[73_AutoShuttersControl.pm] Rolllos automatisiert steuern - Version 0.10
Begonnen von CoolTux, 22 Juni 2020, 12:38:36
h-man-kl
Hier Das List vom NICH-funktionierenden Device:
   04.06.HMLANGW_MSGCNT 12
   04.06.HMLANGW_RAWMSG 05000053F2A41065B90B1511AB0601C800
   04.06.HMLANGW_RSSI -83
   04.06.HMLANGW_TIME 2021-04-21 06:34:37
   DEF        65B90B
   FUUID      6071c220-f33f-627b-e0ce-06fe97e79c24d68a
   HmUART_01_MSGCNT 13
   HmUART_01_RAWMSG 0501003EF2A41065B90B1511AB0601C800
   HmUART_01_RSSI -62
   HmUART_01_TIME 2021-04-21 06:34:37
   HomeMatic_MSGCNT 13
   HomeMatic_RAWMSG E65B90B,0000,0C9CCDFF,FF,FFD2,F2A41065B90B1511AB0601C800
   HomeMatic_RSSI -46
   HomeMatic_TIME 2021-04-21 06:34:37
   IODev      HmUART_01
   LASTInputDev HomeMatic
   MSGCNT     38
   NAME       01.05.RollladenBalkon
   NOTIFYDEV  global
   NR         1448
   NTFY_ORDER 50-01.05.RollladenBalkon
   STATE      rauf
   TYPE       CUL_HM
   chanNo     01
   lastMsg    No:F2 - t:10 s:65B90B d:1511AB 0601C800
   protCmdDel 1
   protLastRcv 2021-04-21 06:34:37
   protRcv    13 last_at:2021-04-21 06:34:37
   protResnd  4 last_at:2021-04-20 20:43:26
   protResndFail 1 last_at:2021-04-19 15:47:08
   protSnd    13 last_at:2021-04-21 06:34:37
   protState  CMDs_done
   rssi_HmUART_01 cnt:9 min:-72 max:-70 avg:-71.22 lst:-72
   rssi_at_04.06.HMLANGW cnt:12 min:-83 max:-76 avg:-79.66 lst:-83
   rssi_at_HmUART_01 cnt:13 min:-62 max:-61 avg:-61.76 lst:-62
   rssi_at_HomeMatic cnt:13 min:-48 max:-46 avg:-46.53 lst:-46
     2021-04-10 17:43:10   ASC_Enable      on
     2021-04-21 06:33:37   ASC_Time_DriveDown 21.04.2021 - 20:44
     2021-04-21 06:33:37   ASC_Time_DriveUp 22.04.2021 - 06:31
     2021-04-21 06:33:39   CommandAccepted yes
     2021-04-10 17:20:56   D-firmware      2.11
     2021-04-10 17:20:56   D-serialNr      OEQ1970031
     2021-04-11 12:45:13   PairedTo        0x1511AB
     2021-04-11 12:45:13   RegL_00.        00:00 02:01 0A:15 0B:11 0C:AB 15:FF 18:00
     2021-04-11 12:45:14   RegL_01.        00:00 08:00 09:00 0A:00 0B:01 0C:F4 0D:01 0E:F4 0F:05 10:00 30:06 56:00 57:24
     2021-04-11 12:46:02   cfgState        ok
     2021-04-21 06:34:37   commState       CMDs_done
     2021-04-21 06:34:37   deviceMsg       on (to VCCU)
     2021-04-21 06:34:37   level           100
     2021-04-21 06:34:37   motor           stop:on
     2021-04-21 06:34:37   pct             100
     2021-04-11 12:44:37   powerOn         2021-04-11 12:44:37
     2021-04-21 06:34:37   recentStateType info
     2021-04-21 06:34:37   state           on
     2021-04-21 06:34:37   timedOn         off
     2021-04-21 06:33:40   trigLast        fhem:02
   helper:
     HM_CMDNR   242
     cSnd       111511AB65B90B020100,111511AB65B90B0201C8
     dlvlCmd    ++A0111511AB65B90B0201C8
     mId        0005
     peerFriend peerSens,peerVirt
     peerIDsState complete
     peerOpt    3:blindActuator
     regLst     0,1,3p
     rxType     1
     supp_Pair_Rep 0
     ack:
     cmds:
       TmplKey    :no:1618839891.98173
       TmplTs     1618839891.98173
       cmdKey     1:1:0::01.05.RollladenBalkon:0005:01:
       cmdLst:
         assignHmKey noArg
         clear      [(readings|trigger|register|oldRegs|rssi|msgEvents|{msgErrors}|attack|all)]
         deviceRename -newName-
         down       'change:'[(0..100;1|{10})] [(-ontime-|{})] [(-ramptime-|{})]
         fwUpdate   -filename- [-bootTime-]
         getConfig  noArg
         getDevInfo noArg
         getRegRaw  (List0|List1|List2|List3|List4|List5|List6|List7) [-peerChn-]
         getVersion noArg
         inhibit    [(on|{off})]
         off        noArg
         on         noArg
         pair       noArg
         pct        -value- [-ontime-]
         peerBulk   -peer1,peer2,...- [({set}|unset)]
         peerIODev  [IO] -btn- [({set}|unset)] 'not for future use'
         peerSmart  -peerOpt-
         press      [(long|{short})] [(-peer-|{self01})] [(-repCount-|{0})] [(-repDelay-|{0.25})]
         raw        -data- [...]
         regBulk    -list-.-peerChn- -addr1:data1- -addr2:data2-...
         regSet     [(prep|{exec})] -regName- -value- [-peerChn-]
         reset      noArg
         sign       [(on|{off})]
         statusRequest noArg
         stop       noArg
         toggle     noArg
         toggleDir  noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
         up         'change:'[(0..100;1|{10})] [(-ontime-|{})] [(-ramptime-|{})]
       lst:
         condition  slider,0,1,255
         peer
         peerOpt    00.00.3Kanaltaster_Sw_01,00.00.3Kanaltaster_Sw_02,00.00.3Kanaltaster_Sw_03,00.05.TasterWandleuchten_Btn_01,00.05.TasterWandleuchten_Btn_02,00_02_TFK_Kellertuer,00_03_TFK_Waschkuechentuer,00_04_TFK_SZ,00_05_TFK_WZ,00_06_TFK_Haustuer,01.03.Taster2fach.01_Btn_01,01.03.Taster2fach.01_Btn_02,01.03.Taster2fach.02_Btn_01,01.03.Taster2fach.02_Btn_02,01.03.Taster2fachTuer01_Btn_01,01.03.Taster2fachTuer01_Btn_02,01.03.TasterKueche_Btn_01,01.03.TasterKueche_Btn_02,01.03.TasterKueche_Btn_03,01.03.TasterKueche_Btn_04,01.03.TasterKueche_Btn_05,01.03.TasterKueche_Btn_06,01.05.TFK.Balkon,01.05.Taster.Esszimmer_Btn_01,01.05.Taster.Esszimmer_Btn_02,01.05.Taster.Esszimmer_Btn_03,01.05.Taster.Esszimmer_Btn_04,01.05.Taster.Esszimmer_Btn_05,01.05.Taster.Esszimmer_Btn_06,01.05.TasterBalkontuer_Btn_01,01.05.TasterBalkontuer_Btn_02,01_01_TFK_Garagentor,01_01_TFK_Garagentuer,01_03_TFK_Kueche,02.03.TasterBad_Btn_01,02.03.TasterBad_Btn_02,02.03.TasterBad_Btn_03,02.03.TasterBad_Btn_04,02.03.TasterBad_Btn_05,02.03.TasterBad_Btn_06,02_01_TFK_Buero,02_03_TFK_Bad,02_04_TFK_Kind,02_05_TFK_SZ,04_03_TFK_Abstell,04_04_PIR_GartenOben1,Fernbedienung.Michael_light,Fernbedienung.Michael_lock,Fernbedienung.Michael_open,Fernbedienung.Michael_unlock,Fernbedienung.Nadine_light,Fernbedienung.Nadine_lock,Fernbedienung.Nadine_open,Fernbedienung.Nadine_unlock,Fernbedienung.Reserve_light,Fernbedienung.Reserve_lock,Fernbedienung.Reserve_open,Fernbedienung.Reserve_unlock,HM.Haustuerkontakt,HM.PIR.Carport,HM.Pir.Flur.EG.Bewegung,HM.Pir.Flur.EG.Btn.1,HM.Pir.Flur.EG.Btn.2,HM.Pir.Flur.OG.Bewegung,HM.Pir.Flur.OG.Btn.1,HM.Pir.Flur.OG.Btn.2,Rauchmelder.Team,VCCU_Btn1,Wetterstation
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         cmdList    [({short}|long)]
         deviceInfo [({short}|long)]
         list       [({normal}|full)]
         param      -param-
         reg        -addr- -list- [-peerChn-]
         regList    noArg
         regTable   noArg
         regVal     -addr- -list- [-peerChn-]
         saveConfig [-filename-]
         tplInfo    noArg
     dir:
       cur        stop
       rct        up
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       newChn     +65B90B,00,00,00
       nextSend   1618979677.57305
       rxt        0
       vccu       VCCU
       p:
         65B90B
         00
         00
         00
       prefIO:
         HmUART_01
     mRssi:
       mNo        F2
       io:
         04.06.HMLANGW:
           -83
           -83
         HmUART_01:
           -58
           -58
         HomeMatic:
           -46
           -46
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         HmUART_01
       flg        A
       ts         1618979677.04018
       ack:
         HASH(0x79d0940)
         F280021511AB65B90B00
     rssi:
       HmUART_01:
         avg        -71.2222222222222
         cnt        9
         lst        -72
         max        -70
         min        -72
       at_04.06.HMLANGW:
         avg        -79.6666666666667
         cnt        12
         lst        -83
         max        -76
         min        -83
       at_HmUART_01:
         avg        -61.7692307692308
         cnt        13
         lst        -62
         max        -61
         min        -62
       at_HomeMatic:
         avg        -46.5384615384615
         cnt        13
         lst        -46
         max        -46
         min        -48
     shadowReg:
     tmpl:
   ASC        2
   IODev      HmUART_01
   IOgrp      VCCU:HmUART_01
   autoReadReg 4_reqStatus
   devStateIcon rauf:fts_shutter_10 runter:fts_shutter_100
   eventMap   off:runter on:rauf
   expert     rawReg
   firmware   2.11
   group      Klima
   icon       fts_shutter_updown
   model      HM-LC-BL1PBU-FM
   peerIDs    00000000
   room       Rollladen,Wohnzimmer,_CUL_HM
   serialNr   OEQ1970031
   subType    blindActuator
   userattr   room_map structexclude
   webCmd     rauf:runter:stop
und hier vom funktionierenden:
   04.06.HMLANGW_MSGCNT 8
   04.06.HMLANGW_RAWMSG 05000051DBA41065B8C11511AB0601C800
   04.06.HMLANGW_RSSI -81
   DEF        65B8C1
   FUUID      5d7931a3-f33f-627b-c287-f1bfcdec32ce80af
   HmUART_01_MSGCNT 9
   HmUART_01_RAWMSG 05000030DBA41065B8C11511AB0601C800
   HmUART_01_RSSI -48
   HomeMatic_MSGCNT 11
   HomeMatic_RAWMSG E65B8C1,0000,0C9CD060,FF,FFD0,DBA41065B8C11511AB0601C800
   HomeMatic_RSSI -48
   IODev      HomeMatic
   MSGCNT     28
   NAME       01.03.Rollladen
   NOTIFYDEV  global
   NR         1198
   NTFY_ORDER 50-01.03.Rollladen
   STATE      rauf
   TYPE       CUL_HM
   chanNo     01
   lastMsg    No:DB - t:10 s:65B8C1 d:1511AB 0601C800
   protRcv    10 last_at:2021-04-21 06:34:37
   protResnd  1 last_at:2021-04-20 20:43:26
   protSnd    10 last_at:2021-04-21 06:34:37
   protState  CMDs_done
   rssi_HomeMatic cnt:5 min:-46 max:-42 avg:-43.8 lst:-46
   rssi_at_04.06.HMLANGW cnt:8 min:-84 max:-80 avg:-82.12 lst:-81
   rssi_at_HmUART_01 cnt:9 min:-51 max:-47 avg:-48.66 lst:-48
   rssi_at_HomeMatic cnt:11 min:-54 max:-44 avg:-46.54 lst:-48
     2019-09-26 09:01:04   ASC_Enable      on
     2020-04-13 06:47:54   ASC_ShuttersLastDrive day open
     2021-04-21 06:33:36   ASC_Time_DriveDown 21.04.2021 - 20:44
     2021-04-21 06:33:36   ASC_Time_DriveUp 22.04.2021 - 06:31
     2020-03-09 15:28:35   D-firmware      2.11
     2020-03-09 15:28:35   D-serialNr      OEQ1970069
     2021-02-05 20:15:29   PairedTo        0x1511AB
     2019-09-26 09:22:41   R-driveDown     50 s
     2019-09-26 09:22:41   R-driveTurn     0.5 s
     2019-09-26 09:22:41   R-driveUp       50 s
     2019-09-26 09:22:40   R-pairCentral   0x1511AB
     2019-09-26 09:22:41   R-sign          off
     2021-02-05 20:15:29   RegL_00.        00:00 02:01 0A:15 0B:11 0C:AB 15:FF 18:00
     2021-02-05 20:15:30   RegL_01.        00:00 08:00 09:00 0A:00 0B:01 0C:F4 0D:01 0E:F4 0F:05 10:00 30:06 56:00 57:24
     2020-04-10 11:03:00   associatedWith  Rollladensteuerung
     2021-04-11 11:52:15   cfgState        ok
     2021-02-05 20:15:04   powerOn         2021-02-05 20:15:04
     2020-01-12 16:25:39   sabotageAttack_ErrIoAttack cnt 1
   helper:
     HM_CMDNR   219
     cSnd       111511AB65B8C1020100,111511AB65B8C10201C8
     dlvlCmd    ++A0111511AB65B8C10201C8
     mId        0005
     regLst     0,1,3p
     rxType     1
     supp_Pair_Rep 0
     ack:
     cmds:
       TmplKey    :no:1618839890.92572
       TmplTs     1618839890.92572
       cmdKey     1:1:0::01.03.Rollladen:0005:01:
       cmdLst:
         assignHmKey noArg
         getConfig  noArg
         getDevInfo noArg
         getVersion noArg
         off        noArg
         on         noArg
         pair       noArg
         peerSmart  -peerOpt-
         raw        -data- [...]
         reset      noArg
         sign       [(on|{off})]
         statusRequest noArg
         stop       noArg
         toggle     noArg
         toggleDir  noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         peer
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     dir:
       cur        stop
       rct        up
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       newChn     +65B8C1,00,00,00
       nextSend   1618979678.20988
       rxt        0
       vccu       VCCU
       p:
         65B8C1
         00
         00
         00
       prefIO:
         HomeMatic
     mRssi:
       mNo        DB
       io:
         04.06.HMLANGW:
           -81
           -81
         HmUART_01:
           -48
           -48
         HomeMatic:
           -40
           -40
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         HmUART_01
       flg        A
       ts         1618979677.65035
       ack:
         HASH(0x67692e0)
         DB80021511AB65B8C100
     rssi:
       HomeMatic:
         avg        -43.8
         cnt        5
         lst        -46
         max        -42
         min        -46
       at_04.06.HMLANGW:
         avg        -82.125
         cnt        8
         lst        -81
         max        -80
         min        -84
       at_HmUART_01:
         avg        -48.6666666666667
         cnt        9
         lst        -48
         max        -47
         min        -51
       at_HomeMatic:
         avg        -46.5454545454545
         cnt        11
         lst        -48
         max        -44
         min        -54
     shadowReg:
     tmpl:
   ASC        2
   ASC_Adv    on
   ASC_BrightnessSensor Wetterstation:brightness
   ASC_Partymode off
   ASC_Pos_Reading pct
   ASC_Shading_MinMax_Elevation 30.0:80.0
   ASC_Shading_Min_OutsideTemperature 22
   ASC_Shading_Mode always
   ASC_Shading_Pos 50
   ASC_Time_Down_Early 18:00
   ASC_Time_Up_Early 06:00
   ASC_Time_Up_WE_Holiday 08:30
   IODev      HomeMatic
   IOgrp      VCCU:HomeMatic
   alias      Rollladen Küche
   expert     defReg,rawReg
   firmware   2.11
   group      Klima
   peerIDs    00000000
   room       Küche,Rollladen,_CUL_HM
   serialNr   OEQ1970069
   userattr   ASC_Adv:on,off ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforDayOpen ASC_BlockingTime_beforNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Down:time,astro,brightness,roommate ASC_DriveUpMaxDuration ASC_Drive_Delay ASC_Drive_DelayStart ASC_ExternalTrigger ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownValue_beforeNightClose ASC_PrivacyDown_Pos ASC_PrivacyUpValue_beforeDayOpen ASC_PrivacyUp_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_AbsentDelay ASC_Self_Defense_Mode:absent,gone,off ASC_Shading_InOutAzimuth ASC_Shading_MinMax_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_SunnyCloudy ASC_Shading_WaitingPeriod ASC_Shutter_IdleDetection ASC_Sleep_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_TempSensor ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness,roommate ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_PosAfterDayClosed:open,lastManual ASC_WindowRec_subType:twostate,threestate room_map structexclude
Danke und Gruß
H-Man
RasPi 3 mit MaxCube für FS20 , HM-Urart, HM-LAN, MiLight, HUE, Lightify, SONOS, Harmony, Unifi, FritzBox 7490... :-)
Ganz nach dem Motto: Normal? Normal is langweilig....
CoolTux
Und Du hast tatsächlich ein shutter Scan gemacht? Zeig bitte noch list vom ASC Device
Das TuxNet Wiki:
https://www.cooltux.net
Bronze
ZitatZitat von: Bronze am Gestern um 18:59:58
Dürfte ich darum bitten, einmal die wesentlichen Einstellungen zu nennen, um ASC die Beschattung steuern zu lassen, ohne eigene Helligkeitssensoren zu nutzen, sondern "nur" über Online-Wetterdienste wie OpenWeatherMap, DWD oder Proplanta.
Ich hatte zum testen letzten Sommer den Wert für Cloudcover mittels eigenen Reading im Wettermodul in Helligkeit umgerechnet.
Also 100 - Cloudcover. So ist bei 0 Bewölkung am Hellsten und bei bedecken Himmel eben 0.
Dann das eigene Reading im Rollo mit ASC_BrightnessSensor verknüpft und noch die Hell Dunkel Werte (ASC_Shading_StateChange_SunnyCloudy) anpassen.
Ich könnte die Leistung der Photovoltaik-Anlage der letzten 15 Minuten abrufen und diese umrechnen in einen Helligkeitswert.
Aber wie macht man bei einem Reading aus einem Wert von 0 (kein Strom erzeugt) bis ca. 7500 (viel Strom erzeugt) ein passendes Userreading?
ch.eick
Hi, ich verwende von Wetterstationen in meiner Nähe den Brightness Wert und mach mir daraus einen eigenen Wert, der aber nichts mit Wissenschaft zu tun hat.
Das ist das device, was das Ergebnis beinhaltet und im ASC angegeben ist
defmod ASC_Brightness dummy
attr ASC_Brightness DbLogExclude .*
attr ASC_Brightness DbLogInclude brightness
attr ASC_Brightness alias ASC_Brightness
attr ASC_Brightness event-on-change-reading brightness
attr ASC_Brightness group ASC Environment
attr ASC_Brightness icon sani_solar_temp
attr ASC_Brightness readingList brightness
attr ASC_Brightness room Rollos
attr ASC_Brightness setList brightness:slider,0,100,1000
attr ASC_Brightness sortby 06
attr ASC_Brightness stateFormat brightness
Dieses Notify triggert auf einen Update vom Sonnenstand im Astro Device und verrechnet drei Wetterstationen miteinander.
Dadurch habe ich den lokalen Effekt von Wolken raus bekommen. Der Zahlenwert schwankt nicht mehr so stark.
defmod ASC_Brightness_calc notify Astro:SunAlt.* {fhem "setreading ASC_Brightness brightness ".(sprintf("%4.0f", (((ReadingsVal("wetter_II","solarRadiation",0)*0.5 +1) * (ReadingsVal("wetter_II","solarUV",0)*0.8 +1) /4) + ((ReadingsVal("wetter_III","solarRadiation",0)*0.5 +1) * (ReadingsVal("wetter_III","solarUV",0)*0.8 +1) /4) + ((ReadingsVal("wetter_IV","solarRadiation",0)*0.5 +1) * (ReadingsVal("wetter_IV","solarUV",0)*0.8 +1) /4) + ReadingsVal("ASC_Brightness","brightness",0) ) / 4 ));;}
attr ASC_Brightness_calc DbLogExclude .*
attr ASC_Brightness_calc alias ASC_Brightness_calc
attr ASC_Brightness_calc group ASC Environment
attr ASC_Brightness_calc icon access_keypad_2
attr ASC_Brightness_calc room Rollos
attr ASC_Brightness_calc sortby 07
Dieses Device holt die Werte von wunderground und ist bei mir drei mal definiert. Die Stationen, mit UV und Radiation, musst Du Dir auf der wunderground Seite raussuchen.
Für die Abfrage bei wunderground wird nichts weiter benötigt, da ich die öffentliche Seite auslese. Die Abfrage alle 15 Minuten reicht vollkommen aus, das es ja auch drei verschiedene Stationen sind!
defmod wetter_II HTTPMOD https://www.wunderground.com/dashboard/pws/<Station mit UV und Radiation> 900
attr wetter_II userattr reading08OExpr reading10OExpr reading12OExpr reading15OMap
attr wetter_II DbLogExclude .*
attr wetter_II DbLogInclude solarRadiation,solarUV,temperature
attr wetter_II alias wetter_wolfskehlen_II
attr wetter_II enableControlSet 1
attr wetter_II event-on-change-reading solarRadiation,solarUV,temperature
attr wetter_II group ASC Environment
attr wetter_II icon weather_sunrise
attr wetter_II reading01Name date
attr wetter_II reading01Regex Summary<.*>([[:alpha:]]{1,9} [\d]{1,2}, [\d]{4})<\/strong
attr wetter_II reading02Format %.1f
attr wetter_II reading02Name dewpointTemperature
attr wetter_II reading02OExpr UConv::f2c($val,2)
attr wetter_II reading02Regex DEWPOINT.*>([\d\.]+)<\/span>.*PRECIP RATE
attr wetter_II reading03Name dewpointTemperature_EN
attr wetter_II reading03Regex DEWPOINT.*>([\d\.]+)<\/span>.*PRECIP RATE
attr wetter_II reading04Format %.0f
attr wetter_II reading04Name humidity
attr wetter_II reading04Regex HUMIDITY.*>([\d\.]+)<.*WIND
attr wetter_II reading05Name precip1hrmetric
attr wetter_II reading05Regex PRECIP RATE.*>([\d\.]+)<.*PRECIP TOTAL
attr wetter_II reading06Name preciptodaymetric
attr wetter_II reading06Regex PRECIP TOTAL.*>([\d\.]+)<.*tile-precipitation
attr wetter_II reading07Format %.2f
attr wetter_II reading07Name pressure
attr wetter_II reading07OExpr UConv::inhg2hpa($val,2)
attr wetter_II reading07Regex CURRENT.*>([\d\.]+)<.*tile-pressure
attr wetter_II reading08Format %.2f
attr wetter_II reading08Name pressure_EN
attr wetter_II reading08Regex CURRENT.*>([\d\.]+)<.*tile-pressure
attr wetter_II reading09Name solarRadiation
attr wetter_II reading09Regex SOLAR RADIATION.*CURRENT.*weather__text">([\d\.]+)
attr wetter_II reading10Name solarUV
attr wetter_II reading10Regex CURRENT UV.*>([\d\.]+)<.*UV RISK
attr wetter_II reading11Format %.1f
attr wetter_II reading11Name temperature
attr wetter_II reading11OExpr UConv::f2c($val,2)
attr wetter_II reading11Regex current-temp.*">([- ]*[\d\.]+).*DEWPOINT
attr wetter_II reading12Format %.1f
attr wetter_II reading12Name temperature_EN
attr wetter_II reading12Regex current-temp.*">([- ]*[\d\.]+).*DEWPOINT
attr wetter_II reading13Format %.1f
attr wetter_II reading13Name windChill
attr wetter_II reading13OExpr UConv::f2c($val,2)
attr wetter_II reading13Regex Feels Like.*>([\d\.]+)<.*wind-dial__container
attr wetter_II reading14Format %.1f
attr wetter_II reading14Name windChill_EN
attr wetter_II reading14Regex Feels Like.*>([\d\.]+)<.*wind-dial__container
attr wetter_II reading15Name windDirection
attr wetter_II reading15OExpr UConv::compasspoint2compasspoint($val,"en",1,"de")
attr wetter_II reading15Regex WIND FROM.*>([NESW]+)<.*GUST
attr wetter_II reading16Name windDirection_EN
attr wetter_II reading16Regex WIND FROM.*>([NESW]+)<.*GUST
attr wetter_II reading17Format %.0f
attr wetter_II reading17Name windSpeed
attr wetter_II reading17OExpr UConv::mph2kph($val,1)
attr wetter_II reading17Regex wind-dial__container.*>([\d\.]+)<.*unit-speed
attr wetter_II reading18Name windSpeed_EN
attr wetter_II reading18Regex wind-dial__container.*>([\d\.]+)<.*unit-speed
attr wetter_II reading19Name windGust
attr wetter_II reading19OExpr UConv::mph2kph($val,1)
attr wetter_II reading19Regex GUST.*>([\d\.]+)<.*mph
attr wetter_II reading20Name windGust_EN
attr wetter_II reading20Regex GUST.*>([\d\.]+)<.*mph
attr wetter_II room Informationen->Wetter,Rollos
attr wetter_II sortby 03
attr wetter_II stateFormat T: temperature °C | F: humidity % | W: windSpeed km/h | D: pressure hPa | U: solarUV | R: solarRadiation W/m²
attr wetter_II timeout 5
Und hier ein Überblick der drei Stationen
wetter_II  T: 18.3 °C | F: 43 % | W: 1 km/h | D: 1022.01 hPa | U: 1 | R: 112.70 W/m²
wetter_III T: 19.4 °C | F: 38 % | W: 0 km/h | D: 1016.26 hPa | U: 1 | R: 136.70 W/m²
wetter_IV  T: 18.3 °C | F: 43 % | W: 0 km/h | D: 1010.50 hPa | U: 0 | R: 88.00 W/m²
VG
   Christian
Bronze
Christian, vielen Dank für Deine wunderbare Beschreibung!
Leider finde ich trotzdem und trotz Registrierung auf der Wunderground-Seite nicht den Filter, um die Wetterstationen mit UV&Radiation herauszufiltern.
Kannst Du mir bitte einen Hinweis geben?
ch.eick
EDIT: Wenn Du auf einer Station bist, kannst Du dort auch die kleine Karte verwenden und die Station wechseln. Das ist dann schneller.
Ich habe mich nicht registriert und auch keinen API Key :-)
- Geht auf die Web Seite von wundergroud.
- Search locations => Deine Stadt
- Bei der Map auf wundermap klicken => Es öffnet sich die Karte
- Rein zoomen, bis zu Deiner Stadt
- rechts "Weather Stations" auswählen und z.B. Temperatur auswählen
- in der Karte erscheinen nun Wetterstationen.
- die kann man anklicken und ein Fenster öffnet sich
- Nun kann man auf die Station ID mit der rechter Maustaste klicken und in einem neuen tab öffnet lassen
- in den Quadratischen Grafiken sollte dann "Solar Radiation" und "UV" angezeigt werden.
- Wenn nicht, dann weiter suchen
Das wäre eine Station, die ich gerade willkürlich ausgewählt habe :-)
https://www.wunderground.com/dashboard/pws/IBADVI14
h-man-kl
Hi CoolTux,
ja klar habe den scan mehrfach gemacht - sonst würden die Aktoren ja nich auftauchen. Hier das List:
   FUUID      5d540d3a-f33f-627b-40e3-4e54c8ac3fee85db
   FVERSION   73_AutoShuttersControl.pm:v0.10.12-s23934/2021-03-12 TESTING
   MID        da39a3ee5e6b4b0d3255bfef95601890afd80709
   NAME       Rollladensteuerung
   NOTIFYDEV  global,Rollladensteuerung,00.04.Rollladen,00.05.Rollladen,01.03.Rollladen,01.05.RollladenBalkon,01.05.RollladenFenster,01.06.Rollladen,02.03.RolloFenster,02.04.RolloFenster,01.03.Rollladen,FS20.RollladenWohnzimmer.E,s_PartyRollos.innen,02.03.RolloFenster,02.04.RolloFenster,01.05.TFK.Balkon,01.05.RolloFenster,00.05.Rollladen,FS20.Rollladen.Abstellkammer.E,01.06.RolloFenster,myTwilight[,myTwilight,FS20.RollladenBalkon.E,01.05.RolloBalkon,FS20.Rollladen.EZ,00.04.Rollo
   NR         1184
   NTFY_ORDER 51-Rollladensteuerung
   STATE      created new drive timer
   TYPE       AutoShuttersControl
   VERSION    v0.10.12
   OLDREADINGS:
     2021-04-21 06:33:34   00.04.Rollladen_lastPosValue 0
     2020-04-13 06:47:37   00.04.Rollo_PosValue 0
     2020-07-04 21:54:43   00.04.Rollo_lastDelayPosValue 100
     2021-03-22 06:35:51   00.04.Rollo_lastPosValue 0
     2020-04-13 06:48:00   00.05.Rollladen_PosValue 100
     2020-07-04 21:54:43   00.05.Rollladen_lastDelayPosValue 0
     2021-04-21 06:33:35   00.05.Rollladen_lastPosValue 0
     2020-04-13 06:47:54   01.03.Rollladen_PosValue 100
     2021-01-06 18:00:11   01.03.Rollladen_lastDelayPosValue 0
     2021-04-21 06:33:36   01.03.Rollladen_lastPosValue 0
     2021-04-21 06:33:37   01.05.RollladenBalkon_lastPosValue 0
     2021-04-21 06:33:37   01.05.RollladenFenster_lastPosValue 0
     2020-04-13 06:47:33   01.05.RolloBalkon_PosValue 0
     2021-01-06 18:00:11   01.05.RolloBalkon_lastDelayPosValue 100
     2021-04-19 06:37:28   01.05.RolloBalkon_lastPosValue 0
     2020-04-13 06:47:34   01.05.RolloFenster_PosValue 0
     2020-12-31 18:00:02   01.05.RolloFenster_lastDelayPosValue 100
     2021-04-19 06:37:29   01.05.RolloFenster_lastPosValue 0
     2021-04-19 06:37:28   01.06.RollladenBalkon_lastPosValue 0
     2021-04-19 06:37:28   01.06.RollladenFenster_lastPosValue 0
     2021-04-21 06:33:38   01.06.Rollladen_lastPosValue 0
     2020-04-13 06:47:34   01.06.RolloFenster_PosValue 0
     2020-12-31 18:00:02   01.06.RolloFenster_lastDelayPosValue 100
     2021-04-19 06:37:28   01.06.RolloFenster_lastPosValue 0
     2020-04-13 06:47:35   02.03.RolloFenster_PosValue 0
     2021-04-21 07:00:05   02.03.RolloFenster_lastPosValue 100
     2020-04-13 08:00:38   02.04.RolloFenster_PosValue 0
     2021-04-21 20:00:02   02.04.RolloFenster_lastPosValue 0
     2021-04-21 20:00:02   02.04.RolloFenster_nextAstroTimeEvent 22.04.2021 - 08:30
     2020-05-28 05:37:03   FS20.Rollladen.Abstellkammer.E_lastPosValue 0
     2020-02-28 18:35:58   FS20.Rollladen.EZ_lastDelayPosValue 0
     2020-05-28 05:37:03   FS20.Rollladen.EZ_lastPosValue 0
     2019-11-14 07:41:13   FS20.Rollladen.Kueche_lastPosValue 0
     2020-05-28 05:37:03   FS20.RollladenBad.E_lastPosValue 0
     2020-04-01 20:28:00   FS20.RollladenBalkon.E_lastDelayPosValue 70
     2020-05-28 05:37:03   FS20.RollladenBalkon.E_lastPosValue 0
     2020-05-28 05:37:04   FS20.RollladenKGSZ_lastPosValue 0
     2020-05-28 05:37:04   FS20.RollladenKZ.E_lastPosValue 0
     2020-02-28 18:35:59   FS20.RollladenWohnzimmer.E_lastDelayPosValue 100
     2020-05-28 05:37:04   FS20.RollladenWohnzimmer.E_lastPosValue 0
     2021-04-19 15:05:55   ascEnable       on
     2020-06-25 07:59:35   controlShading  on
     2019-08-14 15:34:53   hardLockOut     on
     2019-12-24 16:27:24   partyMode       on
     2020-04-10 11:02:59   room_K__che_Rollladen__CUL_HM 01.03.Rollladen
     2020-04-10 11:02:59   room_Rollladen  00.04.Rollo,01.05.RolloBalkon,01.05.RolloFenster,01.06.RolloFenster,02.03.RolloFenster,02.04.RolloFenster
     2020-04-10 11:02:59   room_Rollladen_Wohnzimmer_KG__CUL_HM 00.05.Rollladen
     2020-03-05 18:45:26   s_PartyRollos.innen_lastPosValue 0
     2019-08-14 15:31:40   selfDefense     off
     2021-04-21 20:00:02   state           created new drive timer
     2019-08-15 08:47:33   sunriseTimeWeHoliday on
     2021-04-21 09:32:13   userAttrList    rolled out
   helper:
     shuttersList:
       00.04.Rollladen
       00.05.Rollladen
       01.03.Rollladen
       01.06.Rollladen
       02.03.RolloFenster
       02.04.RolloFenster
   monitoredDevs:
     00.04.Rollo:
     00.05.Rollladen:
     01.03.Rollladen:
     01.05.RolloBalkon:
     01.05.RolloFenster:
     01.05.TFK.Balkon:
       FS20.RollladenBalkon.E ASC_WindowRec
     01.06.RolloFenster:
     02.03.RolloFenster:
     02.04.RolloFenster:
     FS20.Rollladen.Abstellkammer.E:
     FS20.Rollladen.EZ:
     FS20.RollladenBalkon.E:
     FS20.RollladenWohnzimmer.E:
     myTwilight:
       Rollladensteuerung ASC_twilightDevice
     myTwilight[:
     s_PartyRollos.innen:
   ASC_autoAstroModeEvening HORIZON
   ASC_autoAstroModeEveningHorizon -3
   ASC_freezeTemp 2
   ASC_tempSensor Wetterstation:temperature
   ASC_twilightDevice myTwilight:twilight
   devStateIcon { ShuttersControl_DevStateIcon($name) }
   icon       fts_shutter_automatic
   room       Rollladen
   verbose    5
CoolTux
   DEF        65B90B
   HmUART_01_MSGCNT 13
   HmUART_01_RSSI -62
   HomeMatic_MSGCNT 13
   HomeMatic_RSSI -46
   IODev      HmUART_01
   MSGCNT     38
   NOTIFYDEV  global
   NR         1448
   STATE      rauf
   TYPE       CUL_HM
   chanNo     01
   protCmdDel 1
   protState  CMDs_done
   helper:
     HM_CMDNR   242
     mId        0005
     regLst     0,1,3p
     rxType     1
     supp_Pair_Rep 0
     ack:
     cmds:
       cmdLst:
         assignHmKey noArg
         getConfig  noArg
         getDevInfo noArg
         getVersion noArg
         off        noArg
         on         noArg
         pair       noArg
         peerSmart  -peerOpt-
         raw        -data- [...]
         reset      noArg
         sign       [(on|{off})]
         statusRequest noArg
         stop       noArg
         toggle     noArg
         toggleDir  noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         peer
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     dir:
       cur        stop
       rct        up
     expert:
       def        0
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       rxt        0
       vccu       VCCU
       p:
         65B90B
         00
         00
         00
       prefIO:
         HmUART_01
     mRssi:
       mNo        F2
       io:
         04.06.HMLANGW:
           -83
           -83
         HmUART_01:
           -58
           -58
         HomeMatic:
           -46
           -46
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         HmUART_01
       flg        A
       ts         1618979677.04018
       ack:
         HASH(0x79d0940)
     rssi:
       HmUART_01:
         cnt        9
         lst        -72
         max        -70
         min        -72
       at_04.06.HMLANGW:
         cnt        12
         lst        -83
         max        -76
         min        -83
       at_HmUART_01:
         cnt        13
         lst        -62
         max        -61
         min        -62
       at_HomeMatic:
         cnt        13
         lst        -46
         max        -46
         min        -48
     shadowReg:
     tmpl:
   ASC        2
   IODev      HmUART_01
   expert     rawReg
   firmware   2.11
   group      Klima
   peerIDs    00000000
   serialNr   OEQ1970031
   DEF        65B8C1
   HmUART_01_MSGCNT 9
   HmUART_01_RSSI -48
   HomeMatic_MSGCNT 11
   HomeMatic_RSSI -48
   IODev      HomeMatic
   MSGCNT     28
   NOTIFYDEV  global
   NR         1198
   STATE      rauf
   TYPE       CUL_HM
   chanNo     01
   protState  CMDs_done
   helper:
     HM_CMDNR   219
     mId        0005
     regLst     0,1,3p
     rxType     1
     supp_Pair_Rep 0
     ack:
     cmds:
       cmdLst:
         assignHmKey noArg
         getConfig  noArg
         getDevInfo noArg
         getVersion noArg
         off        noArg
         on         noArg
         pair       noArg
         peerSmart  -peerOpt-
         raw        -data- [...]
         reset      noArg
         sign       [(on|{off})]
         statusRequest noArg
         stop       noArg
         toggle     noArg
         toggleDir  noArg
         tplDel     -tplDel-
         tplSet_0   -tplChan-
         unpair     noArg
       lst:
         peer
         tplChan
         tplDel
         tplPeer
       rtrvLst:
         param      -param-
         regList    noArg
         regTable   noArg
         tplInfo    noArg
     dir:
       cur        stop
       rct        up
     expert:
       def        1
       det        0
       raw        1
       tpl        0
     io:
       flgs       0
       rxt        0
       vccu       VCCU
       p:
         65B8C1
         00
         00
         00
       prefIO:
         HomeMatic
     mRssi:
       mNo        DB
       io:
         04.06.HMLANGW:
           -81
           -81
         HmUART_01:
           -48
           -48
         HomeMatic:
           -40
           -40
     peerIDsH:
       00000000   broadcast
     prt:
       bErr       0
       sProc      0
       rspWait:
     q:
       qReqConf
       qReqStat
     role:
       chn        1
       dev        1
       prs        1
     rpt:
       IO         HmUART_01
       flg        A
       ts         1618979677.65035
       ack:
         HASH(0x67692e0)
     rssi:
       HomeMatic:
         avg        -43.8
         cnt        5
         lst        -46
         max        -42
         min        -46
       at_04.06.HMLANGW:
         avg        -82.125
         cnt        8
         lst        -81
         max        -80
         min        -84
       at_HmUART_01:
         cnt        9
         lst        -48
         max        -47
         min        -51
       at_HomeMatic:
         cnt        11
         lst        -48
         max        -44
         min        -54
     shadowReg:
     tmpl:
   ASC        2
   ASC_Adv    on
   ASC_Partymode off
   ASC_Pos_Reading pct
   ASC_Shading_Pos 50
   IODev      HomeMatic
   firmware   2.11
   group      Klima
   peerIDs    00000000
   serialNr   OEQ1970069
Danke und Gruß
H-Man
Kannst Du von den beiden Rollos bitte ein list -r machen?
Wenn du das gemacht hast, eventuell hilft es bei dem "kaputten" Rollo das ASC Attribut zu löschen, im ASC Device ein scanForShutters dann das ASC Attribut wieder rein und wieder scanForShutters.
Das TuxNet Wiki:
h-man-kl
ich mach doch (fast) alles:
"ganzer" Rollo:
define 01.03.Rollladen CUL_HM 65B8C1
attr 01.03.Rollladen userattr ASC_Adv:on,off ASC_Antifreeze:off,soft,hard,am,pm ASC_Antifreeze_Pos:5,10,15,20,25,30,35,40,45,50,55,60,65,70,75,80,85,90,95,100 ASC_AutoAstroModeEvening:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeEveningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_AutoAstroModeMorning:REAL,CIVIL,NAUTIC,ASTRONOMIC,HORIZON ASC_AutoAstroModeMorningHorizon:-9,-8,-7,-6,-5,-4,-3,-2,-1,0,1,2,3,4,5,6,7,8,9 ASC_BlockingTime_afterManual ASC_BlockingTime_beforDayOpen ASC_BlockingTime_beforNightClose ASC_BrightnessSensor ASC_Closed_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_ComfortOpen_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Down:time,astro,brightness,roommate ASC_DriveUpMaxDuration ASC_Drive_Delay ASC_Drive_DelayStart ASC_ExternalTrigger ASC_GuestRoom:on,off ASC_LockOut:soft,hard,off ASC_LockOut_Cmd:inhibit,blocked,protection ASC_Mode_Down:absent,always,off,home ASC_Mode_Up:absent,always,off,home ASC_Open_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_Partymode:on,off ASC_Pos_Reading ASC_PrivacyDownValue_beforeNightClose ASC_PrivacyDown_Pos ASC_PrivacyUpValue_beforeDayOpen ASC_PrivacyUp_Pos ASC_RainProtection:on,off ASC_Roommate_Device ASC_Roommate_Reading ASC_Self_Defense_AbsentDelay ASC_Self_Defense_Mode:absent,gone,off ASC_Shading_InOutAzimuth ASC_Shading_MinMax_Elevation ASC_Shading_Min_OutsideTemperature ASC_Shading_Mode:absent,always,off,home ASC_Shading_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Shading_StateChange_SunnyCloudy ASC_Shading_WaitingPeriod ASC_Shutter_IdleDetection ASC_Sleep_Pos:0,10,20,30,40,50,60,70,80,90,100 ASC_TempSensor ASC_Time_Down_Early ASC_Time_Down_Late ASC_Time_Up_Early ASC_Time_Up_Late ASC_Time_Up_WE_Holiday ASC_Up:time,astro,brightness,roommate ASC_Ventilate_Pos:10,20,30,40,50,60,70,80,90,100 ASC_Ventilate_Window_Open:on,off ASC_WiggleValue ASC_WindParameters ASC_WindProtection:on,off ASC_WindowRec ASC_WindowRec_PosAfterDayClosed:open,lastManual ASC_WindowRec_subType:twostate,threestate room_map structexclude
attr 01.03.Rollladen .mId 006A
attr 01.03.Rollladen ASC 2
attr 01.03.Rollladen ASC_Adv on
attr 01.03.Rollladen ASC_BrightnessSensor Wetterstation:brightness
attr 01.03.Rollladen ASC_Partymode off
attr 01.03.Rollladen ASC_Pos_Reading pct
attr 01.03.Rollladen ASC_Shading_MinMax_Elevation 30.0:80.0
attr 01.03.Rollladen ASC_Shading_Min_OutsideTemperature 22
attr 01.03.Rollladen ASC_Shading_Mode always
attr 01.03.Rollladen ASC_Shading_Pos 50
attr 01.03.Rollladen ASC_Time_Down_Early 18:00
attr 01.03.Rollladen ASC_Time_Up_Early 06:00
attr 01.03.Rollladen ASC_Time_Up_WE_Holiday 08:30
attr 01.03.Rollladen IODev HomeMatic
attr 01.03.Rollladen IOgrp VCCU:HomeMatic
attr 01.03.Rollladen alias Rollladen Küche
attr 01.03.Rollladen autoReadReg 4_reqStatus
attr 01.03.Rollladen devStateIcon rauf:fts_shutter_10 runter:fts_shutter_100
attr 01.03.Rollladen eventMap off:runter on:rauf
attr 01.03.Rollladen expert defReg,rawReg
attr 01.03.Rollladen firmware 2.11
attr 01.03.Rollladen group Klima
attr 01.03.Rollladen icon fts_shutter_updown
attr 01.03.Rollladen model HM-LC-BL1PBU-FM
attr 01.03.Rollladen peerIDs 00000000
attr 01.03.Rollladen room Küche,Rollladen,_CUL_HM
attr 01.03.Rollladen serialNr OEQ1970069
attr 01.03.Rollladen subType blindActuator
attr 01.03.Rollladen webCmd rauf:runter:stop
setstate 01.03.Rollladen rauf
setstate 01.03.Rollladen 2020-03-09 15:28:35 .D-devInfo 010100
setstate 01.03.Rollladen 2020-03-09 15:28:35 .D-stc 30
setstate 01.03.Rollladen 2019-09-26 09:22:40 .R-confBtnTime permanent
setstate 01.03.Rollladen 2019-09-26 09:22:40 .R-intKeyVisib invisib
setstate 01.03.Rollladen 2019-09-26 09:22:40 .R-localResDis off
setstate 01.03.Rollladen 2019-09-26 09:22:41 .R-refRunCounter 0
setstate 01.03.Rollladen 2019-09-26 09:22:41 .R-statusInfoMinDly 2 s
setstate 01.03.Rollladen 2019-09-26 09:22:41 .R-statusInfoRandom 1 s
setstate 01.03.Rollladen 2019-09-26 09:22:41 .R-transmitTryMax 6
setstate 01.03.Rollladen 2021-04-19 15:44:50 .associatedWith 01.03.Rollladen,01.03.Rollladen
setstate 01.03.Rollladen 2021-02-05 20:15:31 .peerListRDate 2021-02-05 20:15:31
setstate 01.03.Rollladen 2021-04-21 06:34:37 .protLastRcv 20210421063437
setstate 01.03.Rollladen 2019-09-26 09:01:04 ASC_Enable on
setstate 01.03.Rollladen 2020-04-13 06:47:54 ASC_ShuttersLastDrive day open
setstate 01.03.Rollladen 2021-04-21 06:33:36 ASC_Time_DriveDown 21.04.2021 - 20:44
setstate 01.03.Rollladen 2021-04-21 06:33:36 ASC_Time_DriveUp 22.04.2021 - 06:31
setstate 01.03.Rollladen 2021-04-21 06:33:39 CommandAccepted yes
setstate 01.03.Rollladen 2020-03-09 15:28:35 D-firmware 2.11
setstate 01.03.Rollladen 2020-03-09 15:28:35 D-serialNr OEQ1970069
setstate 01.03.Rollladen 2021-02-05 20:15:29 PairedTo 0x1511AB
setstate 01.03.Rollladen 2019-09-26 09:22:41 R-driveDown 50 s
setstate 01.03.Rollladen 2019-09-26 09:22:41 R-driveTurn 0.5 s
setstate 01.03.Rollladen 2019-09-26 09:22:41 R-driveUp 50 s
setstate 01.03.Rollladen 2019-09-26 09:22:40 R-pairCentral 0x1511AB
setstate 01.03.Rollladen 2019-09-26 09:22:41 R-sign off
setstate 01.03.Rollladen 2021-02-05 20:15:29 RegL_00. 00:00 02:01 0A:15 0B:11 0C:AB 15:FF 18:00
setstate 01.03.Rollladen 2021-02-05 20:15:30 RegL_01. 00:00 08:00 09:00 0A:00 0B:01 0C:F4 0D:01 0E:F4 0F:05 10:00 30:06 56:00 57:24
setstate 01.03.Rollladen 2020-04-10 11:03:00 associatedWith Rollladensteuerung
setstate 01.03.Rollladen 2021-04-11 11:52:15 cfgState ok
setstate 01.03.Rollladen 2021-04-21 06:34:37 commState CMDs_done
setstate 01.03.Rollladen 2021-04-21 06:34:37 deviceMsg on (to VCCU)
setstate 01.03.Rollladen 2021-04-21 06:34:37 level 100
setstate 01.03.Rollladen 2021-04-21 06:34:37 motor stop:on
setstate 01.03.Rollladen 2021-04-21 06:34:37 pct 100
setstate 01.03.Rollladen 2021-02-05 20:15:04 powerOn 2021-02-05 20:15:04
setstate 01.03.Rollladen 2021-04-21 06:34:37 recentStateType info
setstate 01.03.Rollladen 2020-01-12 16:25:39 sabotageAttack_ErrIoAttack cnt 1
setstate 01.03.Rollladen 2021-04-21 06:34:37 state on
setstate 01.03.Rollladen 2021-04-21 06:34:37 timedOn off
setstate 01.03.Rollladen 2021-04-21 06:33:40 trigLast fhem:02
einer der kaputten:
define 01.05.RollladenBalkon CUL_HM 65B90B
attr 01.05.RollladenBalkon userattr room_map structexclude
attr 01.05.RollladenBalkon .mId 006A
attr 01.05.RollladenBalkon ASC 2
attr 01.05.RollladenBalkon IODev HmUART_01
attr 01.05.RollladenBalkon IOgrp VCCU:HmUART_01
attr 01.05.RollladenBalkon autoReadReg 4_reqStatus
attr 01.05.RollladenBalkon devStateIcon rauf:fts_shutter_10 runter:fts_shutter_100
attr 01.05.RollladenBalkon eventMap off:runter on:rauf
attr 01.05.RollladenBalkon expert rawReg
attr 01.05.RollladenBalkon firmware 2.11
attr 01.05.RollladenBalkon group Klima
attr 01.05.RollladenBalkon icon fts_shutter_updown
attr 01.05.RollladenBalkon model HM-LC-BL1PBU-FM
attr 01.05.RollladenBalkon peerIDs 00000000
attr 01.05.RollladenBalkon room Rollladen,Wohnzimmer,_CUL_HM
attr 01.05.RollladenBalkon serialNr OEQ1970031
attr 01.05.RollladenBalkon subType blindActuator
attr 01.05.RollladenBalkon webCmd rauf:runter:stop
setstate 01.05.RollladenBalkon rauf
setstate 01.05.RollladenBalkon 2021-04-10 17:20:56 .D-devInfo 010100
setstate 01.05.RollladenBalkon 2021-04-10 17:20:56 .D-stc 30
setstate 01.05.RollladenBalkon 2021-04-10 17:21:10 .R-confBtnTime permanent
setstate 01.05.RollladenBalkon 2021-04-10 17:21:14 .R-driveDown 50 s
setstate 01.05.RollladenBalkon 2021-04-10 17:21:14 .R-driveTurn 0.5 s
setstate 01.05.RollladenBalkon 2021-04-10 17:21:14 .R-driveUp 50 s
setstate 01.05.RollladenBalkon 2021-04-10 17:21:10 .R-intKeyVisib invisib
setstate 01.05.RollladenBalkon 2021-04-10 17:21:10 .R-localResDis off
setstate 01.05.RollladenBalkon 2021-04-10 17:21:10 .R-pairCentral 0x1511AB
setstate 01.05.RollladenBalkon 2021-04-10 17:21:14 .R-refRunCounter 0
setstate 01.05.RollladenBalkon 2021-04-10 17:21:14 .R-sign off
setstate 01.05.RollladenBalkon 2021-04-10 17:21:14 .R-statusInfoMinDly 2 s
setstate 01.05.RollladenBalkon 2021-04-10 17:21:14 .R-statusInfoRandom 1 s
setstate 01.05.RollladenBalkon 2021-04-10 17:21:14 .R-transmitTryMax 6
setstate 01.05.RollladenBalkon 2021-04-19 15:44:52 .associatedWith 01.05.RollladenBalkon,01.05.RollladenBalkon
setstate 01.05.RollladenBalkon 2021-04-11 12:45:15 .peerListRDate 2021-04-11 12:45:15
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 .protLastRcv 20210421063437
setstate 01.05.RollladenBalkon 2021-04-10 17:43:10 ASC_Enable on
setstate 01.05.RollladenBalkon 2021-04-21 06:33:37 ASC_Time_DriveDown 21.04.2021 - 20:44
setstate 01.05.RollladenBalkon 2021-04-21 06:33:37 ASC_Time_DriveUp 22.04.2021 - 06:31
setstate 01.05.RollladenBalkon 2021-04-21 06:33:39 CommandAccepted yes
setstate 01.05.RollladenBalkon 2021-04-10 17:20:56 D-firmware 2.11
setstate 01.05.RollladenBalkon 2021-04-10 17:20:56 D-serialNr OEQ1970031
setstate 01.05.RollladenBalkon 2021-04-11 12:45:13 PairedTo 0x1511AB
setstate 01.05.RollladenBalkon 2021-04-11 12:45:13 RegL_00. 00:00 02:01 0A:15 0B:11 0C:AB 15:FF 18:00
setstate 01.05.RollladenBalkon 2021-04-11 12:45:14 RegL_01. 00:00 08:00 09:00 0A:00 0B:01 0C:F4 0D:01 0E:F4 0F:05 10:00 30:06 56:00 57:24
setstate 01.05.RollladenBalkon 2021-04-11 12:46:02 cfgState ok
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 commState CMDs_done
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 deviceMsg on (to VCCU)
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 level 100
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 motor stop:on
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 pct 100
setstate 01.05.RollladenBalkon 2021-04-11 12:44:37 powerOn 2021-04-11 12:44:37
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 recentStateType info
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 state on
setstate 01.05.RollladenBalkon 2021-04-21 06:34:37 timedOn off
setstate 01.05.RollladenBalkon 2021-04-21 06:33:40 trigLast fhem:02
h-man-kl
ASC Attribut gelöscht, scan durchgeführt => Rollo gefundenLeider kann ich wieder nur ASC 0/1/2 setzen.
Echt komisch
H-Man
eurofinder
@h-man-kl:
Nachdem du ASC im Rollladen-Device gesetzt hast musst du im ASC-Device scanForShutters ausführen. Dann sind die weiteren Attribute im Rollladendevice vorhanden.
eurofinder
RPI3+; Raspbian Buster Lite; RPI-RF-MOD; piVCCU3, HMIP-eTRV-2, HmIP-SWDO, HmIP-SRH, HmIP-STHO, HmIP-SLO
Bronze
@Christian, vielen Dank, ich habe 3 passende Stationen in der Nähe gefunden!
ch.eick
Ich hatte dazu glaube ich auch mal einen Thread aufgemacht, damit es hier nicht so stört.
CoolTux
Echt komisch
H-Man
Das ist auch korrekt. Setze dann bitte 1 oder 2 und mache dann noch mal ein scanForShutters.
Das TuxNet Wiki:
h-man-kl
Ich habe das jetzt nochmal bei allen meinen Problemrollos gemacht: ASC gelöscht, gescannt => Rollo taucht korrekterweise nicht auf, ASC auf 2 gesetzt, gescannt => Rollo taucht im ASC Modul wieder auf, bei device userattrib taucht nix mit ASC auf... :-(
H-Man
