[gelöst] - dblog - addLog mag nicht. commandref falsch oder ich zu blöd?
Begonnen von Frank_Huber, 05 November 2018, 10:55:03
Frank_Huber
nach Commandref sollte folgender Syntax gelten:
set <name> addLog <devspec>:<Reading>
mein Device heist "TS_Frank_Temp", das Reading "temperature"
somit müsste ich eine Log-Zeile mit set logdb addLog TS_Frank_Temp:temperature erzeugen können.
EDIT: Lösung:
set logdb addLog TS_Frank_Temp:temperature !useExcludes
Aber: es passiert nichts im dblog. im FHEM-og finde ich:
Zitat2018.11.05 10:52:44 2: DbLog logdb -> Device: "TS_Frank_Temp", reading: ".*" excluded by attribute DbLogExclude from addLog !
List vom dblog:
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION ./db.conf
   DEF        ./db.conf .*:.*
   MODE       asynchronous
   MODEL      SQLITE
   NAME       logdb
   NR         44
   NTFY_ORDER 50-logdb
   PID        406
   REGEXP     .*:.*
   STATE      228 MB, 1678103 Zeilen
   TYPE       DbLog
   VERSION    3.12.6
   dbconn     SQLite:dbname=/opt/fhem/fhem.db
   dbuser
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     OLDSTATE   connected
     READINGCOL 64
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
   Helper:
     DBLOG:
       DbFileSize:
         logdb:
           TIME       1541382300.40768
           VALUE      228
       countHistory:
         logdb:
           VALUE      1678103
     2018-11-05 10:53:06   CacheUsage      0
     2018-11-05 02:45:00   DbFileSize      228
     2018-11-05 10:53:06   NextSync        2018-11-05 10:53:36 or if CacheUsage 500 reached
     2018-11-05 02:45:00   countHistory    1678103
     2018-11-05 10:53:06   state           connected
     2018-11-04 23:55:00   userCommand     delete from HISTORY where DEVICE like "%_rH" and READING = "rH" and cast(VALUE as Integer) >115
     2018-11-04 23:55:03   userCommandResult no result
   cache:
     index      89391
   DbLogExclude .*
   DbLogInclude DbFileSize,countHistory
   DbLogSelectionMode Exclude/Include
   DbLogType  History
   asyncMode  1
   group      Logfiles
   room       SYSTEM
   stateFormat DbFileSize MB, countHistory Zeilen
   userReadings DbFileSize:countHistory.* { (split(' ',`du -m fhem.db`))[0] }
List vom Sensor:
   ALARM      1
   ASYNC      0
   DEF        DS18B20 BD3E60070000
   ERRCOUNT   0
   INTERVAL   300
   IODev      1wire
   NAME       TS_Frank_Temp
   NOTIFYDEV  global
   NR         21
   NTFY_ORDER 50-TS_Frank_Temp
   OW_FAMILY  28
   OW_ID      BD3E60070000
   PRESENT    1
   ROM_ID     28.BD3E60070000.9F
   STATE      22.375 °C
   TYPE       OWTHERM
   owg_temp   23.375
   owg_th     75
   owg_tl     70
   Helper:
     DBLOG:
       temperature:
         logdb:
           TIME       1541411529.36751
           VALUE      22.375
     2018-11-05 10:52:09   state           T: 22.38 °C ↓
     2018-11-05 10:52:09   temperature     22.375
   tempf:
     factor     1
     offset     -1
   DbLogExclude .*
   DbLogInclude temperature
   IODev      1wire
   group      Sensoren
   model      DS18B20
   room       Klima
   stateFormat temperature °C
   tempHigh   74
   tempLow    69
   tempOffset -1
DbLog Version:
93_DbLog.pm       17599 2018-10-22 19:25:46Z DS_Starter
jemand ne Idee?
Heiko?
Danke & Grüße
Frank
DS_Starter
Hi Frank,
du hast den Zusatz !useExcludes vergessen.
Steht in der commandref  ;)
LG,
Heiko
Frank_Huber
Ich will doch aber das reading temperature loggen.
Das ist nicht excludiert. Das ist über include mit drin.
Gesendet von meinem Doogee S60 mit Tapatalk
DS_Starter
Frank_Huber
OK, also arbeitet addlog anderst.
Im device kann ich ja mit exclude .* und include gezielte readings loggen.
addlog kuckt nur auf exclude, nicht auf include.
Damit ist es geklärt woran es liegt.
Wenn es auch im gesamten etwas uneinheitlich scheint.
DS_Starter
Ich schaue mal ob ich das Include mit berücksichtigen kann damit die Einheitlichkeit gewahrt wird.
Muss aber darauf achten, dass ich nichts verschlimmbessere.
wäre schön wenn du bei Tests hilfst wenn ich es implementiert habe.
Heiko
Frank_Huber
klar gerne.
Ich nutze die exclude/include Kombi recht oft. das ist einfacher als bei manchen Geräten zig Readings einzeln ins exclude zu packen.
aber nur keine Eile. mit dem !useexcludes geht es jetzt.
DS_Starter
Hallo Frank,
Im contrib-Verzeichnis:
liegt eine DbLog-Version die DbLogInclude mit berücksichtigt.
set <name> addLog <devspec>:<Reading> [Value] [CN=<caller name>] [!useExcludes]
Fügt einen zusatzlichen Logeintrag einer Device/Reading-Kombination in die Datenbank ein. Die eventuell in den Attributen "DbLogExclude" spezifizierten Readings (im Quelldevice) werden nicht nicht geloggt, es sei denn sie sind im Attribut "DbLogInclude" enthalten bzw. der addLog-Aufruf erfolgte mit der Option "!useExcludes".
Probier's mal aus ...
Heiko
Frank_Huber
Zitat von: DS_Starter am 10 November 2018, 07:52:20
Hallo Frank,
Heiko
Danke! Wird getestet! Aber erst Mo/Di. Bis morgen ist LAN Party. [emoji16]
Frank
Frank_Huber
oh:
2018.11.14 10:05:03 0: Server shutdown
2018.11.14 10:05:19 1: Including fhem.cfg
2018.11.14 10:05:20 3: telnetPort: port 7072 opened
2018.11.14 10:05:21 3: WEB: port 8083 opened
2018.11.14 10:05:21 2: eventTypes: loaded 539 events from ./log/eventTypes.txt
2018.11.14 10:05:21 3: Opening 1wire device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_DAE002xu-if00-port0
2018.11.14 10:05:21 3: 1wire device opened
2018.11.14 10:05:21 3: OWX_SER: opened serial device /dev/serial/by-id/usb-FTDI_FT232R_USB_UART_DAE002xu-if00-port0: Illegal seek
2018.11.14 10:05:31 3: OWTHERM:  Device TS_Frank_Temp defined.
2018.11.14 10:05:40 3: OWMULTI:  Device TS_Frank_rH defined.
2018.11.14 10:05:41 1: PERL WARNING: Bareword found where operator expected at ./FHEM/93_DbLog.pm line 9, near "93_DbLog"
2018.11.14 10:05:41 1: PERL WARNING: (Missing operator before DbLog?)
2018.11.14 10:05:41 1: reload: Error:Modul 93_DbLog deactivated:
syntax error at ./FHEM/93_DbLog.pm line 8, near "<"
Unknown regexp modifier "/D" at ./FHEM/93_DbLog.pm line 9, at end of line
Unknown regexp modifier "/S" at ./FHEM/93_DbLog.pm line 9, at end of line
Unknown regexp modifier "/_" at ./FHEM/93_DbLog.pm line 9, at end of line
Unknown regexp modifier "/t" at ./FHEM/93_DbLog.pm line 9, at end of line
Unknown regexp modifier "/r" at ./FHEM/93_DbLog.pm line 9, at end of line
Unknown regexp modifier "/e" at ./FHEM/93_DbLog.pm line 9, at end of line
./FHEM/93_DbLog.pm has too many errors.
2018.11.14 10:05:41 0: syntax error at ./FHEM/93_DbLog.pm line 8, near "<"
root@FHEM-PI-TEST:/opt/fhem/FHEM# ls -la 93_D*
-rwxrwxrwx 1 fhem dialout 1646408 Nov 14 10:02 93_DbLog.pm
-rwxrwxrwx 1 fhem dialout 3251520 Nov 14 10:02 93_DbRep.pm
vorhin aus dem Contrib geladen. Raspbian und FHEM tagesaktuell
DS_Starter
Frank_Huber
Zitat von: DS_Starter am 14 November 2018, 10:25:35
Du musst den Downloadbutton benutzen !!!
Ah, habs mit rechtsklick, "speichern unter" gemacht.
Hab mit dem SVN keine Erfahrung, wird gleich nochmal geholt.
Frank_Huber
wenn man den download button mal findet... :-)
Testversion ist drauf, FHEM fehlerlos gestartet.
meld mich später wieder.
Frank_Huber
Im contrib-Verzeichnis liegt eine DbLog-Version die DbLogInclude mit berücksichtigt.
Hallo Heiko,
läuft bestens. hat jetzt auf dem Testsystem nahezu 5 Stunden Betrieb hinter sich ohne Auffälligkeiten.
Danke!
Frank
DS_Starter
Sehr schön, freut mich  :)
Wenn du magst und Spaß daran hast, kannst du auch mal die neuen Attribute traceFlag und traceLevel ausprobieren. Die sind noch nicht beschrieben, generieren aber DB-Traces z.B. zur Fehlersuche. Nur mal schauen, ob das auch bei dir fluffig läuft. Diese Möglichkeit hatte ich wegen einem aktuellen Bedarf schon mit eingebaut. Generieren halt recht viele Daten.
Wenn alles weiter smooth läuft passe ich die commandref noch an und übernehme die Version ins Repository.
Heiko
