Module für XBMC
Begonnen von Dennis B., 06 Januar 2013, 22:32:24
Hans Franz
#570
Ich habe keine ChannelGroups und deshhalb wohl:404 Not found.
Hans
Edit:
Habe um 14:10 kodi-TV gestoppt und warte auf die Keys in PendingPlayerCMDs-Meldung. Aber das dauert...
Edit2:
Habe Blödsinn erzählt  :'(
Auf Port 8091:
{"id":6939,"jsonrpc":"2.0","result":{"channelgroups":[{"channelgroupid":1,"channeltype":"tv","label":"Alle Kanäle"}],"limits":{"end":1,"start":0,"total":1}}}
{"id":6939,"jsonrpc":"2.0","result":{"channels":[{"channelid":84,"label":"Das Erste"},{"channelid":94,"label":"ZDF"},{"channelid":21,"label":"RTL Television"},{"channelid":5,"label":"SAT.1"},{"channelid":38,"label":"ProSieben"},{"channelid":33,"label":"kabel eins"},{"channelid":48,"label":"RTL2"},{"channelid":60,"label":"SUPER RTL"},{"channelid":74,"label":"VOX"},{"channelid":58,"label":"DMAX"},{"channelid":42,"label":"SIXX"},{"channelid":54,"label":"Disney Channel"},{"channelid":98,"label":"3sat"},{"channelid":100,"label":"Bayerisches FS Süd"},{"channelid":106,"label":"hr-fernsehen"},{"channelid":83,"label":"WDR Köln"},{"channelid":111,"label":"SWR Fernsehen BW"},{"channelid":88,"label":"WDR Bielefeld"},{"channelid":110,"label":"Radio Bremen TV"},{"channelid":102,"label":"WDR Test A"},{"channelid":108,"label":"Einsfestival"},{"channelid":81,"label":"EinsPlus"},{"channelid":82,"label":"arte"},{"channelid":103,"label":"PHOENIX"},{"channelid":96,"label":"SR Fernsehen"},{"channelid":90,"label":"ARD-alpha"},{"channelid":79,"label":"rbb Brandenburg"},{"channelid":85,"label":"rbb Berlin"},{"channelid":91,"label":"ARD-TEST-1"},{"channelid":89,"label":"NDR FS NDS"},{"channelid":99,"label":"MDR Thüringen"},{"channelid":87,"label":"SWR Fernsehen RP"},{"channelid":49,"label":"N24"},{"channelid":40,"label":"SAT.1 Gold"},{"channelid":72,"label":"ProSieben MAXX"},{"channelid":107,"label":"ALT - SUCHLAUF STARTEN"},{"channelid":63,"label":"Comedy Central/VIVA"},{"channelid":64,"label":"KiKA"},{"channelid":95,"label":"ZDFinfo"},{"channelid":97,"label":"zdf_neo"},{"channelid":86,"label":"zdf.kultur"},{"channelid":101,"label":"tagesschau24"},{"channelid":68,"label":"n-tv"},{"channelid":104,"label":"CBC01"},{"channelid":92,"label":"VOX CH"},{"channelid":39,"label":"RTLNITRO"},{"channelid":80,"label":"RTL Living"},{"channelid":56,"label":"Eurosport Deutschland"},{"channelid":45,"label":"TELE 5"},{"channelid":62,"label":"ServusTV Deutschland"},{"channelid":93,"label":"ServusTV Oesterreich"}],"limits":{"end":51,"start":0,"total":51}}}
Raspi
CUL, Nano-CUL
FHT8V, FHT80B, S300TH
WM1000WZ, ELRO
LW12, LD382,DS18B20
vbs
Joa passt ja, oder? Du hast scheinbar einfach keinen Channel 1, Channel 5 gibts aber.
Hans Franz
Raspi
CUL, Nano-CUL
WM1000WZ, ELRO
LW12, LD382,DS18B20
zensbert
Zitat von: vbs am 08 November 2015, 10:43:55
Benutzt du bewusst http anstatt tcp? Wenn nein, dann solltest du auf tcp umstellen, da der Funktionsumfang von http sehr eingeschränkt ist (zB keine Statusänderungen, wie du auch bemerkt hast).
Ok, daran lags. Danke!
Hans Franz
openchannelid fehlt noch in der Liste der möglichen Argumente.
Um einen Dummy mit den für ein notify nötigen Readings zu befüllen:
#!/usr/bin/perl
use strict;
use warnings;
use LWP::UserAgent;
use HTTP::Request;
use JSON qw( decode_json );
my $jsonUser = "xbmc";
my $jsonPass = "";
my $jsonHost = "localhost:8091";
my $jsonUrl  = sprintf("http://%s:%s@%s/jsonrpc",$jsonUser,$jsonPass,$jsonHost);
my $fhem_port = "7072";
my $dummy_name = "xbmc_channels";
my $jsonReq =sprintf("{
\"jsonrpc\" : \"2.0\",
\"id\" : 1,
\"method\" : \"PVR.GetChannels\",
\"params\" : {\"channelgroupid\" : 1 }
my $http = HTTP::Request->new('POST', $jsonUrl);
$http->header('Content-Type' => 'application/json');
$http->content($jsonReq);
my $ua  = LWP::UserAgent->new;
my $res = $ua->request($http);
if ($res){
    my $setlist;
    my $data = decode_json($res->content);
    system("/opt/fhem/fhem.pl $fhem_port 'defmod $dummy_name dummy'");
    system("/opt/fhem/fhem.pl $fhem_port 'deletereading '.$dummy_name.' .*'");
    foreach my $key1 (keys %$data->{result}->{channels}) {
        my $reading = $data->{result}->{channels}[$key1]->{label};
        my $value   = $data->{result}->{channels}[$key1]->{channelid};
        $reading =~ s/ /_/g;
        system("/opt/fhem/fhem.pl $fhem_port 'setreading $dummy_name $reading $value'");
        $setlist = $setlist.' '.$reading;
    system("/opt/fhem/fhem.pl $fhem_port 'attr $dummy_name setList $setlist'");
    exit(0);
Hans
Raspi
CUL, Nano-CUL
WM1000WZ, ELRO
LW12, LD382,DS18B20
vbs
openchannelid hab ich gestern ergänzt, sollte heute im Update sein.
Ich könnte theoretisch diese Channel-Listen-Sachen hinzufügen. Wäre das nützlich? Wenn ja, wofür? Man müsste dann ja auch die Channel-Groups erstmal anfragen.
Hans Franz
Muss, glaube ich, nicht sein. Kann sich ja jeder selber anpassen. Wann wechselt man schon mal die Kanalzuordnung in Kodi?
Hans
Raspi
CUL, Nano-CUL
WM1000WZ, ELRO
LW12, LD382,DS18B20
zensbert
Nachdem ihr mir so schnell geholfen hattet nochmal eine Frage:
Ich schalte über FHEM Licht ein, wenn bei XBMC Pause ist. aber 2 Nachteile:
-schalte ich über XBMC von Kanal 1 auf 2 ist ca. eine Sekunde Status pause, also geht licht an
-schalte ich über die Harmony alles aus, geht der HTPC nicht schnell genug aus, demnach gibt FHEM nochmal ein Licht-Einschalt-Signal obwohl eigentlich alles aus sein sollte
Der aktuelle Notify sieht so aus:
HTPC.playStatus:.paused set LEDLichtleiste PowerOn
Kann ich da ein 2-3 Sekunden Delay einsetzen? Bzw. auch verhindern dass das Licht anbleibt wenn Harmony Status = PowerOff?
Cool wäre auch generell: wenn Wechsel von Harmony Status auf PowerOff 5 Minuten Licht an, ist aber ja wahrsch. Ein eigenes Notify, oder?
Vielen Dank!!
Thomas
Amenophis86
Schau dir mal in der commandref DOIF und dabei das wait Attribut noch. Erklärungen dazu findest du viele hier im Forum und in der Commandref.
zensbert
Hallo Amenophis86,
Erstmal danke.. Tut mir leid, aber ich muss nochmal nerven.. Ich habe es versucht aber ich sag ganz ehrlich dass ichs nicht so ganz raffe.. Mit dem sleep befehl hat es auch nicht geklappt.
Könntet ihr mir vll. Bei der Syntax etwas helfen?
Nochmal Sry, fange gerade erst mit FHEM an.
Gruß Thomas
Amenophis86
Es gehört zwar eigentlich nicht hier her, aber es könnte in etwa so aussehen:
define LichtTV DOIF ([HTPC:playStatus] eq "paused") (set LEDLichtleiste PowerOn) DOELSE (set LEDLichtleiste PowerOff)
attr LichtTV wait 4:4
Der Code ist jetzt geschrieben, ohne dass ich deine genaue Syntax kenne. Er soll quasi ein Anhaltspunkt sein. Wenn du damit nicht weiter kommst, dann mach doch ein extra Thema auf und ich helfe dir dort gerne weiter.
zensbert
Hallo Amenophis86,
Danke für die Hilfe. Ich habe dass mal in einem eigenen Thread eröffnet.
Würde mich freuen wenn du mir weiterhelfen könntest.
http://forum.fhem.de/index.php/topic,43905.0.html
LG!
Dersch
Hat das Modul jemand mit Kodi 15.2 am laufen? Ich kann machen und einstellen was ich will aber ich bekomme nicht mal eine Verbindung von FEHM zu Kodi :(
vbs
Dersch
Kodi ist richtig konfiguriert (steuerung von externen programmen erlauben) und mehr als das Modul mit tcp einrichten ist doch nicht nötig. Ich verstehe daher nicht waurm er Kodi einfach nicht erkennt und als disconnected anzeigt.
