[GELÖST] Oregon Sensoren lösen ständig ein autocreate aus
Begonnen von Burny4600, 08 Dezember 2018, 19:16:21
Burny4600
Die angelegten Oregon Sensoren verursachen des öfteren ein autocreate obwohl die Sensoren inklusive Filelog und SVG vorhanden sind.
2018.12.06 19:31:15.134 2: autocreate: define FileLog_THGR810_2 FileLog /media/hdd/fhem/log01/autocreate/THGR810_2-%m.log THGR810_2
2018.12.06 19:31:15.172 2: autocreate: define SVG_THGR810_2 SVG FileLog_THGR810_2:temp4hum4:CURRENT
2018.12.06 19:31:16.465 2: autocreate: define FileLog_THGR810_7 FileLog /media/hdd/fhem/log01/autocreate/THGR810_7-%m.log THGR810_7
2018.12.06 19:31:16.501 2: autocreate: define SVG_THGR810_7 SVG FileLog_THGR810_7:temp4hum4:CURRENT
2018.12.06 19:52:24.018 2: autocreate: define FileLog_THWR800_3 FileLog /media/hdd/fhem/log01/autocreate/THWR800_3-%m.log THWR800_3
2018.12.06 19:52:34.425 2: autocreate: define FileLog_WGR800 FileLog /media/hdd/fhem/log01/autocreate/WGR800-%m.log WGR800
2018.12.06 19:52:34.463 2: autocreate: define SVG_WGR800 SVG FileLog_WGR800:wind4windDir4:CURRENT
2018.12.06 19:55:02.518 2: autocreate: define FileLog_THWR800_3 FileLog /media/hdd/fhem/log01/autocreate/THWR800_3-%m.log THWR800_3
Auszug aus dem Monitoring:
2018-12-08 19:51:35.548 TRX_WEATHER THGR810_2 temperature: -3.3
2018-12-08 19:51:35.548 TRX_WEATHER THGR810_2 lx: 1445
2018.12.08 19:51:35.751 2 : autocreate: define FileLog_THGR810_2 FileLog /media/hdd/fhem/log01/autocreate/THGR810_2-%m.log THGR810_2
2018.12.08 19:51:35.792 2 : autocreate: define SVG_THGR810_2 SVG FileLog_THGR810_2:temp4hum4:CURRENT
2018-12-08 19:51:35.942 SVG SVG_THGR810_2 copyGplotFile
2018-12-08 19:51:37.000 Global global UNDEFINED THGR810_2 OREGON THGR810_2
2018-12-08 19:51:37.000 Global global DEFINED FileLog_THGR810_2
2018-12-08 19:51:37.000 Global global DEFINED SVG_THGR810_2
2018-12-08 19:51:37.026 SIGNALduino sduino DMSG u52#FFFFFEBE28497499802D829581
2018-12-08 19:51:37.053 SIGNALduino sduino UNKNOWNCODE u52#FFFFFEBE28497499802D829581
Verwendet wird ein RFXCOM und SIGNALduino Empfänger.
Nur warum erfolgt ein autocreate?
Es passiert zudem nicht bei jedem emfangenen Datenpaket und auch nicht immer bei allen Sensoren im gleichen Abstand.
LG Chris
Devices: APC, Davis, Eastron, FS20, Homematic, IT, MQTT, PV-(DEYE, EPEVER, FRONIUS), Resol-VBUS, SkyWind, TEK603
Sidey
Benennst Du die Sensoren um?
Passiert das vielleicht auch immer durch das gleiche IO Device?
Was genau passiert denn durch das Autocreate. Hast Du dann zwei Devices
Maintainer von: SIGNALduino, SD_WS*, fhem-docker, alexa-fhem-docker, fhempy-docker, WebAuth, fhem-mcp, midea-mqtt, whatsmeow-mqtt
Burny4600
#2
Thema wird unter https://forum.fhem.de/index.php/topic,115128.0.html weiter behandelt.
LG Chris
