AutoShuttersControl erkennt Rollladenfahrten nicht.
Begonnen von JWRu, 10 April 2020, 08:34:44
JWRu
Mit der Testversion hat ASC die manuelle Fahrt erkannt.
Event Monitor:
2020-04-14 14:18:32 DUOFERN Rollladen_EZ_Mitte moving: up
2020-04-14 14:18:32 DUOFERN Rollladen_EZ_Mitte set_up
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte opened
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte sunMode: off
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte moving: stop
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte sunAutomatic: on
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte duskAutomatic: on
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte dawnAutomatic: on
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte sunPosition: 35
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte ventilatingPosition: 0
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte manualMode: off
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte ventilatingMode: off
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte position: 100
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte timeAutomatic: on
2020-04-14 14:18:40 DUOFERN Rollladen_EZ_Mitte ASC_ShuttersLastDrive: manual
Log:
AutoShuttersControl (myASC) - Devname: Helligkeit_aussen_Ost Name: myASC Notify: $VAR1 = [
          'battery: ok',
          'brightness: 10994.55',
          'state: B: 10994.55',
          'batteryState: ok',
          'brightnessDamped: 12734.685'
2020.04.14 14:16:34 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4547.
2020.04.14 14:16:34 1: PERL WARNING: Use of uninitialized value $d in hash element at fhem.pl line 4472.
AutoShuttersControl (myASC) - Devname: Helligkeit_aussen_Sued Name: myASC Notify: $VAR1 = [
          'battery: ok',
          'brightness: 111354.62',
          'state: B: 111354.62',
          'batteryState: ok',
          'brightnessDamped: 102914.725'
AutoShuttersControl (myASC) - Devname: Rollladen_EZ_Mitte Name: myASC Notify: $VAR1 = [
          'moving: up'
          'set_up'
          'state: opened',
          'sunMode: off',
          'moving: stop',
          'sunAutomatic: on',
          'duskAutomatic: on',
          'dawnAutomatic: on',
          'sunPosition: 35',
          'ventilatingPosition: 0',
          'manualMode: off',
          'ventilatingMode: off',
          'position: 100',
          'timeAutomatic: on'
Notify:  ASC_Pos_Reading Event vom Rollo wurde erkannt  - RECEIVED EVENT: EventProcessingShutters:  Fn wurde durch Notify aufgerufen da ASC_Pos_Reading Event erkannt wurde  - RECEIVED EVENT: $VAR1 = 'state: opened sunMode: off moving: stop sunAutomatic: on duskAutomatic: on dawnAutomatic: on sunPosition: 35 ventilatingPosition: 0 manualMode: off ventilatingMode: off position: 100 timeAutomatic: on
2020.04.14 14:18:40 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/73_AutoShuttersControl.pm line 7017.
2020.04.14 14:18:40 1: ERROR: empty name in readingsBeginUpdate
2020.04.14 14:18:40 1: stacktrace:
2020.04.14 14:18:40 1:     main::readingsBeginUpdate           called by fhem.pl (4939)
2020.04.14 14:18:40 1:     main::readingsSingleUpdate          called by ./FHEM/73_AutoShuttersControl.pm (7019)
2020.04.14 14:18:40 1:     ASC_Dev::Readings::setPosReading    called by ./FHEM/73_AutoShuttersControl.pm (2659)
2020.04.14 14:18:40 1:     FHEM::AutoShuttersControl::EventProcessingShutters called by ./FHEM/73_AutoShuttersControl.pm (519)
2020.04.14 14:18:40 1:     FHEM::AutoShuttersControl::Notify   called by fhem.pl (3775)
2020.04.14 14:18:40 1:     main::CallFn                        called by fhem.pl (3695)
2020.04.14 14:18:40 1:     main::DoTrigger                     called by fhem.pl (4062)
2020.04.14 14:18:40 1:     main::Dispatch                      called by ./FHEM/10_DUOFERNSTICK.pm (273)
2020.04.14 14:18:40 1:     main::DUOFERNSTICK_Parse            called by ./FHEM/10_DUOFERNSTICK.pm (206)
2020.04.14 14:18:40 1:     main::DUOFERNSTICK_Read             called by fhem.pl (3775)
2020.04.14 14:18:40 1:     main::CallFn                        called by fhem.pl (757)
2020.04.14 14:18:40 1: PERL WARNING: Use of uninitialized value $name in concatenation (.) or string at fhem.pl line 4794.
2020.04.14 14:18:40 1: readingsUpdate(,Rollladen_EZ_Mitte_PosValue,100) missed to call readingsBeginUpdate first.
2020.04.14 14:18:40 1:     main::readingsBulkUpdate            called by fhem.pl (4940)
2020.04.14 14:18:40 1: PERL WARNING: Use of uninitialized value $dev in hash element at fhem.pl line 3647.
EventProcessingShutters: Rollladen_EZ_Mitte - Event vom Rollo erkannt. Es wird nun eine etwaige manuelle Fahrt ausgewertet. Int von gettimeofday: 1586866720 Last Position Timestamp: 0 Drive Up Max Duration: 27 Last Position: 50 aktuelle Position: 100
2020.04.14 14:18:40 1: PERL WARNING: Use of uninitialized value $name in hash element at ./FHEM/73_AutoShuttersControl.pm line 7006.
2020.04.14 14:18:40 1:     main::readingsSingleUpdate          called by ./FHEM/73_AutoShuttersControl.pm (7008)
2020.04.14 14:18:40 1:     ASC_Dev::Readings::setStateReading  called by ./FHEM/73_AutoShuttersControl.pm (2703)
2020.04.14 14:18:40 1: readingsUpdate(,state,manual) missed to call readingsBeginUpdate first.
EventProcessingShutters: eine manualle Fahrt wurde erkannt!
          'ASC_ShuttersLastDrive: manual'
AutoShuttersControl (myASC) - Devname: myTwilight Name: myASC Notify: $VAR1 = [
          'azimuth: 200.81',
          'elevation: 49.76',
          'twilight: 100',
          'twilight_weather: 100',
          'compasspoint: south'
2020.04.14 14:18:54 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/73_AutoShuttersControl.pm line 7156.
2020.04.14 14:18:54 1: PERL WARNING: Use of uninitialized value in string eq at ./FHEM/73_AutoShuttersControl.pm line 7158.
2020.04.14 14:18:55 1: Error: >none< has no TYPE, but following keys: ><
          'battery: ok',
          'brightness: 11532.02',
          'state: B: 11532.02',
          'batteryState: ok',
          'brightnessDamped: 12657.193'
          'battery: ok',
          'brightness: 118781.35',
          'state: B: 118781.35',
          'batteryState: ok',
          'brightnessDamped: 108653.384'
          'battery: ok',
          'brightness: 10947.87',
          'state: B: 10947.87',
          'batteryState: ok',
          'brightnessDamped: 12495.480'
          'battery: ok',
          'brightness: 68463.39',
          'state: B: 68463.39',
          'batteryState: ok',
          'brightnessDamped: 105167.590'
Beim ASC-Device fehlt jetzt die Übersicht
ZBox; RasPi 3B; RasPi Zero W; Homematic; Z-Wave; EnOcean, Shelly; DuoFern; Oregon- und Bresser-Sensoren; Steuerung Viessmann-Heizung; ESP32 und ESP8266 über MQTT; Arduino
CoolTux
Du hast bestimmt kein Neustart gemacht sondern ein reload. Das klappt aber bei ASC nicht.
Das TuxNet Wiki:
https://www.cooltux.net
JWRu
JWRu
Nach dem Neustart hat die Testversion von ASC die manuelle Fahrt nicht erkannt und ist anschließend wieder in die Beschattung gefahren.
Event Monitor
2020-04-14 14:34:00 DUOFERN Rollladen_EZ_Mitte moving: up
2020-04-14 14:34:00 DUOFERN Rollladen_EZ_Mitte set_up
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte opened
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte duskAutomatic: on
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte manualMode: off
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte sunAutomatic: on
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte ventilatingMode: off
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte moving: stop
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte sunPosition: 35
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte dawnAutomatic: on
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte sunMode: off
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte ventilatingPosition: 0
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte timeAutomatic: on
2020-04-14 14:34:08 DUOFERN Rollladen_EZ_Mitte position: 100
2020-04-14 14:34:18 DUOFERN Rollladen_EZ_Mitte moving: down
2020-04-14 14:34:18 DUOFERN Rollladen_EZ_Mitte set_position 30
2020-04-14 14:34:18 AutoShuttersControl myASC Rollladen_EZ_Mitte_lastPosValue: 100
2020-04-14 14:34:26 AutoShuttersControl myASC Rollladen_EZ_Mitte_PosValue: 70
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte 70
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte sunMode: off
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte ventilatingPosition: 0
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte timeAutomatic: on
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte position: 70
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte sunAutomatic: on
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte duskAutomatic: on
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte manualMode: off
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte ventilatingMode: off
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte moving: stop
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte sunPosition: 35
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte dawnAutomatic: on
2020-04-14 14:34:26 DUOFERN Rollladen_EZ_Mitte ASC_ShuttersLastDrive: shading in
Log:
          'battery: ok',
          'brightness: 13370.74',
          'state: B: 13370.74',
          'batteryState: ok',
          'brightnessDamped: 12287.310'
          'battery: ok',
          'brightness: 65510.65',
          'state: B: 65510.65',
          'batteryState: ok',
          'brightnessDamped: 42388.470'
          'moving: down'
          'set_position 30'
AutoShuttersControl (myASC) - Devname: myASC Name: myASC Notify: $VAR1 = [
          'Rollladen_EZ_Mitte_lastPosValue: 100'
          'state: 70',
          'timeAutomatic: on',
          'position: 70',
          'sunMode: off',
          'sunPosition: 35',
          'sunAutomatic: on',
          'manualMode: off',
          'moving: stop'
Notify:  ASC_Pos_Reading Event vom Rollo wurde erkannt  - RECEIVED EVENT: EventProcessingShutters:  Fn wurde durch Notify aufgerufen da ASC_Pos_Reading Event erkannt wurde  - RECEIVED EVENT: $VAR1 = 'state: 70 timeAutomatic: on position: 70 sunMode: off ventilatingPosition: 0 sunPosition: 35 dawnAutomatic: on sunAutomatic: on duskAutomatic: on manualMode: off ventilatingMode: off moving: stop
          'Rollladen_EZ_Mitte_PosValue: 70'
EventProcessingShutters: Rollladen_EZ_Mitte - Event vom Rollo erkannt. Es wird nun eine etwaige manuelle Fahrt ausgewertet. Int von gettimeofday: 1586867541 Last Position Timestamp: 1586867533 Drive Up Max Duration: 27 Last Position: 100 aktuelle Position: 70
          'state: shading in'
          'ASC_ShuttersLastDrive: shading in'
2020.04.14 14:33:34 3: ZWave got config for popp/700168.xml from ./FHEM/lib/openzwave_deviceconfig.xml.gz
          'moving: up'
          'set_up'
          'battery: ok',
          'brightness: 14864.34',
          'state: B: 14864.34',
          'batteryState: ok',
          'brightnessDamped: 12829.025'
          'azimuth: 206.33',
          'elevation: 48.77',
          'twilight: 100',
          'compasspoint: south-southwest'
          'state: opened',
          'manualMode: off',
          'sunAutomatic: on',
          'moving: stop',
          'sunPosition: 35',
          'sunMode: off',
          'position: 100'
          'battery: ok',
          'brightness: 123978.49',
          'state: B: 123978.49',
          'batteryState: ok',
          'brightnessDamped: 53949.560'
          'moving: down'
          'set_position 30'
          'state: 70',
          'sunMode: off',
          'position: 70',
          'sunAutomatic: on',
          'manualMode: off',
          'moving: stop',
          'sunPosition: 35',
          'dawnAutomatic: on'
Notify:  ASC_Pos_Reading Event vom Rollo wurde erkannt  - RECEIVED EVENT: EventProcessingShutters:  Fn wurde durch Notify aufgerufen da ASC_Pos_Reading Event erkannt wurde  - RECEIVED EVENT: $VAR1 = 'state: 70 sunMode: off ventilatingPosition: 0 timeAutomatic: on position: 70 sunAutomatic: on duskAutomatic: on manualMode: off ventilatingMode: off moving: stop sunPosition: 35 dawnAutomatic: on
EventProcessingShutters: Rollladen_EZ_Mitte - Event vom Rollo erkannt. Es wird nun eine etwaige manuelle Fahrt ausgewertet. Int von gettimeofday: 1586867666 Last Position Timestamp: 1586867658 Drive Up Max Duration: 27 Last Position: 100 aktuelle Position: 70
          'state: shading in'
Bei den Log-Einträgen von ASC gibt's leider keine Zeiten
CoolTux
Also es liegt definitiv daran das die Zeit von der letzten ausgewerteten Erfassung zu kurz ist.
Es fehlen in der Tat Timestamps. Aber
Das hier ist entscheiden. Und hier liegen nur 8s dazwischen. Kannst Du bei genau diesem Rollo bitte mal ein event-on-change-reading .* setzen.
Das TuxNet Wiki:
JWRu
ZitatUnd hier liegen nur 8s dazwischen.
Der Rolladen brauchte nur 8 Sek. um von 70% auf 100% zu fahren - siehe Event Monitor.
Das ist der Test mit event-on-change-reading .*
Auch jetzt ist er direkt anschließend wieder in die Beschattung gefahren.
Event Monitor:
2020-04-14 15:02:21 DUOFERN Rollladen_EZ_Mitte moving: up
2020-04-14 15:02:21 DUOFERN Rollladen_EZ_Mitte set_up
2020-04-14 15:02:31 DUOFERN Rollladen_EZ_Mitte opened
2020-04-14 15:02:31 DUOFERN Rollladen_EZ_Mitte position: 100
2020-04-14 15:02:31 DUOFERN Rollladen_EZ_Mitte moving: stop
2020-04-14 15:02:33 DUOFERN Rollladen_EZ_Mitte moving: down
2020-04-14 15:02:33 DUOFERN Rollladen_EZ_Mitte set_position 30
2020-04-14 15:02:33 AutoShuttersControl myASC Rollladen_EZ_Mitte_lastPosValue: 100
2020-04-14 15:02:41 AutoShuttersControl myASC Rollladen_EZ_Mitte_PosValue: 70
2020-04-14 15:02:41 DUOFERN Rollladen_EZ_Mitte 70
2020-04-14 15:02:41 DUOFERN Rollladen_EZ_Mitte position: 70
2020-04-14 15:02:41 DUOFERN Rollladen_EZ_Mitte moving: stop
Log:
          'battery: ok',
          'brightness: 11488.64',
          'state: B: 11488.64',
          'batteryState: ok',
          'brightnessDamped: 10285.319'
          'moving: up'
          'set_up'
          'state: opened',
          'position: 100',
          'moving: stop'
          'battery: ok',
          'brightness: 109823.74',
          'state: B: 109823.74',
          'batteryState: ok',
          'brightnessDamped: 106031.586'
          'moving: down'
          'set_position 30'
          'state: 70',
          'position: 70',
          'moving: stop'
Notify:  ASC_Pos_Reading Event vom Rollo wurde erkannt  - RECEIVED EVENT: EventProcessingShutters:  Fn wurde durch Notify aufgerufen da ASC_Pos_Reading Event erkannt wurde  - RECEIVED EVENT: $VAR1 = 'state: 70 position: 70 moving: stop
EventProcessingShutters: Rollladen_EZ_Mitte - Event vom Rollo erkannt. Es wird nun eine etwaige manuelle Fahrt ausgewertet. Int von gettimeofday: 1586869361 Last Position Timestamp: 1586869353 Drive Up Max Duration: 27 Last Position: 100 aktuelle Position: 70
          'state: shading in'
CoolTux
Ja das er nur 8s braucht ist ja ok. Aber! Es geht darum um welche Zeit er als letztes festgehalten hat das ASC eine Fahrt initialisiert hat, das wird festgehalten und von dieser Zeit aus müssen laut dem Rollo mindestens 27s vergangen sein.
Also. Lasse das Rollo in shading Pos fahren, warte 30s und dann fahre von Hand hoch.
Das TuxNet Wiki:
JWRu
Jetzt wurde die Fahrt erkannt.
2020-04-14 15:16:31 DUOFERN Rollladen_EZ_Mitte moving: up
2020-04-14 15:16:31 DUOFERN Rollladen_EZ_Mitte set_up
2020-04-14 15:16:39 AutoShuttersControl myASC Rollladen_EZ_Mitte_PosValue: 100
2020-04-14 15:16:39 DUOFERN Rollladen_EZ_Mitte opened
2020-04-14 15:16:39 DUOFERN Rollladen_EZ_Mitte moving: stop
2020-04-14 15:16:39 DUOFERN Rollladen_EZ_Mitte position: 100
2020-04-14 15:16:39 DUOFERN Rollladen_EZ_Mitte ASC_ShuttersLastDrive: manual
          'moving: up'
          'set_up'
          'state: opened',
          'moving: stop',
          'position: 100'
Notify:  ASC_Pos_Reading Event vom Rollo wurde erkannt  - RECEIVED EVENT: EventProcessingShutters:  Fn wurde durch Notify aufgerufen da ASC_Pos_Reading Event erkannt wurde  - RECEIVED EVENT: $VAR1 = 'state: opened moving: stop position: 100
          'Rollladen_EZ_Mitte_PosValue: 100'
EventProcessingShutters: Rollladen_EZ_Mitte - Event vom Rollo erkannt. Es wird nun eine etwaige manuelle Fahrt ausgewertet. Int von gettimeofday: 1586870199 Last Position Timestamp: 1586869353 Drive Up Max Duration: 27 Last Position: 100 aktuelle Position: 100
          'state: manual'
CoolTux
Ich habe mal noch die Änderungen der letzten 24 Stunden mit in den Branch eingebracht. Kannst gerne noch mal runter laden und testen.
Ist dann der selbe Stand wie der welcher morgen über Update kommt mit Ausnahme der erweiterten Logausgabe.
Das TuxNet Wiki:
JWRu
Ich komme heute nicht mehr dazu. Ich mache morgen früh mal ein Update und teste dann weiter.
CoolTux
Aber bitte kein FHEM Update, sondern das aus meinen Git
Das TuxNet Wiki:
JWRu
Ok.
ich habe gerade noch einen Versuch mit einem anderen Rollladen gemacht, der schon eine Zeitlang in der Beschattung war. event-on-change-reading ist auf .* gesetzt.
Hier wurde die Fahrt nicht erkannt.
Event Monitor:
2020-04-14 15:42:30 DUOFERN Rollladen_Kueche moving: up
2020-04-14 15:42:30 DUOFERN Rollladen_Kueche set_up
2020-04-14 15:42:38 DUOFERN Rollladen_Kueche opened
2020-04-14 15:42:38 DUOFERN Rollladen_Kueche moving: stop
2020-04-14 15:42:38 DUOFERN Rollladen_Kueche position: 100
2020-04-14 15:42:49 DUOFERN Rollladen_Kueche moving: down
2020-04-14 15:42:49 DUOFERN Rollladen_Kueche set_position 30
2020-04-14 15:42:49 AutoShuttersControl myASC Rollladen_Kueche_lastPosValue: 100
2020-04-14 15:42:56 AutoShuttersControl myASC Rollladen_Kueche_PosValue: 70
2020-04-14 15:42:56 DUOFERN Rollladen_Kueche 70
2020-04-14 15:42:56 DUOFERN Rollladen_Kueche moving: stop
2020-04-14 15:42:56 DUOFERN Rollladen_Kueche position: 70
Log:AutoShuttersControl (myASC) - Devname: Rollladen_Kueche Name: myASC Notify: $VAR1 = [
          'moving: up'
          'set_up'
          'state: opened',
          'moving: stop',
          'position: 100'
          'battery: ok',
          'brightness: 5530.75',
          'state: B: 5530.75',
          'batteryState: ok',
          'brightnessDamped: 9733.449'
          'battery: ok',
          'brightness: 16700.23',
          'state: B: 16700.23',
          'batteryState: ok',
          'brightnessDamped: 80617.346'
          'moving: down'
          'set_position 30'
          'Rollladen_Kueche_lastPosValue: 100'
          'state: 70',
          'moving: stop',
          'position: 70'
Notify:  ASC_Pos_Reading Event vom Rollo wurde erkannt  - RECEIVED EVENT: EventProcessingShutters:  Fn wurde durch Notify aufgerufen da ASC_Pos_Reading Event erkannt wurde  - RECEIVED EVENT: $VAR1 = 'state: 70 moving: stop position: 70
          'Rollladen_Kueche_PosValue: 70'
EventProcessingShutters: Rollladen_Kueche - Event vom Rollo erkannt. Es wird nun eine etwaige manuelle Fahrt ausgewertet. Int von gettimeofday: 1586871776 Last Position Timestamp: 1586871769 Drive Up Max Duration: 24 Last Position: 100 aktuelle Position: 70
          'state: shading in'
          'azimuth: 228.82',
          'elevation: 41.83',
          'twilight: 100',
          'compasspoint: southwest'
          'battery: ok',
          'brightness: 5226.16',
          'state: B: 5226.16',
          'batteryState: ok',
          'brightnessDamped: 8918.217'
          'battery: ok',
          'brightness: 14593.72',
          'state: B: 14593.72',
          'batteryState: ok',
          'brightnessDamped: 68534.966'
CoolTux
Das TuxNet Wiki:
octek0815
ich denke nicht das es was mit der Beschattung zu tun hat. Wie bereits schon mal geschrieben ich habe zwei Device Typen. Rademacher (DUOFERN) und Homematic (CUL_HM).
Bei allen DUOFERN Rollläden wird das Reading ASC_ShuttersLastDrive korrekt gesetzt. Nur bei meinen beiden CUL_HM Rollladen-Aktoren nicht.
Ich habe mir mal vorhin die Mühe gemacht und das komplette ASC Device gelöscht und somit waren auch alle Attribute aus den Rollläden Devices weg.
Nun habe alles jungfräulich angelegt und das Reading wir weiterhin bei nur bei den beiden CUL_HM Rollladen-Aktoren nicht aktualisiert geschweige überhaupt erzeugt.
Auch bei kurzen Fahrten mit den DUOFERN Rollläden wird das Reading einwandfrei aktualisiert.
Hier nochmal ein List der Komponenten:
ASC Device
   CFGFN
   FUUID      5e95efd7-f33f-445e-01b1-0caae115366d123d
   FVERSION   73_AutoShuttersControl.pm:v0.8.27-s21662/2020-04-13 TESTING
   MID        da39a3ee5e6b4b0d3255bfef95601890afd80709
   NAME       System_Rollladensteuerung
   NOTIFYDEV  Arbeitszimmer_OG_Fensterrollladen1,Arbeitszimmer_OG_Fensterrollladen2,Arbeitszimmer_OG_Fenstersensor1,Arbeitszimmer_OG_Fenstersensor2,Badezimmer_EG_Fensterrollladen,Badezimmer_EG_Fenstersensor,Badezimmer_OG_Dachfensterrollladen,Badezimmer_OG_Dachfenstersensor,Flur_OG_Dachfensterrollladen,Flur_OG_Dachfenstersensor,HWR1_EG_Fensterrollladen,HWR1_EG_Fenstersensor,HWR2_EG_Fensterrollladen,HWR2_EG_Fenstersensor,Kinderzimmer1_OG_Fensterrollladen,Kinderzimmer1_OG_Fenstersensor,Kinderzimmer2_OG_Fensterrollladen,Kinderzimmer2_OG_Fenstersensor,Kueche_EG_Fensterrollladen,Kueche_EG_Fenstersensor,Schlafzimmer_EG_Fensterrollladen,Schlafzimmer_EG_Fenstersensor,System_Rollladensteuerung,Wohnzimmer_EG_Fensterrollladen,Wohnzimmer_EG_Fenstersensor,Wohnzimmer_EG_Terrassentuerrollladen,Wohnzimmer_EG_Terrassentuersensor,global,httpmodFronius1,modbusFroniusMPPT
   NR         5790
   NTFY_ORDER 51-System_Rollladensteuerung
   STATE      manual
   TYPE       AutoShuttersControl
   VERSION    v0.8.27
     2020-04-14 19:20:30   Arbeitszimmer_OG_Fensterrollladen1_PosValue 0
     2020-04-14 19:18:02   Arbeitszimmer_OG_Fensterrollladen1_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Arbeitszimmer_OG_Fensterrollladen2_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Badezimmer_EG_Fensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Badezimmer_OG_Dachfensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Flur_OG_Dachfensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   HWR1_EG_Fensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   HWR2_EG_Fensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Kinderzimmer1_OG_Fensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Kinderzimmer2_OG_Fensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Kueche_EG_Fensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Schlafzimmer_EG_Fensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:02   Wohnzimmer_EG_Fensterrollladen_nextAstroTimeEvent 14.04.2020 - 20:54
     2020-04-14 19:18:41   Wohnzimmer_EG_Terrassentuerrollladen_nextAstroTimeEvent 14.04.2020 - 21:00
     2020-04-14 19:16:07   ascEnable       on
     2020-04-14 19:16:07   controlShading  off
     2020-04-14 19:16:07   hardLockOut     off
     2020-04-14 19:17:59   room_Arbeitszimmer_OG Arbeitszimmer_OG_Fensterrollladen1,Arbeitszimmer_OG_Fensterrollladen2
     2020-04-14 19:17:59   room_Badezimmer_EG Badezimmer_EG_Fensterrollladen
     2020-04-14 19:17:59   room_Badezimmer_OG Badezimmer_OG_Dachfensterrollladen
     2020-04-14 19:17:59   room_Flur_OG    Flur_OG_Dachfensterrollladen
     2020-04-14 19:17:59   room_HWR1_EG    HWR1_EG_Fensterrollladen
     2020-04-14 19:17:59   room_HWR2_EG    HWR2_EG_Fensterrollladen
     2020-04-14 19:17:59   room_Kinderzimmer1_OG Kinderzimmer1_OG_Fensterrollladen
     2020-04-14 19:17:59   room_Kinderzimmer2_OG Kinderzimmer2_OG_Fensterrollladen
     2020-04-14 19:17:59   room_Kueche_EG  Kueche_EG_Fensterrollladen
     2020-04-14 19:17:59   room_Schlafzimmer_EG Schlafzimmer_EG_Fensterrollladen
     2020-04-14 19:17:59   room_Wohnzimmer_EG Wohnzimmer_EG_Fensterrollladen,Wohnzimmer_EG_Terrassentuerrollladen
     2020-04-14 19:16:07   selfDefense     off
     2020-04-14 19:20:30   state           manual
     2020-04-14 19:16:07   sunriseTimeWeHoliday off
     2020-04-14 19:17:59   userAttrList    rolled out
   helper:
     shuttersList:
   monitoredDevs:
     Arbeitszimmer_OG_Fensterrollladen1:
     Arbeitszimmer_OG_Fenstersensor1:
       Arbeitszimmer_OG_Fensterrollladen1 ASC_WindowRec
     Arbeitszimmer_OG_Fenstersensor2:
       Arbeitszimmer_OG_Fensterrollladen2 ASC_WindowRec
     Badezimmer_EG_Fenstersensor:
       Badezimmer_EG_Fensterrollladen ASC_WindowRec
     Badezimmer_OG_Dachfensterrollladen:
     Badezimmer_OG_Dachfenstersensor:
       Badezimmer_OG_Dachfensterrollladen ASC_WindowRec
     Flur_OG_Dachfenstersensor:
       Flur_OG_Dachfensterrollladen ASC_WindowRec
     HWR1_EG_Fenstersensor:
       HWR1_EG_Fensterrollladen ASC_WindowRec
     HWR2_EG_Fenstersensor:
       HWR2_EG_Fensterrollladen ASC_WindowRec
     Kinderzimmer1_OG_Fenstersensor:
       Kinderzimmer1_OG_Fensterrollladen ASC_WindowRec
     Kinderzimmer2_OG_Fenstersensor:
       Kinderzimmer2_OG_Fensterrollladen ASC_WindowRec
     Kueche_EG_Fenstersensor:
       Kueche_EG_Fensterrollladen ASC_WindowRec
     Schlafzimmer_EG_Fenstersensor:
       Schlafzimmer_EG_Fensterrollladen ASC_WindowRec
     Wohnzimmer_EG_Fenstersensor:
       Wohnzimmer_EG_Fensterrollladen ASC_WindowRec
     Wohnzimmer_EG_Terrassentuersensor:
       Wohnzimmer_EG_Terrassentuerrollladen ASC_WindowRec
     httpmodFronius1:
       Arbeitszimmer_OG_Fensterrollladen1 ASC_BrightnessSensor
       Arbeitszimmer_OG_Fensterrollladen2 ASC_BrightnessSensor
       Kueche_EG_Fensterrollladen ASC_BrightnessSensor
       Wohnzimmer_EG_Fensterrollladen ASC_BrightnessSensor
     modbusFroniusMPPT:
       Badezimmer_EG_Fensterrollladen ASC_BrightnessSensor
       Badezimmer_OG_Dachfensterrollladen ASC_BrightnessSensor
       Flur_OG_Dachfensterrollladen ASC_BrightnessSensor
       HWR1_EG_Fensterrollladen ASC_BrightnessSensor
       HWR2_EG_Fensterrollladen ASC_BrightnessSensor
       Schlafzimmer_EG_Fensterrollladen ASC_BrightnessSensor
       Wohnzimmer_EG_Terrassentuerrollladen ASC_BrightnessSensor
   ASC_autoAstroModeEvening HORIZON
   ASC_autoAstroModeEveningHorizon -6
   ASC_autoAstroModeMorning HORIZON
   ASC_autoShuttersControlComfort on
   ASC_autoShuttersControlEvening on
   ASC_autoShuttersControlMorning on
   ASC_expert 1
   ASC_residentsDev dResidents
   ASC_shuttersDriveDelay 30
   ASC_tempSensor Garten_TempRH_Sensor:temperature
   ASC_twilightDevice twilightWathlingen
   devStateIcon { AutoShuttersControl_DevStateIcon($name) }
   icon       fts_shutter_automatic
   room       System
DUOFERN Rollladen
   CODE       42F9B5
   DEF        42F9B5
   FUUID      5c441e66-f33f-445e-16d0-9356576f0444be39
   IODev      Rademacher
   LASTInputDev Rademacher
   MODEL      Rohrmotor-Aktor
   MSGCNT     12
   NAME       Arbeitszimmer_OG_Fensterrollladen1
   NR         701
   Rademacher_MSGCNT 12
   Rademacher_RAWMSG 0FFF0F230900002050321D6433000842F9B5FFFFFF01
   Rademacher_TIME 2020-04-14 19:20:30
   STATE      closed
   SUBTYPE    Rohrmotor-Aktor
   TYPE       DUOFERN
   OLDREADINGS:
     2020-04-14 19:17:59   ASC_Enable      on
     2020-04-14 19:20:31   ASC_ShuttersLastDrive manual
     2020-04-14 19:19:04   ASC_Time_DriveDown 14.04.2020 - 20:54
     2020-04-14 19:19:04   ASC_Time_DriveUp 15.04.2020 - 06:27
     2020-04-14 19:17:59   associatedWith  System_Rollladensteuerung
     2020-04-14 19:20:30   blindsMode      off
     2020-04-14 19:20:30   dawnAutomatic   off
     2020-04-14 19:20:30   duskAutomatic   off
     2020-04-14 19:20:30   manualMode      on
     2020-04-14 19:20:30   motorDeadTime   off
     2020-04-14 19:20:30   moving          stop
     2020-04-14 19:20:30   position        0
     2020-04-14 19:20:30   rainAutomatic   off
     2020-04-14 19:20:30   rainDirection   up
     2020-04-14 19:20:30   rainMode        off
     2020-04-14 19:20:30   reversal        off
     2020-04-14 19:20:30   runningTime     29
     2020-04-14 19:20:30   state           closed
     2020-04-14 19:20:30   sunAutomatic    off
     2020-04-14 19:20:30   sunMode         off
     2020-04-14 19:20:30   sunPosition     50
     2020-04-14 19:20:30   timeAutomatic   off
     2020-04-14 19:20:30   ventilatingMode off
     2020-04-14 19:20:30   ventilatingPosition 20
     2020-04-14 19:20:30   version         3.3
     2020-04-14 19:20:30   windAutomatic   off
     2020-04-14 19:20:30   windDirection   up
     2020-04-14 19:20:30   windMode        off
   helper:
     desiredPosition 100
   ASC        1
   ASC_BrightnessSensor httpmodFronius1:urPower_P_Generate_60MinuteAverage
   ASC_Closed_Pos 100
   ASC_Open_Pos 0
   ASC_Pos_Reading position
   ASC_Shading_InOutAzimuth 113:263
   ASC_Shading_MinMax_Elevation 25
   ASC_Shading_Min_OutsideTemperature 18
   ASC_Shading_Mode always
   ASC_Shading_Pos 90
   ASC_Shading_StateChange_SunnyCloudy 4250:3250
   ASC_Shading_WaitingPeriod 5
   ASC_ShuttersPlace window
   ASC_Time_Down_Early 15:30
   ASC_Time_Down_Late 22:30
   ASC_Time_Up_Early 06:15
   ASC_Time_Up_Late 09:00
   ASC_Time_Up_WE_Holiday 09:00
   ASC_Ventilate_Pos 80
   ASC_Ventilate_Window_Open off
   ASC_WindowRec Arbeitszimmer_OG_Fenstersensor1
   ASC_WindowRec_subType threestate
   IODev      Rademacher
   devStateIcon MISSING.*:message_attention2 closed:shutter180_open opened:shutter180_closed 9\d.*:shutter180_7 8\d.*:shutter180_6 7\d.*:shutter180_halfopen 6\d.*:shutter180_halfopen 5\d.*:shutter180_3 4\d.*:shutter180_3 3\d.*:shutter180_2 2\d.*:shutter180_1 1\d.*:shutter180_1 0\d.*:shutter180_open 1:shutter180_open 2:shutter180_open 3:shutter180_open 4:shutter180_open 5:shutter180_open 6:shutter180_open 7:shutter180_open 8:shutter180_open 9:shutter180_open
   icon       fts_shutter_updown
   positionInverse 1
   room       Arbeitszimmer_OG
   userattr   ASC_Adv:on,off ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforDayOpen ASC_BlockingTime_beforNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Down:time,astro,brightness,roommate ASC_DriveUpMaxDuration ASC_Drive_Delay ASC_Drive_DelayStart ASC_ExternalTrigger ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownValue_beforeNightClose ASC_PrivacyDown_Pos ASC_PrivacyUpValue_beforeDayOpen ASC_PrivacyUp_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_AbsentDelay ASC_Self_Defense_Mode:absent,gone,off ASC_Shading_InOutAzimuth ASC_Shading_MinMax_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_SunnyCloudy ASC_Shading_WaitingPeriod ASC_Shutter_IdleDetection ASC_ShuttersPlace:window,terrace ASC_Sleep_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_TempSensor ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness,roommate ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_PosAfterDayClosed:open,lastManual ASC_WindowRec_subType:twostate,threestate
   verbose    0
   webCmd     getStatus:up:stop:down:position
   DEF        2AC8EF
   FUUID      5c441e66-f33f-445e-76c3-917b17f8afca642b
   IODev      hmuartwlangw1
   LASTInputDev hmusb
   MSGCNT     39
   NAME       Flur_OG_Dachfensterrollladen
   NOTIFYDEV  global
   NR         665
   NTFY_ORDER 50-Flur_OG_Dachfensterrollladen
   STATE      up
   TYPE       CUL_HM
   chanNo     01
   hmuartwlangw1_MSGCNT 13
   hmuartwlangw1_RAWMSG 05000135CD84102AC8EF0000000601C800
   hmuartwlangw1_RSSI -53
   hmuartwlangw1_TIME 2020-04-14 16:39:22
   hmuartwlangw2_MSGCNT 13
   hmuartwlangw2_RAWMSG 0500002CCD84102AC8EF0000000601C800
   hmuartwlangw2_RSSI -44
   hmuartwlangw2_TIME 2020-04-14 16:39:22
   hmusb_MSGCNT 13
   hmusb_RAWMSG E2AC8EF,0000,F1B094AE,FF,FFE2,CD84102AC8EF0000000601C800
   hmusb_RSSI -30
   hmusb_TIME 2020-04-14 16:39:22
   lastMsg    No:CD - t:10 s:2AC8EF d:000000 0601C800
   protLastRcv 2020-04-14 16:39:22
   protRcv    13 last_at:2020-04-14 16:39:22
   protSnd    8 last_at:2020-04-14 16:39:05
   protState  CMDs_done
   rssi_at_hmuartwlangw1 cnt:13 min:-56 max:-53 avg:-53.76 lst:-53
   rssi_at_hmuartwlangw2 cnt:13 min:-50 max:-43 avg:-45.69 lst:-44
   rssi_at_hmusb cnt:13 min:-30 max:-27 avg:-28.69 lst:-30
   rssi_hmuartwlangw1 cnt:7 min:-63 max:-58 avg:-59.71 lst:-58
   OLDREADINGS:
     2020-04-14 16:39:05   CommandAccepted yes
     2019-01-12 11:40:14   D-firmware      1.7
     2019-01-12 11:40:14   D-serialNr      LEQ0475590
     2019-11-24 13:32:58   PairedTo        0x987123
     2019-11-24 14:47:06   R-driveDown     48 s
     2019-11-24 14:47:06   R-driveTurn     0.5 s
     2019-11-24 14:47:06   R-driveUp       48 s
     2019-11-24 14:47:06   R-pairCentral   0x987123
     2019-11-24 14:47:06   R-sign          off
     2020-04-14 16:39:22   deviceMsg       off (to broadcast)
     2020-04-14 16:39:22   level           0
     2020-04-14 16:39:22   motor           stop:off
     2020-04-14 16:39:22   pct             0
     2016-01-08 15:55:57   powerOn         2016-01-08 15:55:57
     2020-04-14 16:39:22   recentStateType info
     2020-04-14 16:39:22   rssi_at_hmuartwlangw1 -53
     2020-04-14 16:39:22   rssi_at_hmuartwlangw2 -44
     2020-04-14 16:39:22   rssi_at_hmusb   -30
     2020-04-14 16:39:05   rssi_hmuartwlangw1 -58
     2020-04-14 16:39:22   state           off
     2020-04-14 16:39:22   timedOn         off
   helper:
     HM_CMDNR   205
     cSnd       119871232AC8EF0201A8,119871232AC8EF0201C8
     dlvlCmd    ++A0119871232AC8EF0201C8
     mId        0005
     peerFriend peerSens,peerVirt
     peerOpt    3:blindActuator
     regLst     0,1,3p
     rxType     1
     supp_Pair_Rep 0
     ack:
     dir:
       cur        stop
       rct        up
     expert:
       def        1
       det        0
       raw        0
       tpl        0
     io:
       newChn     +2AC8EF,00,01,00
       nextSend   1586875162.36696
       rxt        0
       vccu       vccu
       p:
         2AC8EF
         00
         01
         00
       prefIO:
         hmuartwlangw1
         hmuartwlangw2
         hmusb
     mRssi:
       mNo        CD
       io:
         hmuartwlangw1:
           -47
           -47
         hmuartwlangw2:
           -44
           -44
         hmusb:
           -30
           -30
     prt:
       bErr       0
       sProc      0
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rssi:
       at_hmuartwlangw1:
         avg        -53.7692307692308
         cnt        13
         lst        -53
         max        -53
         min        -56
       at_hmuartwlangw2:
         avg        -45.6923076923077
         cnt        13
         lst        -44
         max        -43
         min        -50
       at_hmusb:
         avg        -28.6923076923077
         cnt        13
         lst        -30
         max        -27
         min        -30
       hmuartwlangw1:
         avg        -59.7142857142857
         cnt        7
         lst        -58
         max        -58
         min        -63
     shadowReg:
     tmpl:
   ASC        1
   ASC_BrightnessSensor modbusFroniusMPPT:urPower_DC_String_1_60MinuteAverage
   ASC_Closed_Pos 100
   ASC_LockOut soft
   ASC_Open_Pos 0
   ASC_Pos_Reading pct
   ASC_Shading_InOutAzimuth 0:180
   ASC_Shading_Pos 90
   ASC_Shading_StateChange_SunnyCloudy 2500:1750
   ASC_ShuttersPlace terrace
   ASC_Ventilate_Pos 90
   ASC_WindowRec Flur_OG_Dachfenstersensor
   ASC_WindowRec_subType twostate
   IODev      hmusb
   IOgrp      vccu:hmuartwlangw1,hmuartwlangw2,hmusb
   autoReadReg 4_reqStatus
   devStateIcon MISSING.*:message_attention up:shutter_open off:shutter_open down:shutter_closed on:shutter_closed 9\d.*:shutter_7 8\d.*:shutter_6 7\d.*:shutter_5 6\d.*:shutter_4 5\d.*:shutter_halfopen 4\d.*:shutter_3 3\d.*:shutter_2 2\d.*:shutter_1 1\d.*:shutter_open 0\d.*:shutter_open
   eventMap   on:down off:up
   expert     0_defReg
   firmware   1.7
   icon       fts_roof_shutter_updown
   model      HM-LC-BL1-SM
   param      levelInverse
   peerIDs    00000000,
   room       Flur_OG
   rssiLog    1
   serialNr   LEQ0475590
   subType    blindActuator
   webCmd     statusRequest:up:stop:down:pct
Olli
octek0815
Nachtrag:
Hier noch ein Log (Verbose 5). Habe einen Homematic Rollladen auf 15 gestellt:
2020.04.14 19:42:18 4: AutoShuttersControl (Wohnzimmer_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:18 4: AutoShuttersControl (Arbeitszimmer_OG_Fensterrollladen2) - EventProcessingShadingBrightness
2020.04.14 19:42:18 4: AutoShuttersControl (Arbeitszimmer_OG_Fensterrollladen1) - EventProcessingShadingBrightness
2020.04.14 19:42:18 4: AutoShuttersControl (Kueche_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:22 4: AutoShuttersControl (System_Rollladensteuerung) - Devname: Flur_OG_Dachfensterrollladen Name: System_Rollladensteuerung Notify: [
  'level: set_15'
  'state: set_15'
2020.04.14 19:42:22 3: CUL_HM set Flur_OG_Dachfensterrollladen pct 15
  'deviceMsg: up (to vccu)',
  'level: 0',
  'motor: down:up',
  'rssi_at_hmuartwlangw2: -43',
  'rssi_hmuartwlangw1: -60',
  'state: off'
  'rssi_at_hmuartwlangw1: -54'
  'rssi_at_hmusb: -29',
  'RAWMSG: E2AC8EF,0000,F25820AC,FF,FFE3,CE80022AC8EF9871230101C8203C',
  'RSSI: -29'
2020.04.14 19:42:23 4: AutoShuttersControl (System_Rollladensteuerung) - Devname: httpmodFronius1 Name: System_Rollladensteuerung Notify: [
  'Power_P_Grid: 367.94',
  'Power_P_Load: -807.94000000000005',
  'Power_P_Generate: 440',
  'Relative_Current_Autonomy: 54.459489566056888',
  'EnergyReal_WAC_Sum_EverSince: 34186800',
  'urStrombezugAktuellInWatt: 367.94',
  'urPVEigenverbrauchAktuellInWatt: 440',
  'urStromGesamtverbrauchAktuellInWatt: 807.94'
2020.04.14 19:42:23 4: AutoShuttersControl (Wohnzimmer_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:23 4: AutoShuttersControl (Arbeitszimmer_OG_Fensterrollladen2) - EventProcessingShadingBrightness
2020.04.14 19:42:23 4: AutoShuttersControl (Arbeitszimmer_OG_Fensterrollladen1) - EventProcessingShadingBrightness
2020.04.14 19:42:23 4: AutoShuttersControl (Kueche_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:27 4: AutoShuttersControl (System_Rollladensteuerung) - Devname: modbusFroniusMPPT Name: System_Rollladensteuerung Notify: [
  'Power_String2__W: 401',
  'urPVString2AktuellInWatt: 401'
2020.04.14 19:42:27 4: AutoShuttersControl (Badezimmer_OG_Dachfensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:27 4: AutoShuttersControl (Flur_OG_Dachfensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:27 4: AutoShuttersControl (Badezimmer_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:27 4: AutoShuttersControl (Wohnzimmer_EG_Terrassentuerrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:27 4: AutoShuttersControl (HWR2_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:27 4: AutoShuttersControl (HWR1_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:27 4: AutoShuttersControl (Schlafzimmer_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:28 4: AutoShuttersControl (System_Rollladensteuerung) - Devname: httpmodFronius1 Name: System_Rollladensteuerung Notify: [
  'Power_P_Grid: 380.49000000000001',
  'Power_P_Load: -813.49000000000001',
  'Power_P_Generate: 433',
  'Relative_Current_Autonomy: 53.227452089146766',
  'urStrombezugAktuellInWatt: 380.49000000000001',
  'urPVEigenverbrauchAktuellInWatt: 433',
  'urStromGesamtverbrauchAktuellInWatt: 813.49'
2020.04.14 19:42:28 4: AutoShuttersControl (Wohnzimmer_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:28 4: AutoShuttersControl (Arbeitszimmer_OG_Fensterrollladen2) - EventProcessingShadingBrightness
2020.04.14 19:42:28 4: AutoShuttersControl (Arbeitszimmer_OG_Fensterrollladen1) - EventProcessingShadingBrightness
2020.04.14 19:42:28 4: AutoShuttersControl (Kueche_EG_Fensterrollladen) - EventProcessingShadingBrightness
2020.04.14 19:42:33 4: AutoShuttersControl (System_Rollladensteuerung) - Devname: Flur_OG_Dachfensterrollladen Name: System_Rollladensteuerung Notify: [
  'deviceMsg: 15 (to broadcast)',
  'level: 15',
  'motor: stop:15',
  'pct: 15',
  'state: 15'
  'rssi_at_hmuartwlangw2: -42'
  'rssi_at_hmusb: -30',
  'RSSI: -30',
  'RAWMSG: E2AC8EF,0000,F2584A26,FF,FFE2,CF84102AC8EF0000000601AA00'
