Modul HourCounter - Betriebsstundenzähler mit einem Fensterkontakt
Begonnen von John, 08 April 2013, 22:11:55
fhemjörg
#315
Bei mir wir "countsOverall" nicht gezählt
nur "tickupdate" zählt immer einen höher
014-12-19_11:27:17 Gas verbrTagEuro: 1.02 €
2014-12-19_11:27:17 Gas verbrTag: 1.77 m³
2014-12-19_11:27:17 Gas verbrTagkWh: 18.8 kWh
2014-12-19_11:37:00 Gas countsPerDay: 0
2014-12-19_11:37:00 Gas countsOverall: 3901400
2014-12-19_11:37:00 Gas pulseTimeEdge: 0
2014-12-19_11:37:00 Gas pauseTimeIncrement: 0
2014-12-19_11:37:00 Gas pauseTimeEdge: 0
2014-12-19_11:37:00 Gas pauseTimePerDay: 0
2014-12-19_11:37:00 Gas pauseTimeOverall: 0
2014-12-19_11:37:00 Gas value: 1
2014-12-19_11:37:00 Gas 0
2014-12-19_11:37:00 Gas tickUpdated: 178
2014-12-19_11:37:00 Gas Zaehlerstand: 39014.00 m³
2014-12-19_11:37:00 Gas verbrTag: 1.78 m³
2014-12-19_11:37:00 Gas verbrTagkWh: 18.9 kWh
2014-12-19_11:46:34 Gas tickUpdated: 179
2014-12-19_11:46:34 Gas verbrTagEuro: 1.03 €
2014-12-19_11:46:34 Gas verbrTag: 1.79 m³
2014-12-19_11:46:34 Gas verbrTagkWh: 19.0 kWh
2014-12-19_11:56:23 Gas tickUpdated: 180
2014-12-19_11:56:23 Gas verbrTag: 1.80 m³
2014-12-19_11:56:23 Gas verbrTagkWh: 19.2 kWh
2014-12-19_12:00:00 Gas pulseTimeIncrement: 27675
2014-12-19_12:00:00 Gas pulseTimePerDay: 19034
2014-12-19_12:00:00 Gas pulseTimeOverall: 42551
2014-12-19_12:00:00 Gas tickUpdated: 181
2014-12-19_12:00:00 Gas verbrTagEuro: 1.04 €
2014-12-19_12:00:00 Gas verbrTag: 1.81 m³
2014-12-19_12:00:00 Gas verbrTagkWh: 19.3 kWh
2014-12-19_12:00:00 Gas tickHour: 18
2014-12-19_12:00:00 Gas appCountsPerHourTemp: 0
2014-12-19_12:00:00 Gas appCountsPerHour: 0
2014-12-19_12:06:30 Gas tickUpdated: 182
2014-12-19_12:06:30 Gas verbrTagEuro: 1.05 €
2014-12-19_12:06:30 Gas verbrTag: 1.82 m³
2014-12-19_12:06:30 Gas verbrTagkWh: 19.4 kWh
2014-12-19_12:16:38 Gas tickUpdated: 183
2014-12-19_12:16:38 Gas verbrTag: 1.83 m³
2014-12-19_12:16:38 Gas verbrTagkWh: 19.5 kWh
2014-12-19_12:26:40 Gas tickUpdated: 184
2014-12-19_12:26:40 Gas verbrTagEuro: 1.06 €
2014-12-19_12:26:40 Gas verbrTag: 1.84 m³
2014-12-19_12:26:40 Gas verbrTagkWh: 19.6 kWh
2014-12-19_12:27:07 Gas tickUpdated: 185
2014-12-19_12:27:07 Gas verbrTag: 1.85 m³
2014-12-19_12:27:07 Gas verbrTagkWh: 19.7 kWh
2014-12-19_12:37:05 Gas countsPerDay: 0
2014-12-19_12:37:05 Gas countsOverall: 3901400
2014-12-19_12:37:05 Gas pulseTimeEdge: 0
2014-12-19_12:37:05 Gas pauseTimeIncrement: 0
2014-12-19_12:37:05 Gas pauseTimeEdge: 0
2014-12-19_12:37:05 Gas pauseTimePerDay: 0
2014-12-19_12:37:05 Gas pauseTimeOverall: 0
2014-12-19_12:37:05 Gas value: 1
2014-12-19_12:37:05 Gas 0
2014-12-19_12:37:05 Gas tickUpdated: 186
2014-12-19_12:37:05 Gas Zaehlerstand: 39014.00 m³
2014-12-19_12:37:05 Gas verbrTagEuro: 1.07 €
2014-12-19_12:37:05 Gas verbrTag: 1.86 m³
2014-12-19_12:37:05 Gas verbrTagkWh: 19.8 kWh
2014-12-19_12:47:02 Gas tickUpdated: 187
2014-12-19_12:47:02 Gas verbrTag: 1.87 m³
al_ro
Hallo fhemjörg,
hast du für HourCounter auch ein OFF-Ereignis definiert?
Gruß Alex
fhemjörg
#317
Mein device sieht so aus
define Gas HourCounter Gaszaehler:reading:.on
attr Gas alias Zähler / Tag
attr Gas event-min-interval tick.*:0,.*:3600
attr Gas event-on-change-reading .*
attr Gas room Arduino
Jörg
al_ro
Hallo
ich habe meine Definition um das OFF-Ereignis ergänzt:
define Gaszaehler_HourCounter HourCounter Gaszaehler_Debounce_Flag:on Gaszaehler_Debounce_Flag:off
Danach hat es wieder funktioniert.
Gruß Alex
kvo1
Hallo fhemjörg,
wie (mit welcher Hardware) erfasst Su den Zählerstand ? und
an welcher Stelle rechnest Du das im kwh, Euro etc um ....
Kannst Du das bitte hier Posten ..... bin an ähnlichem "Projekt"
danke
kvo
RPi1: mit CUL: HM-CC-RT-DN,HM-ES-PMSw1-Pl,HM-LC-BL1-FM,HM-LC-Bl1PBU-FM,HM-LC-SW1-PL2,HM-SCI-3-FM,HM-SEC-SC-2,KFM-Sensor
RPi2: Viessmann(optolink) mit 99_VCONTROL.pm,
Cubietruck: Wheezy / Apache / Owncloud
Cubietruck: Armbian(Jessie) / fhem 5.7 / LMS 7.9
RPi3: (Test) mit 7" Touch  &  HM-MOD-RPI-PCB
John
Zitat von: al_ro am 19 Dezember 2014, 14:04:27
Hallo
Gruß Alex
Hallo Alex,
stimmt da ist wohl noch ein Fehler im Modul. Dies betrifft nur diejenigen, die kein OFF-Ereignis definiert haben.
Muss das nochmal testen.
John
CubieTruck Docker Node-Red Tasmota Shelly Homematic-IP
cotecmania
wie kann denn der ON/OFF-Status definiert werden, wenn mein KM271 Strings fuer Ein/Aus liefert mit Leerzeichen :
Kessel aus
1.Stufe an
Joe
FHEM auf Debian 13 in Proxmox VM
MAX!/HM/Sonoff-Thermostate, HM-Rolladenschalter, Shellys aller Art, LevelJet-Ölstandsmessung, KM271, IPCAM, TAB13" FTUI3
John
Hi Joe,
das geht wie immer bei FHEM über regexp.
1. Schritt: man holt sich das on und off Ereignis vom Eventmonitor zur Ansicht
2. Schritt: passendes Regexp formulieren
3. Schritt: Regexp testen z.B. via https://www.regex101.com/
Stell mal das Ergebnis vom 1. Schritt rein, dann sehen wir weiter. (das Problem haben ja einige)
John
kvo1
geht das nicht auch über eventmap ?
attr <xxxxxx> eventMap EIN:on AUS:off
fhemjörg
Hallo Alex,
danke das war es jetzt geht es wieder
Jörg
al_ro
cotecmania
Kessel aus
1.Stufe an
Joe
Habe es so lösen können :
define BrennerCounter HourCounter KM271:Brenner_Ansteuerung:.1.* KM271:Brenner_Ansteuerung:.Kessel.*
Joe
ojb
Hallo John,
erst mal ein herzliches Dank für HourCounter und Dein Engagement hier im Forum.
Leider habe ich ein komisches Problem und kriege einfach keine vernünftigen Ergebnisse zustande.
Ich möchte HourCounter für den klassischen Fall verwenden, die Laufzeit meiner Wärmepumpe auszuwerten.
Als Events bekomme ich so etwas:
2014-12-22 09:13:21 VCONTROL Heizung Status_Verdichter: on
Entsprechend sieht meine Definition aus:
define HourCounter_Heizung_Status_Verdichter HourCounter Heizung:Status_Verdichter:.on Heizung:Status_Verdichter:.off
HourCounter erkennt das Einschalten, zählt aber nicht weiter.
Hier ein Beispiel aus dem Logfile mit
egrep "Status_Verdichter.(pulseTimeIncrement|value)" HourCounter-2014.log
extrahiert:
2014-12-22_09:04:19 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 0
2014-12-22_09:04:19 HourCounter_Heizung_Status_Verdichter value: 0
2014-12-22_09:07:27 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 0
2014-12-22_09:07:27 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:10:32 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 0
2014-12-22_09:10:32 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:13:21 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 0
2014-12-22_09:13:21 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:13:46 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 25
2014-12-22_09:13:46 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:14:09 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 48
2014-12-22_09:14:09 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:16:30 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 48
2014-12-22_09:16:30 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:19:27 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 48
2014-12-22_09:19:27 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:22:19 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 48
2014-12-22_09:22:19 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:25:30 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 48
2014-12-22_09:25:30 HourCounter_Heizung_Status_Verdichter value: 1
2014-12-22_09:28:31 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 229
2014-12-22_09:28:31 HourCounter_Heizung_Status_Verdichter value: 0
2014-12-22_09:31:22 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 229
2014-12-22_09:31:22 HourCounter_Heizung_Status_Verdichter value: 0
2014-12-22_09:34:23 HourCounter_Heizung_Status_Verdichter pulseTimeIncrement: 229
Man sieht die Wärmepumpe ist von 09:07 bis 09:28 gelaufen, also ca. 27 Minuten.
Obwohl der Status, also value, richtig erkannt wird, zählt HourCounter nicht weiter.
Woran kann das liegen?
Danke und lieben Gruß
Oli
FHEM unter Debian auf Asus EEBox: KNX (Wetterstation, Rollläden, Beleuchtung), Maple-CUN (Temperatur und Feuchte über 1-Wire, Intertechno-Funksteckdosen), PV-Anlage mit Plenticore und BYD, Viessmann Wärmepumpe, 1-Wire (Temperatur, Feuchte, Stromverbrauch), Husquarna-Automower, ...
John
Hallo Oli,
das ist noch ein Fehler im Modul, der mit der Version 1.0.1.1 von gestern behoben sein sollte.
Du solltest dir überlegen, ob du nicht auch das OFF_Ereignis aufnimmst, dann kannst du auch die Betriebs- und Stillstandszeiten
erfassen.
John
marko67
könnt mir jemand erklären warum ich Abweichungen bei
- appCountsPerDay 115 zu
- countsPerDay 241
habe?
Welche Einheit h/min/sek wird bei app und appOp verwendet?
z. B : appCountsPerDay= 115 und appOpHoursPerDay= 0.331388888888889
Mein Def lautet : GZaehler_Durchlauf_dummy:on GZaehler_Durchlauf_dummy:off. Gezählt wird durch ein Relais das on geschaltet wird und nach 10 sek nach off.
