[Gelöst]DBLog Fehler nach neuaufsetzen
Begonnen von Tommy82, 22 November 2018, 13:31:06
Tommy82
ich musste meinen Cubitruck leider neu aufsetzen, habe dafür Debian Stretch neu installiert und Fhem runtergeladen und installiert und anschließend mein Backup zurück gespielt, soweit so gut, allerdings bekomme ich im Log jetzt diese Meldungen:
2018.11.22 12:23:43.816 1: PERL WARNING: DBD::SQLite::db do failed: unable to open database file at ./FHEM/93_DbLog.pm line 2442.
2018.11.22 12:23:43.817 1: stacktrace:
2018.11.22 12:23:43.817 1:     main::__ANON__                      called by ./FHEM/93_DbLog.pm (2442)
2018.11.22 12:23:43.817 1:     main::DbLog_ConnectPush             called by ./FHEM/93_DbLog.pm (1506)
2018.11.22 12:23:43.818 1:     (eval)                              called by ./FHEM/93_DbLog.pm (1505)
2018.11.22 12:23:43.818 1:     main::DbLog_Push                    called by ./FHEM/93_DbLog.pm (1462)
2018.11.22 12:23:43.818 1:     main::DbLog_Log                     called by fhem.pl (3603)
2018.11.22 12:23:43.818 1:     main::CallFn                        called by fhem.pl (3523)
2018.11.22 12:23:43.818 1:     main::DoTrigger                     called by fhem.pl (4574)
2018.11.22 12:23:43.819 1:     main::readingsEndUpdate             called by FHEM/ABFALL_setUpdate.pm (220)
2018.11.22 12:23:43.819 1:     main::ABFALL_setUpdate              called by fhem.pl (3146)
2018.11.22 12:23:43.819 1:     main::HandleTimeout                 called by fhem.pl (649)
2018.11.22 12:23:43.888 3: DbLog myDbLog - Creating Push-Handle to database SQLite:dbname=/media/Platte/home/fhem.db with user
2018.11.22 12:23:43.896 3: DbLog myDbLog - Push-Handle to db SQLite:dbname=/media/Platte/home/fhem.db created
2018.11.22 12:23:43.932 1: PERL WARNING: DBD::SQLite::db do failed: unable to open database file at ./FHEM/93_DbLog.pm line 2438.
2018.11.22 12:23:43.932 1: stacktrace:
2018.11.22 12:23:43.933 1:     main::__ANON__                      called by ./FHEM/93_DbLog.pm (2438)
2018.11.22 12:23:43.933 1:     main::DbLog_ConnectPush             called by fhem.pl (3146)
2018.11.22 12:23:43.933 1:     main::HandleTimeout                 called by fhem.pl (649)
2018.11.22 12:23:43.935 1: PERL WARNING: DBD::SQLite::db do failed: unable to open database file at ./FHEM/93_DbLog.pm line 2441.
2018.11.22 12:23:43.935 1: stacktrace:
2018.11.22 12:23:43.935 1:     main::__ANON__                      called by ./FHEM/93_DbLog.pm (2441)
2018.11.22 12:23:43.936 1:     main::DbLog_ConnectPush             called by fhem.pl (3146)
2018.11.22 12:23:43.936 1:     main::HandleTimeout                 called by fhem.pl (649)
2018.11.22 12:23:43.937 1: PERL WARNING: DBD::SQLite::db do failed: unable to open database file at ./FHEM/93_DbLog.pm line 2442.
2018.11.22 12:23:43.937 1: stacktrace:
2018.11.22 12:23:43.938 1:     main::__ANON__                      called by ./FHEM/93_DbLog.pm (2442)
2018.11.22 12:23:43.938 1:     main::DbLog_ConnectPush             called by fhem.pl (3146)
2018.11.22 12:23:43.938 1:     main::HandleTimeout                 called by fhem.pl (649)
Was hab ich vergessen /falsch gemacht?
Fhem Cubitruck  Armbian Buster with Linux 5.3.9-sunxi
HM-CC_RT-DN, HM-Sec-RHS,HM-Sec-SD, HM-Sec-SCo,IT1500,1xIT GRR-3500 Fritz!Dect200,Powerline546E,Enigma2 Modul mit 3 Vu+,Wol Modul für WinServer2016 und WinServer 2019,FB6590
Allnetl Wandtablett mit FTUI
DS_Starter
Der wesentliche Hinweis ist der:
D.h. ist das File dort zu finden (ist in der .conf Datei definiert) ?   Hat der fhem-User die Rechte das File zu öffnen ?
Heiko
Tommy82
Alos das list der dblog sieht so aus:
   COLUMNS    field length used for Device: 64, Type: 64, Event: 512, Reading: 64, Value: 128, Unit: 32
   CONFIGURATION /opt/fhem/db.conf
   DEF        /opt/fhem/db.conf .*:.*
   MODE       synchronous
   MODEL      SQLITE
   NAME       myDbLog
   NR         244
   NTFY_ORDER 50-myDbLog
   PID        4206
   REGEXP     .*:.*
   STATE      DBD::SQLite::db prepare failed: unable to open database file at ./FHEM/93_DbLog.pm line 1572.
   TYPE       DbLog
   VERSION    3.13.0
   dbconn     SQLite:dbname=/media/Platte/home/fhem.db
   dbuser
   HELPER:
     COLSET     1
     DEVICECOL  64
     EVENTCOL   512
     OLDSTATE   DBD::SQLite::db prepare failed: unable to open database file at ./FHEM/93_DbLog.pm line 1572.
     READINGCOL 64
     TYPECOL    64
     UNITCOL    32
     VALUECOL   128
   Helper:
     DBLOG:
       state:
         myDbLog:
           TIME       1542890955.06124
           VALUE      DBD::SQLite::db prepare failed
     2018-01-10 22:12:29   CacheUsage      33
     2018-01-10 22:12:29   NextSync        2018-01-10 22:12:59 or if CacheUsage 500 reached
     2018-01-12 18:42:42   countCurrent    1695
     2018-01-12 18:42:42   countHistory    259075
     2016-03-02 18:45:47   lastReduceLogResult Rows processed: 1028663, deleted: 978048, time: 528.78sec
     2018-11-12 02:02:11   lastRowsDeleted 214243
     2018-01-11 06:07:47   reduceLogState  Rows processed: 0, deleted: 0, time: 0.01sec
     2018-11-22 13:50:41   state           DBD::SQLite::db prepare failed: unable to open database file at ./FHEM/93_DbLog.pm line 1572.
   cache:
     index      0
   DbLogType  Current/History
   asyncMode  0
   group      Info
   room       Zentral
Die db.conf in meinem Fhem Verzeichniss hat den Inhalt
%dbconfig= (
connection => "SQLite:dbname=/media/Platte/home/fhem.db",
user => "",
password => ""
die Berechtigung ist:
-rw-r--r--  1 fhem dialout    102 Jan 10  2018 db.conf
die fhem.db unter /media/Platte/home/  hat die Berechtigung
-rw-r--r--  1 fhem   dialout   472109056 Nov 21 21:47 fhem.db
Ich seh den Fehler nicht...
DS_Starter
#3
Um dieses File geht es:
Ist es vorhanden mit den nötigen Zugriffsberechtigungen ?
Setzt mal bitte auch die Schreibberechtigung für alle. Nur zum Test, später wieder rückgängig machen.
Tommy82
Hi, so sieht die aus, würde sagen die berechtigung passt
DS_Starter
siehe oben .. "Setzt mal bitte auch die Schreibberechtigung für alle. Nur zum Test, später wieder rückgängig machen."
Tommy82
Hab jetzt mal 777 gesetzt, aber keine besserung, kann ich die fhem.db nicht einfach neu anlegen? Auch wenn dann die alten Daten weg sind?
root@cubietruck /media/Platte/home
-rwxrwxrwx 1 fhem   dialout   472109056 Nov 21 21:47 fhem.db
Frank_Huber
erstmal versucht die DB manuell zu öffnen?
in der Konsole sqlite3 /media/Platte/home/fhem.db
Tommy82
Das funktioniert, .dbinfo bringt dann:
.dbinfo
database page size:  4096
write format:        2
read format:         2
reserved bytes:      0
file change counter: 84956
database page count: 115261
freelist page count: 89916
schema cookie:       4
schema format:       4
default cache size:  0
autovacuum top root: 0
incremental vacuum:  0
text encoding:       1 (utf8)
user version:        0
application id:      0
software version:    3016002
number of tables:    3
number of indexes:   1
number of triggers:  0
schema size:         512
DS_Starter
Mach mal mal ein set configCheck und poste die Ausgaben.
Tommy82
Ich glaub jetzt läufts plötzlich, bekomme jetzt ein "connected"
Hier die gewünschte Ausgabe
Result of DbLog version check
Used DbLog version: 3.13.0
Recommendation: Your running version may be the current one. Please check for updates of DbLog periodically.
Result of configuration read check
Connection parameter store type: file
Connection parameter: Connection -> SQLite:dbname=/media/Platte/home/fhem.db, User -> , Password -> read o.k.
Result of connection check
Connection to database /media/Platte/home/fhem.db successfully done.
Recommendation: settings o.k.
Result of encoding check
Encoding used by DB /media/Platte/home/fhem.db: UTF-8
Recommendation: This is only an information about text encoding used by the main database.
Result of logmode check
Logmode of DbLog-device myDbLog is: synchronous
Recommendation: Switch myDbLog to the asynchronous logmode by setting the 'asyncMode' attribute. The advantage of this mode is to log events non-blocking.
There are attributes 'syncInterval' and 'cacheLimit' relevant for this working mode.
Please refer to commandref for further information about these attributes.
Result of plot generation method check
WARNING - at least one of your FHEMWEB devices have attribute "plotfork = 1" not set. This may cause blocking situations when creating plots.
WEB: plotfork=0
WEBphone: plotfork=0
WEBtablet: plotfork=0
Recommendation: You should set attribute "plotfork = 1" in relevant devices
Result of table 'history' check
Column width set in DB /media/Platte/home/fhem.db.history: 'DEVICE' = 32, 'TYPE' = 32, 'EVENT' = 512, 'READING' = 32, 'VALUE' = 32, 'UNIT' = 32
Column width used by myDbLog: 'DEVICE' = 64, 'TYPE' = 64, 'EVENT' = 512, 'READING' = 64, 'VALUE' = 128, 'UNIT' = 32
Recommendation: WARNING - The relation between column width in table history and the field width used by device myDbLog should be equal but it differs.The field width used by myDbLog can be adjusted by setting attributes 'colEvent', 'colReading', 'colValue'. (pls. refer to commandref)Because you use SQLite this is only a warning. Normally the database can handle these differences.
Result of table 'current' check
Column width set in DB /media/Platte/home/fhem.db.current: 'DEVICE' = 32, 'TYPE' = 32, 'EVENT' = 512, 'READING' = 32, 'VALUE' = 32, 'UNIT' = 32
Recommendation: WARNING - The relation between column width in table current and the field width used by device myDbLog should be equal but it differs. The field width used by myDbLog can be adjusted by setting attributes 'colEvent', 'colReading', 'colValue'. (pls. refer to commandref)Because you use SQLite this is only a warning. Normally the database can handle these differences.
Result of check 'Search_Idx' availability
Index 'Search_Idx' exists and contains recommended fields 'DEVICE', 'READING', 'TIMESTAMP'.
Result of check 'Report_Idx' availability for DbRep-devices
No DbRep-device assigned to myDbLog is used. Hence an index for DbRep isn't needed.
DS_Starter
Ausgabe sieht gut aus.  War da eine Zauberhand im Spiel ?  ;)
Tommy82
Seltsam ist es..... der Schritt bevor es plötzlich ging war das öffnen der DB auf der kommandozeile, plötzlich war die Verbindung da.
Naja wenigstens es läuft wieder:-)
Vielen Dank für die Hilfe
Frank_Huber
War da evtl eine Sperre auf der Datei die dadurch gelöst wurde?
Was ist denn vor dem Neuaufsetzen zuletzt passiert?
Gesendet von meinem Doogee S60 mit Tapatalk
Tommy82
Speere?
Also in Fhem dürfte vor dem neuaufsetzen nichts besonderes passiert sein, ich hatte bei einem "bisschen rumspielen" mein Armbian zerschossen, so das ich alles neu aufsetzen musste
