SIGNALduino - Seltsames nach Update in endloser Schleife.
Begonnen von Ralph, 26 Februar 2019, 13:53:53
Ralph
Moin, habe soeben dieses Update gemacht:
2019.02.26 13:25:58 1: New entries in the CHANGED file:
2019.02.26 13:25:58 1:  - changed: 74_Unifi: removed deprecated UnifiSwitch-functions!
2019.02.26 13:25:58 1:  - bugfix:  74_UnififSwitch: fixed poe restart
2019.02.26 13:25:58 1:  - feature: 57_Calendar.pm: new features and attributes
2019.02.26 13:25:58 1:                             german commandref added
2019.02.26 13:25:58 1:  - bugfix: 00_SIGNALduino: Load protocolHash from web if file  is
2019.02.26 13:25:58 1:                            missing on fs
2019.02.26 13:25:58 1:  - bugfix:  49_SSCam: some warnings, Forum:#97706
2019.02.26 13:25:58 1:  - bugfix:  88_HMCCU: Fixed minor bugs.
2019.02.26 13:25:58 1:  - feature: 00_SIGNALduino:
2019.02.26 13:25:58 1:                  new webmenu "Display protocollist".
2019.02.26 13:25:58 1:                  Serval new protocols added.
2019.02.26 13:25:58 1:                  New Oregon V3 sensors suppored.
2019.02.26 13:25:58 1:                  Firmware for avr boards can be downloaded and flashed.
2019.02.26 13:25:58 1:                  on demand from gitghub releases.
2019.02.26 13:25:58 1:                  supports dupTimeout on same iodev
2019.02.26 13:25:58 1:     change: 00_SIGNALduino: Attribute hardware does not longer support nano
2019.02.26 13:25:58 1:                             select nano328 instead
2019.02.26 13:25:58 1:   - feature: 14_SD_RSL: Updated implementation for "all" button on devices
2019.02.26 13:25:58 1:   - feature: 14_SD_WS: support sensors E0001PA,S522,TX-EZ6,other
2019.02.26 13:25:58 1:                       reading sendmode humidityTrend, temperatureTrend,
2019.02.26 13:25:58 1:                       windspeed, batteryState added
2019.02.26 13:25:58 1:                       attr max-deviation-temp and -hum added
2019.02.26 13:25:58 1:   - changed: 14_SD_WS07: attr correction-xxx to offset-xxx renamed!
2019.02.26 13:25:58 1:   - feature: 14_SD_WS07: new negation-batt attribute
2019.02.26 13:25:58 1:                          Temp only sensors supported
2019.02.26 13:25:58 1:                          support for max deviation attribute
2019.02.26 13:25:58 1: ... rest of lines skipped.
Nun finde ich im Logbuch (reverse look) nun dauernd:
2019.02.26 16:02:21 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 15:59:30 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:51:15 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:48:24 2: autocreate: define SVG_SD_WS07_TH_1 SVG FileLog_SD_WS07_TH_1:temp4hum4:CURRENT
2019.02.26 13:48:24 2: autocreate: define FileLog_SD_WS07_TH_1 FileLog ./log/SD_WS07_TH_1-%Y.log SD_WS07_TH_1
2019.02.26 13:48:24 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:47:27 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:43:39 2: autocreate: define SVG_SD_WS07_TH_1 SVG FileLog_SD_WS07_TH_1:temp4hum4:CURRENT
2019.02.26 13:43:39 2: autocreate: define FileLog_SD_WS07_TH_1 FileLog ./log/SD_WS07_TH_1-%Y.log SD_WS07_TH_1
2019.02.26 13:43:39 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:41:45 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:40:21 2: AttrTemplates: got 63 entries
2019.02.26 13:39:51 2: autocreate: define SVG_SD_WS07_TH_1 SVG FileLog_SD_WS07_TH_1:temp4hum4:CURRENT
2019.02.26 13:39:51 2: autocreate: define FileLog_SD_WS07_TH_1 FileLog ./log/SD_WS07_TH_1-%Y.log SD_WS07_TH_1
2019.02.26 13:39:51 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:37:57 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:34:09 2: autocreate: define SVG_SD_WS07_TH_1 SVG FileLog_SD_WS07_TH_1:temp4hum4:CURRENT
2019.02.26 13:34:09 2: autocreate: define FileLog_SD_WS07_TH_1 FileLog ./log/SD_WS07_TH_1-%Y.log SD_WS07_TH_1
2019.02.26 13:34:09 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:33:12 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:32:15 2: autocreate: define SVG_SD_WS07_TH_1 SVG FileLog_SD_WS07_TH_1:temp4hum4:CURRENT
2019.02.26 13:32:15 2: autocreate: define FileLog_SD_WS07_TH_1 FileLog ./log/SD_WS07_TH_1-%Y.log SD_WS07_TH_1
2019.02.26 13:32:15 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 13:29:24 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
Lese, aber verstehe die Update-Meldungen des obigen LOGs nicht. Was soll ich tun ?
Suche bitte für doofen User Kochrezept für Lösung des Problems.
FHEM auf RaspberryPi3 mit Geekworm USV und SignalDUINO 433MHz und HM-MOD-RPI-PCB mit 3 HM-Sec-SD-2, 5 FHT, 2 RM 100-2 Uni S, 2 HMS100, 6 CUL_WS, 6 CUL_FHTTK, 11 FS20 und 7 FS20V Spannungsüberwachungen
Sidey
Es wurde ein neuer Sensor SD_WS07_TH angelegt.
Was ist mit dem SD_WS_51_TH_1. Wird der nicht mehr aktualisiert?
Ein List von deiner SIGNALduino Definition könnte hier helfen.
Grüße Sidey
Gesendet von meinem Moto Z (2) mit Tapatalk
Maintainer von: SIGNALduino, SD_WS*, fhem-docker, alexa-fhem-docker, fhempy-docker, WebAuth, fhem-mcp, midea-mqtt, whatsmeow-mqtt
Ralph
#2
ZitatEs wurde ein neuer Sensor SD_WS07_TH angelegt.
Nee, das Problem ist ja, dass er eben denkt, er sei genau nicht angelegt wird. Sonst würde er ja nicht dauernd nölen.
ZitatWas ist mit dem SD_WS_51_TH_1. Wird der nicht mehr aktualisiert?
Doch, der geht jetzt wieder, er wurde nur 4,5 Stunden nicht erkannt.
list CUL_433
   Clients    :IT:CUL_TCM97001:SD_RSL:OREGON:CUL_TX:SD_AS:Hideki:SD_WS07:SD_WS09: :SD_WS:RFXX10REC:Dooya:SOMFY:SD_BELL:SD_UT:SD_WS_Maverick:FLAMINGO:CUL_WS:Revolt: :FS10:CUL_FHTTK:Siro:FHT:FS20:CUL_EM:Fernotron:SIGNALduino_un:
   DEF        /dev/serial/by-id/usb-Unknown_radino_CC1101-if00@57600
   DMSG       P7#0E80A5F48
   DevState   initialized
   DeviceName /dev/serial/by-id/usb-Unknown_radino_CC1101-if00@57600
   FD         54
   FUUID      5c45bf0e-f33f-a76b-8b41-239805671a1f9029
   IDsNoDispatch 2,72.1,82
   LASTDMSG   P7#0E80A5F48
   MSGCNT     116
   NAME       CUL_433
   NR         512
   PARTIAL
   RAWMSG     MS;P1=516;P2=-1041;P3=-1948;P7=-3868;D=1712121212131313121312121212121212131213121213121313131313121312121312121216;CP=1;SP=7;R=251;
   RSSI       -76.5
   STATE      opened
   TIME       1551193170
   TYPE       SIGNALduino
   sendworking 0
   unknownmessages
   version    V 3.3.1-dev SIGNALduino cc1101 (433Mhz )- compiled at Mar 10 2017 23:27:29
   versionmodul v3.3.3
   DoubleMsgIDs:
   MatchList:
     10:SD_WS07 ^P7#[A-Fa-f0-9]{6}F[A-Fa-f0-9]{2}(#R[A-F0-9][A-F0-9]){0,1}$
     11:SD_WS09 ^P9#F[A-Fa-f0-9]+
     12:SD_WS   ^W\d+x{0,1}#.*
     13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
     14:Dooya   ^P16#[A-Fa-f0-9]+
     15:SOMFY   ^Ys[0-9A-F]+
     16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
     17:SD_UT   ^P(?:14|29|30|34|46|69|76|81|83|86|90|91|91.1|92)#.*
     18:FLAMINGO ^P13\.?1?#[A-Fa-f0-9]+
     19:CUL_WS  ^K[A-Fa-f0-9]{5,}
     1:IT       ^i......
     20:Revolt  ^r[A-Fa-f0-9]{22}
     21:FS10    ^P61#[A-F0-9]+
     22:Siro    ^P72#[A-Fa-f0-9]+
     23:FHT     ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     24:FS20    ^81..(04|0c)..0101a001
     25:CUL_EM  ^E0.................
     26:Fernotron ^P82#.*
     27:SD_BELL ^P(?:15|32|41|42|57|79)#.*
     2:CUL_TCM97001 ^s[A-Fa-f0-9]+
     3:SD_RSL   ^P1#[A-Fa-f0-9]{8}
     4:OREGON   ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
     5:CUL_TX   ^TX..........
     6:SD_AS    ^P2#[A-Fa-f0-9]{7,8}
     7:Hideki   ^P12#75[A-F0-9]+
     9:CUL_FHTTK ^T[A-F0-9]{8}
     X:SIGNALduino_un ^[u]\d+#.*
   QUEUE:
     2019-02-18 22:36:27   ping            OK
     2019-02-26 13:29:01   state           opened
     2019-02-26 13:29:01   version         V 3.3.1-dev SIGNALduino cc1101 (433Mhz )- compiled at Mar 10 2017 23:27:29
   keepalive:
     ok         0
     retry      0
   mcIdList:
     10
     11
     12
     18
     43
     47
     52
     57
     58
   msIdList:
     0
     0.1
     0.2
     0.3
     0.4
     1
     3
     3.1
     4
     6
     7
     13
     13.2
     14
     15
     17
     23
     25
     33
     35
     41
     51
     55
     65
     90
     91.1
   muIdList:
     8
     9
     13.1
     16
     17.1
     19
     21
     22
     24
     26
     27
     28
     29
     30
     31
     32
     34
     36
     37
     38
     39
     40
     42
     44
     44.1
     45
     46
     48
     49
     50
     56
     59
     60
     61
     62
     64
     66
     67
     69
     70
     71
     72
     74
     76
     79
     80
     81
     83
     84
     85
     86
     89
     91
     92
   comment    set CUL_433 flash https://github.com/RFD-FHEM/SIGNALDuino/releases/download/3.3.1-RC4/SIGNALDuino_radinocc1101.hex
Norm /dev/serial/by-id/usb-Unknown_radino_CC1101-if00
Boot                   usb-In-Circuit_radino_CC1101-if00
   flashCommand avrdude -c arduino -b [BAUDRATE] -P [PORT] -p atmega328p -vv -U flash:w:./SIGNALDuino_radinocc1101.hex 2>[LOGFILE]
   hardware   nanoCC1101
   room       Unsorted
   verbose    3
Nachtrag:
Ich habe jetzt mal vor lauter Verzweiflung das autocreate disabled. Trotzdem nervt es weiter herum:2019.02.26 17:00:18 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:59:21 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:58:24 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:57:27 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:55:33 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:54:36 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:53:39 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:52:42 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:50:48 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:49:51 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:47:57 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:47:00 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:42:15 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:41:18 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:40:21 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
2019.02.26 16:36:33 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code 1
aber so ein dings ist doch angelegt:Internals:
   CFGFN
   CODE       SD_WS07_TH
   DEF        SD_WS07_TH
   FUUID      5c755757-f33f-a76b-45c8-32a3836d6adc412d
   NAME       SD_WS07_TH
   NR         1101
   STATE      Defined
   TYPE       SD_WS07
   bitMSG
   lastMSG
   ignore     1
   room       Unsorted
jetzt verstehe ich gar nix mehr.
Ralf9
Durch einen Patch vom SD_WS07 Modul am 04.07.18 hat sich ein Fehler eingeschlichen, dies ist anscheinend seither noch niemand aufgefallen.
siehe auch hier:
https://forum.fhem.de/index.php/topic,97704.0.html
Bis es eine neue Version gibt, kannst Du meine Version in der Anlage verwenden.
Nach dem kopieren ins FHEM-Verzeichnis ist ein neustart oder der folgende Befehl notwendig:
reload 14_SD_WS07
Gruß Ralf
hjgode
Danke, Ralf
hat mir nach dem offiziellen Update vom FHEM geholfen.
Warum wird sowas nicht in 'release' Versionen eingepflegt?
Nochmals Danke
Josef
Debian SID mit aktuellem FHEM, nanoCUL 866, JeeLink EC3000, fhemduino, SIGNALduino,
3 x TFA TH Sensor, 1 x TFA TH Arduino Sender, 3 x EC3000, 4 x Elro Schaltsteckdosen, ESA2000
offline: Wibo Funkthermostat, 2 x ELV Funkthermostat FHT80, 2 FS20 ST4 Funksteckdose
Sidey
Zitat von: hjgode am 05 März 2019, 18:45:39
Danke, Ralf
Nochmals Danke
Josef
Hi hjgode,
Wir sind noch dabei das Problem und auch ein Folgeproblem zu beheben.
Sollte nicht mehr lange dauern.
Grüße Sidey
Sidey
Der Fix ist eigentlich fertig. Es hat ihn nur leider noch niemand mit echten Sensoren verifiziert :)
Es wäre top, wenn jemand mit dem betreffenden Sensor verifizieren könnte, dass wir auch kein neues Problem haben.
1. ganz normales Update ausführen
2. Die gepatchte Version des SD_WS07 Modules gibt es über update all https://raw.githubusercontent.com/RFD-FHEM/RFFHEM/master/controls_signalduino.txt
Wenn ich hier ein positives Feedback sehe, dann aktualisiere ich die Version im SVN.
Grüße Sidey
buennerbernd
Ich habe dieses Update aus dem Git gemacht und hatte zuvor einen Update-Stand von Weihnachten.
Es geht alles, außer das battery-Reading, was wohl Absicht war.
Vor dem Update:
   CHANGED
   CODE       SD_WS07_T_3
   DEF        SD_WS07_T_3
   FUUID      5c59eefd-f33f-9a9b-54fe-8e5c9486abaaef3c
   LASTInputDev sduino
   MSGCNT     5079
   NAME       SD_WS07_T_3
   NR         118
   STATE      T: 19.6
   TYPE       SD_WS07
   bitMSG     01110010 1 010 000011000100 1111 00000000
   lastMSG    72A0C4F00
   lastReceive 1552048084.38779
   sduino_DMSG P7#72A0C4F00
   sduino_MSGCNT 5079
   sduino_RAWMSG MS;P2=478;P3=-1011;P4=-1945;P5=-4022;D=25232424242323242324232423232323232424232323242323242424242323232323232323;CP=2;SP=5;R=0;
   sduino_RSSI -74
   sduino_TIME 2019-03-08 13:28:04
     2019-03-08 13:28:04   battery         ok
     2019-03-08 13:28:04   batteryState    ok
     2019-03-08 13:28:04   channel         3
     2019-03-08 13:28:04   state           T: 19.6
     2019-03-08 13:28:04   temperature     19.6
   alias      Thermometer Arbeitszimmer
   event-min-interval .*:300
   event-on-change-reading .*
   group      Sensor
   icon       temp_temperature
   room       Dachboden
Nach dem Update:
   CHANGED
   CODE       SD_WS07_T_3
   DEF        SD_WS07_T_3
   LASTInputDev sduino
   MSGCNT     3
   NAME       SD_WS07_T_3
   NR         118
   STATE      T: 19.6
   TYPE       SD_WS07
   bitMSG     01110010 1010 000011000100 1111 00000000
   lastMSG    72A0C4F00
   lastReceive 1552048716.82536
   sduino_MSGCNT 3
   sduino_RAWMSG MS;P2=-2046;P3=490;P4=-970;P5=-4018;D=35343232323434323432343234343434343232343434323434323232323434343434343434;CP=3;SP=5;R=252;
   sduino_RSSI -76
   sduino_TIME 2019-03-08 13:38:36
   OLDREADINGS:
     2019-03-08 13:38:36   batteryState    ok
     2019-03-08 13:38:36   channel         3
     2019-03-08 13:38:36   state           T: 19.6
     2019-03-08 13:38:36   temperature     19.6
   group      Sensor
   room       Dachboden
Also von mir: grünes Licht!
Gruß, Stefan.
Modulentwickler von KLF200 und KLF200Node
Ralph
Zwischenmeldung: habe oben gesagtes getan, muss noch abwarten, ob wieder seltsames kommt. Bitte Geduld.
hdad
Nach update der Sinaldino version 3.3.3 heute Morgen habe ich auch Probleme mit einem SD_WS07_TH Device.
Der Sensor ist in einem Zimmer sendet regelmäßig Temperatur und Humidity.Wobei man der Luftfeuchtigkeit
nicht trauen kann.
   CFGFN
   CODE       481
   DEF        481
   FUUID      5c81f44d-f33f-b62b-0a98-b150d75569f444d3
   LASTInputDev SIGNALDuino
   MSGCNT     621
   NAME       SD_WS07_TH_481
   NR         57
   SIGNALDuino_DMSG P7#48809EF09
   SIGNALDuino_MSGCNT 621
   SIGNALDuino_RAWMSG MS;P1=502;P2=-1938;P3=-959;P4=-465;P5=-3888;D=1513121313121313131213131313131313121313121212121312121212131313131213131214;CP=1;SP=5;R=237;O;s=40;m0;
   SIGNALDuino_RSSI -83.5
   SIGNALDuino_TIME 2019-03-08 20:35:23
   STATE      T: 15.8 H: 9
   TYPE       SD_WS07
   bitMSG     01001000 1000 000010011110 1111 00001001
   lastMSG    48809EF09
   lastReceive 1552073723
     2019-03-08 20:35:23   battery         ok
     2019-03-08 20:35:23   batteryState    ok
     2019-03-08 20:35:23   channel         1
     2019-03-08 20:35:23   humidity        9
     2019-03-08 20:35:23   model           TH
     2019-03-08 20:35:23   state           T: 15.8 H: 9
     2019-03-08 20:35:23   temperature     15.8
   room       SD_WS07
   userattr   max-deviation-hum:1,2,3,4,5,6,7,8,9,10,15,20,25,30,35,40,45,50 max-deviation-temp:1,2,3,4,5,6,7,8,9,10,15,20,25,30,35,40,45,50 offset-hum:slider,-50,1.0,50 offset-temp:slider,-25,1.0,25
Im Logfile habe ich im Minutentakt folgenden Eintrag:
2019.03.08 19:38:23 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:39:20 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:40:17 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:41:14 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:42:11 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:43:08 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:44:05 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:45:02 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:45:59 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
2019.03.08 19:46:56 3: SIGNALDuino: SD_WS07_TH_481 ERROR - Humidity unknown (253)
Sinaldino läuft auf einem Raspi2 welches nichts anderes zutun hat als Temperaturen zu empfangen
und sie über MQTT bereit zu stellen.Mich stören nur die Massen an Logeinträgen.
Gibt es eine Möglichkeit diese abzustellen.
Gruß Holger
FHEM auf IntelNuc; TabletUI; MAX Heizung ; div HM-Actoren ;Z-Wave; YAMAHA Musiccast WX-030 ,YSP-1600
Sidey
Zitat von: hdad am 08 März 2019, 20:39:56
Kannst Du bitte den beschriebenen Fix ausprobieren:
https://forum.fhem.de/index.php/topic,97910.msg915692.html#msg915692
Ralph
#11
Mein Ergebnis ist eher un-nett:
   CFGFN
   CHANGED
   CODE       SD_WS07_TH_1
   CUL_433_DMSG P7#0E8064F16
   CUL_433_MSGCNT 147
   CUL_433_RAWMSG MS;P0=-960;P1=509;P2=-1941;P4=-3913;D=1410101010121212101210101010101010101212101012101012121212101010121012121013;CP=1;SP=4;R=2;O;
   CUL_433_RSSI -73
   CUL_433_TIME 2019-03-08 23:16:33
   DEF        SD_WS07_TH_1
   FUUID      5c829207-f33f-a76b-0f97-a8de0e4f0025acd1
   LASTInputDev CUL_433
   MSGCNT     147
   NAME       SD_WS07_TH_1
   NR         661
   STATE      T: 10 H: 22
   TYPE       SD_WS07
   bitMSG     00001110 1000 000001100100 1111 00010110
   lastMSG    0E8064F16
   lastReceive 1552083393
     2019-03-08 23:16:33   batteryState    ok
     2019-03-08 23:16:33   channel         1
     2019-03-08 23:16:33   humidity        22
     2019-03-08 23:16:33   state           T: 10 H: 22
     2019-03-08 23:16:33   temperature     10
   room       SD_WS07
   userattr   max-deviation-hum:1,2,3,4,5,6,7,8,9,10,15,20,25,30,35,40,45,50 offset-hum
   CFGFN
   DEF        ./log/SD_WS07_TH_1-%Y.log SD_WS07_TH_1
   FD         73
   FUUID      5c829207-f33f-a76b-a735-b746a773432431fa
   NAME       FileLog_SD_WS07_TH_1
   NOTIFYDEV  SD_WS07_TH_1
   NR         662
   NTFY_ORDER 50-FileLog_SD_WS07_TH_1
   REGEXP     SD_WS07_TH_1
   STATE      active
   TYPE       FileLog
   currentlogfile ./log/SD_WS07_TH_1-2019.log
   logfile    ./log/SD_WS07_TH_1-%Y.log
     2019-03-08 23:13:42   linesInTheFile  202
   logtype    temp4hum4:Temp/Hum,text
   room       SD_WS07
Von unten nach oben zu lesen, da ist noch mehr unerklärliches, bitte alles durchgucken
2019.03.08 23:01:21 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (224)
2019.03.08 23:00:24 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:59:27 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:58:30 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:57:33 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:56:36 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:55:39 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:54:42 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:53:45 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:52:48 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:51:51 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:49:00 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:48:03 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:47:06 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:46:09 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:44:15 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:43:18 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:42:21 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (224)
2019.03.08 22:42:21 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:41:24 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:39:30 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:37:36 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:31:54 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:30:57 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:30:00 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:17:39 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:16:42 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:13:51 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:12:54 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:10:03 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:09:06 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:07:12 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:06:15 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:03:24 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:02:27 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:01:30 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 22:00:33 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:59:36 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:58:39 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:56:45 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:55:48 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:54:51 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:53:54 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:52:57 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:51:03 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:50:06 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:49:09 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:47:16 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:45:21 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:44:24 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 21:14:57 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:14:00 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:11:09 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:10:12 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:09:15 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:06:24 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:05:27 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:04:30 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:03:33 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 21:01:39 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 20:59:45 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 20:58:48 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 20:57:51 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 20:51:12 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 20:45:30 1: CUL_433: SD_UT_Parse UNDEFINED sensor unknown detected, protocol 91.1, data 5FE78278, code
2019.03.08 20:45:30 3: CUL_433 RSL_Parse UNDEFINED Remotebutton send to define: 187D86_3_2
2019.03.08 20:13:12 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 20:12:15 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 20:04:39 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (184)
2019.03.08 19:52:18 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:50:24 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:49:27 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:48:30 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:47:33 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:45:39 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:44:42 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:43:45 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:42:48 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (226)
2019.03.08 19:30:27 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (207)
2019.03.08 19:27:36 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (207)
2019.03.08 19:11:27 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (207)
2019.03.08 19:10:30 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (207)
2019.03.08 19:08:36 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (207)
2019.03.08 19:06:42 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (207)
2019.03.08 18:45:48 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (162)
2019.03.08 18:44:51 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (162)
2019.03.08 18:43:54 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (162)
2019.03.08 18:39:09 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:38:12 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:37:15 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:36:18 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:35:21 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:34:24 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:34:24 1: CUL_433: SD_UT_Parse UNDEFINED sensor unknown detected, protocol 91.1, data F17F9508, code
2019.03.08 18:32:30 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:31:33 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:29:39 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (123)
2019.03.08 18:28:42 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:27:45 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:26:48 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:25:51 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:24:54 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:23:57 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:23:01 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:22:03 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:20:09 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:19:12 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:18:15 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (143)
2019.03.08 18:17:19 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (213)
2019.03.08 18:16:21 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (213)
2019.03.08 18:03:03 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (248)
2019.03.08 18:01:09 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (248)
2019.03.08 18:00:12 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (248)
2019.03.08 17:59:15 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (248)
2019.03.08 17:58:18 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (248)
2019.03.08 17:52:36 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (248)
2019.03.08 17:50:42 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (251)
2019.03.08 17:48:48 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (251)
2019.03.08 17:47:51 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (251)
2019.03.08 17:46:54 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (251)
2019.03.08 17:45:57 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (251)
2019.03.08 17:44:03 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (251)
2019.03.08 17:24:06 1: PERL WARNING: Use of uninitialized value in string ne at fhem.pl line 4778.
2019.03.08 17:23:09 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:22:12 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:21:15 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:19:21 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:18:24 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:17:27 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:16:30 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:15:33 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:14:36 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:13:39 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:12:42 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:11:45 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:08:54 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:06:04 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (120)
2019.03.08 17:05:06 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (140)
2019.03.08 17:04:09 3: CUL_433: SD_WS07_TH_1 ERROR - Humidity unknown (140)
2019.03.08 17:02:15 2: autocreate: define SVG_SD_WS07_TH_1 SVG FileLog_SD_WS07_TH_1:temp4hum4:CURRENT
2019.03.08 17:02:15 2: autocreate: define FileLog_SD_WS07_TH_1 FileLog ./log/SD_WS07_TH_1-%Y.log SD_WS07_TH_1
2019.03.08 17:02:15 2: autocreate: define SD_WS07_TH_1 SD_WS07 SD_WS07_TH_1
2019.03.08 17:02:15 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code SD_WS07_TH_1
2019.03.08 17:01:18 1: CUL_433: UNDEFINED Sensor SD_WS07_TH detected, code SD_WS07_TH_1
Der fix ist natürlich mit drin, trotzdem ...
Sidey
#12
Hi Danke fürs testen.
[quote author=Ralph link=topic=97910.msg916505#msg916505 date=1552083649]
[/quote]
Ja, jetzt wo der Sensor richtig zugeordnet werden kann werden die Daten verarbeitet.
Die Logmeldung möchte dir mitteilen, dass beim Dekodieren der empfangenen Daten ein nicht plausibler Wert für Humidity errechnet wurde. 143% geht halt nicht.
Ich habe den Loglevel angepasst. Kommt jetzt erst ab Loglevel 4.
Dem Problem sollten wir aber dennoch mal nachgehen.
Grüße Sidey
hdad
Habe jetzt die Modul Version v3.4.0_dev_08.03 das SD_WS07_TH_481 wurde sofort erkannt und hat Daten geliefert.
  2019-03-09_07:27:05 SD_WS07_TH_481 T: 14.7 H: 73
2019-03-09_07:27:05 SD_WS07_TH_481 temperature: 14.7
2019-03-09_07:27:05 SD_WS07_TH_481 humidity: 73
2019-03-09_07:27:05 SD_WS07_TH_481 batteryState: ok
2019-03-09_07:27:05 SD_WS07_TH_481 channel: 1
2019-03-09_07:32:47 SD_WS07_TH_481 T: 14.7 H: 73
2019-03-09_07:32:47 SD_WS07_TH_481 temperature: 14.7
2019-03-09_07:32:47 SD_WS07_TH_481 humidity: 73
2019-03-09_07:32:47 SD_WS07_TH_481 batteryState: ok
2019-03-09_07:32:47 SD_WS07_TH_481 channel: 1
Nun kann man der Luftfeuchtigkeit wohl auch trauen. Im Logfile ist bis jetzt auch alles ruhig.
Ich werde die Sache Mal weiter beobachten.
Danke für die schnelle Hilfe.
Gruß Holger
Ralf9
Ich habe von den SD_WS07 sechs Stück  (siehe Anlage), ich habe damit keine Probleme, daß falsche oder unplausilble Werte angezeigt werden.
Ich habe in das Attribut doubleMsgCheck_IDs 7 eingetragen.
ZitatDieses Attribut erlaubt es, Protokolle anzugeben, die zwei gleiche Nachrichten enthalten müssen, um diese an die Module zu übergeben. Sie können mehrere IDs mit einem Komma angeben: 0,3,7
Was für ein SD_WS07_TH Device hast Du?
Gruß Ralf
