gelöst: MQTT Befehle für Shelly Plus 1PM
Begonnen von romakrau, 19 November 2021, 18:02:29
romakrau
ich versuche meinen Shelly Plus 1PM per MQTT2 ein- und auszuschalten. Leider gelingt mir dies nicht und ich brauche Hilfe.
Anbei das List des Devices:
   CFGFN
   CID        shellyplus1pm_a8032abe179c
   DEF        shellyplus1pm_a8032abe179c
   DEVICETOPIC MQTT2_shellyplus1pm_a8032abe179c
   FUUID      6197d5c8-f33f-e93f-d43c-da313fabf5089409
   IODev      myBroker
   LASTInputDev myBroker
   MSGCNT     14
   NAME       MQTT2_shellyplus1pm_a8032abe179c
   NR         427
   STATE      ???
   TYPE       MQTT2_DEVICE
   myBroker_MSGCNT 14
   myBroker_TIME 2021-11-19 17:53:10
     2021-11-19 17:50:16   IODev           myBroker
     2021-11-19 17:50:16   mqtt_connected  true
     2021-11-19 17:50:16   online          true
     2021-11-19 17:53:10   rpc_dst         shellyplus1pm-a8032abe179c/events
     2021-11-19 17:53:10   rpc_method      NotifyStatus
     2021-11-19 17:50:16   rpc_params_mqtt_connected true
     2021-11-19 17:53:10   rpc_params_switch_0_aenergy_by_minute_1 0.000
     2021-11-19 17:53:10   rpc_params_switch_0_aenergy_by_minute_2 0.000
     2021-11-19 17:53:10   rpc_params_switch_0_aenergy_by_minute_3 0.000
     2021-11-19 17:53:10   rpc_params_switch_0_aenergy_minute_ts 1637340778
     2021-11-19 17:53:10   rpc_params_switch_0_aenergy_total 271.561
     2021-11-19 17:53:10   rpc_params_switch_0_id 0
     2021-11-19 17:50:16   rpc_params_switch_0_temperature_tC 52.00
     2021-11-19 17:50:16   rpc_params_switch_0_temperature_tF 125.60
     2021-11-19 17:50:16   rpc_params_switch_0_voltage 234.09
     2021-11-19 17:50:26   rpc_params_sys_available_updates_beta_version 0.9.0-beta2
     2021-11-19 17:53:10   rpc_params_ts   1637340780.19
     2021-11-19 17:50:16   rpc_params_wifi_rssi -47
     2021-11-19 17:50:16   rpc_params_wifi_ssid Finger von die Box
     2021-11-19 17:50:16   rpc_params_wifi_sta_ip 192.168.187.246
     2021-11-19 17:50:16   rpc_params_wifi_status got ip
     2021-11-19 17:53:10   rpc_src         shellyplus1pm-a8032abe179c
     2021-11-19 17:52:59   switch_0_aenergy_by_minute_1 0.000
     2021-11-19 17:52:59   switch_0_aenergy_by_minute_2 0.000
     2021-11-19 17:52:59   switch_0_aenergy_by_minute_3 0.000
     2021-11-19 17:52:59   switch_0_aenergy_minute_ts 1637340778
     2021-11-19 17:52:59   switch_0_aenergy_total 271.561
     2021-11-19 17:52:59   switch_0_apower 0.000
     2021-11-19 17:52:59   switch_0_id     0
     2021-11-19 17:52:59   switch_0_output true
     2021-11-19 17:52:59   switch_0_source init
     2021-11-19 17:52:59   switch_0_temperature_tC 52.1
     2021-11-19 17:52:59   switch_0_temperature_tF 125.8
     2021-11-19 17:52:59   switch_0_voltage 233.790
     2021-11-19 17:50:26   sys_available_updates_beta_version 0.9.0-beta2
     2021-11-19 17:50:26   sys_fs_free     258781
     2021-11-19 17:50:26   sys_fs_size     414401
     2021-11-19 17:50:26   sys_mac         A8032ABE179C
     2021-11-19 17:50:26   sys_ram_free    181036
     2021-11-19 17:50:26   sys_ram_size    250040
     2021-11-19 17:50:26   sys_restart_required false
     2021-11-19 17:50:26   sys_time        17:50
     2021-11-19 17:50:26   sys_unixtime    1637340626
     2021-11-19 17:50:26   sys_uptime      15
   alias      Trockner
   readingList shellyplus1pm_a8032abe179c:shellyplus1pm-a8032abe179c/online:.* online
shellyplus1pm_a8032abe179c:shellyplus1pm-a8032abe179c/status/mqtt:.* { json2nameValue($EVENT, 'mqtt_', $JSONMAP) }
shellyplus1pm_a8032abe179c:shellyplus1pm-a8032abe179c/events/rpc:.* { json2nameValue($EVENT, 'rpc_', $JSONMAP) }
shellyplus1pm_a8032abe179c:shellyplus1pm-a8032abe179c/status/sys:.* { json2nameValue($EVENT, 'sys_', $JSONMAP) }
shellyplus1pm_a8032abe179c:shellyplus1pm-a8032abe179c/status/switch_0:.* { json2nameValue($EVENT, 'switch_0_', $JSONMAP) }
   room       MQTT2_DEVICE
Bisher habe ich diese SetList ausprobiert :
on shellies/shellyplus1pm_a8032abe179c/relay/0/command on
off shellies/shellyplus1pm_a8032abe179c/relay/0/command off
auch ein
off shellies/shellyplus1pm_a8032abe179c/rpc {"method":"Switch.Set","params":{"id":0,"on":false}}
hat nicht funktioniert.
Roman
EDIT: Falscher Type im Betreff, geändert
Hallo Roman,
schon ein Template probiert?
romakrau
Hallo Otto,
ja das Shelly1 Template. Es listet mir auch die angezeigten Readings auf. Leider enthält es keine setList's.
Roman
Das glaube ich nicht, bei mir ist es komplett. Ich sehe bei Dir auch kein Reading attrTemplateVersion  ::)
ist dein attrTemplate aktuell?
{ Svn_GetFile("FHEM/lib/AttrTemplate/mqtt2.template", "FHEM/lib/AttrTemplate/mqtt2.template", sub(){ AttrTemplate_Initialize() }) }
Das steht bei mir im template im setList:
attr DEVICE setList\
  off:noArg shellies/DEVNAME/relay/0/command off\
  on:noArg shellies/DEVNAME/relay/0/command on\
  x_update:noArg shellies/DEVNAME/command update_fw\
  x_mqttcom shellies/DEVNAME/command $EVTPART1
romakrau
Hallo Otto,
das scheint es zu sein. Das MQTT-Template ist nicht aktuell. Wie werden denn die Templates aktualisiert. Update all mit nachfolgendem shutdown restart hatte ich gemacht.
Roman
Hab ich doch geschrieben!? Die erste Codezeile im Post in die FHEM Kommandozeile werfen und ausführen
romakrau
Hatte ich durchgeführt aber keine Änderung in der Template Auswahl.
2021.11.19 21:57:12 1: SVN download of FHEM/lib/AttrTemplate/mqtt2.template to FHEM/lib/AttrTemplate/mqtt2.template finished
2021.11.19 21:57:12 2: AttrTemplates: got 232 entries
TomLee
Hast du irgendwie was am Topic-Pfad in den Einstellungen des Shelly geändert ?
Das Template erwartet in ReadingList shellies am Anfang des Topic-Pfad, das bei dir irgendwie nicht der Fall .
Also bspw. so:
shellyplus1pm_a8032abe179c:shellies/shellyplus1pm-a8032abe179c/status/mqtt:.*
und nicht so:
Es geht vielleicht auch nicht um die Auswahl, Du hast gesagt Du hast shelly1 angewendet - aber aus deinem List geht das nicht hervor - was ist wenn Du das Template shelly1 nochmal anwendest?
Wenn Du shelly1 auswählst bekommst Du den Inhalt des Templates angezeigt, da solltest Du sehen, was das Template macht.
romakrau
Tut mir leid, aus irgendeinem Grund werden bei mir nicht die Shelly Templates angezeigt (A_10...,A_11...).
Ich sehe nur das shelly1 template. Dieses generiert gelegentlich ein von dir beschriebenes setlist (shellies...).
TomLee
Schonmal ohne shellies versucht ?
on shellyplus1pm_a8032abe179c/relay/0/command on
off shellyplus1pm_a8032abe179c/relay/0/command off
romakrau
Hallo Tom,
alle Varianten schon versucht. Danke
romakrau
Ich denke das Kernproblem ist das fhem mir nicht die Shelly Templates anbietet. Irgendetwas ist da faul.
TomLee
Nochmal, weil das shellies am Anfang des Topic fehlt:
filter:TYPE=MQTT2_DEVICE:FILTER=readingList=.*shellies.*
aber selbst wenn sie zur Auswahl hast passt doch nach dem anwenden der Topicpfad nicht, das Template erstellt mit shellies und deine ReadingList oben sagt ohne muss es sein.
romakrau
Hi Tom,
hatte ich im ersten Beitrag geschrieben das ich es schon ausprobiert hatte.
