[gelöst] Hminfo stürzt ab und lässt FHEM nahezu stillstehen
Begonnen von andies, 27 November 2018, 07:03:04
andies
Weiß jemand, was ich hier machen kann:
2018.11.27 06:40:39 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/98_HMinfo.pm line 225.
2018.11.27 06:40:39 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/98_HMinfo.pm line 225.
2018.11.27 06:40:39 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/98_HMinfo.pm line 228.
2018.11.27 06:40:39 1: PERL WARNING: Use of uninitialized value in split at ./FHEM/98_HMinfo.pm line 228.
2018.11.27 06:40:39 1: ERROR: empty name in readingsBeginUpdate
2018.11.27 06:40:39 1: stacktrace:
2018.11.27 06:40:39 1:     main::readingsBeginUpdate           called by ./FHEM/98_HMinfo.pm (394)
2018.11.27 06:40:39 1:     main::HMinfo_status                 called by ./FHEM/98_HMinfo.pm (1601)
2018.11.27 06:40:39 1:     main::HMinfo_SetFn                  called by ./FHEM/98_HMinfo.pm (413)
2018.11.27 06:40:39 1:     main::HMinfo_autoUpdate             called by fhem.pl (3142)
2018.11.27 06:40:39 1:     main::HandleTimeout                 called by fhem.pl (649)
2018.11.27 06:40:39 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 4605.
2018.11.27 06:40:39 1: readingsUpdate(,C_sumDefined,entities:30,device:9,channel:25,virtual:1) missed to call readingsBeginUpdate first.
2018.11.27 06:40:39 1:     main::readingsBulkUpdate            called by ./FHEM/98_HMinfo.pm (401)
2018.11.27 06:40:39 1: readingsUpdate(,I_actTotal,alive:7,dead:0,unkn:0,off:0) missed to call readingsBeginUpdate first.
2018.11.27 06:40:39 1: readingsUpdate(,CRI__protocol,-) missed to call readingsBeginUpdate first.
2018.11.27 06:40:39 1: readingsUpdate(,ERR__protocol,-) missed to call readingsBeginUpdate first.
2018.11.27 06:40:39 1: readingsUpdate(,W__protocol,Resnd:2) missed to call readingsBeginUpdate first.
2018.11.27 06:40:39 1: readingsUpdate(,ERR__unreachable,0) missed to call readingsBeginUpdate first.
2018.11.27 06:40:39 1: readingsUpdate(,I_autoReadPend,0) missed to call readingsBeginUpdate first.
2018.11.27 06:40:39 1: readingsUpdate(,I_rssiMinLevel,59<:1 60>:4 80>:3 99>:0) missed to call readingsBeginUpdate first.
2018.11.27 06:40:39 1: PERL WARNING: Use of uninitialized value $dev in hash element at fhem.pl line 3471.
2018.11.27 06:40:46 1: Error: >hminfo< has no TYPE, but following keys: >helper<
Das device hminfo hatte ich schon gestern gelöscht.
FHEM 6.3 auf RaspPi4 (Raspbian:  6.6.28+; Perl: v5.36.0)
frank
FHEM: 6.0(SVN) => Pi3(buster)
andies
Danke für die Hilfe - Output ist leer?! Auch bei verschiedener Groß-Kleinschreibung.
frank
andies
Ja, auch update. Ich weiß allerdings nicht mehr, ob die Fehlermeldung vor oder nach dem update kam. Vermutlich davor, oder? Bisher war alles ruhig.
CoolTux
Die Fehlermeldung weißt eher schon in die Richtung das das Device gelöscht würde aber die Informationen dazu weiterhin im Hash %defs erhalten geblieben ist.
Das TuxNet Wiki:
https://www.cooltux.net
frank
wenn das device gelöscht wurde, müssten doch eventulle "reste" nach einem anschliessenden restart verschwunden sein. oder was übersehe ich hier?
wie wurde denn überhaupt gelöscht? etwa auf die "böse" art und weise?
andies
CoolTux
Nach einem Neustart sollte alles weg sein.
Das TuxNet Wiki:
