OSRAM LED Strip Farbe wird nicht richtig gesetzt über Alexa
Begonnen von link611, 29 Dezember 2020, 17:39:09
link611
amenomade
#31
Kannst Du folgendes probieren?
attr KiZ2.Bett homebridgeMapping clear On=state,cmdOn=on,cmdOff=off RGB=rgb,cmd=rgb ColorTemperature=ct,cmd=ct
Bitte dann die Log bei "set alexa reload" und bei "Alexa rot". Ich sehe im Code schon Sachen wegen mappings.RGB
EDIT: Alternativ auch zu probieren
attr KiZ2.Bett homebridgeMapping clear On=state,cmdOn=on,cmdOff=off Hue=hue,cmd=rgb Brightness=bri,cmd=rgb Saturation=sat,cmd=rgb ColorTemperature=ct,cmd=ct
Wenn beide nicht gehen, dann werden wir über ein cmdalias probieren.
link611
Reload:
[1/5/2021, 8:07:02 AM] [FHEM] KiZ2.Bett is light
[1/5/2021, 8:07:02 AM] [FHEM] KiZ2.Bett has
[1/5/2021, 8:07:02 AM] [FHEM]   On [state;on,off]
[1/5/2021, 8:07:02 AM] [FHEM]   RGB [rgb]
[1/5/2021, 8:07:02 AM] [FHEM]   ColorTemperature [ct]
[1/5/2021, 8:07:02 AM] [FHEM] KiZ2.Bett will not send proactive events
[1/5/2021, 8:07:02 AM] [FHEM] KiZ2.Bett uses ID: 7c:b0:3e:aa:00:b0:33:e9-03
  2021-01-05 08:07:02 caching: KiZ2.Bett-rgb: 100e0e
"Gerät unterstützt das nicht."
Reload:
[1/5/2021, 8:12:16 AM] [FHEM] KiZ2.Bett is light
[1/5/2021, 8:12:16 AM] [FHEM] KiZ2.Bett has
[1/5/2021, 8:12:16 AM] [FHEM]   On [state;on,off]
[1/5/2021, 8:12:16 AM] [FHEM]   Hue [hue;rgb;0-undefined]
[1/5/2021, 8:12:16 AM] [FHEM]   Brightness [bri]
[1/5/2021, 8:12:16 AM] [FHEM]   Saturation [sat;rgb;0-undefined]
[1/5/2021, 8:12:16 AM] [FHEM]   ColorTemperature [ct]
[1/5/2021, 8:12:16 AM] [FHEM] KiZ2.Bett will not send proactive events
[1/5/2021, 8:12:16 AM] [FHEM] KiZ2.Bett uses ID: 7c:b0:3e:aa:00:b0:33:e9-03
Setze rot:
[1/5/2021, 8:14:29 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"9a4ced04-39c3-40b2-b445-d80ced117b67","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":0,"saturation":1,"brightness":1}}}}
[1/5/2021, 8:14:29 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 0
[1/5/2021, 8:14:29 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20rgb%200&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 8:14:29 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 8:14:29 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20rgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 8:14:29 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 8:14:29 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":0,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T07:14:29.869Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"50d8e6f6-fadd-415d-a677-1ecf1ce9642e","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
[1/5/2021, 8:14:30 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa","name":"ReportState","payloadVersion":"3","messageId":"314da25d-2f9b-424f-86cd-a9b14cb4a6bf","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{}}}
[1/5/2021, 8:14:30 AM] [FHEM]     caching: On: off (as string; from 'off')
[1/5/2021, 8:14:30 AM] [FHEM]     caching: Brightness: 16 (as string; from '16')
[1/5/2021, 8:14:30 AM] [FHEM]     caching: Hue: 0 (as string; from '0')
[1/5/2021, 8:14:30 AM] [FHEM]     caching: Saturation: 27 (as string; from '27')
[1/5/2021, 8:14:30 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.PowerController","name":"powerState","value":"ON","timeOfSample":"2021-01-05T07:14:30.182Z","uncertaintyInMilliseconds":500},{"namespace":"Alexa.BrightnessController","name":"brightness","value":16,"timeOfSample":"2021-01-05T07:14:30.183Z","uncertaintyInMilliseconds":500},{"namespace":"Alexa.ColorTemperatureController","name":"colorTemperatureInKelvin","value":6250,"timeOfSample":"2021-01-05T07:14:30.183Z","uncertaintyInMilliseconds":500},{"namespace":"Alexa.ColorController","name":"color","value":{"hue":"0","saturation":0.27,"brightness":0.16},"timeOfSample":"2021-01-05T07:14:30.183Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"StateReport","payloadVersion":"3","messageId":"00c9bf19-f6eb-4af2-ac71-a4b1647a2c12","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
Alexa bestätigt mit OK.
Ergebnis ist, die Lampe bleibt aus und readings verändern sich nicht.
An und aus geht noch.
amenomade
Pfff...
Dann los mit cmdalias:
defmod huergb cmdalias set [\w\.]+ huergb \d+ AS {fhem "set $EVTPART0 hue ". $EVTPART2*182.548 .";; set $EVTPART0 rgb ".Color::hsv2hex(int($EVTPART2/360), int(ReadingsVal("$EVTPART0","sat",254)/254), int(ReadingsVal("$EVTPART0","bri",254)/254))}
defmod brirgb cmdalias set [\w\.]+ brirgb \d+ AS {fhem "set $EVTPART0 bri ". $EVTPART2*2.54 .";; set $EVTPART0 rgb ".Color::hsv2hex(int(ReadingsVal("$EVTPART0","hue",65535)/182.548), int(ReadingsVal("$EVTPART0","sat",254)/254), int($EVTPART2/100))}
defmod satrgb cmdalias set [\w\.]+ satrgb \d+ AS {fhem "set $EVTPART0 sat ". $EVTPART2*2.54 .";; set $EVTPART0 rgb ".Color::hsv2hex(int(ReadingsVal("$EVTPART0","hue",65535)/182.548), int($EVTPART2/100), int(ReadingsVal("$EVTPART0","bri",254)/254))}
Bin mir nicht sicher für die Konvertierung der Farbwerte (die Farbe könnte evtl nicht stimmen), aber zumindest sollte zuerst ein Kommando "set ... hue|sat|bri ..." und dann ein "set ... rgb ..." geschickt werden
attr KiZ2.Bett homebridgeMapping clear On=state,cmdOn=on,cmdOff=off Hue=hue,cmd=huergb Brightness=bri,cmd=brirgb Saturation=sat,cmd=satrgb ColorTemperature=ct,cmd=ct
link611
#34
Zitat von: amenomade am 05 Januar 2021, 12:17:55
Pfff...
Reload:
[1/5/2021, 2:31:27 PM] [FHEM] KiZ2.Bett is light
[1/5/2021, 2:31:27 PM] [FHEM] KiZ2.Bett has
[1/5/2021, 2:31:27 PM] [FHEM]   On [state;on,off]
[1/5/2021, 2:31:27 PM] [FHEM]   Hue [hue;huergb;0-undefined]
[1/5/2021, 2:31:27 PM] [FHEM]   Brightness [bri]
[1/5/2021, 2:31:27 PM] [FHEM]   Saturation [sat;satrgb;0-undefined]
[1/5/2021, 2:31:27 PM] [FHEM]   ColorTemperature [ct]
[1/5/2021, 2:31:27 PM] [FHEM] KiZ2.Bett will not send proactive events
[1/5/2021, 2:31:27 PM] [FHEM] KiZ2.Bett uses ID: 7c:b0:3e:aa:00:b0:33:e9-03
Habe dann ein paar Befehle abgesetzt, rot ist eher ein orange aber erstmal OK. Wenn ich dann zu blau wechsle, wird es kurz blau dann wieder weiß, gleiches wenn ich zu grün wechsle (nur eben mit grün).
Wenn ich zu warmweiß wechsle und dann zu grün, wird es grün. Wenn ich dann wieder zu blau wechsle, kurz blau, dann wieder weiß
Teilweise war's auch so, wenn ich von rot zu was anderem gewechselt habe, dass er dann kurz z.b. blau gemacht hat, dann rot (wobei rot ja dieses orange ist).
Alle Befehle habe ich über Alexa abgesetzt.
Kann das bei Bedarf gerne noch genauer testen.
Hier Mal das Log dazu:
/2021, 2:32:11 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"246d8fd0-372c-4838-8cd6-494ad5ae25a8","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":0,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:32:11 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 0
[1/5/2021, 2:32:11 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%200&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:11 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:32:11 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:11 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:32:11 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:11 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":0,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:32:11.438Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"320d0a47-048e-4acd-b849-887aa0bb9b49","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:32:11 caching: KiZ2.Bett-state: dim12%
[1/5/2021, 2:32:11 PM] [FHEM]     caching: On: dim12% (as string; from 'dim12%')
  2021-01-05 14:32:11 caching: KiZ2.Bett-sat: 254
[1/5/2021, 2:32:11 PM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-05 14:32:11 caching: KiZ2.Bett-bri: 254
[1/5/2021, 2:32:11 PM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-05 14:32:11 caching: KiZ2.Bett-state: on
[1/5/2021, 2:32:11 PM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-05 14:32:11 caching: KiZ2.Bett-bri: 16
[1/5/2021, 2:32:11 PM] [FHEM]     caching: Brightness: 16 (as string; from '16')
[1/5/2021, 2:32:11 PM] [FHEM]     caching: Brightness: 2 (as string; from '2')
  2021-01-05 14:32:11 caching: KiZ2.Bett-state: dim06%
[1/5/2021, 2:32:11 PM] [FHEM]     caching: On: dim06% (as string; from 'dim06%')
  2021-01-05 14:32:13 caching: KiZ2.Bett-hue: 5376
[1/5/2021, 2:32:13 PM] [FHEM]     caching: Hue: 5376 (as string; from '5376')
  2021-01-05 14:32:13 caching: KiZ2.Bett-sat: 5
[1/5/2021, 2:32:13 PM] [FHEM]     caching: Saturation: 5 (as string; from '5')
  2021-01-05 14:32:13 caching: KiZ2.Bett-bri: 254
[1/5/2021, 2:32:13 PM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-05 14:32:13 caching: KiZ2.Bett-state: on
[1/5/2021, 2:32:13 PM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-05 14:32:18 caching: AR.Eisschrank_Temp-temperature: -22.47
[1/5/2021, 2:32:18 PM] [FHEM]     caching: CurrentTemperature: -22.47 (as number; from '-22.47')
[1/5/2021, 2:32:32 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"fca47f2c-ab62-4309-8fc0-ac136a8e36b4","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":120,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:32:32 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 120
[1/5/2021, 2:32:32 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20120&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:32 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:32:32 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:32 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:32:32 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:32 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":120,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:32:32.094Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"236b1983-b68d-4cdb-b1b7-d17f533be4b1","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:32:32 caching: KiZ2.Bett-hue: 21906
[1/5/2021, 2:32:32 PM] [FHEM]     caching: Hue: 21906 (as string; from '21906')
  2021-01-05 14:32:32 caching: KiZ2.Bett-sat: 254
[1/5/2021, 2:32:32 PM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-05 14:32:37 caching: KiZ2.Bett-hue: 5376
[1/5/2021, 2:32:37 PM] [FHEM]     caching: Hue: 5376 (as string; from '5376')
  2021-01-05 14:32:37 caching: KiZ2.Bett-sat: 5
[1/5/2021, 2:32:37 PM] [FHEM]     caching: Saturation: 5 (as string; from '5')
[1/5/2021, 2:32:39 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"8437e943-a884-4929-91f1-fd77b7788adf","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":240,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:32:39 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 240
[1/5/2021, 2:32:39 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20240&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:39 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:32:39 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:39 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:32:39 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:39 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":240,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:32:39.606Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"b1cf7691-43f3-4d91-a4c4-03c1885ad4de","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:32:39 caching: KiZ2.Bett-hue: 43812
[1/5/2021, 2:32:39 PM] [FHEM]     caching: Hue: 43812 (as string; from '43812')
  2021-01-05 14:32:39 caching: KiZ2.Bett-sat: 254
[1/5/2021, 2:32:39 PM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-05 14:32:43 caching: KiZ2.Bett-hue: 5376
[1/5/2021, 2:32:43 PM] [FHEM]     caching: Hue: 5376 (as string; from '5376')
  2021-01-05 14:32:43 caching: KiZ2.Bett-sat: 5
[1/5/2021, 2:32:43 PM] [FHEM]     caching: Saturation: 5 (as string; from '5')
[1/5/2021, 2:32:48 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"e6ab63e9-ed88-4f8b-a5a8-2558c27e2bb2","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":0,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:32:48 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 0
[1/5/2021, 2:32:48 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%200&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:48 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:32:48 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:48 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:32:48 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:48 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":0,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:32:48.030Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"c20d6499-1112-4580-9941-c60bb94e5d09","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:32:48 caching: KiZ2.Bett-hue: 0
[1/5/2021, 2:32:48 PM] [FHEM]     caching: Hue: 0 (as string; from '0')
  2021-01-05 14:32:48 caching: KiZ2.Bett-sat: 254
[1/5/2021, 2:32:48 PM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-05 14:32:50 caching: KiZ2.Bett-hue: 2048
[1/5/2021, 2:32:50 PM] [FHEM]     caching: Hue: 2048 (as string; from '2048')
[1/5/2021, 2:32:57 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"36d12eb9-35d0-4793-873f-843b842dafb0","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":240,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:32:57 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 240
[1/5/2021, 2:32:57 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20240&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:57 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:32:57 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:57 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:32:57 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:32:57 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":240,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:32:57.060Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"6b8227ee-8dcf-41ae-9b67-3fad81ad505f","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:32:57 caching: KiZ2.Bett-hue: 43812
[1/5/2021, 2:32:57 PM] [FHEM]     caching: Hue: 43812 (as string; from '43812')
  2021-01-05 14:32:59 caching: BZ.Bewegungsmelder-state: nomotion
[1/5/2021, 2:32:59 PM] [FHEM] BZ.Bewegungsmelder-state value nomotion not handled in values
  2021-01-05 14:33:01 caching: KiZ2.Bett-hue: 768
[1/5/2021, 2:33:01 PM] [FHEM]     caching: Hue: 768 (as string; from '768')
  2021-01-05 14:33:01 caching: KiZ2.Bett-sat: 252
[1/5/2021, 2:33:01 PM] [FHEM]     caching: Saturation: 252 (as string; from '252')
[1/5/2021, 2:33:02 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"c0fab06b-7ed3-4c94-93e8-48c597dccf41","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":120,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:33:02 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 120
[1/5/2021, 2:33:02 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20120&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:02 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:33:02 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:02 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:33:02 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:02 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":120,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:33:02.977Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"00dd76e6-a862-4bb6-abbf-aee98348e241","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:33:03 caching: KiZ2.Bett-hue: 21906
[1/5/2021, 2:33:03 PM] [FHEM]     caching: Hue: 21906 (as string; from '21906')
  2021-01-05 14:33:03 caching: KiZ2.Bett-sat: 254
[1/5/2021, 2:33:03 PM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-05 14:33:05 caching: KiZ2.Bett-hue: 5376
[1/5/2021, 2:33:05 PM] [FHEM]     caching: Hue: 5376 (as string; from '5376')
  2021-01-05 14:33:05 caching: KiZ2.Bett-sat: 5
[1/5/2021, 2:33:05 PM] [FHEM]     caching: Saturation: 5 (as string; from '5')
  2021-01-05 14:33:09 caching: KU.Kuehlschrank_Temp-temperature: 2.43
[1/5/2021, 2:33:09 PM] [FHEM]     caching: CurrentTemperature: 2.43 (as number; from '2.43')
[1/5/2021, 2:33:09 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"eb526108-54a1-49a1-9fcf-cd1ea806a2b1","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":0,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:33:09 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 0
[1/5/2021, 2:33:09 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%200&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:09 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:33:09 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:09 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:33:09 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:09 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":0,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:33:09.754Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"bfb3e80c-b3f3-4931-8b57-9246c5842f3a","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:33:09 caching: KiZ2.Bett-hue: 0
[1/5/2021, 2:33:09 PM] [FHEM]     caching: Hue: 0 (as string; from '0')
  2021-01-05 14:33:09 caching: KiZ2.Bett-sat: 254
[1/5/2021, 2:33:09 PM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-05 14:33:12 caching: KiZ2.Bett-hue: 2048
[1/5/2021, 2:33:12 PM] [FHEM]     caching: Hue: 2048 (as string; from '2048')
[1/5/2021, 2:33:15 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorTemperatureController","name":"SetColorTemperature","payloadVersion":"3","messageId":"6ad969b4-b882-4e37-9ca0-c849ae6e3c85","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"colorTemperatureInKelvin":2700}}}
[1/5/2021, 2:33:15 PM] [FHEM] KiZ2.Bett: executing set cmd for ColorTemperature with value 2700
[1/5/2021, 2:33:15 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20ct%202700&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:15 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorTemperatureController","name":"colorTemperatureInKelvin","value":2700,"timeOfSample":"2021-01-05T13:33:15.754Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"47fc60d5-4749-474c-96a0-0afb3127a555","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:33:15 caching: KiZ2.Bett-ct: 370 (2702K)
[1/5/2021, 2:33:15 PM] [FHEM]     caching: ColorTemperature: 370 (2702K) (as string; from '370 (2702K)')
  2021-01-05 14:33:15 caching: KiZ2.Bett-ct: 481 (2079K)
[1/5/2021, 2:33:15 PM] [FHEM]     caching: ColorTemperature: 481 (2079K) (as string; from '481 (2079K)')
  2021-01-05 14:33:17 caching: KiZ2.Bett-ct: 370 (2702K)
[1/5/2021, 2:33:17 PM] [FHEM]     caching: ColorTemperature: 370 (2702K) (as string; from '370 (2702K)')
[1/5/2021, 2:33:21 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorTemperatureController","name":"SetColorTemperature","payloadVersion":"3","messageId":"18dedcd6-8bb9-4c52-b562-02cd5fb94920","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"colorTemperatureInKelvin":7000}}}
[1/5/2021, 2:33:21 PM] [FHEM] KiZ2.Bett: executing set cmd for ColorTemperature with value 7000
[1/5/2021, 2:33:21 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20ct%207000&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:21 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorTemperatureController","name":"colorTemperatureInKelvin","value":7000,"timeOfSample":"2021-01-05T13:33:21.356Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"616b5611-a009-4a7c-9bfa-32b7236cd64f","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:33:21 caching: KiZ2.Bett-ct: 142 (7042K)
[1/5/2021, 2:33:21 PM] [FHEM]     caching: ColorTemperature: 142 (7042K) (as string; from '142 (7042K)')
  2021-01-05 14:33:21 caching: KiZ2.Bett-ct: 331 (3021K)
[1/5/2021, 2:33:21 PM] [FHEM]     caching: ColorTemperature: 331 (3021K) (as string; from '331 (3021K)')
  2021-01-05 14:33:21 caching: KiZ2.Bett-ct: 177 (5649K)
[1/5/2021, 2:33:21 PM] [FHEM]     caching: ColorTemperature: 177 (5649K) (as string; from '177 (5649K)')
  2021-01-05 14:33:23 caching: KiZ2.Bett-ct: 142 (7042K)
[1/5/2021, 2:33:23 PM] [FHEM]     caching: ColorTemperature: 142 (7042K) (as string; from '142 (7042K)')
[1/5/2021, 2:33:26 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"bc4e4d81-0850-459a-8160-a0cbef779905","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":120,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:33:26 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 120
[1/5/2021, 2:33:26 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20120&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:26 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:33:26 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:26 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:33:26 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:26 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":120,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:33:26.938Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"c32d2c2f-afb1-436f-bc16-aed8e280e208","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:33:27 caching: KiZ2.Bett-hue: 21906
[1/5/2021, 2:33:27 PM] [FHEM]     caching: Hue: 21906 (as string; from '21906')
  2021-01-05 14:33:30 caching: BZ.Heizung_Clima-measured-temp: 21.1
[1/5/2021, 2:33:30 PM] [FHEM]     caching: CurrentTemperature: 21.1 (as number; from '21.1')
  2021-01-05 14:33:32 caching: KiZ2.Bett-hue: 21760
[1/5/2021, 2:33:32 PM] [FHEM]     caching: Hue: 21760 (as string; from '21760')
[1/5/2021, 2:33:33 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"9dbc1558-253a-4999-b07b-e909b2a3eaa3","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":240,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:33:33 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 240
[1/5/2021, 2:33:33 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20240&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:33 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:33:33 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:33 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:33:33 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:33 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":240,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:33:33.710Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"31c33533-2a26-4a89-b309-e3f0a9f07a00","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:33:33 caching: KiZ2.Bett-hue: 43812
[1/5/2021, 2:33:33 PM] [FHEM]     caching: Hue: 43812 (as string; from '43812')
[1/5/2021, 2:33:39 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"4a2c942d-d599-4710-815e-cc959a061261","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":0,"saturation":1,"brightness":1}}}}
[1/5/2021, 2:33:39 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 0
[1/5/2021, 2:33:39 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%200&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:39 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 2:33:39 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:39 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 2:33:39 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 2:33:39 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":0,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T13:33:39.758Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"01b7dea6-ae56-4593-a6ab-e177c8706747","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 14:33:39 caching: KiZ2.Bett-hue: 0
[1/5/2021, 2:33:39 PM] [FHEM]     caching: Hue: 0 (as string; from '0')
  2021-01-05 14:33:43 caching: KiZ2.Bett-hue: 42240
amenomade
#35
OK... schon ein Schritt weiter. Zumindest geht jetzt die Lampe auf Farbe.
Zum Tuning der Farben brauche ich:
- die Werte die bei jeweiligen Farben in der alexa-fhem Log in der directive "Alexa.ColorController" "payload":{"color":{"hue":0,"saturation":1,"brightness":1}" kommen, und was als "caching ... from" kommt. Die habe ich schon teilweise hieroben, aber zugeordnet zu den gewünschten Farben wäre hilfreich.
- die Werte die nach einer Statusaktualisierung der Lampe in Fhem in hue, sat, bri und rgb kommen. Am besten mit Timestamp (also, das "READINGS" Teil von einem "list"). Wenn Du noch dazu die Ausgabe vom Eventmonitor für die Lampe gleichzeitig hast, noch besser.
Das mit "kurz eine Farbe, dann eine andere" kann man wahrscheinlich nicht vermeiden, da alexa-fhem drei Befehle nacheinander (jeweils mit hue, bri, sat) schickt. Was interessant ist, ist die Zielfarbe am Ende.
link611
#36
stelle auf blau von OFF kommend (ergebnis ist türkis):
[1/5/2021, 5:13:53 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 240
[1/5/2021, 5:13:53 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20240&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:13:53 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 5:13:53 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:13:53 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 5:13:53 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:13:53 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":240,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T16:13:53.353Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"0f7c32c1-3a40-4208-a281-e960b4d38aee","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 17:13:53 caching: KiZ2.Bett-hue: 43812
[1/5/2021, 5:13:53 PM] [FHEM]     caching: Hue: 43812 (as string; from '43812')
  2021-01-05 17:13:53 caching: KiZ2.Bett-state: on
[1/5/2021, 5:13:53 PM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-05 17:13:59 caching: KiZ2.Bett-hue: 35072
[1/5/2021, 5:13:59 PM] [FHEM]     caching: Hue: 35072 (as string; from '35072')
list vom Device:
     2021-01-03 15:23:52   alert           none
     2021-01-05 14:32:13   bri             254
     2021-01-05 17:13:54   colormode       xy
     2021-01-05 14:33:23   ct              142 (7042K)
     2021-01-03 15:23:52   effect          none
     2021-01-05 17:13:59   hue             35072
     2021-01-05 17:14:59   lastseen        2021-01-05T16:14Z
     2021-01-05 17:13:53   onoff           1
     2021-01-05 17:13:53   pct             100
     2021-01-05 14:33:34   reachable       1
     2021-01-05 17:13:56   rgb             31c2fc
     2021-01-05 14:33:09   sat             254
     2021-01-05 17:13:53   state           on
     2021-01-05 17:13:56   xy              0.1086,0.3111
stelle auf grün von OFF kommend (das passt eigtl.)
  2021-01-05 17:17:02 caching: KiZ2.Bett-state: off
[1/5/2021, 5:17:02 PM] [FHEM]     caching: On: off (as string; from 'off')
[1/5/2021, 5:17:07 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"3374a282-7fc1-479b-a122-89b203b477a5","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":120,"saturation":1,"brightness":1}}}}
[1/5/2021, 5:17:07 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 120
[1/5/2021, 5:17:07 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20120&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:17:07 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 5:17:07 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:17:07 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 5:17:07 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:17:07 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":120,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T16:17:07.654Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"39a78f71-8260-40cb-ad1e-fc0dc94814c6","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 17:17:07 caching: KiZ2.Bett-hue: 21906
[1/5/2021, 5:17:07 PM] [FHEM]     caching: Hue: 21906 (as string; from '21906')
  2021-01-05 17:17:07 caching: KiZ2.Bett-state: on
[1/5/2021, 5:17:07 PM] [FHEM]     caching: On: on (as string; from 'on')
list:
     2021-01-05 17:17:09   colormode       hs
     2021-01-05 17:17:07   hue             21906
     2021-01-05 17:17:08   lastseen        2021-01-05T16:17Z
     2021-01-05 17:17:07   onoff           1
     2021-01-05 17:17:07   pct             100
     2021-01-05 17:17:08   reachable       1
     2021-01-05 17:17:09   rgb             00ff01
     2021-01-05 17:17:07   state           on
     2021-01-05 17:17:11   xy              0.1086,0.3111
stelle auf rot von grün kommend (das passt)
[1/5/2021, 5:19:10 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":120,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T16:19:10.004Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"864b0a39-dfd8-47fa-8839-3685754766e7","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 17:19:10 caching: KiZ2.Bett-hue: 21906
[1/5/2021, 5:19:10 PM] [FHEM]     caching: Hue: 21906 (as string; from '21906')
  2021-01-05 17:19:10 caching: KiZ2.Bett-sat: 254
[1/5/2021, 5:19:10 PM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-05 17:19:12 caching: KiZ2.Bett-hue: 21504
[1/5/2021, 5:19:12 PM] [FHEM]     caching: Hue: 21504 (as string; from '21504')
[1/5/2021, 5:19:16 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"02ed82d3-bdfb-4139-a6a2-fa7e2a956835","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":0,"saturation":1,"brightness":1}}}}
[1/5/2021, 5:19:16 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 0
[1/5/2021, 5:19:16 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%200&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:19:16 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 5:19:16 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:19:16 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 5:19:16 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:19:16 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":0,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T16:19:16.602Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"1095d496-90f5-4047-9971-052ceec57c28","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 17:19:16 caching: KiZ2.Bett-hue: 0
[1/5/2021, 5:19:16 PM] [FHEM]     caching: Hue: 0 (as string; from '0')
list:
     2021-01-05 17:19:01   bri             254
     2021-01-05 17:19:20   colormode       hs
     2021-01-05 17:19:16   hue             0
     2021-01-05 17:19:59   lastseen        2021-01-05T16:19Z
     2021-01-05 17:18:59   onoff           1
     2021-01-05 17:19:01   pct             100
     2021-01-05 17:19:20   rgb             ff0000
     2021-01-05 17:19:10   sat             254
     2021-01-05 17:19:01   state           on
     2021-01-05 17:19:20   xy              0.2734,0.7109
von rot zu gelb (das passt auch eigtl.)
[1/5/2021, 5:21:17 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"842ca8fb-0623-437c-92cc-cd421d04544c","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":60,"saturation":1,"brightness":1}}}}
[1/5/2021, 5:21:17 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 60
[1/5/2021, 5:21:17 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%2060&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:21:17 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 5:21:17 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:21:17 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 5:21:17 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:21:17 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":60,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T16:21:17.257Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"62771045-ebbb-4d70-b70e-4d7539ff4aba","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 17:21:17 caching: KiZ2.Bett-hue: 10953
[1/5/2021, 5:21:17 PM] [FHEM]     caching: Hue: 10953 (as string; from '10953')
  2021-01-05 17:21:21 caching: KiZ2.Bett-hue: 7680
[1/5/2021, 5:21:21 PM] [FHEM]     caching: Hue: 7680 (as string; from '7680')
list:
     2021-01-05 17:21:17   colormode       hs
     2021-01-05 17:21:21   hue             7680
     2021-01-05 17:21:59   lastseen        2021-01-05T16:21Z
     2021-01-05 17:21:21   rgb             ffb300
     2021-01-05 17:21:19   xy              0.4805,0.5078
von gelb auf lila -> Aus :D
1/5/2021, 5:22:47 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 300
[1/5/2021, 5:22:47 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20300&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:22:47 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 45
[1/5/2021, 5:22:47 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%2045&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:22:47 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 92
[1/5/2021, 5:22:47 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%2092&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:22:47 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":300,"saturation":0.45,"brightness":0.92},"timeOfSample":"2021-01-05T16:22:47.192Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"767de018-df86-499e-9274-e40ec01e77e4","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 17:22:47 caching: KiZ2.Bett-hue: 54764
[1/5/2021, 5:22:47 PM] [FHEM]     caching: Hue: 54764 (as string; from '54764')
  2021-01-05 17:22:47 caching: KiZ2.Bett-sat: 114
[1/5/2021, 5:22:47 PM] [FHEM]     caching: Saturation: 114 (as string; from '114')
  2021-01-05 17:22:47 caching: KiZ2.Bett-bri: 234
[1/5/2021, 5:22:47 PM] [FHEM]     caching: Brightness: 234 (as string; from '234')
  2021-01-05 17:22:47 caching: KiZ2.Bett-state: dim87%
[1/5/2021, 5:22:47 PM] [FHEM]     caching: On: dim87% (as string; from 'dim87%')
  2021-01-05 17:22:47 caching: KiZ2.Bett-state: off
[1/5/2021, 5:22:47 PM] [FHEM]     caching: On: off (as string; from 'off')
  2021-01-05 17:22:47 caching: KiZ2.Bett-bri: 254
[1/5/2021, 5:22:47 PM] [FHEM]     caching: Brightness: 254 (as string; from '254')
list:
     2021-01-05 17:22:47   bri             254
     2021-01-05 17:22:47   hue             54764
     2021-01-05 17:22:59   lastseen        2021-01-05T16:22Z
     2021-01-05 17:22:47   onoff           0
     2021-01-05 17:22:47   pct             0
     2021-01-05 17:22:47   rgb             ff8dfd
     2021-01-05 17:22:47   sat             114
     2021-01-05 17:22:47   state           off
     2021-01-05 17:22:47   xy              0.3333,0.3333
von off zu lila 8ergebnis nach 2 farbwechseln ist es weiß:
[1/5/2021, 5:24:09 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"9c88dbba-1d97-43fc-b74f-0842c3e6875c","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":300,"saturation":0.4515,"brightness":0.9294}}}}
[1/5/2021, 5:24:09 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 300
[1/5/2021, 5:24:09 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20300&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:24:09 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 45
[1/5/2021, 5:24:09 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%2045&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:24:09 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 92
[1/5/2021, 5:24:09 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%2092&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:24:09 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":300,"saturation":0.45,"brightness":0.92},"timeOfSample":"2021-01-05T16:24:09.867Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"db7468b1-30dc-48de-8144-ce0b6f7166d4","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 17:24:10 caching: KiZ2.Bett-state: on
[1/5/2021, 5:24:10 PM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-05 17:24:10 caching: KiZ2.Bett-state: off
[1/5/2021, 5:24:10 PM] [FHEM]     caching: On: off (as string; from 'off')
  2021-01-05 17:24:10 caching: KiZ2.Bett-bri: 234
[1/5/2021, 5:24:10 PM] [FHEM]     caching: Brightness: 234 (as string; from '234')
  2021-01-05 17:24:10 caching: KiZ2.Bett-state: dim87%
[1/5/2021, 5:24:10 PM] [FHEM]     caching: On: dim87% (as string; from 'dim87%')
  2021-01-05 17:24:10 caching: KiZ2.Bett-bri: 254
[1/5/2021, 5:24:10 PM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-05 17:24:11 caching: KiZ2.Bett-bri: 20
[1/5/2021, 5:24:11 PM] [FHEM]     caching: Brightness: 20 (as string; from '20')
  2021-01-05 17:24:11 caching: KiZ2.Bett-state: dim12%
[1/5/2021, 5:24:11 PM] [FHEM]     caching: On: dim12% (as string; from 'dim12%')
  2021-01-05 17:24:12 caching: KiZ2.Bett-bri: 115
[1/5/2021, 5:24:12 PM] [FHEM]     caching: Brightness: 115 (as string; from '115')
  2021-01-05 17:24:12 caching: KiZ2.Bett-state: dim43%
[1/5/2021, 5:24:12 PM] [FHEM]     caching: On: dim43% (as string; from 'dim43%')
  2021-01-05 17:24:14 caching: KiZ2.Bett-bri: 234
[1/5/2021, 5:24:14 PM] [FHEM]     caching: Brightness: 234 (as string; from '234')
  2021-01-05 17:24:14 caching: KiZ2.Bett-state: dim87%
[1/5/2021, 5:24:14 PM] [FHEM]     caching: On: dim87% (as string; from 'dim87%')
  2021-01-05 17:24:14 caching: KiZ2.Bett-hue: 60160
[1/5/2021, 5:24:14 PM] [FHEM]     caching: Hue: 60160 (as string; from '60160')
     2021-01-05 17:24:13   bri             234
     2021-01-05 17:24:09   colormode       hs
     2021-01-05 17:24:14   hue             60160
     2021-01-05 17:24:59   lastseen        2021-01-05T16:24Z
     2021-01-05 17:24:10   onoff           1
     2021-01-05 17:24:13   pct             92
     2021-01-05 17:24:14   rgb             eb81b5
     2021-01-05 17:24:13   state           dim87%
     2021-01-05 17:24:12   xy              0.3672,0.2852
so, im nächsetn Fall wollte ich wieder zu blau wechseln, es war kurz blau und ist dann wieder zu weiß umgesprungen, anscheinend wird da ein "on" gesetzt:
[1/5/2021, 5:25:19 PM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"f0d1261f-1b46-4509-9c2f-7b73e6e02cec","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":240,"saturation":1,"brightness":1}}}}
[1/5/2021, 5:25:19 PM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 240
[1/5/2021, 5:25:19 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20240&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:25:19 PM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/5/2021, 5:25:19 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:25:19 PM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/5/2021, 5:25:19 PM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/5/2021, 5:25:19 PM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":240,"saturation":1,"brightness":1},"timeOfSample":"2021-01-05T16:25:19.596Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"af4be25b-a550-4459-bf00-4567b31c0b5d","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-05 17:25:19 caching: KiZ2.Bett-hue: 43812
[1/5/2021, 5:25:19 PM] [FHEM]     caching: Hue: 43812 (as string; from '43812')
  2021-01-05 17:25:19 caching: KiZ2.Bett-sat: 254
[1/5/2021, 5:25:19 PM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-05 17:25:19 caching: KiZ2.Bett-bri: 254
[1/5/2021, 5:25:19 PM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-05 17:25:19 caching: KiZ2.Bett-state: on
[1/5/2021, 5:25:19 PM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-05 17:25:20 caching: KiZ2.Bett-bri: 2
[1/5/2021, 5:25:20 PM] [FHEM]     caching: Brightness: 2 (as string; from '2')
  2021-01-05 17:25:20 caching: KiZ2.Bett-state: dim06%
[1/5/2021, 5:25:20 PM] [FHEM]     caching: On: dim06% (as string; from 'dim06%')
  2021-01-05 17:25:21 caching: KiZ2.Bett-bri: 57
[1/5/2021, 5:25:21 PM] [FHEM]     caching: Brightness: 57 (as string; from '57')
  2021-01-05 17:25:21 caching: KiZ2.Bett-state: dim25%
[1/5/2021, 5:25:21 PM] [FHEM]     caching: On: dim25% (as string; from 'dim25%')
  2021-01-05 17:25:21 caching: KiZ2.Bett-hue: 5376
[1/5/2021, 5:25:21 PM] [FHEM]     caching: Hue: 5376 (as string; from '5376')
  2021-01-05 17:25:21 caching: KiZ2.Bett-sat: 5
[1/5/2021, 5:25:21 PM] [FHEM]     caching: Saturation: 5 (as string; from '5')
  2021-01-05 17:25:22 caching: KiZ2.Bett-bri: 254
[1/5/2021, 5:25:22 PM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-05 17:25:22 caching: KiZ2.Bett-state: on
[1/5/2021, 5:25:22 PM] [FHEM]     caching: On: on (as string; from 'on')
list:
     2021-01-05 17:25:22   bri             254
     2021-01-05 17:25:19   colormode       xy
     2021-01-05 17:25:21   hue             5376
     2021-01-05 17:27:00   lastseen        2021-01-05T16:26Z
     2021-01-05 17:25:22   pct             100
     2021-01-05 17:25:22   rgb             ffffff
     2021-01-05 17:25:21   sat             5
     2021-01-05 17:25:22   state           on
     2021-01-05 17:25:21   xy              0.3333,0.3333
Hab jetzt dann noch mit Rosa, Gelb und Pink getestet, da ist es aber auch so, das ganz kurz eine Farbe auftaucht und dann wieder zu weiß wechselt.
So wie es aussieht, verhält sich das ganze anders, je nachdem von welcher farbe der Farbwechsel angestoßen wird.
Wenn ich von grün -> blau -> rot mache gehts
wenn ich von rot -> blau gehe, springt er kurz auf blau dann wieder auf rot
von rot -> grün geht
von blau -> grün geht
Ich glaube für's erste reicht das mal, es gibt da noch einige probleme mehr, z.b. von diesem Weiß das kommt wenn man gelb, pink oder rosa macht, und dann zu grün geht, ist es ein anders grün, eher bläulich.
zu rot ist es dann eher orange
wenn man zu blau will, ist es manchmal ok, manchmal kommt dann auch nur kurz blau und dann wieder weiß
es ist alles komisch :D
link611
Sind die Infos zu schlecht?
Was könnte ich denn noch besser mitteilen?
amenomade
Hab dich nicht vergessen ;)
Jetzt bin ich aber nicht mehr in Urlaub und habe weniger Zeit für Fhem. Ich kümmere mich am Wochenende darum.
amenomade
#39
OK, ich habe einen dummen Denkfehler gemacht. Versuche mal mit:
defmod huergb cmdalias set [\w\.]+ huergb \d+ AS {fhem "set $EVTPART0 hue ". round($EVTPART2*182.0416,0) .";; set $EVTPART0 rgb ".Color::hsv2hex($EVTPART2/360, ReadingsVal("$EVTPART0","sat",255)/255, ReadingsVal("$EVTPART0","bri",255)/255)}
defmod satrgb cmdalias set [\w\.]+ satrgb \d+ AS {fhem "set $EVTPART0 sat ". round($EVTPART2*2.55,0) .";; set $EVTPART0 rgb ".Color::hsv2hex(ReadingsVal("$EVTPART0","hue",65535)/65535, $EVTPART2/100, ReadingsVal("$EVTPART0","bri",255)/255)}
defmod brirgb cmdalias set [\w\.]+ brirgb \d+ AS {fhem "set $EVTPART0 bri ". round($EVTPART2*2.55,0) .";; set $EVTPART0 rgb ".Color::hsv2hex(ReadingsVal("$EVTPART0","hue",65535)/65535, ReadingsVal("$EVTPART0","sat",255)/255, $EVTPART2/100)}
link611
Ok, eins vorneweg, wenn ich sage "Alexa stelle auf X Prozent", stellt er die Helligkeit um, aber ändert die Farbe immer auf Rot, das müssten wir noch ändern.
Ansonsten sind jetzt die set befehle in Ordnung, jetzt müssen wir nur noch die Farben richtig hin bekommen.
habe vorhin schon mal ein wenig getestet, da kam bei blau ein lila, jetzt wo ich nochmal mit den logs testen wollte, kam, als ich auf blau gestellt habe erst rot, beim nächsten versuch dann pink.
habe mal die Farbwechsel im FHEM beobachtet, hier landen die LEDs in dem Fall wirklich erst auf Blau, in echt aber nur einen bruchteil einer Sekunde sichtbar und wechselt dann zu pink, nur falls das weiter hilft.
Ansonsten ist es auch noch weiterhin so, dass er immer erst eine Farbei kurz annimmt und dann zu einem Endergebnis kommt, ist nicht weiter schlimm, nur falls es weiter hilft.
Ich poste hier jetzt mal die Logs entsprechend der Endergebnisse:
stelle auf Blau (ergebnis Pink, beim ersten Test lila):
     2021-01-09 11:02:24   bri             254
     2021-01-09 11:02:24   colormode       hs
     2021-01-09 09:33:31   ct              370 (2702K)
     2021-01-09 11:02:26   hue             61034
     2021-01-09 11:04:14   lastseen        2021-01-09T10:03Z
     2021-01-09 11:02:22   onoff           1
     2021-01-09 11:02:24   pct             100
     2021-01-09 11:02:18   reachable       1
     2021-01-09 11:02:26   rgb             ff0069
     2021-01-09 09:14:56   sat             254
     2021-01-09 11:02:24   state           on
     2021-01-09 11:02:26   xy              0.5078,0.1602
[1/9/2021, 11:05:37 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"bd98ee06-4ac3-4026-9038-8f16ac43b531","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":240,"saturation":1,"brightness":1}}}}
[1/9/2021, 11:05:37 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 240
[1/9/2021, 11:05:37 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20240&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:05:37 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/9/2021, 11:05:37 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:05:37 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/9/2021, 11:05:37 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:05:37 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":240,"saturation":1,"brightness":1},"timeOfSample":"2021-01-09T10:05:37.670Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"5a2c380c-42c9-4898-a91d-c8a0c4fb3edb","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:05:37 caching: KiZ2.Bett-hue: 43690
[1/9/2021, 11:05:37 AM] [FHEM]     caching: Hue: 43690 (as string; from '43690')
  2021-01-09 11:05:37 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:05:37 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:05:37 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:05:37 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:05:37 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:05:37 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:05:37 caching: KiZ2.Bett-state: on
[1/9/2021, 11:05:37 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:05:38 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:05:38 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:05:38 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:05:38 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
stelle auf rot (ergebnis Rot mit einem leichten Pink stich, war beim ersten Test wirklich rot)
     2021-01-09 11:06:36   bri             254
     2021-01-09 11:06:37   colormode       hs
     2021-01-09 11:06:37   hue             64358
     2021-01-09 11:06:14   lastseen        2021-01-09T10:05Z
     2021-01-09 11:06:36   pct             100
     2021-01-09 11:06:37   rgb             ff001b
     2021-01-09 11:06:36   state           on
     2021-01-09 11:06:37   xy              0.6483,0.2228
[1/9/2021, 11:06:36 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"7d79e78a-4a22-4bf9-8a9a-f96df6d80fea","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":0,"saturation":1,"brightness":1}}}}
[1/9/2021, 11:06:36 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 0
[1/9/2021, 11:06:36 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%200&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:06:36 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/9/2021, 11:06:36 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:06:36 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/9/2021, 11:06:36 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:06:36 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":0,"saturation":1,"brightness":1},"timeOfSample":"2021-01-09T10:06:36.186Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"cb3e856b-6cae-42eb-84f8-7df8b6d028c8","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:06:36 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:06:36 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:06:36 caching: KiZ2.Bett-hue: 0
[1/9/2021, 11:06:36 AM] [FHEM]     caching: Hue: 0 (as string; from '0')
  2021-01-09 11:06:36 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:06:36 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:06:36 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:06:36 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:06:36 caching: KiZ2.Bett-state: on
[1/9/2021, 11:06:36 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:06:37 caching: KiZ2.Bett-hue: 64358
[1/9/2021, 11:06:37 AM] [FHEM]     caching: Hue: 64358 (as string; from '64358')
stelle auf Grün (ergebnis gelb, war beim ersten Test eher ein Orange)
     2021-01-09 11:08:13   bri             254
     2021-01-09 11:08:12   colormode       hs
     2021-01-09 11:08:16   hue             6007
     2021-01-09 11:09:14   lastseen        2021-01-09T10:08Z
     2021-01-09 11:08:13   pct             100
     2021-01-09 11:08:16   rgb             ff8c00
     2021-01-09 11:08:13   state           on
     2021-01-09 11:08:14   xy              0.5117,0.4766
[1/9/2021, 11:08:11 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"00dc9b88-83c5-4c97-b67c-99dd64c70d0a","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":120,"saturation":1,"brightness":1}}}}
[1/9/2021, 11:08:11 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 120
[1/9/2021, 11:08:11 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20120&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:08:11 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/9/2021, 11:08:11 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:08:11 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/9/2021, 11:08:11 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:08:11 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":120,"saturation":1,"brightness":1},"timeOfSample":"2021-01-09T10:08:11.168Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"a49b10a9-1700-4121-a38c-022eb44fc894","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:08:11 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:08:11 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:08:11 caching: KiZ2.Bett-hue: 21845
[1/9/2021, 11:08:11 AM] [FHEM]     caching: Hue: 21845 (as string; from '21845')
  2021-01-09 11:08:11 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:08:11 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:08:11 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:08:11 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:08:11 caching: KiZ2.Bett-state: on
[1/9/2021, 11:08:11 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:08:12 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:08:12 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:08:12 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:08:12 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:08:13 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:08:13 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:08:13 caching: KiZ2.Bett-state: on
[1/9/2021, 11:08:13 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:08:16 caching: KiZ2.Bett-hue: 6007
[1/9/2021, 11:08:16 AM] [FHEM]     caching: Hue: 6007 (as string; from '6007')
stelle auf Lila (ergebnis Weiß)
     2021-01-09 11:10:20   bri             235
     2021-01-09 11:10:18   colormode       hs
     2021-01-09 11:10:21   hue             2560
     2021-01-09 11:10:14   lastseen        2021-01-09T10:09Z
     2021-01-09 11:10:20   pct             92
     2021-01-09 11:10:21   rgb             ec9a81
     2021-01-09 11:10:16   sat             115
     2021-01-09 11:10:18   state           dim87%
     2021-01-09 11:10:20   xy              0.3867,0.3438
1/9/2021, 11:10:16 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"3384d679-7877-42b4-b309-7acbc911e8a7","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":300,"saturation":0.4515,"brightness":0.9294}}}}
[1/9/2021, 11:10:16 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 300
[1/9/2021, 11:10:16 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20300&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:10:16 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 45
[1/9/2021, 11:10:16 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%2045&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:10:16 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 92
[1/9/2021, 11:10:16 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%2092&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:10:16 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":300,"saturation":0.45,"brightness":0.92},"timeOfSample":"2021-01-09T10:10:16.788Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"b6bbf1c3-baeb-4ed0-8ea5-ed922d87b7b6","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:10:16 caching: KiZ2.Bett-hue: 54612
[1/9/2021, 11:10:16 AM] [FHEM]     caching: Hue: 54612 (as string; from '54612')
  2021-01-09 11:10:16 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:10:16 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:10:16 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:10:16 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:10:16 caching: KiZ2.Bett-sat: 115
[1/9/2021, 11:10:16 AM] [FHEM]     caching: Saturation: 115 (as string; from '115')
  2021-01-09 11:10:16 caching: KiZ2.Bett-bri: 233
[1/9/2021, 11:10:16 AM] [FHEM]     caching: Brightness: 233 (as string; from '233')
  2021-01-09 11:10:16 caching: KiZ2.Bett-state: dim87%
[1/9/2021, 11:10:16 AM] [FHEM]     caching: On: dim87% (as string; from 'dim87%')
  2021-01-09 11:10:16 caching: KiZ2.Bett-bri: 235
[1/9/2021, 11:10:16 AM] [FHEM]     caching: Brightness: 235 (as string; from '235')
  2021-01-09 11:10:17 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:10:17 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:10:17 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:10:17 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:10:18 caching: KiZ2.Bett-bri: 243
[1/9/2021, 11:10:18 AM] [FHEM]     caching: Brightness: 243 (as string; from '243')
  2021-01-09 11:10:18 caching: KiZ2.Bett-state: dim87%
[1/9/2021, 11:10:18 AM] [FHEM]     caching: On: dim87% (as string; from 'dim87%')
  2021-01-09 11:10:20 caching: KiZ2.Bett-bri: 235
[1/9/2021, 11:10:20 AM] [FHEM]     caching: Brightness: 235 (as string; from '235')
  2021-01-09 11:10:21 caching: KiZ2.Bett-hue: 2560
[1/9/2021, 11:10:21 AM] [FHEM]     caching: Hue: 2560 (as string; from '2560')
stelle auf rosa (ergebnis weiß)
     2021-01-09 11:11:30   bri             254
     2021-01-09 11:11:30   colormode       hs
     2021-01-09 11:11:30   hue             499
     2021-01-09 11:11:14   lastseen        2021-01-09T10:10Z
     2021-01-09 11:11:30   pct             100
     2021-01-09 11:11:30   rgb             ffc2bf
     2021-01-09 11:11:29   sat             64
     2021-01-09 11:11:30   state           on
     2021-01-09 11:11:30   xy              0.3594,0.3281
[1/9/2021, 11:11:29 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"c237af01-7926-4372-801d-4e4f72cfd31d","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":348,"saturation":0.251,"brightness":1}}}}
[1/9/2021, 11:11:29 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 348
[1/9/2021, 11:11:29 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20348&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:11:29 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 25
[1/9/2021, 11:11:29 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%2025&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:11:29 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/9/2021, 11:11:29 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:11:29 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":348,"saturation":0.25,"brightness":1},"timeOfSample":"2021-01-09T10:11:29.277Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"9213b6ee-25d8-47bd-8835-37a94709807f","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:11:29 caching: KiZ2.Bett-bri: 234
[1/9/2021, 11:11:29 AM] [FHEM]     caching: Brightness: 234 (as string; from '234')
  2021-01-09 11:11:29 caching: KiZ2.Bett-hue: 63350
[1/9/2021, 11:11:29 AM] [FHEM]     caching: Hue: 63350 (as string; from '63350')
  2021-01-09 11:11:29 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:11:29 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:11:29 caching: KiZ2.Bett-sat: 64
[1/9/2021, 11:11:29 AM] [FHEM]     caching: Saturation: 64 (as string; from '64')
  2021-01-09 11:11:29 caching: KiZ2.Bett-state: on
[1/9/2021, 11:11:29 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:11:29 caching: KiZ2.Bett-bri: 238
[1/9/2021, 11:11:29 AM] [FHEM]     caching: Brightness: 238 (as string; from '238')
  2021-01-09 11:11:29 caching: KiZ2.Bett-state: dim87%
[1/9/2021, 11:11:29 AM] [FHEM]     caching: On: dim87% (as string; from 'dim87%')
  2021-01-09 11:11:30 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:11:30 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:11:30 caching: KiZ2.Bett-state: on
[1/9/2021, 11:11:30 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:11:30 caching: KiZ2.Bett-hue: 499
[1/9/2021, 11:11:30 AM] [FHEM]     caching: Hue: 499 (as string; from '499')
stelle auf Pink (ergebnis Weiß)
     2021-01-09 11:12:16   bri             254
     2021-01-09 11:12:17   colormode       xy
     2021-01-09 11:12:18   hue             256
     2021-01-09 11:12:14   lastseen        2021-01-09T10:11Z
     2021-01-09 11:12:16   pct             100
     2021-01-09 11:12:18   rgb             fbbebc
     2021-01-09 11:12:18   sat             108
     2021-01-09 11:12:16   state           on
     2021-01-09 11:12:18   xy              0.3883,0.3269
[1/9/2021, 11:12:14 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"2b9d94f9-1d8d-4d4c-b11f-7b871c043b79","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":348,"saturation":0.251,"brightness":1}}}}
[1/9/2021, 11:12:14 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 348
[1/9/2021, 11:12:14 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20348&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:12:14 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 25
[1/9/2021, 11:12:14 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%2025&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:12:14 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/9/2021, 11:12:14 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:12:14 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":348,"saturation":0.25,"brightness":1},"timeOfSample":"2021-01-09T10:12:14.686Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"4e0bcda4-58ac-4716-87d1-218e02fdc54b","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:12:14 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:12:14 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:12:14 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:12:14 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:12:14 caching: KiZ2.Bett-hue: 63350
[1/9/2021, 11:12:14 AM] [FHEM]     caching: Hue: 63350 (as string; from '63350')
  2021-01-09 11:12:14 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:12:14 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:12:14 caching: KiZ2.Bett-state: on
[1/9/2021, 11:12:14 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:12:15 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:12:15 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:12:15 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:12:15 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:12:16 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:12:16 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:12:16 caching: KiZ2.Bett-state: on
[1/9/2021, 11:12:16 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:12:18 caching: KiZ2.Bett-hue: 256
[1/9/2021, 11:12:18 AM] [FHEM]     caching: Hue: 256 (as string; from '256')
  2021-01-09 11:12:18 caching: KiZ2.Bett-sat: 108
[1/9/2021, 11:12:18 AM] [FHEM]     caching: Saturation: 108 (as string; from '108')
stelle auf gelb (ist jetzt rot, war beim ersten test ein rötliches Orange)
     2021-01-09 11:15:01   bri             254
     2021-01-09 11:15:01   colormode       hs
     2021-01-09 11:15:00   hue             10922
     2021-01-09 11:14:15   lastseen        2021-01-09T10:13Z
     2021-01-09 11:15:01   pct             100
     2021-01-09 11:15:01   rgb             ffff00
     2021-01-09 11:15:00   sat             254
     2021-01-09 11:15:01   state           on
     2021-01-09 11:15:03   xy              0.7109,0.2773
1/9/2021, 11:14:59 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"315616e8-975e-4dcb-84a6-804a5add6688","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":60,"saturation":1,"brightness":1}}}}
[1/9/2021, 11:14:59 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 60
[1/9/2021, 11:14:59 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%2060&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:14:59 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/9/2021, 11:14:59 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:14:59 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/9/2021, 11:14:59 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:14:59 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":60,"saturation":1,"brightness":1},"timeOfSample":"2021-01-09T10:14:59.897Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"af060587-a049-4d5d-9ea8-303346774e88","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:15:00 caching: KiZ2.Bett-hue: 10922
[1/9/2021, 11:15:00 AM] [FHEM]     caching: Hue: 10922 (as string; from '10922')
  2021-01-09 11:15:00 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:15:00 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:15:00 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:15:00 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:15:00 caching: KiZ2.Bett-sat: 254
[1/9/2021, 11:15:00 AM] [FHEM]     caching: Saturation: 254 (as string; from '254')
  2021-01-09 11:15:00 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:15:00 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:15:00 caching: KiZ2.Bett-state: on
[1/9/2021, 11:15:00 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:15:01 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:15:01 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:15:01 caching: KiZ2.Bett-state: on
[1/9/2021, 11:15:01 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:15:04 caching: KiZ2.Bett-hue: 256
[1/9/2021, 11:15:04 AM] [FHEM]     caching: Hue: 256 (as string; from '256')
stelle Türkis (ergebnis Weiß mit minimalem blau-stich, war beim ersten Test ein eher grünliches Licht)
     2021-01-09 11:15:57   bri             222
     2021-01-09 11:15:55   colormode       hs
     2021-01-09 11:15:56   hue             3959
     2021-01-09 11:16:15   lastseen        2021-01-09T10:15Z
     2021-01-09 11:15:57   pct             87
     2021-01-09 11:15:57   rgb             df7a40
     2021-01-09 11:15:55   sat             181
     2021-01-09 11:15:57   state           dim81%
     2021-01-09 11:15:56   xy              0.4375,0.3789
[1/9/2021, 11:15:54 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"8b6752ba-b877-4c53-8b18-9737a778cfff","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":174,"saturation":0.7188,"brightness":0.8784}}}}
[1/9/2021, 11:15:54 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 174
[1/9/2021, 11:15:54 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%20174&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:15:54 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 71
[1/9/2021, 11:15:54 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%2071&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:15:54 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 87
[1/9/2021, 11:15:54 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%2087&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:15:54 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":174,"saturation":0.71,"brightness":0.87},"timeOfSample":"2021-01-09T10:15:54.979Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"ca062a95-42a5-4f56-9340-29ace0c20f57","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:15:55 caching: KiZ2.Bett-bri: 253
[1/9/2021, 11:15:55 AM] [FHEM]     caching: Brightness: 253 (as string; from '253')
  2021-01-09 11:15:55 caching: KiZ2.Bett-hue: 31675
[1/9/2021, 11:15:55 AM] [FHEM]     caching: Hue: 31675 (as string; from '31675')
  2021-01-09 11:15:55 caching: KiZ2.Bett-state: dim93%
[1/9/2021, 11:15:55 AM] [FHEM]     caching: On: dim93% (as string; from 'dim93%')
  2021-01-09 11:15:55 caching: KiZ2.Bett-sat: 181
[1/9/2021, 11:15:55 AM] [FHEM]     caching: Saturation: 181 (as string; from '181')
  2021-01-09 11:15:55 caching: KiZ2.Bett-bri: 222
[1/9/2021, 11:15:55 AM] [FHEM]     caching: Brightness: 222 (as string; from '222')
  2021-01-09 11:15:55 caching: KiZ2.Bett-state: dim81%
[1/9/2021, 11:15:55 AM] [FHEM]     caching: On: dim81% (as string; from 'dim81%')
  2021-01-09 11:15:55 caching: KiZ2.Bett-bri: 249
[1/9/2021, 11:15:55 AM] [FHEM]     caching: Brightness: 249 (as string; from '249')
  2021-01-09 11:15:56 caching: KiZ2.Bett-hue: 3959
[1/9/2021, 11:15:56 AM] [FHEM]     caching: Hue: 3959 (as string; from '3959')
  2021-01-09 11:15:57 caching: KiZ2.Bett-bri: 222
[1/9/2021, 11:15:57 AM] [FHEM]     caching: Brightness: 222 (as string; from '222')
  2021-01-09 11:15:57 caching: KiZ2.Bett-state: dim81%
[1/9/2021, 11:15:57 AM] [FHEM]     caching: On: dim81% (as string; from 'dim81%')
stelle orange (das stimmt, war auch beim ersten Test so)
     2021-01-09 11:17:08   bri             232
     2021-01-09 11:17:09   colormode       hs
     2021-01-09 11:17:07   hue             3959
     2021-01-09 11:17:08   pct             91
     2021-01-09 11:17:09   rgb             e97f43
     2021-01-09 11:17:08   state           dim87%
     2021-01-09 11:17:08   xy              0.5313,0.3867
[1/9/2021, 11:17:07 AM] >>>> [ssh] {"directive":{"header":{"namespace":"Alexa.ColorController","name":"SetColor","payloadVersion":"3","messageId":"e7f350ea-030f-4024-b299-4dc4ea7045c6","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03","cookie":{"fuuid":"5e09d5fa-f33f-9205-3028-8e2b682171eb0e03","device":"KiZ2.Bett"}},"payload":{"color":{"hue":39,"saturation":1,"brightness":1}}}}
[1/9/2021, 11:17:07 AM] [FHEM] KiZ2.Bett: executing set cmd for Hue with value 39
[1/9/2021, 11:17:07 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20huergb%2039&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:17:07 AM] [FHEM] KiZ2.Bett: executing set cmd for Saturation with value 100
[1/9/2021, 11:17:07 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20satrgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:17:07 AM] [FHEM] KiZ2.Bett: executing set cmd for Brightness with value 100
[1/9/2021, 11:17:07 AM] [FHEM]   executing: https://127.0.0.1:8087/fhem?cmd=set%20KiZ2.Bett%20brirgb%20100&fwcsrf=csrf_887131233427728&XHR=1
[1/9/2021, 11:17:07 AM] <<<< [ssh] {"context":{"properties":[{"namespace":"Alexa.ColorController","name":"color","value":{"hue":39,"saturation":1,"brightness":1},"timeOfSample":"2021-01-09T10:17:07.059Z","uncertaintyInMilliseconds":500}]},"event":{"header":{"namespace":"Alexa","name":"Response","payloadVersion":"3","messageId":"bea777b8-02e4-4ddc-88fc-4f3d02fddb8e","correlationToken":"-"},"endpoint":{"scope":{"type":"BearerToken","token":"AA769229-E677E0C69217D3BC"},"endpointId":"7c:b0:3e:aa:00:b0:33:e9-03"},"payload":{}}}
  2021-01-09 11:17:07 caching: KiZ2.Bett-bri: 221
[1/9/2021, 11:17:07 AM] [FHEM]     caching: Brightness: 221 (as string; from '221')
  2021-01-09 11:17:07 caching: KiZ2.Bett-hue: 7100
[1/9/2021, 11:17:07 AM] [FHEM]     caching: Hue: 7100 (as string; from '7100')
  2021-01-09 11:17:07 caching: KiZ2.Bett-hue: 3959
[1/9/2021, 11:17:07 AM] [FHEM]     caching: Hue: 3959 (as string; from '3959')
  2021-01-09 11:17:07 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:17:07 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:17:07 caching: KiZ2.Bett-state: on
[1/9/2021, 11:17:07 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:17:07 caching: KiZ2.Bett-state: dim81%
[1/9/2021, 11:17:07 AM] [FHEM]     caching: On: dim81% (as string; from 'dim81%')
  2021-01-09 11:17:08 caching: KiZ2.Bett-bri: 232
[1/9/2021, 11:17:08 AM] [FHEM]     caching: Brightness: 232 (as string; from '232')
  2021-01-09 11:17:08 caching: KiZ2.Bett-state: dim87%
[1/9/2021, 11:17:08 AM] [FHEM]     caching: On: dim87% (as string; from 'dim87%')
  2021-01-09 11:17:10 caching: KiZ2.Bett-bri: 254
[1/9/2021, 11:17:10 AM] [FHEM]     caching: Brightness: 254 (as string; from '254')
  2021-01-09 11:17:10 caching: KiZ2.Bett-state: on
[1/9/2021, 11:17:10 AM] [FHEM]     caching: On: on (as string; from 'on')
  2021-01-09 11:17:12 caching: KiZ2.Bett-hue: 3058
[1/9/2021, 11:17:12 AM] [FHEM]     caching: Hue: 3058 (as string; from '3058')
  2021-01-09 11:17:12 caching: KiZ2.Bett-sat: 254
[1/9/2021, 11:17:12 AM] [FHEM]     caching: Saturation: 254 (as string; from '254')
amenomade
Bin langsam ratlos. Hast Du etwas anderes, das die Lampe steuert? Jedes Mal sieht man zuerst "Caching KiZ2.Bett-hue: xxxx" mit dem richtigen Wert, und eine Sekunde später wir Hue auf einen anderen Wert gestellt.
Wenn Du den Eventmonitor gleichzeitig schaust, solltest Du die "set ... rgb ..." Befehle sehen können. Der dritte sollte jedes mal den richtigen rgb Wert haben: rot FF0000, blau 0000FF, grün 00FF00, usw. Ist es der Fall?
link611
#42
Habe nichts mehr, was die Lampe aktiv steuert.
Habe es jetzt aber hin bekommen, dass ich Deconz/phoscon direkt mit Alexa pairen konnte, jetzt kann ich die Lampe richtig steuern per Alexa. Komisch ist es aber trotzdem dass da was nicht passt wenn es über FHEM kommt.
Noch zur Info, habe es gerade noch mit gassistant gegengetestet, dazu habe ich das Homebridge-Mapping gelöscht. Hier funktionieren alle Farben ohne Probleme (nur grün will er nicht machen, er sagt zwar OK, passieren tut aber nix)
Also scheint es wohl doch eher ein Thema vom alexa-Modul zu sein?
amenomade
Ja, justme hatte mal geschrieben, dass für Geräte, die nur set rgb unterstützen, es noch nicht implementiert war. Schade, dass er sich in diesem Thread nicht gemeldet hat, er hätte vielleicht gute Empfehlungen wegen cmdalias gehabt.
