httpmod.template: bugs, Fragen, Anregungen
Begonnen von Beta-User, 21 Februar 2019, 12:04:17
DeeSPe
Hab mir jetzt mal den MQTT Traffic am MQTT2_SERVER angesehen beim Neustart von z2m und dort sehe ich überhaupt nichts vom Topic "bridge/info".
Meine aktuelle DEF:
defmod MQTT2_zigbee_bridge MQTT2_DEVICE zigbee_bridge
attr MQTT2_zigbee_bridge DbLogExclude .+
attr MQTT2_zigbee_bridge IODev m2s
attr MQTT2_zigbee_bridge autocreate 0
attr MQTT2_zigbee_bridge bridgeRegexp zigbee2mqtt/((?!bridge)[A-Za-z0-9._]+)/?.*:.* "zigbee_$1"
attr MQTT2_zigbee_bridge comment To check for new updates of the deamon software, you might want to use a separate HTTPMOD device. See HTTPMOD template zigbee2mqtt_daemon_updates for further details.
attr MQTT2_zigbee_bridge devicetopic zigbee2mqtt
attr MQTT2_zigbee_bridge event-on-change-reading state
attr MQTT2_zigbee_bridge getList networkmap_raw:noArg raw $DEVICETOPIC/bridge/request/networkmap raw\
networkmap_graphviz:noArg graphviz $DEVICETOPIC/bridge/request/networkmap graphviz
attr MQTT2_zigbee_bridge group Bridges
attr MQTT2_zigbee_bridge icon mqtt_bridge_1
attr MQTT2_zigbee_bridge model zigbee2mqtt_bridge
attr MQTT2_zigbee_bridge readingList $DEVICETOPIC/bridge/state:.* { json2nameValue($EVENT) }\
$DEVICETOPIC/bridge/config/devices:.* {}\
$DEVICETOPIC/bridge/config/log_level:.* log_level\
$DEVICETOPIC/bridge/config/permit_join:.* permit_join\
$DEVICETOPIC/bridge/config/rename:.* { json2nameValue($EVENT, 'rename_') }\
$DEVICETOPIC/bridge/config:.* { json2nameValue($EVENT) }\
$DEVICETOPIC/bridge/log:.* log\
$DEVICETOPIC/bridge/logging:.* {}\
$DEVICETOPIC/bridge/response/networkmap:.* { my $type = $EVENT =~ /.*,"type":"(raw|graphviz)",.*/ ? $1 : 'networkmap';; $EVENT =~ /{"data":\{.*"value":"?(.*[^"])"?\},"status":"ok"\}/ ? { $type=>$1 } : {} }\
$DEVICETOPIC/bridge/event:.* {}\
$DEVICETOPIC/bridge/extensions:.* {}\
$DEVICETOPIC/bridge/response/permit_join:.* { json2nameValue($EVENT) }\
$DEVICETOPIC/bridge/info:.* { json2nameValue($EVENT) }\
$DEVICETOPIC/bridge/health:.* {}
attr MQTT2_zigbee_bridge room Module->MQTT2_DEVICE,Technik
attr MQTT2_zigbee_bridge setList log_level:debug,info,warn,error $DEVICETOPIC/bridge/config/log_level $EVTPART1\
permit_join:true,false $DEVICETOPIC/bridge/request/permit_join $EVTPART1\
remove:textField $DEVICETOPIC/bridge/config/remove $EVTPART1\
ota_update:textField $DEVICETOPIC/bridge/ota_update/update $EVTPART1\
ota_update_check:textField $DEVICETOPIC/bridge/ota_update/check $EVTPART1\
y_device_setting:textField $DEVICETOPIC/$EVTPART1/set {"$EVTPART2": "$EVTPART3"}\
x_bind:textField $DEVICETOPIC/bridge/bind/$EVTPART1 $EVTPART2\
x_bind_unbind:textField $DEVICETOPIC/bridge/unbind/$EVTPART1 $EVTPART2\
x_device_options:textField $DEVICETOPIC/bridge/config/device_options {"friendly_name":"$EVTPART1","options": {"$EVTPART2": "$EVTPART3"}}\
x_group_add_to:textField $DEVICETOPIC/bridge/group/$EVTPART1/add $EVTPART2\
x_group_rm_from:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove $EVTPART2\
x_group_rm_from_all:textField $DEVICETOPIC/bridge/group/$EVTPART1/remove_all $EVTPART2\
x_group_add_group:textField $DEVICETOPIC/bridge/config/add_group $EVTPART1\
x_group_rm_group:textField $DEVICETOPIC/bridge/config/remove_group $EVTPART1\
z_elapsed:textField $DEVICETOPIC/bridge/config/elapsed $EVTPART1\
z_last_seen:disable,ISO_8601,epoch,ISO_8601_local $DEVICETOPIC/bridge/config/last_seen $EVTPART1\
z_ban:textField $DEVICETOPIC/bridge/config/ban $EVTPART1\
z_rename:textField $DEVICETOPIC/bridge/config/rename  {"old":"$EVTPART1","new":"$EVTPART2"}\
z_reset_CC:noArg $DEVICETOPIC/bridge/config/reset
attr MQTT2_zigbee_bridge verbose 2
Hab mal bei Github einen Issue eröffnet.
Allerdings ist das dort beschriebene Problem wohl eher auf den MQTT-Explorer zu schieben. Mit etwas suchen kam heraus dass dieser wohl auf 20k große Mitteilungen beschränkt ist.
Dan
