Neues Modul: vitoconnect
Begonnen von andreas13, 24 November 2018, 17:42:33
jemu75
#735
in meinem LogFile häufen sich Fehlermeldungen. Daten werden aber problemlos abgerufen. Was kann ich da machen?
2021.11.21 21:47:18 1: PERL WARNING: "my" variable $param masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1858, <$fh> line 2145.
2021.11.21 21:47:18 1: PERL WARNING: "my" variable $err masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1865, <$fh> line 2145.
2021.11.21 21:47:18 1: PERL WARNING: "my" variable $msg masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1865, <$fh> line 2145.
2021.11.21 21:47:18 1: PERL WARNING: "my" variable $decode_json masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1866, <$fh> line 2145.
2021.11.21 21:47:18 3: vitoconnect - Passwort war bereits gespeichert
2021.11.21 21:47:30 1: PERL WARNING: Argument "" isn't numeric in numeric eq (==) at ./FHEM/98_vitoconnect.pm line 1755.
2021.11.21 21:47:30 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/98_vitoconnect.pm line 1849.
2021.11.21 21:47:30 1: vitoconnect - Fehler während installation features:  :: {"viErrorId":"req-c2a0ffb569274e8a8458c969d818269d","statusCode":500,"errorType":"INTERNAL_ERROR","message":"Internal server error"}
2021.11.21 22:11:37 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/98_vitoconnect.pm line 1948.
2021.11.21 22:11:37 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/98_vitoconnect.pm line 1953.
2021.11.21 22:11:37 1: vitoconnect - unbekannter Fehler: Bitte den Entwickler informieren!
2021.11.21 22:11:37 1: PERL WARNING: Use of uninitialized value in concatenation (.) or string at ./FHEM/98_vitoconnect.pm line 1996.
2021.11.21 22:11:37 1: vitoconnect - statusCode: 500 errorType: INTERNAL_ERROR message: Internal server error error:
2021.11.21 22:47:50 1: vitoconnect - Fehler während installation features:  :: {"viErrorId":"req-4001c8c03ff14dfaa37e7e8a95c79fd7","statusCode":500,"errorType":"INTERNAL_ERROR","message":"Internal server error"}
2021.11.21 22:53:52 1: vitoconnect - unbekannter Fehler: Bitte den Entwickler informieren!
2021.11.21 22:53:52 1: vitoconnect - statusCode: 500 errorType: INTERNAL_ERROR message: Internal server error error:
andreas13
Du kannst Viessmann sagen, sie mögen den Fehler bei,ihrem Server reparieren.
[ quote author=jemu75 link=topic=93664.msg1188525#msg1188525 date=1637534211]
[/quote]
Maintainer des Vitoconnect Moduls
In Betrieb: FritzBox 7590, Homematic
piko Wechelrichter (HTTPMOD). Sonos ....
noch: IT
marhof
Hi hier die Daten.
Danke im Voraus.
Zitat von: andreas13 am 21 November 2021, 17:20:00
Du kannst mal das Attribut vitoconnect_actions_active auf 1 setzen und mir die dann erzeugten zusätzlichen Readings schicken. Dann kann ich schauen, ob die API einen solchen Befehl kenn und ihn ggf. implementieren.
Andreas
defmod vitoconnect vitoconnect xxxx
attr vitoconnect room Heizung
attr vitoconnect vitoconnect_actions_active 1
setstate vitoconnect last update: 2021-11-23 21:37:18
setstate vitoconnect 2021-11-23 21:37:18 Aktive_Heizkreise 0
setstate vitoconnect 2021-11-23 21:37:18 Aussen_Status connected
setstate vitoconnect 2021-11-23 21:37:18 Aussentemperatur 4.3
setstate vitoconnect 2021-11-23 21:37:18 Aussentemperatur/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 Controller_Seriennummer xxxxxxxxxxxxxx
setstate vitoconnect 2021-11-23 21:37:18 Device_Time_Offset 59
setstate vitoconnect 2021-11-23 21:37:18 HK1-Betriebsart dhwAndHeatingCooling
setstate vitoconnect 2021-11-23 21:37:18 HK1-Fixed_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Frostschutz_Status off
setstate vitoconnect 2021-11-23 21:37:18 HK1-Heizkurve-Niveau 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Heizkurve-Steigung 0.3
setstate vitoconnect 2021-11-23 21:37:18 HK1-Name
setstate vitoconnect 2021-11-23 21:37:18 HK1-Normal_Standby_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Programmstatus normal
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_Anforderung unknown
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_comfort 20
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_comfort_Anforderung unknown
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_comfort_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_eco 20
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_eco_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_normal 20
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_reduziert 16
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_reduziert_Anforderung unknown
setstate vitoconnect 2021-11-23 21:37:18 HK1-Solltemperatur_reduziert_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Standby_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-Typ heatingCircuit
setstate vitoconnect 2021-11-23 21:37:18 HK1-Vorlauftemperatur 27.2
setstate vitoconnect 2021-11-23 21:37:18 HK1-Vorlauftemperatur/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 HK1-Vorlauftemperatur_aktiv connected
setstate vitoconnect 2021-11-23 21:37:18 HK1-WW_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 HK1-WW_und_Heizen_Kuehlen_aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 HK1-Zeitsteuerung_Heizung {"fri":[{"mode":"normal","start":"00:00","end":"24:00","position":0}],"mon":[{"start":"00:00","mode":"normal","end":"24:00","position":0}],"wed":[{"start":"00:00","mode":"normal","end":"24:00","position":0}],"sat":[{"mode":"normal","start":"00:00","position":0,"end":"24:00"}],"thu":[{"mode":"normal","start":"00:00","position":0,"end":"24:00"}],"sun":[{"position":0,"end":"24:00","start":"00:00","mode":"normal"}],"tue":[{"end":"24:00","position":0,"mode":"normal","start":"00:00"}]}
setstate vitoconnect 2021-11-23 21:37:18 HK1-Zeitsteuerung_Heizung_aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 HK1-Zirkulationspumpe on
setstate vitoconnect 2021-11-23 21:37:18 HK1-aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 HK2-Heizkurve-Niveau 0
setstate vitoconnect 2021-11-23 21:37:18 HK2-Heizkurve-Steigung 0.6
setstate vitoconnect 2021-11-23 21:37:18 HK3-Heizkurve-Niveau 0
setstate vitoconnect 2021-11-23 21:37:18 HK3-Heizkurve-Steigung 0.6
setstate vitoconnect 2021-11-23 21:37:18 Kessel_Common_Supply notConnected
setstate vitoconnect 2021-11-23 21:37:18 Kessel_Common_Supply_Temperatur/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 Kessel_Seriennummer xxxxxxxxxx
setstate vitoconnect 2021-11-23 21:37:18 Mehrfamilenhaus_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 Urlaub_Ende
setstate vitoconnect 2021-11-23 21:37:18 Urlaub_Start
setstate vitoconnect 2021-11-23 21:37:18 Urlaub_aktiv 0
setstate vitoconnect 2021-11-23 21:37:18 WW-Aufladung 0
setstate vitoconnect 2021-11-23 21:37:18 WW-Haupttemperatur 35
setstate vitoconnect 2021-11-23 21:37:18 WW-Hysterese 5
setstate vitoconnect 2021-11-23 21:37:18 WW-Isttemperatur 45.4
setstate vitoconnect 2021-11-23 21:37:18 WW-Isttemperatur/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 WW-Sensoren_Auslauf_Status notConnected
setstate vitoconnect 2021-11-23 21:37:18 WW-Sensoren_Auslauf_Wert/Einheit celsius
setstate vitoconnect 2021-11-23 21:37:18 WW-Status on
setstate vitoconnect 2021-11-23 21:37:18 WW-Temperatur_2 48
setstate vitoconnect 2021-11-23 21:37:18 WW-Temperatur_aktiv connected
setstate vitoconnect 2021-11-23 21:37:18 WW-Zeitplan {"sun":[{"position":0,"end":"14:00","mode":"temp-2","start":"11:00"},{"position":1,"end":"24:00","mode":"normal","start":"14:00"},{"end":"05:30","position":2,"mode":"normal","start":"00:00"},{"start":"05:30","mode":"temp-2","position":3,"end":"07:00"},{"end":"11:00","position":4,"mode":"normal","start":"07:00"}],"tue":[{"mode":"temp-2","start":"11:00","position":0,"end":"14:00"},{"end":"24:00","position":1,"mode":"normal","start":"14:00"},{"mode":"normal","start":"00:00","end":"11:00","position":2}],"thu":[{"end":"14:00","position":0,"mode":"temp-2","start":"11:00"},{"start":"14:00","mode":"normal","position":1,"end":"24:00"},{"mode":"normal","start":"00:00","end":"11:00","position":2}],"sat":[{"start":"11:00","mode":"temp-2","position":0,"end":"14:00"},{"mode":"normal","start":"14:00","end":"24:00","position":1},{"position":2,"end":"05:30","mode":"normal","start":"00:00"},{"end":"07:00","position":3,"start":"05:30","mode":"temp-2"},{"start":"07:00","mode":"normal","position":4,"end":"11:00"}],"wed":[{"mode":"temp-2","start":"11:00","end":"14:00","position":0},{"mode":"normal","start":"14:00","position":1,"end":"24:00"},{"position":2,"end":"11:00","start":"00:00","mode":"normal"}],"mon":[{"mode":"temp-2","start":"11:00","end":"14:00","position":0},{"mode":"normal","start":"14:00","end":"24:00","position":1},{"end":"05:30","position":2,"mode":"normal","start":"00:00"},{"mode":"temp-2","start":"05:30","end":"07:00","position":3},{"start":"07:00","mode":"normal","end":"11:00","position":4}],"fri":[{"position":0,"end":"14:00","mode":"temp-2","start":"11:00"},{"end":"24:00","position":1,"mode":"normal","start":"14:00"},{"start":"00:00","mode":"normal","end":"05:30","position":2},{"mode":"temp-2","start":"05:30","position":3,"end":"07:00"},{"position":4,"end":"11:00","start":"07:00","mode":"normal"}]}
setstate vitoconnect 2021-11-23 21:37:18 WW-Zirkulationspumpe_Status off
setstate vitoconnect 2021-11-23 21:37:18 WW-Zirkulationspumpe_Zeitplan {"tue":[{"position":0,"end":"06:40","start":"06:30","mode":"5/10-cycles"},{"position":1,"end":"12:10","start":"12:00","mode":"5/10-cycles"},{"position":2,"end":"17:10","start":"17:00","mode":"5/10-cycles"},{"position":3,"end":"08:10","mode":"5/10-cycles","start":"08:00"}],"sun":[{"mode":"5/10-cycles","start":"06:30","end":"06:40","position":0},{"mode":"5/10-cycles","start":"12:00","end":"12:10","position":1},{"end":"17:10","position":2,"start":"17:00","mode":"5/10-cycles"},{"mode":"5/10-cycles","start":"08:00","end":"08:10","position":3}],"thu":[{"end":"06:40","position":0,"mode":"5/10-cycles","start":"06:30"},{"start":"12:00","mode":"5/10-cycles","end":"12:10","position":1},{"end":"17:10","position":2,"mode":"5/10-cycles","start":"17:00"},{"position":3,"end":"08:10","mode":"5/10-cycles","start":"08:00"}],"sat":[{"position":0,"end":"06:40","start":"06:30","mode":"5/10-cycles"},{"end":"12:10","position":1,"mode":"5/10-cycles","start":"12:00"},{"position":2,"end":"17:10","mode":"5/10-cycles","start":"17:00"},{"mode":"5/10-cycles","start":"08:00","position":3,"end":"08:10"}],"mon":[{"start":"06:30","mode":"5/10-cycles","position":0,"end":"06:40"},{"end":"12:10","position":1,"start":"12:00","mode":"5/10-cycles"},{"mode":"5/10-cycles","start":"17:00","position":2,"end":"17:10"},{"start":"08:00","mode":"5/10-cycles","end":"08:10","position":3}],"wed":[{"mode":"5/10-cycles","start":"06:30","end":"06:40","position":0},{"end":"12:10","position":1,"mode":"5/10-cycles","start":"12:00"},{"mode":"5/10-cycles","start":"17:00","end":"17:10","position":2},{"mode":"5/10-cycles","start":"08:00","end":"08:10","position":3}],"fri":[{"end":"06:40","position":0,"mode":"5/10-cycles","start":"06:30"},{"position":1,"end":"12:10","mode":"5/10-cycles","start":"12:00"},{"start":"17:00","mode":"5/10-cycles","end":"17:10","position":2},{"mode":"5/10-cycles","start":"08:00","end":"08:10","position":3}]}
setstate vitoconnect 2021-11-23 21:37:18 WW-Zirkulationspumpe_Zeitsteuerung_aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 WW-Zirkulationspumpe_primaer off
setstate vitoconnect 2021-11-23 21:37:18 WW-aktiv 1
setstate vitoconnect 2021-11-23 21:37:18 WW-einmaliges_Aufladen 0
setstate vitoconnect 2021-11-23 21:37:18 WW-zeitgesteuert_aktiv 1
setstate vitoconnect 2021-11-23 21:35:15 device xxxxx
setstate vitoconnect 2021-11-23 21:35:15 gw {"data":xxxxxx
setstate vitoconnect 2021-11-23 21:35:16 gw_features xxxxxx
setstate vitoconnect 2021-11-23 21:37:18 heating.buffer.sensors.temperature.main.status notConnected
setstate vitoconnect 2021-11-23 21:37:18 heating.buffer.sensors.temperature.main.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.buffer.sensors.temperature.top.status notConnected
setstate vitoconnect 2021-11-23 21:37:18 heating.buffer.sensors.temperature.top.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.heating.roomInfluenceFactor.value 10
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.operating.modes.cooling.active 0
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.levels.max 47
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.levels.maxUnit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.levels.min 15
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.levels.minUnit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.0.temperature.value 29.1
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.1.heating.roomInfluenceFactor.value 10
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.1.temperature.value 0
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.2.heating.roomInfluenceFactor.value 10
setstate vitoconnect 2021-11-23 21:37:18 heating.circuits.2.temperature.value 0
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.active 0
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.cooling.week.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.cooling.week.unit kilowattHour
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.cooling.week.value 0
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.dhw.week.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.dhw.week.unit kilowattHour
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.dhw.week.value 13.7
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.heating.week.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.heating.week.unit kilowattHour
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.heat.production.heating.week.value 89.1
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.phase off
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hours 670.9
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassFive 22
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassFour 147
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassOne 51
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassThree 263
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.hoursLoadClassTwo 140
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.0.statistics.starts 3432
setstate vitoconnect 2021-11-23 21:37:18 heating.compressors.enabled 0
setstate vitoconnect 2021-11-23 21:37:18 heating.configuration.secondaryHeatGenerator.modeOnError.mode reduced
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.bottom.status notConnected
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.bottom.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.top.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.top.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.dhw.sensors.temperature.hotWaterStorage.top.value 45.4
setstate vitoconnect 2021-11-23 21:37:18 heating.heatingRod.runtime.levelOne 949099
setstate vitoconnect 2021-11-23 21:37:18 heating.heatingRod.runtime.levelTwo 781188
setstate vitoconnect 2021-11-23 21:37:18 heating.heatingRod.runtime.unit seconds
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.return.status notConnected
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.return.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.supply.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.supply.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.primaryCircuit.sensors.temperature.supply.value 5.2
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.return.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.return.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.return.value 26.9
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.supply.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.supply.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.secondaryCircuit.sensors.temperature.supply.value 27
setstate vitoconnect 2021-11-23 21:37:18 heating.sensors.temperature.return.status connected
setstate vitoconnect 2021-11-23 21:37:18 heating.sensors.temperature.return.unit celsius
setstate vitoconnect 2021-11-23 21:37:18 heating.sensors.temperature.return.value 26.9
setstate vitoconnect 2021-11-23 21:35:15 installation xxxxxxxxxx
setstate vitoconnect 2021-11-23 21:35:16 installation_features {"data":[]}
setstate vitoconnect 2021-11-23 21:37:18 state last update: 2021-11-23 21:37:18
setstate vitoconnect 2021-11-23 21:37:18 ventilation.active 1
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.modes.active.value ventilation
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.modes.standard.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.modes.standby.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.modes.ventilation.active 1
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.active.value levelTwo
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.comfort.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.eco.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.holiday.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.holiday.end
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.holiday.start
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelFour.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelFour.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelFour.volumeFlow 215
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelOne.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelOne.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelOne.volumeFlow 120
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelThree.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelThree.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelThree.volumeFlow 170
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelTwo.active 1
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelTwo.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.levelTwo.volumeFlow 120
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.standby.active 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.standby.unit cubicMeter/hour
setstate vitoconnect 2021-11-23 21:37:18 ventilation.operating.programs.standby.volumeFlow 0
setstate vitoconnect 2021-11-23 21:37:18 ventilation.schedule.active 1
setstate vitoconnect 2021-11-23 21:37:18 ventilation.schedule.entries {"sat":[{"end":"14:00","position":0,"mode":"levelThree","start":"06:00"},{"start":"00:00","mode":"levelTwo","position":1,"end":"06:00"},{"end":"24:00","position":2,"start":"20:00","mode":"levelTwo"},{"end":"20:00","position":3,"mode":"levelFour","start":"14:00"}],"tue":[{"end":"20:00","position":0,"mode":"levelThree","start":"06:00"},{"mode":"levelTwo","start":"00:00","position":1,"end":"06:00"},{"mode":"levelTwo","start":"20:00","position":2,"end":"24:00"}],"sun":[{"end":"20:00","position":0,"start":"06:00","mode":"levelThree"},{"end":"06:00","position":1,"start":"00:00","mode":"levelTwo"},{"position":2,"end":"24:00","mode":"levelTwo","start":"20:00"}],"thu":[{"end":"20:00","position":0,"mode":"levelThree","start":"06:00"},{"end":"06:00","position":1,"start":"00:00","mode":"levelTwo"},{"end":"24:00","position":2,"mode":"levelTwo","start":"20:00"}],"fri":[{"mode":"levelThree","start":"06:00","end":"20:00","position":0},{"mode":"levelTwo","start":"00:00","end":"06:00","position":1},{"mode":"levelTwo","start":"20:00","end":"24:00","position":2}],"mon":[{"mode":"levelThree","start":"06:00","position":0,"end":"20:00"},{"mode":"levelTwo","start":"00:00","position":1,"end":"06:00"},{"position":2,"end":"24:00","start":"20:00","mode":"levelTwo"}],"wed":[{"start":"06:00","mode":"levelThree","end":"20:00","position":0},{"mode":"levelTwo","start":"00:00","end":"06:00","position":1},{"position":2,"end":"24:00","start":"20:00","mode":"levelTwo"}]}
andreas13
Hallo marof,
ich seh gerade, dass ich das Feature nach der Umstellung noch nicht implementiert habe :-( Vielleicht schaffe ich es zwischen den Jahren. Ich melde mich dann nochmal.
Andreas
Zitat von: marhof am 23 November 2021, 21:47:37
Hi hier die Daten.
Danke im Voraus.
noch: IT
xls
Seit heute Nacht startet meine Wärmepumpe immer wieder neu.
Ich habe erstmal die Verbindung Heizung <-> Vitoconnect getrennt. Jetzt geht es wieder.
Irgendwie scheint die Heizung immer wieder den Befehl zum Neustart zu bekommen.
Keine Ahnung ob der Befehl aus dem Modul, oder direkt von Viessmann kommt.
andreas13
Das Modul sendet garantiert keine Befehle an Deine Heizung. Ein Befehl zum Neustart gibt es in der API nicht. Das muss eine andere Ursache haben.
noch: IT
jemu75
#741
ich bekomme direkt nach dem Neustart von FHEM folgende Fehlermeldungen.
2021.12.03 21:23:53 1: PERL WARNING: "my" variable $param masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1858, <$fh> line 2135.
2021.12.03 21:23:53 1: PERL WARNING: "my" variable $err masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1865, <$fh> line 2135.
2021.12.03 21:23:53 1: PERL WARNING: "my" variable $msg masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1865, <$fh> line 2135.
2021.12.03 21:23:53 1: PERL WARNING: "my" variable $decode_json masks earlier declaration in same scope at ./FHEM/98_vitoconnect.pm line 1866, <$fh> line 2135.
2021.12.03 21:23:53 3: vitoconnect - Passwort war bereits gespeichert
2021.12.03 21:24:04 1: PERL WARNING: Argument "" isn't numeric in numeric eq (==) at ./FHEM/98_vitoconnect.pm line 1755.
2021.12.03 21:24:05 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/98_vitoconnect.pm line 1849.
2021.12.03 21:24:05 1: PERL WARNING: Use of uninitialized value in string ne at ./FHEM/98_vitoconnect.pm line 1867.
Woran kann das liegen?
andreas13
das liegt daran, dass ich ein lausiger Programmierer bin. Das sind aber keine Fehlermeldungen, sondern nur Warnungen. Das Modul sollte aber trotzdem funktionieren. Wenn sonst alles ok ist, kannst Du das einfach ignorieren.
Andreas
noch: IT
matthewk
Hallo! Ich hatte schon immer das Problem, dass das Reading "heating.controller.serial.value" Probleme machte. Es produzierte einen Absturz wegen "wide character" beim Speichern in die Datenbank per LogDB. Dies Problem konnte ich das Attribut "DbLogExclude" lösen. Aber seit einiger Zeit ist dieser Parameter mit einem sehr großen Wert gefüllt, der aus unzähligen Wiederholungen von "Ã" besteht. Der Wert ist so groß, dass das Aufrufen des Vitoconnect Devices im FHEM das Webinterface erstmal für die nächsten paar Minuten lahmlegt. Ich vermute mal, ursächlich kann nur Viessmann das Problem in Ordnung bringen, aber gibt es eventuell eine Möglichkeit, die Anzeige des Readings bereits im Webinterface zu verhindern, bzw. das Reading mit einem vordefinierten Wert zu ersetzen?
Danke!
CQuadrat
Hallo Zusammen,
hat außer mir auch jemand Probleme mit der Verbindung zum Kommunikationsmodul?
Seit heute morgen bekomme ich keine Verbindung mehr; auch nicht mit der Original Viessmann-App. Komischerweise trat der Fehler auf, nachdem meine FritzBox heute Nacht eine neue IP vom Provider zugewiesen bekommen hat. Neustart diverser Geräte hat nichts gebracht.
Auf der Viessmann-Seite kann ich leider auch nichts finden
Danke und Gruß
Christoph
FHEM auf Mini-ITX-Server mit Intel Quad-Core J1900:
+ HM: HM-LAN, HM-USB, HM-MOD-UART mit div. HM-Komponenten
+ RFXtrx: Funkwetterstation Bresser mit ext. Thermometer, Regenmesser und Windmesser
+ TUL (KNX-Anbindung), MQTT, SONOS (div. Gimmicks), OneWire, Hue
plin
Meine ViCare-App hat auch keine Verbindung. Das VitoConnect-Modul blinkt rot (auch nach einem Restart).
FHEM1 (Main) Raspi4 mit CUL, Homematic, SDUINO 433/OOK, zentrale Steuerung
FHEM2 (Keller) x86 mit CUL/hmland, IP-basierte Module
FHEM3 (Erdgeschoss) Raspi2 mit SDUINO 868/GFSK
FHEM4 (Hausanschlussraum), USV und OBIS-Modul
FHEM5 (Docker) mit FHEM2FHEM, InfluxDB
CQuadrat
Danke für den Hinweis. Dann vermute ich den Fehler mal bei Viessmann und warte mal noch ab.
Ich hasse Cloud-Lösungen :-\ Leider ging es bei der Heizung nicht ohne.  >:(
uron
Kann ich auch bestätigen, bin Gott sei Dank nicht der Einzige und warte mal ab!
Mini-PC (FHEM im Container unter Proxmox)  FHEMobile  CUL  FS20-, HM-, Intertechno-, AVM- und Shelly-Aktoren, Vitoconnect 100, Vitocal 200-S, Optolink, FTUI auf iPad, FTUI auf iPhone, Stromzähler von Powerfox, Wechselrichter Growatt MIN 4600 TL-XH, Mini-PC (ioBroker im Container unter Proxmox)
uron
Seit heute, 12:55 Uhr, läuft das Kommunikationsmodul bei mir wieder rund!  :)
andreas13
in der Tat ist das ein Problem, dass nur Viessmann ursächlich lösen kann. Als workaround kannst du Dir mit "inform" und "setreading" etwas basteln, dass das Reading auf einen vordefinierter Wert setzt,
Andreas
Danke!
noch: IT
