New module 57_Calendar.pm for testing
Begonnen von Dr. Boris Neubert, 03 Juni 2012, 00:05:17
Heiermann
habe gerade mal das Log geöffnet, und erschrocken festgestellt, dass bei
mir auch massenhaft Fehlermeldungen drinstehen.
Zumindest ist seit dem heutigen Update der Fehler in Zeile 174
"Use of uninitialized value $parameter in string at ./FHEM/57_Calendar.pm
line 59, <$fh> line 174"
verschwunden. Die Fehlermeldung bezgl.Zeile 59 ist weiterhin vorhanden.
-Heiermann
Am Sonntag, 3. Juni 2012 00:05:17 UTC+2 schrieb Boris:
> Hi,
> the module 57_Calendar.pm is now available for testing. You can retrieve
> it from the SVN. Its features are documented in commandref.html - read
> it attentively, please.
> Summary:
> A calendar device periodically reads the calendar events from a source
> calendar, e.g.from  a Google calendar. You can show calendar events in
> your photo frame (with the aid of the RSS module) or you can trigger
> actions in fhem when the alarm, start or end time of a calendar event is
> reached. The module is designed to provide maximum flexibility. There is
> some functionality to find and show events on the command line.
> Caveat Emptor:
> It works for me but I did not test it well. Please consider it in
> testing stage. It may not work at all for you.
> Send bug reports only to this list. If something does not work as
> expected try to reproduce the problem with a minimal test calendar and
> attach the calendar in ICal format as well as the define command to your
> bug report. Please do not be so stupid as to post the private URL of
> your calendar here - shuffle the letters and numbers first.
> Future plan:
> Add support for reccuring events.
> Have fun!
> Boris
