Letsencrypt Zertifikat erneuern
Begonnen von TWART016, 27 Dezember 2018, 20:27:02
TWART016
ich nutze einen Apache Reverse Proxy mit letsencrypt.
Nach einem Jahr muss ich es nun das Zertifikat erneuern. Mit dem Befehl
/opt/letsencrypt/letsencrypt-auto renew
bekomme ich allerdings immer den Fehler:
Attempting to renew cert (domain) from /etc/letsencrypt/renewal/domain.conf produced an unexpected error: Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to the CA that you control your domain. Please add a virtual host for port 80.. Skipping.
All renewal attempts failed. The following certs could not be renewed:
  /etc/letsencrypt/live/domain/fullchain.pem (failure)
In der Datei /etc/apache2/sites-available/domain.conf habe ich unter VirtualHost nur *:443 stehen. Von 80 steht da nichts.
TWART016
amenomade
TWART016
Ich habe nun in der Datei den Eintrag für 80 hinzugefügt.
<VirtualHost *:80>
    ServerName domain
    ProxyPass / http://192,168.178.11/fhem
    ProxyPassReverse / http://192.168.178.11/fhem
</VirtualHost>
Nun kommt der Fehler:
Cert is due for renewal, auto-renewing...
Plugins selected: Authenticator apache, Installer apache
Renewing an existing certificate
Performing the following challenges:
http-01 challenge for domain
Waiting for verification...
Cleaning up challenges
Attempting to renew cert (domain) from /etc/letsencrypt/renewal/domain.conf produced an unexpected error: Failed authorization procedure. domain (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://domain/.well-known/acme-challenge/xne7MmucPiGdaYpXgl0hrcBbTzMfWZiIsWT8bregIUY: "<!DOCTYPE HTML PUBLIC \"-//IETF//DTD HTML 2.0//EN\">\n<html><head>\n<title>404 Not Found</title>\n</head><body>\n<h1>Not Found</h1>\n<p". Skipping.
1 renew failure(s), 0 parse failure(s)
IMPORTANT NOTES:
- The following errors were reported by the server:
   Domain: domain
   Type:   unauthorized
   Detail: Invalid response from
   To fix these errors, please make sure that your domain name was
   entered correctly and the DNS A/AAAA record(s) for that domain
   contain(s) the right IP address.
Icinger
Ich mache immer ein
sudo service apache2 stop
vor dem renew, und danach wieder ein "start".
Somit klappt das renewen problemlos.
Verwende deine Zeit nicht mit Erklärungen. Die Menschen hören (lesen) nur, was sie hören (lesen) wollen. (c) Paulo Coelho
TWART016
Das mache ich auch:
sudo service apache2 stop && /opt/letsencrypt/letsencrypt-auto renew && sudo service apache2 start
