73_PRESENCE Force report
Begonnen von gabvoir, 31 Oktober 2018, 12:32:26
gabvoir
Hello,
I'm french, so i'll speak in english :)
I installed recently FHEM with lepresenced in order to communicate with my eedomus box.
All is okey for a normal use but I would like to improve the interface.
I would like from my box, therefore through an HTTP API, to force the presence report.
Actually I set time report to "30/60", but I would like send a report when for instance my entrance door is opened.
Is it possible ?
Thank's for helping
PatrickR
Bonsoir!
set presencedevice statusRequest
should do the trick.
Patrick
Von unterwegs gesendet.
lepresenced - Tracking von Bluetooth-LE-Tags (Gigaset G-Tag) mittels PRESENCE
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the universe trying to produce bigger and better idiots. So far, the universe is winning." - Rich Cook
gabvoir
Thank you for trick !
Then I would like to do through WEB API and return result in XML format.
I set :
define WEBeedomus FHEMWEB [PORT] global
attr WEBeedomus allowfrom [IPBOX]
attr WEBeedomus csrfToken none
And then :
http://[IPFHEM]:[PORT]/fhem?cmd=set%20Pebblebee_Gab%20statusRequest%201
But how could I have Pebblebee_Gab status in XML ?
Thank you
