issue with gplot configuration
Begonnen von Guest, 23 Oktober 2012, 15:56:38
Guest
Hi all !
I struggle a bit to plot data from my sensor. The solution is probably easy
but I can't figure it out :).
I have data in a logfile looking like this :
2012-10-19_12:43:05 ftf_sensor temperature: 24.0
I want to plot them. So far I defined the logfile's logtype as
ftf55:Plot,text.
My file ftf55 is pretty similar to temp4.gplot, available by default.
I tried to plot using this script, and I also tried after removing
conditions, but even the basic #FileLog 4::: does not give me any data.
I followed the wiki page<http://www.fhemwiki.de/wiki/Creating_Plots#Plot_Commands> and
tried in telnet  : get FileLog_ftf_sensor - - 2012-10-08 2012-10-23 4:: ,
which gives me a correct output:
2012-10-18_19:52:48 0.0
2012-10-19_13:58:08 21.3
2012-10-19_14:35:51 24.0
#4:::
Unfortunately, I obtain an empty graph when I click on Plot.
It would be great if someone as a clew. Tell me if you need more info.
Thanks in advance.
Best Regards,
Bernard
Guest
Hope I got it right, but there isn't a gplot file like ftf55.gplot
At least there isn't one on my installation. If you haven't createt it,
then there should be an error when trying to plot the graph.
Have you tried temp4.gplot already? Maybe it's worth giving it a try.
BR
Ralf
