Thermoter hinzufügen
Begonnen von xls, 08 Januar 2019, 21:15:11
xls
Guten Abend,
ich habe einige "alte" Thermometer, die über 433 MHz an eine Zentralstation funken.
Nun kam ich auf die Idee diese auch in mein FHEM zu integrieren. Mein nanoCUL empfängt laut Log Datei folgendes:
2019.01.08 20:47:18 3: CUL433: Unknown code B88A3E98683357C1FF157D30D166AE82FF2BFA60A2CD5C 5, help me!
2019.01.08 20:49:44 3: CUL433: Unknown code B88A3E986830F9C3FF157D30D160F287FF2BFA60A2C1E4 F, help me!
2019.01.08 20:50:57 3: CUL433: Unknown code B88A3E98A833FDC2FF157D305167FA85FF2BFA60A2CEF4 B, help me!
2019.01.08 20:53:23 3: CUL433: Unknown code B88A3E98A83071C0FF157D305161E280FF2BFA60A2C2C4 1, help me!
2019.01.08 20:54:36 3: CUL433: Unknown code B88A3E982833 DC0FF157D3051661A80FF2BFA60A2CC34 0, help me!
2019.01.08 20:57:02 3: CUL433: Unknown code B88A3E982831 5C3FF157D305162 A86FF2BFA60A2C414 C, help me!
2019.01.08 20:58:15 3: CUL433: Unknown code B88A3E98283289C1FF157D3051641283FF2BFA60A2C824 6, help me!
2019.01.08 20:59:28 3: CUL433: Unknown code B88A3E98283081C2FF157D305160 285FF2BFA60A2C0 4 A, help me!
2019.01.08 21:00:41 3: CUL433: Unknown code B88A3E98283081C2FF157D305160 285FF2BFA60A2C0 4 A, help me!
2019.01.08 21:01:54 3: CUL433: Unknown code B88A3E98C83339C3FF157D3091677286FF2BFA6022CFE4 C, help me!
2019.01.08 21:03:07 3: CUL433: Unknown code B88A3E98C83339C3FF157D3091677286FF2BFA6022CFE4 C, help me!
2019.01.08 21:04:20 3: CUL433: Unknown code B88A3E98C83131C0FF157D3091636280FF2BFA6022C7C4 0, help me!
2019.01.08 21:05:33 3: CUL433: Unknown code B88A3E98C83131C0FF157D3091636280FF2BFA6022C7C4 0, help me!
2019.01.08 21:06:46 3: CUL433: Unknown code B88A3E98C832BDC2FF157D3091657A85FF2BFA6022CBF4 A, help me!
2019.01.08 21:07:59 3: CUL433: Unknown code B88A3E98C832BDC2FF157D3091657A85FF2BFA6022CBF4 A, help me!
2019.01.08 21:09:12 3: CUL433: Unknown code B88A3E98C832BDC2FF157D3091657A85FF2BFA6022CBF4 A, help me!
2019.01.08 21:10:25 3: CUL433: Unknown code B88A3E98C832BDC2FF157D3091657A85FF2BFA6022CBF4 A, help me!
2019.01.08 21:11:39 3: CUL433: Unknown code B88A3E98C832BDC2FF157D3091657A85FF2BFA6022CBF4 A, help me!
Der Sensor müsste die Temperatur und Luftfeuchtigkeit übertragen.
Habe ich eine Chance die Sensoren zu integrieren?
Vielen Dank.
Tim
Firmware von dem nanoCUL?
Anmerkungen noch:
- CUL-Fragen gehören in einen anderen Forenbereich (selbst verschieben: unten links)
- die aculfw ist für 433MHz-Geräte besser
- Zwischenzeitlich noch besser ist m.E. die Signalduino-Firmware. Kann dann aber sein, dass du dann das IO für andere Geräte auch ändern müsstest; die meisten (z.B. IT-Funksteckdosen) sollten aber ohne sonstige große Änderungen auch damit funktionieren.
xls
#2
CMDS
ABCeFfGiKLlMNRTtUVWXx
Clients
:FS20:FHT.*:KS300:USF1000:BS:HMS: :CUL_EM:CUL_WS:CUL_FHTTK:CUL_HOERMANN: :ESA2000:CUL_IR:CUL_TX:Revolt:IT:UNIRoll:SOMFY: :STACKABLE_CC:TSSTACKED:STACKABLE:CUL_RFR::CUL_TCM97001:CUL_REDIRECT:
DEF
/dev/serial/by-id/usb-SHK_NANO_CUL_433-if00-port0@38400 0000
DeviceName
FD
13
FHTID
0000
NAME
CUL433
NR
28
PARTIAL
STATE
Initialized
TYPE
CUL
VERSION
V 1.26.05 a-culfw Build: 311 (2018-12-09_19-12-53) nanoCUL433 (F-Band: 433MHz)
initString
X21
auf eine andere Version ändern?
...ist schon die aculfw, der zweite Strich hat sich also erledigt.
Wenn, dann wäre die Signalduino-firmware noch einen Versuch wert. Ist aber "was anderes" (von der Definition her gedacht - zwischen den Firmwares kann man innerhalb der CUL-firmwares hin- und hertauschen ohne die Def anzufassen. Für Signalduino braucht man auch FHEM-seitig ein anderes Modul).
Kannst dich ja mal im Wiki zu Signalduino einlesen und dann ggf. mal testen...
xls
Ich bin langsam am verzweifeln.
Beim flashen von signalduino habe ich wohl meinen bootloader zerstört. Musste mir erstmal einen neuen nano besorgen.
So, signalduino ist geflasht und die Thermometer wurden super per autocreate erfasst. Danke!
Nur gehen leider (fast alle) meiner Fernbedienungen nicht mehr. :(
Habe das IODev entsprechend angepasst.
Die original Fernbedienung der Steckdosen funktioniert. Damit habe ich so billig Fernbedienung von ebay angelernt, also quasi gleicher Befehl. Mit aculfw hat es auch funktioniert, nur signalduino erkenntdie angelernten Fernbedienungen nicht.
Was mache ich falsch?
bootloader kann man reparieren (ggf. mit einem 2. Nano).
Ansonsten: mit Frequenzen und Bandbreiten mal spielen; sehen was üerbhaupt ankommt (raw) usw..
Bitte ggf. nach Lektüre der Optionen mit dem Signalduino den Thread in den passenden Forenbereich verschieben oder einen neuen aufmachen.
