMFY_sendCommand: PC.Rollo -> cmd :on:
2018.10.22 20:39:18 4: sduino/set: sending via SendMsg: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=AEEBEE10113333;F=10AB85550A;
2018.10.22 20:39:18 4: sduino/set: sending via SendMsg: SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A5E1E421220000;F=10AB85550A;
2018.10.22 20:39:18 4: sduino SendrawFromQueue: msg=SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A1EACC8D88AAAA;F=10AB85550A;
2018.10.22 20:39:18 4: sduino/msg READ: MS;P0=-3905;P2=505;P3=-971;P4=-1931;D=20232323242423242424232423232323232323242423242423242424242324232324242324;CP=2;SP=0;R=228;O;m1;
2018.10.22 20:39:18 4: sduino Dispatch: P7#1BA036F4D, Dropped due to short time or equal msg
2018.10.22 20:39:18 4: sduino/msg READ: Received answer (MS;P0=-3905;P2=505;P3=-971;P4=-1931;D=20232323242423242424232423232323232323242423242423242424242324232324242324;CP=2;SP=0;R=228;O;m1;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:18 4: sduino/msg READ: MS;P0=-3898;P2=504;P3=-963;P4=-1936;D=20232323242423242424232423232323232323242423242423242424242324232324242324;CP=2;SP=0;R=228;O;m0;
2018.10.22 20:39:18 4: sduino/msg READ: Received answer (MS;P0=-3898;P2=504;P3=-963;P4=-1936;D=20232323242423242424232423232323232323242423242423242424242324232324242324;CP=2;SP=0;R=228;O;m0;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:18 4: sduino/msg READ: MS;P0=-3901;P2=466;P3=-1004;P4=-1961;D=20232323242423242424232423232323232323242423242423242424242324232324242324;CP=2;SP=0;R=228;O;
2018.10.22 20:39:18 4: sduino/msg READ: Received answer (MS;P0=-3901;P2=466;P3=-1004;P4=-1961;D=20232323242423242424232423232323232323242423242423242424242324232324242324;CP=2;SP=0;R=228;O;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:19 4: sduino/msg READ: 10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A1EACC8D88AAAA;F=10AB85550A;
2018.10.22 20:39:19 4: sduino/msg READ: Received answer (10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A1EACC8D88AAAA;F=10AB85550A;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:20 4: sduino/HandleWriteQueue: sendraw no answer (timeout)
2018.10.22 20:39:20 4: sduino SendrawFromQueue: msg=SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=ACE5C3BFBB9999;F=10AB85550A;
2018.10.22 20:39:21 4: sduino/msg READ: 10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=ACE5C3BFBB9999;F=10AB85550A;
2018.10.22 20:39:21 4: sduino/msg READ: Received answer (10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=ACE5C3BFBB9999;F=10AB85550A;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:22 4: sduino/HandleWriteQueue: sendraw no answer (timeout)
2018.10.22 20:39:22 4: sduino SendrawFromQueue: msg=SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A5EFECE9EECCCC;F=10AB85550A;
2018.10.22 20:39:23 4: sduino/msg READ: 10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A5EFECE9EECCCC;F=10AB85550A;
2018.10.22 20:39:23 4: sduino/msg READ: Received answer (10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A5EFECE9EECCCC;F=10AB85550A;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:24 4: sduino/HandleWriteQueue: sendraw no answer (timeout)
2018.10.22 20:39:24 4: sduino SendrawFromQueue: msg=SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=ABEEEDE6EECCCC;F=10AB85550A;
2018.10.22 20:39:25 4: sduino/msg READ: 10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=ABEEEDE6EECCCC;F=10AB85550A;
2018.10.22 20:39:25 4: sduino/msg READ: Received answer (10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=ABEEEDE6EECCCC;F=10AB85550A;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:26 4: sduino/HandleWriteQueue: sendraw no answer (timeout)
2018.10.22 20:39:26 4: sduino SendrawFromQueue: msg=SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=AEEBEE10113333;F=10AB85550A;
2018.10.22 20:39:27 4: sduino/msg READ: 10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=AEEBEE10113333;F=10AB85550A;
2018.10.22 20:39:27 4: sduino/msg READ: Received answer (10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=AEEBEE10113333;F=10AB85550A;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:28 4: sduino/HandleWriteQueue: sendraw no answer (timeout)
2018.10.22 20:39:28 4: sduino SendrawFromQueue: msg=SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A5E1E421220000;F=10AB85550A;
2018.10.22 20:39:29 4: sduino/msg READ: 10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A5E1E421220000;F=10AB85550A;
2018.10.22 20:39:29 4: sduino/msg READ: Received answer (10AB85550A10B0715700SC;R=6;SR;P0=-2560;P1=2560;P3=-640;D=10101010101010113;SM;C=645;D=A5E1E421220000;F=10AB85550A;) for sendraw does not match ^S(R|C|M);
2018.10.22 20:39:30 4: sduino/HandleWriteQueue: sendraw no answer (timeout)
2018.10.22 20:39:30 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:39:40 3: sduino IT_set: Leselicht on
2018.10.22 20:39:40 4: sduino IT_set: sendMsg=P3#is0FFF00FFFF0F#R6#C300
2018.10.22 20:39:40 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304040423;
2018.10.22 20:39:40 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304040423;
2018.10.22 20:39:41 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304040423;
2018.10.22 20:39:41 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304040423;
2018.10.22 20:39:41 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:39:43 3: sduino IT_set: Leselicht off
2018.10.22 20:39:43 4: sduino IT_set: sendMsg=P3#is0FFF00FFFFF0#R6#C300
2018.10.22 20:39:43 4: sduino/set: sending via SendMsg: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304230404;
2018.10.22 20:39:43 4: sduino SendrawFromQueue: msg=SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304230404;
2018.10.22 20:39:43 4: sduino/msg READ: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304230404;
2018.10.22 20:39:43 4: sduino/read sendraw answer: SR;R=6;P0=300;P1=-9300;P2=900;P3=-300;P4=-900;D=01040404230423042304040404042304230423042304230404;
2018.10.22 20:39:43 4: sduino/HandleWriteQueue: nothing to send, stopping timer
2018.10.22 20:39:44 4: sduino/msg READ: MS;P0=234;P1=451;P2=-8576;P4=-4032;P5=-2164;P6=120;D=121415151415141414141465151515151515056505151405050415;CP=1;SP=2;R=217;
2018.10.22 20:39:44 4: sduino: Matched MS Protocol id 0 -> weather1
2018.10.22 20:39:44 4: sduino: Matched MS Protocol id 68 -> PFR-130
2018.10.22 20:39:45 4: sduino/msg READ: MS;P0=506;P1=-1944;P3=-3893;P5=-8701;D=0503010103010303030303010101010101010101010103010103010303010101030303010103;CP=0;SP=5;R=221;O;m2;
2018.10.22 20:39:45 4: sduino: Matched MS Protocol id 0 -> weather1
2018.10.22 20:39:45 4: sduino: Decoded MS Protocol id 0 dmsg s97C004B1C800 length 40 RSSI = -91.5
2018.10.22 20:39:45 4: sduino: CUL_TCM97001 using longid: 1 model: Prologue
2018.10.22 20:39:45 4: sduino/msg READ: MS;P0=452;P1=-1999;P3=-3913;P5=-8708;D=0503010103010303030303010101010101010101010103010103010303010101030303010103;CP=0;SP=5;R=221;O;m1;
2018.10.22 20:39:45 4: sduino Dispatch: s97C004B1C800, Dropped due to short time or equal msg
2018.10.22 20:39:45 4: sduino: Matched MS Protocol id 68 -> PFR-130
2018.10.22 20:39:45 4: sduino: Decoded MS Protocol id 68 dmsg s97C004B1C800 length 40 RSSI = -91.5
2018.10.22 20:39:45 4: sduino/msg READ: MS;P0=430;P1=-2021;P3=-3945;P5=-8728;D=0503010103010303030303010101010101010101010103010103010303010101030303010103;CP=0;SP=5;R=221;O;m0;
2018.10.22 20:39:45 4: sduino/msg READ: MS;P0=435;P1=-2013;P3=-3959;P5=-8728;D=0503010103010303030303010101010101010101010103010103010303010101030303010103;CP=0;SP=5;R=221;
Sidey
#8
Kannst Du mir die Zeilen mit
ccconf
ccpatable
ccreg
aus dem List Befehl nach dem Reset noch mal zukommen lassen? (Also in dem Zustand in dem es funktioniert)
maddinthebrain
Hallo Sidey,
Also mit der Rc8 ist das Ganze die letzte Zeit stabil. Das ich auch eine Markise mit Somfy RTS Antrieb, wurde ich kurz stutzig, wie die Einträge von fervor gelesen habe. Ich muss allerdings sagen, dass ich solche Probleme nicht habe. Jedoch ist die Markise auch das einzige Device wohin gesendet wird. Der Rest wird empfangen.
Gibt es eine Möglichkeit das über die Schnittstelle zu debuggen? So wie es mit der Arduino Umgebung gemacht werden kann? Nur mal so als Anregung. Vielleicht läuft irgendwo nach einer gewissen Menge an Vorgängen ein Speicher über?
Schönen Abend noch...
Martin
fervor
Hier die benötigten Infos:
ccconf: freq:433.391MHz bWidth:325KHz rAmpl:42dB sens:4dB (DataRate:3173.83Baud)
ccpatable: C3E = 00 84 00 00 00 00 00 00 => 5_dBm
die Infos kommen direkt aus dem pulldown mit get
ccreg konnte ich auf diese Weise nicht abrufen, daher direkt aus den Readings kopiert
ccreg:
2018-10-06 09:35:24
bin gespannt ...
Sidey
Ich war der Meinung, dass da ein List Output war, in dem auch die Konfigurierte Bandbreite stand. Jetzt finde ich ihn nicht mehr :(
Es sieht für mich so aus, als ob die Frequenz und die Bandbreite nicht mehr korrekt eingestellt sind.
Daher klappt es dann mit der Lampe auch nicht mehr.
Wenn das Problem wieder auftritt. Ändere doch bitte mal die Frquenz auf 433.92 und prüfe ob sich die Lampe dann schalten lässt.
Grüße Sidey
fervor
#12
Mhm, habs gerade ausprobiert, scheinbar wird die neue Frequenz von 433.92 angenommen, erscheint aber nicht im Reading.
cconf zeigt aber:
ccconf: freq:433.920MHz bWidth:135KHz rAmpl:42dB sens:4dB (DataRate:198.36Baud)
nur leider tut sich trotzdem nichts bei den Steckdosen. Ein kurzer Test zeigt zumindest, dass die Rollläden noch funktionieren. Hätte gedacht, dass die Frequenz zu stark abweicht, bzw. das die Reichweite zu stark eingeschränkt wird.
beste Grüße und hast du vielleicht noch eine Idee?
PS: Nach einiger Zeit wird das Reading doch aktualisiert. Mir ist noch ein Gedanke gekommen, ich schalte mehrere Rollläden zusammen mit einem Dummy. Kann es sein, dass die Vielzahl an Signalgenerierungen das System überlasten?
PPS: Ich habe gerade bemerkt, dass auf der Empfängerseite auch Funkstille ist. Hab jedenfalls von einem externen Temperatursensor in den betreffenden Zeiträumen keine Daten bekommen. Hier könnte man notfalls ansetzten und beim Ausbleiben von Daten einen reset des Signalduinos anstoßen. Keine Lösung des Problems, aber vielleicht ein gangbarer workaround.
Sidey
Du kannst ja mal deinen dummy posten, aber für mich sieht das nach einem Bug in der Firmware aus.
Nachdem Somfy Senden sind die Register verstellt. Nach einem reset, werden die Registerwerte neu aus dem eeprom geladen und dann geht es wieder.
Ich brauche leider noch ein paar Tage bis ich das beheben kann, da ich noch ein anderes Problem am  beseitigen bin.
Workaround wäre die Register nach dem Senden wieder neu zu setzen. Das müsste ich aber selbst erst herausfinden, wie man da am besten vorgeht :)
Grüße Sidey
fervor
lass dir Zeit, ist ja schließlich unbezahlte Freizeit  :D
Habe mit ein wenig Hilfe aus dem DOIF Lager jetzt den angedeuteten workaround eingebaut, denke damit geht es erstmal.
define sduino_reset DOIF ([SD_WS07_TH_3])\
(set sduino reset)
attr sduino_reset do resetwait
attr sduino_reset repeatsame 1
attr sduino_reset wait 650
Hier mal mein Dummy für die Westseite. Nord und Ost sehen analog aus. Bei Bedarf schalte ich ein DOIF mit (set Rollo.west my, set Rollo.ost my)
define Rollo.west dummy
attr Rollo.west alias Rollläden West
attr Rollo.west cmdIcon up:black_up down:black_down
attr Rollo.west devStateIcon open:fts_shutter_10 up:fts_shutter_10 closed:fts_shutter_100@gray down:fts_shutter_100@gray my:fts_shutter_70 10:fts_shutter_10 20:fts_shutter_20 30:fts_shutter_30 40:fts_shutter_40 50:fts_shutter_50 60:fts_shutter_60 70:fts_shutter_70 80:fts_shutter_80 90:fts_shutter_90
attr Rollo.west eventMap on:down off:up go-my:my
attr Rollo.west group Rollläden
attr Rollo.west room Rollladen
attr Rollo.west sortby 3
attr Rollo.west webCmd up:my:down
define n_up_Rollo.west notify Rollo.west:up set K.Rollo,WZ.klein.Rollo,WZ.gross.Rollo up
define n_down_Rollo.west notify Rollo.west:down set K.Rollo,WZ.klein.Rollo,WZ.gross.Rollo down
define n_stop_Rollo.west notify Rollo.west:stop set K.Rollo,WZ.klein.Rollo,WZ.gross.Rollo stop
define n_my_Rollo.west notify Rollo.west:my set WZ.gross.Rollo,WZ.klein.Rollo,K.Rollo my
VG und ein schönes WE
