Symbol ändern in Apple Home ???
Begonnen von Sky, 31 Januar 2019, 19:34:53
Sky
Bei allen Versuchen kommt im Log:
[2/3/2019, 3:50:58 PM] [FHEM] Garagentor-state value off not handled in values
justme1968
homebridgeMapping CurrentDoorState=state,values=closed:CLOSED;open:OPEN;opening:OPENING;closing:CLOSING
TargetDoorState=state,cmds=OPEN:Auf;CLOSED:Zu,values=Zu:CLOSED;Auf:OPEN
was genau zu deinem mapping passt. dort taucht weder on noch off auf...
Sky
Habe jetzt folgendes probiert :
homebridgeMapping CurrentDoorState=state,values=off:CLOSED;on:OPEN;opening:OPENING;closing:CLOSING
TargetDoorState=state,cmds=on:Auf;off:Zu,values=off:CLOSED;on:OPEN
Im Log sieht das dann so aus :
[2/3/2019, 3:58:19 PM] [FHEM] Garagentor: executing set cmd for TargetDoorState with value 1
[2/3/2019, 3:58:19 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20Garagentor%20undefined%201&XHR
[2/3/2019, 3:58:34 PM] [FHEM] Garagentor: executing set cmd for TargetDoorState with value 0
[2/3/2019, 3:58:34 PM] [FHEM]   executing: http://127.0.0.1:8083/fhem?cmd=set%20Garagentor%20undefined%200&XHR
Mein Akktor bzw. das Garagentor reagiert aber nicht ......
Sky
Bei genauerem lesen des Log ist mir folgendes aufgefallen .
[2/3/2019, 4:13:35 PM] [FHEM] Initializing platform accessory 'Garagentor'...
[2/3/2019, 4:13:35 PM] [FHEM] creating services for Garagentor
[2/3/2019, 4:13:35 PM] [FHEM]   information service for Garagentor
[2/3/2019, 4:13:35 PM] [FHEM]     manufacturer, model and serial number characteristics for Garagentor
[2/3/2019, 4:13:35 PM] [FHEM]     firmware revision characteristic for Garagentor
[2/3/2019, 4:13:35 PM] [FHEM]   GarageDoorOpener service for Garagentor
HAP Warning: Characteristic 00000025-0000-1000-8000-0026BB765291 not in required or optional characteristics for service 00000041-0000-1000-8000-0026BB765291.                                    Adding anyway.
[2/3/2019, 4:13:35 PM] [FHEM]     On characteristic for Garagentor:state
[2/3/2019, 4:13:35 PM] [FHEM]     TargetDoorState characteristic for Garagentor:state
justme1968
versuch es mal so:
homebridgeMapping CurrentDoorState:state,values=off:CLOSED;on:OPEN TargetDoorState:CurrentDoorState,cmds=OPEN:on;CLOSED:off
Sky
#35
Jaaaaaaaaaaa...
Vielen Dank für Deine Mühe , das macht so eine Freude wenn etwas funktioniert !!!!
P.S.: Für jemanden der nicht so viel Wissen hat wie Du ist es manchmal schon Nervenzermürbend .
        Aber man will ja nicht aufgeben !
leachim200
#36
hallo
Danke für die Hilfe auch bei mir hat es dank der dem letzten Code funktioniert.
Es handelt sich bei mir um einen  HM-LC-Bl1PBU-FM mit dem ich mein Garangetor steuere
genericDeviceType: garage
homebridgeMapping: CurrentDoorState:state,values=off:CLOSED;on:OPEN TargetDoorState:CurrentDoorState,cmds=OPEN:on;CLOSED:off
gibt es eine möglichkeit die fahrt nach oben und unten auch noch zu mappen sprich das wird geöffnet und wird geschlossen angezeigt wird?
Logfileauszug
[2019-6-9 12:36:52] [FHEM] Garagentor-state value 99 not handled in values
  2019-06-09 12:36:55 caching: Garagentor-motor: down:83.5
[2019-6-9 12:36:55] [FHEM]     caching: PositionState: 0 (as number; means DECREASING; from 'down:83.5')
  2019-06-09 12:36:55 caching: Garagentor-pct: 83.5
[2019-6-9 12:36:55] [FHEM]     caching: Brightness: 84 (as number; from '83.5')
  2019-06-09 12:36:55 caching: Garagentor-state: 83.5
[2019-6-9 12:36:55] [FHEM] Garagentor-state value 83.5 not handled in values
  2019-06-09 12:37:17 caching: Garagentor-motor: stop:off
[2019-6-9 12:37:17] [FHEM]     caching: PositionState: 2 (as number; means STOPPED; from 'stop:off')
  2019-06-09 12:37:17 caching: Garagentor-pct: 0
[2019-6-9 12:37:17] [FHEM]     caching: Brightness: 0 (as number; from '0')
  2019-06-09 12:37:17 caching: Garagentor-state: off
[2019-6-9 12:37:17] [FHEM]     caching: CurrentDoorState: 1 (as number; means CLOSED; from 'off')
[2019-6-9 12:37:17] [FHEM]     caching: TargetDoorState: 1 (as number; means CLOSED; from 'off')
