[Gelöst] Fehler beim Start von FHEM: Meta.pm (?)
Begonnen von scooty, 05 April 2019, 11:52:53
scooty
nach einer Woche mal wieder ein Update von FHEM gemacht, nach Restart können aber einige Module nicht geladen werden.
Hier der Auszug aus dem FHEM-Log:
2019.04.05 10:03:14.421 1: reload: Error:Modul 59_Wunderground deactivated:
This Perl not built to support threads
Compilation failed in require at FHEM/Meta.pm line 8, <$fh> line 6475.
BEGIN failed--compilation aborted at FHEM/Meta.pm line 8, <$fh> line 6475.
Compilation failed in require at /opt/fhem/FHEM/59_Wunderground.pm line 15, <$fh> line 6475.
BEGIN failed--compilation aborted at /opt/fhem/FHEM/59_Wunderground.pm line 15, <$fh> line 6475.
2019.04.05 10:03:14.421 0: This Perl not built to support threads
2019.04.05 10:03:16.627 1: reload: Error:Modul 73_AMADCommBridge deactivated:
Attempt to reload FHEM/Meta.pm aborted.
Compilation failed in require at /opt/fhem/FHEM/73_AMADCommBridge.pm line 65, <$fh> line 8605.
BEGIN failed--compilation aborted at /opt/fhem/FHEM/73_AMADCommBridge.pm line 65, <$fh> line 8605.
2019.04.05 10:03:16.627 0: Attempt to reload FHEM/Meta.pm aborted.
2019.04.05 10:03:16.647 1: reload: Error:Modul 74_AMADDevice deactivated:
Compilation failed in require at /opt/fhem/FHEM/74_AMADDevice.pm line 51, <$fh> line 8610.
BEGIN failed--compilation aborted at /opt/fhem/FHEM/74_AMADDevice.pm line 51, <$fh> line 8610.
2019.04.05 10:03:16.647 0: Attempt to reload FHEM/Meta.pm aborted.
2019.04.05 10:03:18.262 1: reload: Error:Modul 73_GardenaSmartBridge deactivated:
Compilation failed in require at /opt/fhem/FHEM/73_GardenaSmartBridge.pm line 60, <$fh> line 10723.
BEGIN failed--compilation aborted at /opt/fhem/FHEM/73_GardenaSmartBridge.pm line 60, <$fh> line 10723.
2019.04.05 10:03:18.262 0: Attempt to reload FHEM/Meta.pm aborted.
Nach Auskommentieren von Zeile 8 in Meta.pm
use threads;
startet FHEM ohne Fehler.
Kann jetzt leider nicht beurteilen, ob es wirklich an Meta.pm liegt oder all den anderen Modulen?
Da ich im Bereich "FHEM Development" im Thread "Meta.pm: Metadaten über FHEM Module" leider nichts erstellen darf bin ich nun hier gelandet. Den Maintainer der Meta.pm habe ich per PN informiert.
Vielen Dank und Grüße,
Andreas
PS: Perl Version ist
This is perl 5, version 26, subversion 0 (v5.26.0) built for x86_64-linux
PPS: Mir ist bewußt, dass 59_Wunderground wegen geändertem API nicht mehr läuft, das entsprechende Device möchte ich aber erst einmal drin lassen, ist disabled.
Fhem auf Gigabyte Brix
CUL V3 HM / CUL V3 MAX / MaxCube aFW Homematic&MAX / ZWave.me ZME_UZB1 / SDuino 433 / Velux KLF200
Homematic / MAX / Logitech Hub / ZWave / Wifi LED / div. 433 Temperatursensoren / pywws WH1080 / IO Homecontrol
Loredo
Ich denke ich kann den Workaround in Meta.pm entfernen, damit die Abhängigkeit an dieser Stelle nicht mehr gegeben ist.
Fix ist ins SVN eingecheckt.
Maintainer:
scooty
Vielen Dank für die prompte Behebung!
Andreas
