[73_AutoShuttersControl.pm] Rolllos automatisiert steuern - Version 0.6.x
Begonnen von CoolTux, 27 April 2019, 08:04:52
Karflyer
ZitatHallo Stefan
Das wäre lieb, bei mir vermute ich, dass es am SIGNALduino liegt.
Welchen set-Befehl hast du bei deinen Somfys ?
Ralf, hier mal das List eines Rolladen. Als CUL ist bei mir ebenfalls ein SignalDuino im Einsatz.
   ADDRESS    000001
   CFGFN      /opt/fhem/devices_somfy.cfg
   DEF        000001 A3 0453
   FUUID      5c55644d-f33f-bb67-160e-dd2fd1535ba438ce
   IODev      CUL_SOMFY
   NAME       sht_ezr
   NR         78
   STATE      open
   TYPE       SOMFY
   move       stop
   CODE:
     1          000001
     2019-05-09 07:54:09   ASC_ShuttersLastDrive manual
     2019-05-09 05:45:01   ASC_Time_DriveDown  9.05.2019 - 21:29
     2019-05-09 05:45:01   ASC_Time_DriveUp 10.05.2019 - 05:45
     2019-05-09 05:45:01   ASC_Time_PrivacyDriveDown  9.05.2019 - 21:09
     2019-05-09 03:19:20   associatedWith  ASControl
     2019-05-09 07:54:09   enc_key         A3
     2019-05-09 07:54:29   exact           0
     2019-05-09 07:54:29   position        0
     2019-05-09 07:54:09   rolling_code    0453
     2019-05-09 07:54:29   state           open
   ASC        1
   ASC_Antifreeze off
   ASC_Antifreeze_Pos 85
   ASC_AutoAstroModeEvening none
   ASC_AutoAstroModeEveningHorizon none
   ASC_AutoAstroModeMorning none
   ASC_AutoAstroModeMorningHorizon none
   ASC_BlockingTime_afterManual 60
   ASC_BlockingTime_beforDayOpen 0
   ASC_BlockingTime_beforNightClose 0
   ASC_BrightnessSensor brightness_eastside:brightness
   ASC_Closed_Pos 200
   ASC_ComfortOpen_Pos 20
   ASC_Down   astro
   ASC_DriveUpMaxDuration 23
   ASC_Drive_Offset -1
   ASC_Drive_OffsetStart 1
   ASC_GuestRoom off
   ASC_LockOut off
   ASC_LockOut_Cmd none
   ASC_Mode_Down always
   ASC_Mode_Up always
   ASC_Open_Pos 0
   ASC_Partymode off
   ASC_Pos_Reading position
   ASC_PrivacyDownTime_beforNightClose 1200
   ASC_PrivacyDown_Pos 50
   ASC_RainProtection off
   ASC_Roommate_Device none
   ASC_Roommate_Reading state
   ASC_Self_Defense_Exclude off
   ASC_Shading_Angle_Left 85
   ASC_Shading_Angle_Right 75
   ASC_Shading_Direction 135
   ASC_Shading_Min_Elevation 15
   ASC_Shading_Min_OutsideTemperature 18
   ASC_Shading_Mode off
   ASC_Shading_Pos 100
   ASC_Shading_StateChange_Cloudy 20000
   ASC_Shading_StateChange_Sunny 35000
   ASC_Shading_WaitingPeriod 1200
   ASC_ShuttersPlace window
   ASC_Time_Down_Early 16:00
   ASC_Time_Down_Late 22:30
   ASC_Time_Up_Early 05:45
   ASC_Time_Up_Late 08:30
   ASC_Time_Up_WE_Holiday 07:30
   ASC_Up     time
   ASC_Ventilate_Pos 70
   ASC_Ventilate_Window_Open on
   ASC_WiggleValue 5
   ASC_WindParameters -1
   ASC_WindProtection off
   ASC_WindowRec sc_ezr
   ASC_WindowRec_subType threestate
   DbLogExclude .*
   IODev      CUL_SOMFY
   alias      Esszimmer (r)
   devStateIcon open|10:fts_shutter_10 20:fts_shutter_20 30:fts_shutter_30 40:fts_shutter_40 50:fts_shutter_50 60:fts_shutter_60 70:fts_shutter_70 80:fts_shutter_80 90:fts_shutter_90 100|down|closed:fts_shutter_100
   drive-down-time-to-100 16
   drive-down-time-to-close 19
   drive-up-time-to-100 3
   drive-up-time-to-open 20
   eventMap   /on:down/off:up/pos 60:go-my/
   group      Shutter
   model      somfyshutter
   room       SOMFY
   sortby     01
   userattr   ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforDayOpen ASC_BlockingTime_beforNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Down:time,astro,brightness ASC_DriveUpMaxDuration ASC_Drive_Offset ASC_Drive_OffsetStart ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownTime_beforNightClose ASC_PrivacyDown_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_Exclude:on,off ASC_Shading_Angle_Left ASC_Shading_Angle_Right ASC_Shading_Direction ASC_Shading_Min_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_Cloudy ASC_Shading_StateChange_Sunny ASC_Shading_WaitingPeriod ASC_ShuttersPlace:window,terrace ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_subType:twostate,threestate
   webCmd     down:stop:up:go-my
   widgetOverride position:slider,0,10,100
Als Set-Befehle gibt es die für das Device bereitgestellten Befehle down, go-my, manual, off, off-for-timer, on, on-for-timer, pos, position, prog, stop, up, wind_only_a, wind_sun_9 und z_custom.
Die Befehle off und down bringen den Rolladen über 100 in die Postion 200. Wie gesagt, hat das ASC-Modul kein Problem den Rolladen in die Postion 200 zu fahren.
@CoolTux
Zum Anfang der Modulentwicklung hatten wir mal die Besonderheit bei den SOMFY-Rolläden diskutiert, dass nach Position 100 (Lamellen sind noch nicht ganz zu gefahren) der Positionswert 200 (Rolladen komplett zu) kommt. Hattest du das nicht sogar im Code berücksichtigt?
Stefan
CoolTux
   ADDRESS    000001
   DEF        000001 A3 0453
   IODev      CUL_SOMFY
   NAME       sht_ezr
   NR         78
   STATE      open
   TYPE       SOMFY
   move       stop
   CODE:
     1          000001
   ASC        1
   ASC_Antifreeze off
   ASC_Closed_Pos 200
   ASC_Down   astro
   ASC_Drive_Offset -1
   ASC_GuestRoom off
   ASC_LockOut off
   ASC_Mode_Up always
   ASC_Open_Pos 0
   ASC_Partymode off
   ASC_Shading_Pos 100
   ASC_Up     time
   ASC_WiggleValue 5
   DbLogExclude .*
   IODev      CUL_SOMFY
   alias      Esszimmer (r)
   group      Shutter
   model      somfyshutter
   room       SOMFY
   sortby     01
@CoolTux
Stefan
Hallo Stefan,
Da habe ich nichts weiter gemacht vom Code her. Es wird entsprechend der Attributswerte gefahren. Wir wollten da mal so ein Zwischending einbauen. Aber dazu bin ich noch nicht gekommen.
Das TuxNet Wiki:
https://www.cooltux.net
FunkOdyssey
Zitat von: CoolTux am 09 Mai 2019, 06:27:04
Die letzten Tage sind meine Rolllos im Kinderzimmer und der Küche korrekt nach Brightness gefahren.
Wie sehen Eure Erfahrungen mit der aktuellen Version aus?
Leider negativ.
Die Brightness-Jalousien sind alle über 'day open' gefahren und nicht nach dem Brightness-Event.
Ich hatte seit gestern morgen keinen Neustart gemacht. War das nicht auch Thema bei dir?
Wetten, dass du einen Neustart durchgeführt hast? :-)
CoolTux
Zitat von: FunkOdyssey am 09 Mai 2019, 12:33:13
Leider negativ.
Wette verloren. Kein Neustart seit dem Brightness Tests.
Dann gib mal bitte Logfile damit ich schauen kann wo es klemmen könnte. Bitte mit list vom ASC und einem exemplarischen Rollladen Device.
Das TuxNet Wiki:
RalfPit
   ADDRESS    000001
   DEF        000001 A3 0453
   IODev      CUL_SOMFY
   NAME       sht_ezr
   NR         78
   STATE      open
   TYPE       SOMFY
   move       stop
   CODE:
     1          000001
   ASC        1
   ASC_Antifreeze off
   ASC_Closed_Pos 200
   ASC_Down   astro
   ASC_Drive_Offset -1
   ASC_GuestRoom off
   ASC_LockOut off
   ASC_Mode_Up always
   ASC_Open_Pos 0
   ASC_Partymode off
   ASC_Shading_Pos 100
   ASC_Up     time
   ASC_WiggleValue 5
   DbLogExclude .*
   IODev      CUL_SOMFY
   alias      Esszimmer (r)
   group      Shutter
   model      somfyshutter
   room       SOMFY
   sortby     01
@CoolTux
Stefan
Hallo Stefan, danke für die Info.
Das versehe nicht, warum habe ich weniger Set-Befehle ?
Kannst du mir auch ein List von deinem SignalDuino senden ?
Irgendwo muss ich dann wohl einen Fehler gemacht haben.
LG Ralf
Karflyer
LG Ralf
Das List zum SignalDuino. Sollte der letzte Post zu den Themen SOMFYoder SignalDuino sein. Hier geht es ja um ASC. Bei Bedarf dann weiter im SOMFY oder SignalDuino-Thread.
Die vielleicht seltsam anmutende DEF des Signal-Duino-Device rührt daher, dass ich die CULS' an einem separaten RASPI laufen haben und dort per SER2NET eine Umsetzung auf Ethernet mache. Das hat aber nichts mit deinem Problem zu tun.
   Clients    :IT:CUL_TCM97001:SD_RSL:OREGON:CUL_TX:SD_AS:Hideki:SD_WS07:SD_WS09: :SD_WS:RFXX10REC:Dooya:SOMFY:SD_BELL:SD_UT:SD_WS_Maverick:FLAMINGO:CUL_WS:Revolt: :FS10:CUL_FHTTK:Siro:FHT:FS20:CUL_EM:Fernotron:SIGNALduino_un:
   DEF        192.168.2.8:2003@57600
   DMSG       nothing
   DevState   initialized
   DeviceName 192.168.2.8:2003@57600
   FD         10
   FUUID      5c556449-f33f-bb67-1a67-0031efbfa40c6ab6
   LASTDMSG   nothing
   NAME       CUL_SOMFY
   NR         15
   PARTIAL
   STATE      opened
   TIME       1557399004
   TYPE       SIGNALduino
   sendworking 0
   unknownmessages
   version    V 3.3.1-dev SIGNALduino cc1101 - compiled at Apr 20 2017 21:06:32
   versionmodul v3.3.3
   MatchList:
     10:SD_WS07 ^P7#[A-Fa-f0-9]{6}F[A-Fa-f0-9]{2}(#R[A-F0-9][A-F0-9]){0,1}$
     11:SD_WS09 ^P9#F[A-Fa-f0-9]+
     12:SD_WS   ^W\d+x{0,1}#.*
     13:RFXX10REC ^(20|29)[A-Fa-f0-9]+
     14:Dooya   ^P16#[A-Fa-f0-9]+
     15:SOMFY   ^Ys[0-9A-F]+
     16:SD_WS_Maverick ^P47#[A-Fa-f0-9]+
     17:SD_UT   ^P(?:14|29|30|34|46|69|76|81|83|86|90|91|91.1|92)#.*
     18:FLAMINGO ^P13\.?1?#[A-Fa-f0-9]+
     19:CUL_WS  ^K[A-Fa-f0-9]{5,}
     1:IT       ^i......
     20:Revolt  ^r[A-Fa-f0-9]{22}
     21:FS10    ^P61#[A-F0-9]+
     22:Siro    ^P72#[A-Fa-f0-9]+
     23:FHT     ^81..(04|09|0d)..(0909a001|83098301|c409c401)..
     24:FS20    ^81..(04|0c)..0101a001
     25:CUL_EM  ^E0.................
     26:Fernotron ^P82#.*
     27:SD_BELL ^P(?:15|32|41|42|57|79)#.*
     2:CUL_TCM97001 ^s[A-Fa-f0-9]+
     3:SD_RSL   ^P1#[A-Fa-f0-9]{8}
     4:OREGON   ^(3[8-9A-F]|[4-6][0-9A-F]|7[0-8]).*
     5:CUL_TX   ^TX..........
     6:SD_AS    ^P2#[A-Fa-f0-9]{7,8}
     7:Hideki   ^P12#75[A-F0-9]+
     9:CUL_FHTTK ^T[A-F0-9]{8}
     X:SIGNALduino_un ^[u]\d+#.*
   QUEUE:
     2019-02-15 14:44:43   ccconf          freq:433.420MHz bWidth:464KHz rAmpl:42dB sens:16dB  (DataRate:3173.83Baud)
     2019-05-09 16:21:32   ping            OK
     2019-05-09 12:50:30   state           opened
     2019-03-04 19:31:20   uptime          0 02:30:40
     2019-05-09 12:50:30   version         V 3.3.1-dev SIGNALduino cc1101 - compiled at Apr 20 2017 21:06:32
   getcmd:
   keepalive:
     ok         0
     retry      0
   mcIdList:
     43
   msIdList:
   muIdList:
   DbLogExclude .*
   addvaltrigger RSSI
   flashCommand avrdude -c arduino -b [BAUDRATE] -P [PORT] -p atmega328p -vv -U flash:w:[HEXFILE] 2>[LOGFILE]
   group      CUL
   hardware   nanoCC1101
   room       SOMFY,Server
   verbose    1
   whitelist_IDs 43
Stefan
eurofinder
@CoolTux:
Wie bekomme ich denn diese Fehlermeldung:
Messages collected while initializing FHEM:
configfile: ASC: unknown attribute ASC_autoShuttersControlShading. Type 'attr ASC ?' for a detailed list.
wieder weg?
Im ASC kann ich ja das Attribut nicht mehr löschen nach dem Update auf 0.6.7.
eurofinder
RPI3+; Raspbian Buster Lite; RPI-RF-MOD; piVCCU3, HMIP-eTRV-2, HmIP-SWDO, HmIP-SRH, HmIP-STHO, HmIP-SLO
FunkOdyssey
Das ist kein Problem. Du musst nur im Global-Device das 'motd'-Attribut löschen oder auf 'none' setzen. Je nachdem wie es zuvor aussah.
CoolTux
Nach dem Neustart in Dein Logfile schauen ob nichts anderes schief gelaufen ist und somit nicht in der aktuellen Konfig steht und wenn sonst alles ok ist einfach save drücken.
Das TuxNet Wiki:
eurofinder
Danke. An global habe ich jetzt gar nicht dran gedacht:-)
eurofinder
CoolTux
Wie schaut es aus bei Euch?
Kam irgendwas bezüglich Freitagsproblem?
Das TuxNet Wiki:
volschin
Zitat von: CoolTux am 07 Mai 2019, 04:24:17
Kann ich pauschal nicht sagen. Da brauche ich bitte list vom ASC und dem Rolllo
ASC:
   FUUID      5cc99082-f33f-3c0c-1030-7c33a024d704b92c
   FVERSION   73_AutoShuttersControl.pm:v0.6.7-s19344/2019-05-07 UNDER DEVELOP
   MID        da39a3ee5e6b4b0d3255bfef95601890afd80709
   NAME       myASControl
   NOTIFYDEV  global,myASControl,Rollo.Bad,RolloL.Schlafen,RolloL.Wohnen,RolloR.Schlafen,RolloR.Wohnen,rgr_Residents,Fenster_L.Wohnen,Helligkeit,Fenster_R.Wohnen,Fenster_L.Schlafen,RolloL.Schlafen,Rollo.Bad,Helligkeitsmelder.Outdoor,Fenster.Bad,Wetter,RolloR.Wohnen,myTwilight,Fenster_R.Schlafen,RolloR.Schlafen,rr_Veit,RolloL.Wohnen
   NR         587
   NTFY_ORDER 51-myASControl
   STATE      created new drive timer
   TYPE       AutoShuttersControl
   VERSION    0.6.7
   OLDREADINGS:
     2019-05-10 05:28:12   Rollo.Bad_PosValue 0
     2019-05-10 05:28:12   Rollo.Bad_lastPosValue 100
     2019-05-10 05:28:12   Rollo.Bad_nextAstroTimeEvent 10.05.2019 - 20:40
     2019-05-10 06:45:02   RolloL.Schlafen_PosValue 0
     2019-05-10 08:30:01   RolloL.Schlafen_lastPosValue 100
     2019-05-10 08:30:01   RolloL.Schlafen_nextAstroTimeEvent 10.05.2019 - 22:00
     2019-05-10 06:45:02   RolloL.Wohnen_PosValue 0
     2019-05-10 08:30:01   RolloL.Wohnen_lastPosValue 100
     2019-05-10 08:30:01   RolloL.Wohnen_nextAstroTimeEvent 10.05.2019 - 22:00
     2019-05-10 06:45:02   RolloR.Schlafen_PosValue 0
     2019-05-06 04:51:52   RolloR.Schlafen_lastDelayPosValue 70
     2019-05-10 08:30:01   RolloR.Schlafen_lastPosValue 50
     2019-05-10 08:30:01   RolloR.Schlafen_nextAstroTimeEvent 10.05.2019 - 22:00
     2019-05-10 05:52:43   RolloR.Wohnen_PosValue 0
     2019-05-10 08:30:01   RolloR.Wohnen_lastPosValue 100
     2019-05-10 08:30:01   RolloR.Wohnen_nextAstroTimeEvent 10.05.2019 - 22:00
     2019-05-08 22:57:19   controlShading  off
     2019-05-01 14:26:43   hardLockOut     off
     2019-05-01 14:26:43   partyMode       off
     2019-05-08 22:57:19   room_Bad_Sicherheit_alexa Rollo.Bad
     2019-05-08 22:57:19   room_Schlafen_Sicherheit_alexa RolloL.Schlafen,RolloR.Schlafen
     2019-05-08 22:57:19   room_Sicherheit_Wohnen_alexa_harmony RolloL.Wohnen,RolloR.Wohnen
     2019-05-01 14:26:43   selfDefense     off
     2019-05-10 08:30:01   state           created new drive timer
     2019-05-01 14:26:43   sunriseTimeWeHoliday off
     2019-05-08 22:57:19   userAttrList    rolled out
   helper:
     shuttersList:
       Rollo.Bad
       RolloL.Schlafen
       RolloL.Wohnen
       RolloR.Schlafen
       RolloR.Wohnen
   monitoredDevs:
     Fenster.Bad:
       Rollo.Bad  ASC_WindowRec
     Fenster_L.Schlafen:
       RolloL.Schlafen ASC_WindowRec
       RolloR.Schlafen ASC_WindowRec
     Fenster_L.Wohnen:
       RolloL.Wohnen ASC_WindowRec
     Fenster_R.Schlafen:
     Fenster_R.Wohnen:
       RolloR.Wohnen ASC_WindowRec
     Helligkeit:
       RolloL.Wohnen ASC_BrightnessSensor
     Helligkeitsmelder.Outdoor:
       Rollo.Bad  ASC_BrightnessSensor
       RolloL.Schlafen ASC_BrightnessSensor
       RolloR.Schlafen ASC_BrightnessSensor
       RolloR.Wohnen ASC_BrightnessSensor
     Rollo.Bad:
     RolloL.Schlafen:
     RolloL.Wohnen:
     RolloR.Schlafen:
     RolloR.Wohnen:
     Wetter:
       myASControl ASC_windSensor
     myTwilight:
       myASControl ASC_twilightDevice
     rgr_Residents:
       RolloL.Wohnen ASC_Roommate_Device
       myASControl ASC_residentsDev
     rr_Veit:
       RolloL.Schlafen ASC_Roommate_Device
       RolloR.Schlafen ASC_Roommate_Device
   ASC_autoAstroModeEvening REAL
   ASC_autoAstroModeMorning REAL
   ASC_autoShuttersControlComfort on
   ASC_autoShuttersControlEvening on
   ASC_autoShuttersControlMorning on
   ASC_brightnessDriveUpDown 90:30
   ASC_freezeTemp 3
   ASC_residentsDev rgr_Residents
   ASC_tempSensor Wetter
   ASC_twilightDevice myTwilight
   ASC_windSensor Wetter
   devStateIcon selfeDefense.terrace:fts_door_tilt created.new.drive.timer:clock .*asleep:scene_sleeping roommate.(awoken|home):user_available residents.(home|awoken):status_available manual:fts_shutter_manual selfeDefense.active:status_locked selfeDefense.inactive:status_open day.open:scene_day night.close:scene_night shading.in:weather_sun shading.out:weather_cloudy
   icon       fts_shutter_automatic
   room       Sicherheit
Rollo:
   CHANNEL    1
   DEF        74315211
   FUUID      5c4c1ae4-f33f-3c0c-0bb4-951b060b5bf8d267
   ID         7431521
   IODev      radino
   NAME       RolloR.Schlafen
   NR         517
   NTFY_ORDER 50-RolloR.Schlafen
   STATE      0
   TYPE       Siro
   Version    V 0.49
   state      0
   CODE:
     1          74315211
     2019-05-10 06:45:02   ASC_ShuttersLastDrive roommate awoken
     2019-05-10 08:30:01   ASC_Time_DriveDown 10.05.2019 - 22:00
     2019-05-10 08:30:01   ASC_Time_DriveUp 11.05.2019 - 08:30
     2019-05-10 06:45:25   action          no action
     2019-05-08 22:57:19   associatedWith  myASControl
     2019-05-10 08:30:01   firmware        0.49
     2019-05-09 20:39:22   last_reset_os   4
     2019-05-10 06:45:25   operating_seconds 255.82
     2019-05-03 08:21:54   parsestate      off
     2019-05-10 06:45:02   position        0
     2019-05-03 02:07:01   prog_mode       inaktiv
     2019-05-10 06:45:02   state           0
   helper:
     LastMODE   virtual
     MODE       virtual
     aktMsg     position 0 1557463502.51831
     lastMsg    stop 50 1557435916.37031
     lastProg   0
     lastparse  P72#743152111E 1556864514.34628
     lastparse_stop stop 1556842021.6404
     motorstart 1557463502.64215
     parse_aborted 0
     position   0
     positiontimer 27586.1
   ASC        1
   ASC_BrightnessSensor Helligkeitsmelder.Outdoor:brightness 90:30
   ASC_Closed_Pos 50
   ASC_ComfortOpen_Pos 30
   ASC_Down   brightness
   ASC_Roommate_Device rr_Veit
   ASC_Shading_Direction 125
   ASC_Shading_Min_OutsideTemperature 10
   ASC_Shading_Mode always
   ASC_Shading_StateChange_Cloudy 6000
   ASC_Shading_StateChange_Sunny 30000
   ASC_Shading_WaitingPeriod 360
   ASC_Time_Up_Early 05:30
   ASC_Up     brightness
   ASC_Ventilate_Window_Open off
   ASC_WindowRec Fenster_R.Schlafen
   IODev      radino
   Rollos     s_Rollos.Schlafen
   SignalLongStopRepeats 15
   SignalRepeats 9
   alexaName  Rollo rechts Schlafzimmer
   alexaRoom  Schlafzimmer
   devStateIcon {return '.*:fts_shutter_1w_'.(int($state/10)*10)}
   down_auto_stop 0
   down_limit_mode_1 100
   event-on-change-reading .*
   genericDeviceType blind
   homebridgeMapping TargetPosition=position,cmd=position,cmds=100:on,invert=1,minValue=0,maxValue=100,minStep=1
CurrentPosition=position,cmd=position,invert=1,minValue=0,maxValue=100,minStep=1
   invers_position 0
   model      ERB16LE
   operation_mode 0
   prog_fav_sequence prog,2,stop,2,stop
   room       Schlafen,Sicherheit,alexa
   time_down_to_favorite 11
   time_to_close 40
   time_to_open 43
   userReadings firmware {substr(InternalVal ($name, 'Version', '1.0'),2)}
   userattr   ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforDayOpen ASC_BlockingTime_beforNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Down:time,astro,brightness ASC_DriveUpMaxDuration ASC_Drive_Offset ASC_Drive_OffsetStart ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownTime_beforNightClose ASC_PrivacyDown_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_Exclude:on,off ASC_Shading_Angle_Left ASC_Shading_Angle_Right ASC_Shading_Direction ASC_Shading_Min_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_Cloudy ASC_Shading_StateChange_Sunny ASC_Shading_WaitingPeriod ASC_ShuttersPlace:window,terrace ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_subType:twostate,threestate Rollos Rollos_map structexclude
   webCmd     stop:open:close:fav:position
CoolTux
Zitat von: volschin am 10 Mai 2019, 08:59:34
ASC:
   NAME       myASControl
   NR         587
   VERSION    0.6.7
   OLDREADINGS:
   helper:
     shuttersList:
       Rollo.Bad
       RolloL.Schlafen
       RolloL.Wohnen
       RolloR.Schlafen
       RolloR.Wohnen
   monitoredDevs:
     Fenster.Bad:
     Fenster_L.Schlafen:
     Fenster_L.Wohnen:
     Fenster_R.Schlafen:
     Fenster_R.Wohnen:
     Helligkeit:
     Rollo.Bad:
     RolloL.Schlafen:
     RolloL.Wohnen:
     RolloR.Schlafen:
     RolloR.Wohnen:
     Wetter:
     myTwilight:
     rgr_Residents:
     rr_Veit:
   ASC_freezeTemp 3
   room       Sicherheit
Rollo:
   CHANNEL    1
   DEF        74315211
   ID         7431521
   IODev      radino
   NR         517
   STATE      0
   TYPE       Siro
   Version    V 0.49
   state      0
   CODE:
     1          74315211
   helper:
     LastMODE   virtual
     MODE       virtual
     lastProg   0
     parse_aborted 0
     position   0
   ASC        1
   ASC_Closed_Pos 50
   ASC_Down   brightness
   ASC_Up     brightness
   IODev      radino
   SignalRepeats 9
   down_auto_stop 0
   invers_position 0
   model      ERB16LE
   operation_mode 0
   time_to_close 40
   time_to_open 43
Dann ist klar das er da Fenster nicht beachtet.
Das TuxNet Wiki:
Karflyer
War lange Zeit von dem 'Freitagsproblem' betroffen. Heute erstmal keine Auffälligkeiten beobachtet. Lief wie gewünscht  :)
Der WAF-Faktor ist um einiges gestiegen  ;D
Stefan
CoolTux
Es wird morgen früh ein Update geben. Ich habe da noch etwas in Bezug auf Brightness und sunset sunrise gefunden.
Das TuxNet Wiki:
