Klikaankluit sensors
Begonnen von Guest, 14 Dezember 2012, 15:59:54
Guest
Hi
I can confirm that you shouldn't use AMST606 door/window sensors with the
Rfxtrx module. I thougt it was a different story as the pir sensors. :-(
 I wonder if there is a way to find out if the rfxtrx module has rejected
fhem commands because it detected the swarm of signals from the AMST606
sensor. I can imagine that the rfxtrx modules sends some kind of nack back.
{HT}
Guest
I have both sensors in use....without issues!
A KAKU PIR and a door sensor. Both are working fine, auto detected by means of FHEM icw RFXTRX
R.
Eeg.
Guest
Sure, but the problem is that they generate so much traffic that the rfx
module stops sending messages for a few seconds. So when reacting with a
kaku command on a message of a kaku sensor it might be that this is never
sended.
Just open and close the door a few times after each other and let fhem
switch the light on when the door is opened. You will se the result.
{HT}
Op vrijdag 14 december 2012 17:07:48 UTC+1 schreef Superbert het volgende:
> R.
> Eeg.
Guest
Yes, that's an issue I have seen.
I added a "sleep 4" before sending a command after receiving from some KAKU
actors.
I use the PIR and doorsensor just for detecting "at home", so for those
sensors I don't have much issues.
But I have to admit that there can be quite some traffic going on due these
sensors sending all the time....so this will for sure lead to interrupted
transmissions and missing receptions :-(
I guess that's the price for going "cheap".
Cheers,
Eeg.
Op zaterdag 15 december 2012 22:02:33 UTC+1 schreef dudler het volgende:
> sended.
> {HT}
>> R.
>> Eeg.
