mailcheck.pm, imapclient.pm - Fehler im Log seit Update 2019-02-18
Begonnen von Ralph, 28 Februar 2019, 23:07:26
Ralph
Moin allerseits, ich betreibe u. a. auch den EMail-Client Internals:
   CONNECTS   18
   DEF        imap.gmail.com:993 ...@gmail.com ...
   FD         10
   FUUID      5c4af1e5-f33f-a76b-9dad-f8117faa4ad1e0fb
   Folder     INBOX
   HAS_GPG    0
   HAS_IDLE   1
   HAS_MIME   1
   Host       imap.gmail.com:993
   INTERVAL   180
   LAST_CONNECT 2019-02-28 22:11:41
   LAST_DISCONNECT 2019-02-28 22:11:41
   LAST_LOGIN 2019-02-28 22:11:42
   LAST_POLL  2019-02-28 22:56:43
   NAME       Email
   NOTIFYDEV  global
   NR         573
   NTFY_ORDER 50-Email
   STATE      Logged in
   TYPE       mailcheck
   tag        49
     2019-02-22 18:24:28   From            ...@gmail.com
     2019-02-22 18:24:28   Subject         wie lang darf die bezeichnung der funkt Alarm inaktiv
   helper:
     password   ...
     user       ...
   interval   180
   room       Internet
Im Log ( reverse Mode ) finde ich in regelmäßigen Abständen immer wieder 2019.02.28 22:11:41 3: Email: connected to imap.gmail.com:993
2019.02.28 22:11:41 3: Email: Disconnected
2019.02.28 22:11:41 3: Email: logged out
main::CallFn("Email", "ReadFn", HASH(0x23aba38)) called at fhem.pl line 742
main::mailcheck_Read(HASH(0x23aba38)) called at fhem.pl line 3693
Mail::IMAPClient::idle(Mail::IMAPClient=HASH(0x2f2e818)) called at ./FHEM/32_mailcheck.pm line 483
Mail::IMAPClient::_imap_command(Mail::IMAPClient=HASH(0x2f2e818), "IDLE", "+") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1125
Mail::IMAPClient::LastError(Mail::IMAPClient=HASH(0x2f2e818), "Error sending '18 IDLE': NO not connected") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1286
2019.02.28 22:11:41 1: PERL WARNING: Trying command when NOT connected! LastError was: Error sending '18 IDLE': NO not connected at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 123.
Mail::IMAPClient::_imap_command_do(Mail::IMAPClient=HASH(0x2f2e818), "IDLE", "+") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1236
Mail::IMAPClient::LastError(Mail::IMAPClient=HASH(0x2f2e818), "Error sending '18 IDLE': NO not connected") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1333
2019.02.28 22:11:41 1: PERL WARNING: Trying command when NOT connected! LastError was: NO not connected at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 123.
Mail::IMAPClient::_send_line(Mail::IMAPClient=HASH(0x2f2e818), "18 IDLE", 0) called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1332
Mail::IMAPClient::LastError(Mail::IMAPClient=HASH(0x2f2e818), "NO not connected") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1556
2019.02.28 22:11:41 1: PERL WARNING: Trying command when NOT connected! at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 123.
Mail::IMAPClient::done(Mail::IMAPClient=HASH(0x2f2e818)) called at ./FHEM/32_mailcheck.pm line 382
Mail::IMAPClient::_imap_command(Mail::IMAPClient=HASH(0x2f2e818), HASH(0x2f3b2e0), "DONE") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1174
Mail::IMAPClient::LastError(Mail::IMAPClient=HASH(0x2f2e818), "Error sending 'DONE': NO not connected") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1286
2019.02.28 22:11:41 1: PERL WARNING: Trying command when NOT connected! LastError was: Error sending 'DONE': NO not connected at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 123.
Mail::IMAPClient::_imap_command_do(Mail::IMAPClient=HASH(0x2f2e818), HASH(0x2f3b2e0), "DONE") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1236
Mail::IMAPClient::LastError(Mail::IMAPClient=HASH(0x2f2e818), "Error sending 'DONE': NO not connected") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1333
Mail::IMAPClient::_send_line(Mail::IMAPClient=HASH(0x2f2e818), "DONE", 0) called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1332
Mail::IMAPClient::idle_data(Mail::IMAPClient=HASH(0x2f2e818)) called at ./FHEM/32_mailcheck.pm line 378
Mail::IMAPClient::_get_response(Mail::IMAPClient=HASH(0x2f2e818), "*", qr((?!BAD|BYE|NO)(?:\d+\s+\w+|\S+))) called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1149
Mail::IMAPClient::_read_line(Mail::IMAPClient=HASH(0x2f2e818)) called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1404
Mail::IMAPClient::LastError(Mail::IMAPClient=HASH(0x2f2e818), "NO not connected") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1628
2019.02.28 22:11:41 1: PERL WARNING: Trying command when NOT connected! LastError was: Error sending '16 IDLE': NO not connected at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 123.
main::HandleTimeout() called at fhem.pl line 665
main::mailcheck_poll(HASH(0x23aba38)) called at fhem.pl line 3236
Mail::IMAPClient::idle(Mail::IMAPClient=HASH(0x2f2e818)) called at ./FHEM/32_mailcheck.pm line 276
Mail::IMAPClient::LastError(Mail::IMAPClient=HASH(0x2f2e818), "Error sending '16 IDLE': NO not connected") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1286
Mail::IMAPClient::LastError(Mail::IMAPClient=HASH(0x2f2e818), "Error sending '16 IDLE': NO not connected") called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1333
Mail::IMAPClient::_send_line(Mail::IMAPClient=HASH(0x2f2e818), "16 IDLE", 0) called at /usr/local/share/perl/5.24.1/Mail/IMAPClient.pm line 1332
2019.02.28 21:59:40 3: Email: logged in to ...@gmail.com
2019.02.28 21:59:38 3: Email: connected to imap.gmail.com:993
2019.02.28 21:59:38 3: Email: Disconnected
2019.02.28 21:59:38 3: Email: logged out
Was mach(t)e ich falsch ?
FHEM auf RaspberryPi3 mit Geekworm USV und SignalDUINO 433MHz und HM-MOD-RPI-PCB mit 3 HM-Sec-SD-2, 5 FHT, 2 RM 100-2 Uni S, 2 HMS100, 6 CUL_WS, 6 CUL_FHTTK, 11 FS20 und 7 FS20V Spannungsüberwachungen
Ellert
Du hast verbose nicht auf 0 gesetzt.
32_mailcheck.pm 16299 2018-03-01 ist die aktuelle Version.
Warum wird die Verbindung "Disconnected", hast Du Netzwerkprobleme?
Ralph
Ellert
Ja, dann sind die Meldungen weg, die kommen auch bei Zwangsunterbrechung.
Ralph
Ellert
Dann kommen nicht alle Meldungen aus mailcheck. Da bleibt dann nur die Ursachen für die Verbindungsabbrüche zu beheben.
Ralph
Und eben deswegen habe ich oben ein ausführliches Protokoll angehängt.
Weil ich nämlich - wer hätte das gedacht - weder weiß, wo ich suchen soll, noch, wie ich den Fehler beheben könnte.
Ellert
Ralph
Ellert
Kannst Du den Zustand vor dem Update herstellen, wenn es tatsächlich am Update liegt, lässt sich ein möglicher Fehler durch schrittweises Updaten vielleicht eingrenzen.
