FHEM Update 02/2019
Begonnen von mfeske, 26 Februar 2019, 15:56:10
mfeske
nach dem heutigen FHEM Update dreht alles durch :-( In den Logs ist nur zu finden:
2019.02.26 15:22:26 1: reload: Error:Modul 98_GEOFANCY deactivated:
Attempt to reload FHEM/Meta.pm aborted.
Compilation failed in require at ./FHEM/98_GEOFANCY.pm line 11, <$fh> line 1490.
BEGIN failed--compilation aborted at ./FHEM/98_GEOFANCY.pm line 11, <$fh> line 1490.
2019.02.26 15:22:26 0: Attempt to reload FHEM/Meta.pm aborted.
2019.02.26 15:22:29 1: reload: Error:Modul 10_RESIDENTS deactivated:
Compilation failed in require at FHEM/RESIDENTStk.pm line 9, <$fh> line 1534.
BEGIN failed--compilation aborted at FHEM/RESIDENTStk.pm line 9, <$fh> line 1534.
Compilation failed in require at ./FHEM/10_RESIDENTS.pm line 9, <$fh> line 1534.
2019.02.26 15:22:29 0: Attempt to reload FHEM/Meta.pm aborted.
2019.02.26 15:22:29 1: PERL WARNING: Subroutine RESIDENTS_Initialize redefined at ./FHEM/10_RESIDENTS.pm line 12, <$fh> line 1542.
2019.02.26 15:22:29 1: PERL WARNING: Subroutine RESIDENTS_UpdateReadings redefined at ./FHEM/10_RESIDENTS.pm line 33, <$fh> line 1542.
Attempt to reload RESIDENTStk.pm aborted.
Compilation failed in require at ./FHEM/10_RESIDENTS.pm line 9, <$fh> line 1542.
2019.02.26 15:22:29 0: Attempt to reload RESIDENTStk.pm aborted.
2019.02.26 15:22:29 1: PERL WARNING: Subroutine RESIDENTS_Initialize redefined at ./FHEM/10_RESIDENTS.pm line 12, <$fh> line 1550.
2019.02.26 15:22:29 1: PERL WARNING: Subroutine RESIDENTS_UpdateReadings redefined at ./FHEM/10_RESIDENTS.pm line 33, <$fh> line 1550.
Compilation failed in require at ./FHEM/10_RESIDENTS.pm line 9, <$fh> line 1550.
2019.02.26 15:22:30 1: reload: Error:Modul 20_ROOMMATE deactivated:
Compilation failed in require at ./FHEM/20_ROOMMATE.pm line 9, <$fh> line 1561.
2019.02.26 15:22:30 0: Attempt to reload RESIDENTStk.pm aborted.
2019.02.26 15:22:30 1: PERL WARNING: Subroutine ROOMMATE_Initialize redefined at ./FHEM/20_ROOMMATE.pm line 13, <$fh> line 1602.
Compilation failed in require at ./FHEM/20_ROOMMATE.pm line 9, <$fh> line 1602.
2019.02.26 15:22:31 1: PERL WARNING: Subroutine ROOMMATE_Initialize redefined at ./FHEM/20_ROOMMATE.pm line 13, <$fh> line 1612.
2019.02.26 15:22:31 1: reload: Error:Modul 20_ROOMMATE deactivated:
Compilation failed in require at ./FHEM/20_ROOMMATE.pm line 9, <$fh> line 1612.
2019.02.26 15:22:31 0: Attempt to reload RESIDENTStk.pm aborted.
2019.02.26 15:22:31 1: PERL WARNING: Subroutine ROOMMATE_Initialize redefined at ./FHEM/20_ROOMMATE.pm line 13, <$fh> line 1622.
Compilation failed in require at ./FHEM/20_ROOMMATE.pm line 9, <$fh> line 1622.
2019.02.26 15:22:37 3: myDeparture: URL is none, periodic updates will be limited to explicit GetXXPoll attribues (if defined)
2019.02.26 15:22:37 3: myDeparture: interval is 0, no periodic updates will done.
2019.02.26 15:22:37 3: myDeparture: Defined without URL featurelevel 5.9
2019.02.26 15:22:44 1: Including ./log/fhem.save
2019.02.26 15:23:17 1: configfile: Cannot load module Pushover
Please define pushmsg -f33f-a44f-3b21-10bbd41903c2c5e9 first
Cannot load module GEOFANCY
Please define geofancy -f33f-a44f-3202-d125321fd16d329f first
Cannot load module RESIDENTS
Please define Eltern -f33f-a44f-5a09-6a3b70fed4c67e17 first
Please define Bewohner -f33f-a44f-63a5-73f2db415228766b first
Please define Kinder -f33f-a44f-68df-8585d1c721b26244 first
Cannot load module ROOMMATE
Please define rr_location_michael -f33f-a44f-ae72-de1ba1ff1ccafaf2 first
Please define rr_location_dana -f33f-a44f-b988-e7a072417811f844 first
Please define rr_location_janic -f33f-a44f-895b-7813e75cc000ddde first
Please define rr_location_tania -f33f-a44f-ded7-abe2bc80e39a4c4d first
./log/fhem.save: Please define Bewohner first
da ist wohl gründlich was schief gegangen bei mir :-(
Kann ich das aus einem Backup wieder herstellen ?
Micha
Hardware:
1 x Raspberry Pi Mod. B 512 MB
eq-3 2 x MAX! eTRV Heizungssteller, 1 x MAX! Fensterkontakt, 1 x MAX! Cube - LAN Gateway (ausser Betrieb)
Intertechno 1x ITZ-500, 3x ITT-1500, 9x ITR-1500, 3 x ITDL-1000, 2 x ITL-500
1 x CC1101-USB-Lite 433MHz (CUL433)  V3 1 x CC1101-USB-Lite 868MHz (CUL868)
Hallo Micha,
schau mal hier
https://forum.fhem.de/index.php/topic,97899.msg911689.html#msg911689
Edit: Da war einer schneller :) und genauer ;)
mfeske
@Beta-User und @Otto123 ,
vielen lieben Dank für Eure schnelle Antwort. Restore und warten bis morgen ;-) Alles wird gut.
Micha
Hardware:
topa_LE
Hatte nach gestrigen Update auch das Problem, das pushover und npmjs nicht geladen werden konnten.
Heute morgen wieder ein update all gemacht, die meta.pm passt nun wieder.
Läuft alles wieder, danke für die Korrektur.
