HM-SEC-SCo erzeugt periodisch Close-Event
Begonnen von budy, 04 Februar 2019, 06:17:24
budy
ich habe gesetern einen HM-SEC-SCo in Betrieb genommen und mit meiner vccu gepaired. Seit dem habe ich im Log (dbLog) periodische Close-Events, obwohl der Sensor nicht ausgelöst hat. Im log der DB diehst das so aus:
2019-02-04 00:36:38 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 00:36:39 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 00:36:40 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 00:36:42 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 01:30:33 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 01:30:34 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 01:30:35 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 01:30:36 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 01:30:37 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 02:32:16 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 02:32:18 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 02:32:19 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 02:32:21 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 03:25:14 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 03:25:15 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 03:25:17 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 03:25:18 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 04:21:49 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 04:21:51 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 04:21:52 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 04:21:53 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 05:22:34 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 05:22:36 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 05:22:37 Tuerkontakt_Haustuer CUL_HM state: closed state closed
2019-02-04 05:22:38 Tuerkontakt_Haustuer CUL_HM state: closed state closed
Diese Events triggern dann auch ein paar Notifies, welches auf das Close-Event reagieren. Das List des Devices sieht aktuell so aus:
list Tuerkontakt_Haustuer
   .triggerUsed 1
   DEF        613629
   FUUID      5c572f46-f33f-437e-4d3f-9b0ef13373689a6d
   HMLAN1_MSGCNT 128
   HMLAN1_RAWMSG E613629,0000,08070442,FF,FFC1,E8A61061362929A07E06010000
   HMLAN1_RSSI -63
   HMLAN1_TIME 2019-02-04 05:22:38
   IODev      RM_HmUART_EG
   LASTInputDev HMLAN1
   MSGCNT     261
   NAME       Tuerkontakt_Haustuer
   NOTIFYDEV  global
   NR         5041
   RM_HmUART_EG_MSGCNT 133
   RM_HmUART_EG_RAWMSG 05010145E8A61061362929A07E06010000
   RM_HmUART_EG_RSSI -69
   RM_HmUART_EG_TIME 2019-02-04 05:22:38
   STATE      closed
   TYPE       CUL_HM
   lastMsg    No:E8 - t:10 s:613629 d:29A07E 06010000
   peerList   Heizung_Flur_EG_WindowRec,
   protCmdDel 5
   protEvt_AESCom-ok 7 last_at:2019-02-03 19:34:35
   protLastRcv 2019-02-04 05:22:38
   protNack   3 last_at:2019-02-03 19:23:17
   protRcv    129 last_at:2019-02-04 05:22:38
   protRcvB   19 last_at:2019-02-03 19:39:38
   protResnd  1 last_at:2019-02-03 19:13:42
   protSnd    113 last_at:2019-02-04 05:22:38
   protState  CMDs_done
   rssi_at_HMLAN1 cnt:128 min:-77 max:-44 avg:-56.69 lst:-63
   rssi_at_RM_HmUART_EG cnt:126 min:-79 max:-45 avg:-66.19 lst:-69
   .attraggr:
   .attrminint:
   Helper:
     DBLOG:
       Activity:
         sensorsDblog:
           TIME       1549218872.34254
           VALUE      alive
       D-firmware:
         sensorsDblog:
           VALUE      1.0
       D-serialNr:
         sensorsDblog:
           VALUE      OEQ1555807
       R-Heizung_Flur_EG_WindowRec-expectAES:
         sensorsDblog:
           TIME       1549218876.88043
           VALUE      off
       R-Heizung_Flur_EG_WindowRec-peerNeedsBurst:
         sensorsDblog:
           VALUE      on
       R-eventDlyTime:
         sensorsDblog:
           TIME       1549218876.0245
           VALUE      0 s
       R-sign:
         sensorsDblog:
           VALUE      on
       aesCommToDev:
         sensorsDblog:
           TIME       1549218875.34115
           VALUE      ok
       aesKeyNbr:
         sensorsDblog:
           TIME       1549218875.31551
           VALUE      00
       alive:
         sensorsDblog:
           TIME       1549254158.62066
           VALUE      yes
       battery:
         sensorsDblog:
           VALUE      ok
       contact:
         sensorsDblog:
           VALUE      closed (to vccu)
       powerOn:
         sensorsDblog:
           TIME       1549218164.53228
           VALUE      2019-02-03 19:22:44
       sabotageError:
         sensorsDblog:
           VALUE      off
       state:
         sensorsDblog:
           VALUE      closed
       trigger_cnt:
         sensorsDblog:
           TIME       1549219179.37624
           VALUE      32
     2019-02-03 19:34:32   .D-devInfo      810101
     2019-02-03 19:34:32   .D-stc          80
     2019-02-03 19:34:36   .R-msgScPosA    open
     2019-02-03 19:34:36   .R-msgScPosB    closed
     2019-02-03 19:13:43   .R-transmDevTryMax 6
     2019-02-03 19:34:36   .R-transmitTryMax 6
     2019-02-03 19:34:36   .peerListRDate  2019-02-03 19:34:36
     2019-02-04 05:22:38   .protLastRcv    2019-02-04 05:22:38
     2019-02-03 19:34:32   Activity        alive
     2019-02-03 19:34:35   CommandAccepted yes
     2019-02-03 19:34:32   D-firmware      1.0
     2019-02-03 19:34:32   D-serialNr      OEQ1555807
     2019-02-03 19:34:35   PairedTo        0x29A07E
     2019-02-03 19:34:36   R-Heizung_Flur_EG_WindowRec-expectAES off
     2019-02-03 19:34:36   R-Heizung_Flur_EG_WindowRec-peerNeedsBurst on
     2019-02-03 19:13:43   R-cyclicInfoMsg on
     2019-02-03 19:34:36   R-eventDlyTime  0 s
     2019-02-03 19:13:43   R-pairCentral   0x29A07E
     2019-02-03 19:13:43   R-sabotageMsg   on
     2019-02-03 19:34:36   R-sign          on
     2019-02-03 19:34:35   RegL_00.         00:00 02:01 09:01 0A:29 0B:A0 0C:7E 10:01 14:06
     2019-02-03 19:34:36   RegL_01.         00:00 08:01 20:9C 21:00 30:06
     2019-02-03 19:34:36   RegL_04.Heizung_Flur_EG_WindowRec  00:00 01:01
     2019-02-03 19:34:35   aesCommToDev    ok
     2019-02-03 19:34:35   aesKeyNbr       00
     2019-02-04 05:22:38   alive           yes
     2019-02-04 05:22:38   battery         ok
     2019-02-04 05:22:38   contact         closed (to vccu)
     2019-02-03 19:34:36   peerList        Heizung_Flur_EG_WindowRec,
     2019-02-03 19:22:44   powerOn         2019-02-03 19:22:44
     2019-02-04 05:22:38   recentStateType info
     2019-02-04 05:22:38   sabotageError   off
     2019-02-04 05:22:38   state           closed
     2019-02-03 19:39:39   trigger_cnt     32
   helper:
     HM_CMDNR   232
     PONtest    0
     cSnd       0129A07E6136290103,0129A07E61362901042E7B4E0304
     mId        00C7
     peerIDsRaw ,2E7B4E03,00000000
     regLst     ,0,1,4p
     rxType     28
     supp_Pair_Rep 0
     ack:
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       newCh      1
       newChn     +613629,00,02,00
       nextSend   1549254158.82657
       prefIO
       rxt        2
       vccu
       p:
         613629
         00
         02
         00
     mRssi:
       mNo        E8
       io:
         HMLAN1:
           -63
           -63
         RM_HmUART_EG:
           -65
           -65
     prt:
       bErr       0
       sProc      0
       sleeping   0
       rspWait:
     q:
       qReqConf
       qReqStat
     regCollect:
     role:
       chn        1
       dev        1
     rpt:
       IO         RM_HmUART_EG
       flg        A
       ts         1549254158.53141
       ack:
         HASH(0x5569940c0920)
         E8800229A07E61362900
     rssi:
       at_HMLAN1:
         avg        -56.6953125
         cnt        128
         lst        -63
         max        -44
         min        -77
       at_RM_HmUART_EG:
         avg        -66.1904761904762
         cnt        126
         lst        -69
         max        -45
         min        -79
     shadowReg:
     tmpl:
   IODev      RM_HmUART_EG
   IOgrp      vccu:RM_HmUART_EG
   actCycle   002:50
   actStatus  alive
   alias      Haustür
   autoReadReg 4_reqStatus
   devStateIcon closed:fts_door@blue open:fts_door_open@red
   expert     2_raw
   firmware   1.0
   group      Sensoren
   model      HM-SEC-SCo
   peerIDs    00000000,2E7B4E03,
   room       Flur EG
   serialNr   OEQ1555807
   subType    threeStateSensor
Hat jemand eine Idee, was das sein könnte?
budy
Debian stretch, FHEM 5.9.
HM-CC-RT-DN, HM-ES-PMSw1-Pl, HM-LC-Dim1TPBU-FM, HMUARTLGW, HMLAN, HM-SEC-KEY, HM-SEC-RHS, HM-SEC-SC-2, HM-SEC-SCo, HM-SEC-SD-2, HM-OU-CFM-TW, div. HUEs, Wifilight, Ring Video Pro
ehrlich gesagt sehen die Events komisch aus, zweimal state closed hintereinander habe ich noch nicht gesehen.
Solange Du event-on-change-reading nicht gesetzt hast, ist es normal, dass immer mal (aber nicht jede Minute) ein Feuer an Events kommt. Aber ein solcher Event ist bei mir nicht dabei!
Da hast Du irgendwas anderes gemacht. :o
budy
Moin Otto,
stimmt... ich hatte event-on-change-reading noch nicht gesetzt...
Danke,
budy
