HM-PB-4Dis
Begonnen von SGi, 28 April 2013, 22:41:02
martinp876
hm - mit welchem Interface gibst du ein?
Schon einmal mit der Konsole probiert - nur zur sicherheit?
steht im Device etwas von AES? Irgend ein Parameter mit AES im Namen?
Gruss Martin
sherwood
JA, da steht was von aesKeyNbr  FF.
Sagt dir das was?
BNO
12
BNOCNT
3
DEF
1EAC8A
EVENTS
204
HMLAN1_MSGCNT
244
HMLAN1_RAWMSG
E1EAC8A,0000,004F91D7,FF,FFCC,64A0401EAC8A1C2467410C
HMLAN1_RSSI
-52
HMLAN1_TIME
2013-11-22 17:06:19
IODev
HMLAN1
LASTInputDev
HMLAN1
MSGCNT
244
NAME
Display_Taster
NR
42
STATE
CMDs_pending
TYPE
CUL_HM
channel_01
Display_Taster_Btn_01
channel_02
Display_Taster_Btn_02
channel_03
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_03
channel_04
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_04
channel_05
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_05
channel_06
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_06
channel_07
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_07
channel_08
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_08
channel_09
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_09
channel_0A
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_10
channel_0B
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_11
channel_0C
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_12
channel_0D
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_13
channel_0E
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_14
channel_0F
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15
channel_10
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_16
channel_11
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_17
channel_12
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_18
channel_13
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_19
channel_14
CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_20
lastMsg
No:64 - t:40 s:1EAC8A d:1C2467 410C
protCmdDel
171
protCmdPend
22 CMDs_pending
protIOerr
2 last_at:2013-11-22 14:38:37
protLastRcv
2013-11-22 17:06:19
protResndFail
7 last_at:2013-11-22 16:36:57
protSnd
66 last_at:2013-11-22 16:50:37
protState
CMDs_pending
rssi_at_HMLAN1
avg:-56.13 min:-78 max:-46 lst:-52 cnt:244
Readings
CommandAccepted
yes
2013-11-22 16:50:37
PairedTo
0x1E9E5A
2013-11-22 16:36:54
R-language
German
2013-11-22 14:35:32
R-pairCentral
0x1E9E5A
2013-11-22 14:35:32
R-stbyTime
10 s
2013-11-22 13:14:55
RegL_00:
02:01 07:01 0A:1E 0B:9E 0C:5A 0E:0A 00:00
2013-11-22 16:36:54
aesKeyNbr
FF
2013-11-22 16:36:56
battery
ok
2013-11-22 17:06:20
powerOn
2013-11-22 15:23:12
state
CMDs_pending
2013-11-22 17:12:18
text1
2013-11-22 16:33:18
text2
2013-11-22 16:33:18
Habe es eben auch nochmal über die Console und telnet versucht. Kein unterschied.
fhem> set Display_Taster_Btn_01 text WZ AN
fhem> 2013-11-22 18:53:09 CUL_HM Display_Taster_Btn_01 text1: set_WZ
2013-11-22 18:53:09 CUL_HM Display_Taster_Btn_01 text2: set_AN
2013-11-22 18:53:10 CUL_HM Display_Taster aesKeyNbr: FF
2013-11-22 18:53:10 CUL_HM Display_Taster ResndFail
2013-11-22 18:53:11 CUL_HM Display_Taster RESPONSE TIMEOUT:RegisterRead
Der Read kommt automatisch, wenn ich vor dem Befehl "Zentrale Übernehmen" am 4Dis aktivere.
Ohne vorher zu aktivieren passiert nur das.
2013-11-22 18:55:04 CUL_HM Display_Taster_Btn_01 text1: set_WZ
2013-11-22 18:55:04 CUL_HM Display_Taster_Btn_01 text2: set_AN
martinp876
Zentrale Übernehmen ist demnach das Anlernen - oder auch Config(ure) des 4dis
das AES scheit mit zu bedeuten, dass das Device AES "wünscht" aber der HMLAN keines (oder kein passendes) hat. Da habe ich noch zu wenig Erfahrungswerte...
Sehen kann ich ob AES von Device gewünscht ist, wenn du die rohmessages schickst.
Da der 4dis ein config-device ist musst du immer die komamndos in FHEM absetzen und dann "übernehmen" drücken. Danach sollten alle Kommandos (erfolgreich oder nicht) übertragen sein. Es sollten keine Commands-pending sein! Sonst noch einmal "Übernehmen".
Wenn AES gefordert/gewünscht oder eingeschaltet ist musst du es über die PC-SW einstellen/abschalten oder den Key vergeben. Den Key dann in HMLAN eintragen.
Gruss Martin
sherwood
Es funktioniert jetzt :)
Habe nochmal alles reseted und einen update force gemacht.
Danke für die Unterstützung.
sherwood
Eine Frage habe ich noch.
Wie bekomme ich den ein Blank für den ersten Text hin? Also "Text1" soll leer bleiben.
sherwood
Irgendwas ist da faul.
Jetzt geht es wieder nicht, wenn ich versuche nur Text zu senden.
Hier der Log:
2013.11.23 20:45:53 5: Cmd: >set CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 test WLAN An<
2013.11.23 20:45:55 5: HMLAN_Send:  HMLAN1 I:K
2013.11.23 20:45:55 5: HMLAN_Parse: HMLAN1 V:03C1 sNo:JEQ0707135 d:1E9E5A O:1E9E5A t:003B143B IDcnt:0005
2013.11.23 20:46:01 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0000 t:003B2C20 d:FF r:FFCC     m:F5 8400 1EAC8A 000000 1400604A45513037303537313340940000
2013.11.23 20:46:01 5: HMLAN1 dispatch A1AF584001EAC8A0000001400604A45513037303537313340940000::-52:HMLAN1
2013.11.23 20:46:01 2: CUL_HM set Display_Taster getConfig
2013.11.23 20:46:01 5: HMLAN_Send:  HMLAN1 S:+1EAC8A,01,01,FE1F
2013.11.23 20:46:01 5: HMLAN_Send:  HMLAN1 S:S867F59C6 stat:  00 t:00000000 d:01 r:867F59C6 m:2D A001 1E9E5A 1EAC8A 00040000000000
2013.11.23 20:46:02 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:003B2D3C d:FF r:FFC8     m:2D A010 1EAC8A 1E9E5A 02020107010A1E0B9E0C5A0E0A0000
2013.11.23 20:46:02 5: HMLAN1 dispatch A182DA0101EAC8A1E9E5A02020107010A1E0B9E0C5A0E0A0000:AESKey-FF:-56:HMLAN1
2013.11.23 20:46:02 5: HMLAN_Parse: HMLAN1 R:R867F59C6 stat:0041 t:003B2D41 d:01 r:FFC8     m:2D A010 1EAC8A 1E9E5A 02020107010A1E0B9E0C5A0E0A0000
2013.11.23 20:46:02 5: HMLAN1 dispatch A182DA0101EAC8A1E9E5A02020107010A1E0B9E0C5A0E0A0000::-56:HMLAN1
2013.11.23 20:46:02 4: CUL_HM Display_Taster dup: dont process
2013.11.23 20:46:02 5: HMLAN_Send:  HMLAN1 S:+1EAC8A,01,01,FE1F
2013.11.23 20:46:02 5: HMLAN_Send:  HMLAN1 S:S867F5C23 stat:  00 t:00000000 d:01 r:867F5C23 m:2E A001 1E9E5A 1EAC8A 01040000000001
2013.11.23 20:46:02 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:003B3045 d:FF r:FFC2     m:2E A010 1EAC8A 1E9E5A 02080036573761386E39643A6C3B613C6D
2013.11.23 20:46:02 5: HMLAN1 dispatch A1A2EA0101EAC8A1E9E5A02080036573761386E39643A6C3B613C6D:AESKey-FF:-62:HMLAN1
2013.11.23 20:46:03 5: HMLAN_Parse: HMLAN1 R:R867F5C23 stat:0041 t:003B304A d:01 r:FFC2     m:2E A010 1EAC8A 1E9E5A 02080036573761386E39643A6C3B613C6D
2013.11.23 20:46:03 5: HMLAN1 dispatch A1A2EA0101EAC8A1E9E5A02080036573761386E39643A6C3B613C6D::-62:HMLAN1
2013.11.23 20:46:03 4: CUL_HM Display_Taster dup: dont process
2013.11.23 20:46:03 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:003B3240 d:FF r:FFC2     m:2E A010 1EAC8A 1E9E5A 023D703E653F0040004100464147754873
2013.11.23 20:46:03 5: HMLAN1 dispatch A1A2EA0101EAC8A1E9E5A023D703E653F0040004100464147754873:AESKey-FF:-62:HMLAN1
2013.11.23 20:46:03 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:003B3240 d:01 r:FFC2     m:2E A010 1EAC8A 1E9E5A 023D703E653F0040004100464147754873
2013.11.23 20:46:03 5: HMLAN1 dispatch A1A2EA0101EAC8A1E9E5A023D703E653F0040004100464147754873::-62:HMLAN1
2013.11.23 20:46:03 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:003B3436 d:FF r:FFC1     m:2E A010 1EAC8A 1E9E5A 0249004A654B324C004D704E654F005072
2013.11.23 20:46:03 5: HMLAN1 dispatch A1A2EA0101EAC8A1E9E5A0249004A654B324C004D704E654F005072:AESKey-FF:-63:HMLAN1
2013.11.23 20:46:04 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:003B3436 d:01 r:FFC1     m:2E A010 1EAC8A 1E9E5A 0249004A654B324C004D704E654F005072
2013.11.23 20:46:04 5: HMLAN1 dispatch A1A2EA0101EAC8A1E9E5A0249004A654B324C004D704E654F005072::-63:HMLAN1
2013.11.23 20:46:04 4: CUL_HM Display_Taster dup: dont process
2013.11.23 20:46:04 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:003B3621 d:FF r:FFC7     m:2E A010 1EAC8A 1E9E5A 0251000000
2013.11.23 20:46:04 5: HMLAN1 dispatch A0E2EA0101EAC8A1E9E5A0251000000:AESKey-FF:-57:HMLAN1
2013.11.23 20:46:04 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:003B3621 d:01 r:FFC7     m:2E A010 1EAC8A 1E9E5A 0251000000
2013.11.23 20:46:04 5: HMLAN1 dispatch A0E2EA0101EAC8A1E9E5A0251000000::-57:HMLAN1
2013.11.23 20:46:04 5: Triggering Display_Taster (1 changes)
2013.11.23 20:46:04 5: Notify loop for Display_Taster ResndFail
2013.11.23 20:46:04 4: eventTypes: CUL_HM Display_Taster ResndFail -> ResndFail
2013.11.23 20:46:05 5: Triggering Display_Taster (1 changes)
2013.11.23 20:46:05 5: Notify loop for Display_Taster RESPONSE TIMEOUT:RegisterRead
2013.11.23 20:46:05 4: eventTypes: CUL_HM Display_Taster RESPONSE TIMEOUT:RegisterRead -> RESPONSE TIMEOUT:RegisterRead
martinp876
Hallo sherwood,
es werde keine Register geschrieben, nur gelesen.
Kann es sein, dass der Test so schon im 4dis steht? CUL_HM schreibt nur, was sich geändert hat (sollte besser einen log vorsehen)
Probieren einmal einen andere Text
Gruss Martin
sherwood
#67
Ne, noch ein ganz neuer unberührter Chanel. Ist auch noch nicht gepeert.
Hier nochmal zwei nacheinander unterschiedlich abgesetzte "text" Commands.
2013.11.24 18:38:00 4: HTTP FHEMWEB:192.168.0.107:50475 GET /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22text%22,%22%22)}&XHR=1
2013.11.24 18:38:00 5: Cmd: >{ReadingsVal("CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15","text","")}<
2013.11.24 18:38:00 4: /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22text%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2013.11.24 18:38:07 5: HMLAN_Send:  HMLAN1 I:K
2013.11.24 18:38:07 5: HMLAN_Parse: HMLAN1 V:03C1 sNo:JEQ0707135 d:1E9E5A O:1E9E5A t:00020BCD IDcnt:0005
2013.11.24 18:38:08 4: Connection closed for FHEMWEB:192.168.0.107:50429
2013.11.24 18:38:08 4: HTTP FHEMWEB:192.168.0.107:50475 GET /fhem&detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&dev.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&cmd.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=set&arg.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=text&val.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=neu+123
2013.11.24 18:38:08 5: Cmd: >set CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text neu 123<
2013.11.24 18:38:08 5: Triggering CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 (2 changes)
2013.11.24 18:38:08 5: Notify loop for CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text1: set_neu
2013.11.24 18:38:08 4: eventTypes: CUL_HM CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text1: set_neu -> text1: set_neu
2013.11.24 18:38:08 4: eventTypes: CUL_HM CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text2: set_123 -> text2: set_.*
2013.11.24 18:38:08 2: CUL_HM set CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text neu 123
2013.11.24 18:38:08 4: HTTP FHEMWEB:192.168.0.107:50475 GET /fhem?detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15
2013.11.24 18:38:08 4: /fhem?detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 / RL:3673 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50475 GET /fhem/pgm2/style.css
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50462 GET /fhem/pgm2/fhemweb.js
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50474 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem/pgm2/fhemweb_noArg.js
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50471 GET /fhem/pgm2/svg.js
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50462 GET /fhem/pgm2/fhemweb_textField.js
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50474 GET /fhem/pgm2/fhemweb_time.js
2013.11.24 18:38:09 4: Connection accepted from FHEMWEB:192.168.0.107:50479
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50475 GET /fhem/pgm2/fhemweb_svg.js
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50479 GET /fhem/pgm2/fhemweb_slider.js
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50475 GET /fhem/images/default/icoEverything.png
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50462 GET /fhem/images/default/fhemicon.png
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem?cmd={AttrVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22room%22,%22%22)}&XHR=1
2013.11.24 18:38:09 5: Cmd: >{AttrVal("CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15","room","")}<
2013.11.24 18:38:09 4: /fhem?cmd={AttrVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22room%22,%22%22)}&XHR=1 / RL:27 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50471 GET /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22clear%22,%22%22)}&XHR=1
2013.11.24 18:38:09 5: Cmd: >{ReadingsVal("CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15","clear","")}<
2013.11.24 18:38:09 4: /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22clear%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2013.11.24 18:38:09 4: HTTP FHEMWEB:192.168.0.107:50475 GET /fhem?room=all&XHR=1&inform=1&timestamp=1385314694675
2013.11.24 18:38:21 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0000 t:00024220 d:FF r:FFC6     m:30 8400 1EAC8A 000000 1400604A45513037303537313340940000
2013.11.24 18:38:21 5: HMLAN1 dispatch A1A3084001EAC8A0000001400604A45513037303537313340940000::-58:HMLAN1
2013.11.24 18:38:21 2: CUL_HM set Display_Taster getConfig
2013.11.24 18:38:21 5: HMLAN_Send:  HMLAN1 S:+1EAC8A,01,01,FE1F
2013.11.24 18:38:21 5: HMLAN_Send:  HMLAN1 S:S8B30D2F0 stat:  00 t:00000000 d:01 r:8B30D2F0 m:15 A001 1E9E5A 1EAC8A 0F050000000001
2013.11.24 18:38:21 5: HMLAN_Parse: HMLAN1 R:R8B30D2F0 stat:0001 t:00024336 d:FF r:FFC9     m:15 8002 1EAC8A 1E9E5A 00
2013.11.24 18:38:21 5: HMLAN1 dispatch A0A1580021EAC8A1E9E5A00::-55:HMLAN1
2013.11.24 18:38:21 5: HMLAN_Send:  HMLAN1 S:S8B30D39B stat:  00 t:00000000 d:01 r:8B30D39B m:16 A001 1E9E5A 1EAC8A 0F08366E376538753900463147324833
2013.11.24 18:38:22 5: HMLAN_Parse: HMLAN1 R:R8B30D39B stat:0001 t:000244C0 d:FF r:FFCB     m:16 8002 1EAC8A 1E9E5A 00
2013.11.24 18:38:22 5: HMLAN1 dispatch A0A1680021EAC8A1E9E5A00::-53:HMLAN1
2013.11.24 18:38:22 5: HMLAN_Send:  HMLAN1 S:S8B30D526 stat:  00 t:00000000 d:01 r:8B30D526 m:17 A001 1E9E5A 1EAC8A 0F084900
2013.11.24 18:38:22 5: HMLAN_Parse: HMLAN1 R:R8B30D526 stat:0001 t:0002464B d:FF r:FFCA     m:17 8002 1EAC8A 1E9E5A 00
2013.11.24 18:38:22 5: HMLAN1 dispatch A0A1780021EAC8A1E9E5A00::-54:HMLAN1
2013.11.24 18:38:22 5: HMLAN_Send:  HMLAN1 S:S8B30D6B0 stat:  00 t:00000000 d:01 r:8B30D6B0 m:18 A001 1E9E5A 1EAC8A 0F06
2013.11.24 18:38:23 5: HMLAN_Parse: HMLAN1 R:R8B30D6B0 stat:0001 t:00024800 d:FF r:FFCA     m:18 8002 1EAC8A 1E9E5A 00
2013.11.24 18:38:23 5: HMLAN1 dispatch A0A1880021EAC8A1E9E5A00::-54:HMLAN1
2013.11.24 18:38:23 5: HMLAN_Send:  HMLAN1 S:+1EAC8A,01,01,FE1F
2013.11.24 18:38:23 5: HMLAN_Send:  HMLAN1 S:S8B30D866 stat:  00 t:00000000 d:01 r:8B30D866 m:19 A001 1E9E5A 1EAC8A 00040000000000
2013.11.24 18:38:23 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:00024991 d:FF r:FFCA     m:19 A010 1EAC8A 1E9E5A 02020107010A1E0B9E0C5A0E0A0000
2013.11.24 18:38:23 5: HMLAN1 dispatch A1819A0101EAC8A1E9E5A02020107010A1E0B9E0C5A0E0A0000:AESKey-FF:-54:HMLAN1
2013.11.24 18:38:23 5: HMLAN_Parse: HMLAN1 R:R8B30D866 stat:0041 t:00024996 d:01 r:FFCA     m:19 A010 1EAC8A 1E9E5A 02020107010A1E0B9E0C5A0E0A0000
2013.11.24 18:38:23 5: HMLAN1 dispatch A1819A0101EAC8A1E9E5A02020107010A1E0B9E0C5A0E0A0000::-54:HMLAN1
2013.11.24 18:38:23 4: CUL_HM Display_Taster dup: dont process
2013.11.24 18:38:23 5: HMLAN_Send:  HMLAN1 S:S8B30DBA0 stat:  00 t:00000000 d:01 r:8B30DBA0 m:1A A001 1E9E5A 1EAC8A 01040000000001
2013.11.24 18:38:24 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:00024C9A d:FF r:FFCA     m:1A A010 1EAC8A 1E9E5A 02080036573761386E39643A6C3B613C6D
2013.11.24 18:38:24 5: HMLAN1 dispatch A1A1AA0101EAC8A1E9E5A02080036573761386E39643A6C3B613C6D:AESKey-FF:-54:HMLAN1
2013.11.24 18:38:24 5: HMLAN_Parse: HMLAN1 R:R8B30DBA0 stat:0041 t:00024C9F d:01 r:FFCA     m:1A A010 1EAC8A 1E9E5A 02080036573761386E39643A6C3B613C6D
2013.11.24 18:38:24 5: HMLAN1 dispatch A1A1AA0101EAC8A1E9E5A02080036573761386E39643A6C3B613C6D::-54:HMLAN1
2013.11.24 18:38:24 4: CUL_HM Display_Taster dup: dont process
2013.11.24 18:38:24 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:00024E94 d:FF r:FFCA     m:1A A010 1EAC8A 1E9E5A 023D703E653F0040004100464147754873
2013.11.24 18:38:24 5: HMLAN1 dispatch A1A1AA0101EAC8A1E9E5A023D703E653F0040004100464147754873:AESKey-FF:-54:HMLAN1
2013.11.24 18:38:25 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:00024E94 d:01 r:FFCA     m:1A A010 1EAC8A 1E9E5A 023D703E653F0040004100464147754873
2013.11.24 18:38:25 5: HMLAN1 dispatch A1A1AA0101EAC8A1E9E5A023D703E653F0040004100464147754873::-54:HMLAN1
2013.11.24 18:38:25 4: CUL_HM Display_Taster dup: dont process
2013.11.24 18:38:25 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:0002508A d:FF r:FFCA     m:1A A010 1EAC8A 1E9E5A 0249004A654B324C004D704E654F005072
2013.11.24 18:38:25 5: HMLAN1 dispatch A1A1AA0101EAC8A1E9E5A0249004A654B324C004D704E654F005072:AESKey-FF:-54:HMLAN1
2013.11.24 18:38:25 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:0002508A d:01 r:FFCA     m:1A A010 1EAC8A 1E9E5A 0249004A654B324C004D704E654F005072
2013.11.24 18:38:25 5: HMLAN1 dispatch A1A1AA0101EAC8A1E9E5A0249004A654B324C004D704E654F005072::-54:HMLAN1
2013.11.24 18:38:25 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:00025277 d:FF r:FFCA     m:1A A010 1EAC8A 1E9E5A 0251000000
2013.11.24 18:38:25 5: HMLAN1 dispatch A0E1AA0101EAC8A1E9E5A0251000000:AESKey-FF:-54:HMLAN1
2013.11.24 18:38:26 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:00025277 d:01 r:FFCA     m:1A A010 1EAC8A 1E9E5A 0251000000
2013.11.24 18:38:26 5: HMLAN1 dispatch A0E1AA0101EAC8A1E9E5A0251000000::-54:HMLAN1
2013.11.24 18:38:26 4: CUL_HM Display_Taster dup: dont process
2013.11.24 18:38:26 5: Triggering Display_Taster (1 changes)
2013.11.24 18:38:26 5: Notify loop for Display_Taster ResndFail
2013.11.24 18:38:26 4: eventTypes: CUL_HM Display_Taster ResndFail -> ResndFail
2013.11.24 18:38:26 5: Notify loop for Display_Taster RESPONSE TIMEOUT:RegisterRead
2013.11.24 18:38:26 4: eventTypes: CUL_HM Display_Taster RESPONSE TIMEOUT:RegisterRead -> RESPONSE TIMEOUT:RegisterRead
2013.11.24 18:38:32 5: HMLAN_Send:  HMLAN1 I:K
2013.11.24 18:38:32 5: HMLAN_Parse: HMLAN1 V:03C1 sNo:JEQ0707135 d:1E9E5A O:1E9E5A t:00026D78 IDcnt:0005
2013.11.24 18:38:46 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22text%22,%22%22)}&XHR=1
2013.11.24 18:38:46 5: Cmd: >{ReadingsVal("CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15","text","")}<
2013.11.24 18:38:46 4: /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22text%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2013.11.24 18:38:52 2: CUL_HM set wz_Wandlampe statusRequest
2013.11.24 18:38:52 5: HMLAN_Send:  HMLAN1 S:+1C2467,00,01,
2013.11.24 18:38:52 5: HMLAN_Send:  HMLAN1 S:S8B314B31 stat:  00 t:00000000 d:01 r:8B314B31 m:1B A001 1E9E5A 1C2467 010E
2013.11.24 18:38:52 5: HMLAN_Parse: HMLAN1 R:E1C2467   stat:0000 t:0002BB7B d:FF r:FFC4     m:1B A410 1C2467 1E9E5A 06011E003E
2013.11.24 18:38:52 5: HMLAN1 dispatch A0E1BA4101C24671E9E5A06011E003E::-60:HMLAN1
2013.11.24 18:38:52 5: Triggering wz_Wandlampe (9 changes)
2013.11.24 18:38:52 5: Notify loop for wz_Wandlampe level: 15 %
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe level: 15 % -> level: .* %
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe pct: 15 -> pct: .*
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe deviceMsg: 15 % (to HMLAN1) -> deviceMsg: .* % (to HMLAN1)
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe 15 % -> .* %
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe timedOn: off -> timedOn: off
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe dim: stop:15 % -> dim: stop:.* %
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe overload: off -> overload: off
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe overheat: off -> overheat: off
2013.11.24 18:38:52 4: eventTypes: CUL_HM wz_Wandlampe reduced: off -> reduced: off
2013.11.24 18:38:52 5: HMLAN_Parse: HMLAN1 R:R8B314B31 stat:0001 t:0002BB80 d:FF r:FFC4     m:1B A410 1C2467 1E9E5A 06011E003E
2013.11.24 18:38:52 4: CUL_HM wz_Wandlampe dup: dont process
2013.11.24 18:38:56 4: Connection closed for FHEMWEB:192.168.0.107:50475
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem&detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&dev.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&cmd.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=set&arg.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=text&val.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=456+test
2013.11.24 18:38:56 5: Cmd: >set CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text 456 test<
2013.11.24 18:38:56 5: Triggering CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 (2 changes)
2013.11.24 18:38:56 5: Notify loop for CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text1: set_456
2013.11.24 18:38:56 4: eventTypes: CUL_HM CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text1: set_456 -> text1: set_.*
2013.11.24 18:38:56 4: eventTypes: CUL_HM CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text2: set_test -> text2: set_test
2013.11.24 18:38:56 2: CUL_HM set CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text 456 test
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem?detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15
2013.11.24 18:38:56 4: /fhem?detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 / RL:3675 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem/pgm2/style.css
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50462 GET /fhem/pgm2/fhemweb_noArg.js
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50474 GET /fhem/pgm2/fhemweb.js
2013.11.24 18:38:56 4: Connection accepted from FHEMWEB:192.168.0.107:50487
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50471 GET /fhem/pgm2/svg.js
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50479 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50462 GET /fhem/pgm2/fhemweb_textField.js
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50474 GET /fhem/pgm2/fhemweb_time.js
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem/pgm2/fhemweb_svg.js
2013.11.24 18:38:56 4: HTTP FHEMWEB:192.168.0.107:50487 GET /fhem/pgm2/fhemweb_slider.js
2013.11.24 18:38:57 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem/images/default/icoEverything.png
2013.11.24 18:38:57 4: HTTP FHEMWEB:192.168.0.107:50471 GET /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22clear%22,%22%22)}&XHR=1
2013.11.24 18:38:57 5: Cmd: >{ReadingsVal("CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15","clear","")}<
2013.11.24 18:38:57 4: /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22clear%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2013.11.24 18:38:57 4: HTTP FHEMWEB:192.168.0.107:50479 GET /fhem?cmd={AttrVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22room%22,%22%22)}&XHR=1
2013.11.24 18:38:57 5: Cmd: >{AttrVal("CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15","room","")}<
2013.11.24 18:38:57 4: /fhem?cmd={AttrVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22room%22,%22%22)}&XHR=1 / RL:27 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2013.11.24 18:38:57 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem/images/default/fhemicon.png
2013.11.24 18:38:57 4: HTTP FHEMWEB:192.168.0.107:50477 GET /fhem?room=all&XHR=1&inform=1&timestamp=1385314742674
2013.11.24 18:38:57 5: HMLAN_Send:  HMLAN1 I:K
2013.11.24 18:38:58 5: HMLAN_Send:  HMLAN1 I:K
2013.11.24 18:38:59 5: HMLAN_Parse: HMLAN1 V:03C1 sNo:JEQ0707135 d:1E9E5A O:1E9E5A t:0002D50E IDcnt:0005
2013.11.24 18:38:59 5: HMLAN_Parse: HMLAN1 V:03C1 sNo:JEQ0707135 d:1E9E5A O:1E9E5A t:0002D511 IDcnt:0005
2013.11.24 18:39:05 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0000 t:0002ED30 d:FF r:FFCB     m:31 8400 1EAC8A 000000 1400604A45513037303537313340940000
2013.11.24 18:39:05 5: HMLAN1 dispatch A1A3184001EAC8A0000001400604A45513037303537313340940000::-53:HMLAN1
2013.11.24 18:39:05 2: CUL_HM set Display_Taster getConfig
2013.11.24 18:39:05 5: HMLAN_Send:  HMLAN1 S:+1EAC8A,01,01,FE1F
2013.11.24 18:39:05 5: HMLAN_Send:  HMLAN1 S:S8B317DF9 stat:  00 t:00000000 d:01 r:8B317DF9 m:1C A001 1E9E5A 1EAC8A 0F050000000001
2013.11.24 18:39:05 5: HMLAN_Parse: HMLAN1 R:R8B317DF9 stat:0001 t:0002EE47 d:FF r:FFC8     m:1C 8002 1EAC8A 1E9E5A 00
2013.11.24 18:39:05 5: HMLAN1 dispatch A0A1C80021EAC8A1E9E5A00::-56:HMLAN1
2013.11.24 18:39:05 5: HMLAN_Send:  HMLAN1 S:S8B317EA6 stat:  00 t:00000000 d:01 r:8B317EA6 m:1D A001 1E9E5A 1EAC8A 0F083634373538363900467447654873
2013.11.24 18:39:06 5: HMLAN_Parse: HMLAN1 R:R8B317EA6 stat:0001 t:0002EFD2 d:FF r:FFC9     m:1D 8002 1EAC8A 1E9E5A 00
2013.11.24 18:39:06 5: HMLAN1 dispatch A0A1D80021EAC8A1E9E5A00::-55:HMLAN1
2013.11.24 18:39:06 5: HMLAN_Send:  HMLAN1 S:S8B318031 stat:  00 t:00000000 d:01 r:8B318031 m:1E A001 1E9E5A 1EAC8A 0F0849744A00
2013.11.24 18:39:06 5: HMLAN_Parse: HMLAN1 R:R8B318031 stat:0001 t:0002F15C d:FF r:FFC8     m:1E 8002 1EAC8A 1E9E5A 00
2013.11.24 18:39:06 5: HMLAN1 dispatch A0A1E80021EAC8A1E9E5A00::-56:HMLAN1
2013.11.24 18:39:06 5: HMLAN_Send:  HMLAN1 S:S8B3181BA stat:  00 t:00000000 d:01 r:8B3181BA m:1F A001 1E9E5A 1EAC8A 0F06
2013.11.24 18:39:06 5: HMLAN_Parse: HMLAN1 R:R8B3181BA stat:0001 t:0002F310 d:FF r:FFC8     m:1F 8002 1EAC8A 1E9E5A 00
2013.11.24 18:39:06 5: HMLAN1 dispatch A0A1F80021EAC8A1E9E5A00::-56:HMLAN1
2013.11.24 18:39:06 5: HMLAN_Send:  HMLAN1 S:+1EAC8A,01,01,FE1F
2013.11.24 18:39:06 5: HMLAN_Send:  HMLAN1 S:S8B31836E stat:  00 t:00000000 d:01 r:8B31836E m:20 A001 1E9E5A 1EAC8A 00040000000000
2013.11.24 18:39:07 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:0002F4A1 d:FF r:FFC7     m:20 A010 1EAC8A 1E9E5A 02020107010A1E0B9E0C5A0E0A0000
2013.11.24 18:39:07 5: HMLAN1 dispatch A1820A0101EAC8A1E9E5A02020107010A1E0B9E0C5A0E0A0000:AESKey-FF:-57:HMLAN1
2013.11.24 18:39:07 5: HMLAN_Parse: HMLAN1 R:R8B31836E stat:0041 t:0002F4A6 d:01 r:FFC7     m:20 A010 1EAC8A 1E9E5A 02020107010A1E0B9E0C5A0E0A0000
2013.11.24 18:39:07 5: HMLAN1 dispatch A1820A0101EAC8A1E9E5A02020107010A1E0B9E0C5A0E0A0000::-57:HMLAN1
2013.11.24 18:39:07 4: CUL_HM Display_Taster dup: dont process
2013.11.24 18:39:07 5: HMLAN_Send:  HMLAN1 S:+1EAC8A,01,01,FE1F
2013.11.24 18:39:07 5: HMLAN_Send:  HMLAN1 S:S8B3186AE stat:  00 t:00000000 d:01 r:8B3186AE m:21 A001 1E9E5A 1EAC8A 01040000000001
2013.11.24 18:39:08 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:0002F7AA d:FF r:FFC8     m:21 A010 1EAC8A 1E9E5A 02080036573761386E39643A6C3B613C6D
2013.11.24 18:39:08 5: HMLAN1 dispatch A1A21A0101EAC8A1E9E5A02080036573761386E39643A6C3B613C6D:AESKey-FF:-56:HMLAN1
2013.11.24 18:39:08 5: HMLAN_Parse: HMLAN1 R:R8B3186AE stat:0041 t:0002F7AF d:01 r:FFC8     m:21 A010 1EAC8A 1E9E5A 02080036573761386E39643A6C3B613C6D
2013.11.24 18:39:08 5: HMLAN1 dispatch A1A21A0101EAC8A1E9E5A02080036573761386E39643A6C3B613C6D::-56:HMLAN1
2013.11.24 18:39:08 4: CUL_HM Display_Taster dup: dont process
2013.11.24 18:39:08 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:0002F9A6 d:FF r:FFC8     m:21 A010 1EAC8A 1E9E5A 023D703E653F0040004100464147754873
2013.11.24 18:39:08 5: HMLAN1 dispatch A1A21A0101EAC8A1E9E5A023D703E653F0040004100464147754873:AESKey-FF:-56:HMLAN1
2013.11.24 18:39:08 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:0002F9A6 d:01 r:FFC8     m:21 A010 1EAC8A 1E9E5A 023D703E653F0040004100464147754873
2013.11.24 18:39:08 5: HMLAN1 dispatch A1A21A0101EAC8A1E9E5A023D703E653F0040004100464147754873::-56:HMLAN1
2013.11.24 18:39:09 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:0002FB9C d:FF r:FFC8     m:21 A010 1EAC8A 1E9E5A 0249004A654B324C004D704E654F005072
2013.11.24 18:39:09 5: HMLAN1 dispatch A1A21A0101EAC8A1E9E5A0249004A654B324C004D704E654F005072:AESKey-FF:-56:HMLAN1
2013.11.24 18:39:09 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:0002FB9C d:01 r:FFC8     m:21 A010 1EAC8A 1E9E5A 0249004A654B324C004D704E654F005072
2013.11.24 18:39:09 5: HMLAN1 dispatch A1A21A0101EAC8A1E9E5A0249004A654B324C004D704E654F005072::-56:HMLAN1
2013.11.24 18:39:09 4: CUL_HM Display_Taster dup: dont process
2013.11.24 18:39:09 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:0002FD87 d:FF r:FFC9     m:21 A010 1EAC8A 1E9E5A 0251000000
2013.11.24 18:39:09 5: HMLAN1 dispatch A0E21A0101EAC8A1E9E5A0251000000:AESKey-FF:-55:HMLAN1
2013.11.24 18:39:09 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:0002FD87 d:01 r:FFC9     m:21 A010 1EAC8A 1E9E5A 0251000000
2013.11.24 18:39:09 5: HMLAN1 dispatch A0E21A0101EAC8A1E9E5A0251000000::-55:HMLAN1
2013.11.24 18:39:10 5: Triggering Display_Taster (1 changes)
2013.11.24 18:39:10 5: Notify loop for Display_Taster ResndFail
2013.11.24 18:39:10 4: eventTypes: CUL_HM Display_Taster ResndFail -> ResndFail
2013.11.24 18:39:10 5: Notify loop for Display_Taster RESPONSE TIMEOUT:RegisterRead
2013.11.24 18:39:10 4: eventTypes: CUL_HM Display_Taster RESPONSE TIMEOUT:RegisterRead -> RESPONSE TIMEOUT:RegisterRead
Wenn ich übrigens noch ein peering anlege, werden auch die Texte übertragen und angelegt. Also Text ohne einen verknüpften peer ist nicht möglich. Nehme ich den peer wieder raus, ist auch der Text auf dem 4Dis wieder weg.
Kann ich dir noch andere Logs schicken um evtl. den Fehler weiter einzugrenzen?
martinp876
Hallo sherwood,
der text ist unabhängig vom peer - setzen und löschen von peers darf also keinen Einfluss haben.
In deinen Logs sehe ich, dass das setzen des Textes problemlos ist.
Probleme gibt es beim Lesen der Konfiguration. Der 4dis hat wohl einen bug in der message-Nummerierung - da muss ich (leider) eine Ausnahme einbauen.
=> ich gehe davon aus, dass (wegen des Bugs) getConfig beim 4Dis bei keinem Channel funktioniert - korrekt?
=> da der 4Dis falsch zählt wird es Probleme gebe, sollte man mehrere IO Devices nutzen und einen 4Dis in betrieb zu haben.
Dass die Texte beim löschen eines peers verschwinden ist nicht logisch. Du könntest es einmal aufzeichnen - aber wenn es der 4Dis intern macht kann man nichts ändern.
Jetzt kommt erst einmal der workaround
Probieren den workaround für 4dis register lesen in Version 4288
Gruss Martin
sherwood
Hallo Martin,
ich glaub der 4Dis macht das intern. Ist nur Sau blöd, da ich ja so keinen chanel mit z.B. einem notify verbinden kann ohne vorher irgend ein device damit zu peeren. Egal, muss ich wohl mit leben oder mir etwas anders ausdenken.
Hier der Log mit der neuen 4288.
2013.11.26 18:43:15 4: Connection closed for FHEMWEB:192.168.0.107:55286
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55288 GET /fhem&detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&dev.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15&cmd.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=set&arg.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=text&val.setCUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15=4288+TEST
2013.11.26 18:43:15 5: Cmd: >set CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text 4288 TEST<
2013.11.26 18:43:15 5: Triggering CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 (2 changes)
2013.11.26 18:43:15 5: Notify loop for CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text1: set_4288
2013.11.26 18:43:15 4: eventTypes: CUL_HM CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text1: set_4288 -> text1: set_.*
2013.11.26 18:43:15 4: eventTypes: CUL_HM CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text2: set_TEST -> text2: set_TEST
2013.11.26 18:43:15 2: CUL_HM set CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text 4288 TEST
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55288 GET /fhem?detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15
2013.11.26 18:43:15 4: /fhem?detail=CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 / RL:3813 / text/html; charset=UTF-8 / Content-Encoding: gzip
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55288 GET /fhem/pgm2/style.css
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55285 GET /fhem/pgm2/fhemweb_noArg.js
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55289 GET /fhem/pgm2/fhemweb.js
2013.11.26 18:43:15 4: Connection accepted from FHEMWEB:192.168.0.107:55292
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55284 GET /fhem/pgm2/fhemweb_colorpicker.js
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55287 GET /fhem/pgm2/svg.js
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55285 GET /fhem/pgm2/fhemweb_textField.js
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55292 GET /fhem/pgm2/fhemweb_slider.js
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55289 GET /fhem/pgm2/fhemweb_time.js
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55288 GET /fhem/pgm2/fhemweb_svg.js
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55288 GET /fhem/images/default/icoEverything.png
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55285 GET /fhem/images/default/fhemicon.png
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55284 GET /fhem?cmd={AttrVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22room%22,%22%22)}&XHR=1
2013.11.26 18:43:15 5: Cmd: >{AttrVal("CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15","room","")}<
2013.11.26 18:43:15 4: /fhem?cmd={AttrVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22room%22,%22%22)}&XHR=1 / RL:27 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55287 GET /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22clear%22,%22%22)}&XHR=1
2013.11.26 18:43:15 5: Cmd: >{ReadingsVal("CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15","clear","")}<
2013.11.26 18:43:15 4: /fhem?cmd={ReadingsVal(%22CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15%22,%22clear%22,%22%22)}&XHR=1 / RL:21 / text/plain; charset=UTF-8 / Content-Encoding: gzip
2013.11.26 18:43:15 4: HTTP FHEMWEB:192.168.0.107:55288 GET /fhem?room=all&XHR=1&inform=1&timestamp=1385487796100
2013.11.26 18:43:24 1: 192.168.0.111:1000 reappeared (HMLAN1)
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 I:A1E9E5A
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 I:C
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 I:Y01,00,
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 I:Y02,00,
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 I:Y03,00,
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 I:T1A278C2C,04,00,00000000
2013.11.26 18:43:24 1: HMLAN_Parse: HMLAN1 new condition init
2013.11.26 18:43:24 5: Triggering HMLAN1 (3 changes)
2013.11.26 18:43:24 5: Notify loop for HMLAN1 cond: init
2013.11.26 18:43:24 4: eventTypes: HMLAN HMLAN1 cond: init -> cond: init
2013.11.26 18:43:24 4: eventTypes: HMLAN HMLAN1 Xmit-Events: init:1  -> Xmit-Events: init:.*
2013.11.26 18:43:24 4: eventTypes: HMLAN HMLAN1 prot_init: last -> prot_init: last
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 S:S958229BB stat:  00 t:00000000 d:01 r:958229BB m:99 8112 1E9E5A 000001
2013.11.26 18:43:24 5: Triggering HMLAN1 (1 changes)
2013.11.26 18:43:24 5: Notify loop for HMLAN1 CONNECTED
2013.11.26 18:43:24 4: eventTypes: HMLAN HMLAN1 CONNECTED -> CONNECTED
2013.11.26 18:43:24 5: HMLAN_Parse: HMLAN1 V:03C1 sNo:JEQ0707135 d:1E9E5A O:1E9E5A t:000BE552 IDcnt:0000
2013.11.26 18:43:24 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0000 t:000BD398 d:FF r:FFCB     m:62 8400 1EAC8A 000000 1400604A45513037303537313340940000
2013.11.26 18:43:24 5: HMLAN1 dispatch A1A6284001EAC8A0000001400604A45513037303537313340940000::-53:HMLAN1
2013.11.26 18:43:24 2: CUL_HM set Display_Taster getConfig
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 I:+1EAC8A,00,00,
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 S:S95822A69 stat:  00 t:00000000 d:01 r:95822A69 m:0A A001 1E9E5A 1EAC8A 0F050000000001
2013.11.26 18:43:24 5: HMLAN_Parse: HMLAN1 R:R958229BB stat:0002 t:00000000 d:FF r:7FFF     m:99 8112 1E9E5A 000001
2013.11.26 18:43:24 1: HMLAN_Parse: HMLAN1 new condition ok
2013.11.26 18:43:24 5: Notify loop for HMLAN1 cond: ok
2013.11.26 18:43:24 4: eventTypes: HMLAN HMLAN1 cond: ok -> cond: ok
2013.11.26 18:43:24 4: eventTypes: HMLAN HMLAN1 Xmit-Events: ok:1  -> Xmit-Events: ok:.*
2013.11.26 18:43:24 4: eventTypes: HMLAN HMLAN1 prot_ok: last -> prot_ok: last
2013.11.26 18:43:24 5: HMLAN_Parse: HMLAN1 R:R95822A69 stat:0001 t:000BE70A d:FF r:FFC4     m:0A 8002 1EAC8A 1E9E5A 00
2013.11.26 18:43:24 5: HMLAN1 dispatch A0A0A80021EAC8A1E9E5A00::-60:HMLAN1
2013.11.26 18:43:24 5: HMLAN_Send:  HMLAN1 S:S95822B34 stat:  00 t:00000000 d:01 r:95822B34 m:0B A001 1E9E5A 1EAC8A 0F0836343732383839383A0046544745
2013.11.26 18:43:25 5: HMLAN_Parse: HMLAN1 R:R95822B34 stat:0001 t:000BE894 d:FF r:FFC4     m:0B 8002 1EAC8A 1E9E5A 00
2013.11.26 18:43:25 5: HMLAN1 dispatch A0A0B80021EAC8A1E9E5A00::-60:HMLAN1
2013.11.26 18:43:25 5: HMLAN_Send:  HMLAN1 S:S95822CBF stat:  00 t:00000000 d:01 r:95822CBF m:0C A001 1E9E5A 1EAC8A 0F08485349544A00
2013.11.26 18:43:25 5: HMLAN_Parse: HMLAN1 R:R95822CBF stat:0001 t:000BEA1E d:FF r:FFC5     m:0C 8002 1EAC8A 1E9E5A 00
2013.11.26 18:43:25 5: HMLAN1 dispatch A0A0C80021EAC8A1E9E5A00::-59:HMLAN1
2013.11.26 18:43:25 5: HMLAN_Send:  HMLAN1 S:S95822E48 stat:  00 t:00000000 d:01 r:95822E48 m:0D A001 1E9E5A 1EAC8A 0F06
2013.11.26 18:43:26 5: HMLAN_Parse: HMLAN1 R:R95822E48 stat:0001 t:000BEBD2 d:FF r:FFC5     m:0D 8002 1EAC8A 1E9E5A 00
2013.11.26 18:43:26 5: HMLAN1 dispatch A0A0D80021EAC8A1E9E5A00::-59:HMLAN1
2013.11.26 18:43:26 5: HMLAN_Send:  HMLAN1 S:+1EAC8A,01,01,FE1F
2013.11.26 18:43:26 5: HMLAN_Send:  HMLAN1 S:S95822FFC stat:  00 t:00000000 d:01 r:95822FFC m:0E A001 1E9E5A 1EAC8A 00040000000000
2013.11.26 18:43:26 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:000BED63 d:FF r:FFC5     m:0E A010 1EAC8A 1E9E5A 02020107010A1E0B9E0C5A0E0A0000
2013.11.26 18:43:26 5: HMLAN1 dispatch A180EA0101EAC8A1E9E5A02020107010A1E0B9E0C5A0E0A0000:AESKey-FF:-59:HMLAN1
2013.11.26 18:43:26 5: HMLAN_Parse: HMLAN1 R:R95822FFC stat:0041 t:000BED68 d:01 r:FFC5     m:0E A010 1EAC8A 1E9E5A 02020107010A1E0B9E0C5A0E0A0000
2013.11.26 18:43:26 5: HMLAN1 dispatch A180EA0101EAC8A1E9E5A02020107010A1E0B9E0C5A0E0A0000::-59:HMLAN1
2013.11.26 18:43:26 4: CUL_HM Display_Taster dup: dont process
2013.11.26 18:43:26 5: HMLAN_Send:  HMLAN1 S:S9582333A stat:  00 t:00000000 d:01 r:9582333A m:0F A001 1E9E5A 1EAC8A 01040000000001
2013.11.26 18:43:27 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:000BF06B d:FF r:FFC5     m:0F A010 1EAC8A 1E9E5A 02080036573761386E39643A6C3B613C6D
2013.11.26 18:43:27 5: HMLAN1 dispatch A1A0FA0101EAC8A1E9E5A02080036573761386E39643A6C3B613C6D:AESKey-FF:-59:HMLAN1
2013.11.26 18:43:27 5: HMLAN_Parse: HMLAN1 R:R9582333A stat:0041 t:000BF070 d:01 r:FFC5     m:0F A010 1EAC8A 1E9E5A 02080036573761386E39643A6C3B613C6D
2013.11.26 18:43:27 5: HMLAN1 dispatch A1A0FA0101EAC8A1E9E5A02080036573761386E39643A6C3B613C6D::-59:HMLAN1
2013.11.26 18:43:27 4: CUL_HM Display_Taster dup: dont process
2013.11.26 18:43:27 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:000BF267 d:FF r:FFC4     m:0F A010 1EAC8A 1E9E5A 023D703E653F0040004100464147754873
2013.11.26 18:43:27 5: HMLAN1 dispatch A1A0FA0101EAC8A1E9E5A023D703E653F0040004100464147754873:AESKey-FF:-60:HMLAN1
2013.11.26 18:43:28 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:000BF267 d:01 r:FFC4     m:0F A010 1EAC8A 1E9E5A 023D703E653F0040004100464147754873
2013.11.26 18:43:28 5: HMLAN1 dispatch A1A0FA0101EAC8A1E9E5A023D703E653F0040004100464147754873::-60:HMLAN1
2013.11.26 18:43:28 4: CUL_HM Display_Taster dup: dont process
2013.11.26 18:43:28 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:000BF45D d:FF r:FFC5     m:0F A010 1EAC8A 1E9E5A 0249004A654B324C004D704E654F005072
2013.11.26 18:43:28 5: HMLAN1 dispatch A1A0FA0101EAC8A1E9E5A0249004A654B324C004D704E654F005072:AESKey-FF:-59:HMLAN1
2013.11.26 18:43:28 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:000BF45D d:01 r:FFC5     m:0F A010 1EAC8A 1E9E5A 0249004A654B324C004D704E654F005072
2013.11.26 18:43:28 5: HMLAN1 dispatch A1A0FA0101EAC8A1E9E5A0249004A654B324C004D704E654F005072::-59:HMLAN1
2013.11.26 18:43:28 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0100 t:000BF64A d:FF r:FFC4     m:0F A010 1EAC8A 1E9E5A 0251000000
2013.11.26 18:43:28 5: HMLAN1 dispatch A0E0FA0101EAC8A1E9E5A0251000000:AESKey-FF:-60:HMLAN1
2013.11.26 18:43:29 5: HMLAN_Parse: HMLAN1 R:E1EAC8A   stat:0040 t:000BF64A d:01 r:FFC4     m:0F A010 1EAC8A 1E9E5A 0251000000
2013.11.26 18:43:29 5: HMLAN1 dispatch A0E0FA0101EAC8A1E9E5A0251000000::-60:HMLAN1
2013.11.26 18:43:29 4: CUL_HM Display_Taster dup: dont process
2013.11.26 18:43:29 5: Triggering Display_Taster (1 changes)
2013.11.26 18:43:29 5: Notify loop for Display_Taster ResndFail
2013.11.26 18:43:29 4: eventTypes: CUL_HM Display_Taster ResndFail -> ResndFail
2013.11.26 18:43:29 5: Notify loop for Display_Taster RESPONSE TIMEOUT:RegisterRead
2013.11.26 18:43:29 4: eventTypes: CUL_HM Display_Taster RESPONSE TIMEOUT:RegisterRead -> RESPONSE TIMEOUT:RegisterRead
Und der inform
2013-11-26 18:43:14 CUL_HM CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text1: set_4288
2013-11-26 18:43:14 CUL_HM CUL_HM_HM_PB_4DIS_WM_1EAC8A_Btn_15 text2: set_TEST
2013-11-26 18:43:24 HMLAN HMLAN1 cond: init
2013-11-26 18:43:24 HMLAN HMLAN1 Xmit-Events: init:1
2013-11-26 18:43:24 HMLAN HMLAN1 prot_init: last
2013-11-26 18:43:24 HMLAN HMLAN1 CONNECTED
2013-11-26 18:43:24 HMLAN HMLAN1 cond: ok
2013-11-26 18:43:24 HMLAN HMLAN1 Xmit-Events: ok:1
2013-11-26 18:43:24 HMLAN HMLAN1 prot_ok: last
2013-11-26 18:43:28 CUL_HM Display_Taster ResndFail
2013-11-26 18:43:28 CUL_HM Display_Taster RESPONSE TIMEOUT:RegisterRead
Der "RESPONSE TIMEOUT:RegisterRead" scheint aber noch da zu sein. Ist doch der Fehler den du meinst, oder?
sherwood
martinp876
Hi sherwood,
das Problem mit RegisterReadFail ist in CUL_HM - werde ich suchen.
Kannst du mir sagen, was in RegL_01 steht, nach dieser Aktion?
Gruss Martin
nicola
gibts hierzu einen neuen Stand?
Habe meinen OLED Taster komplett zurück gesetzt, nachdem ich ich den Fehler Registerread bekommen hatte und kann den Taster nun nicht mehr neu programmieren.
Hätte ich besser zuvor mal hier rein gesehen. :-/
Nicola
Cubieboard V2, Cubiez Debian Wheezy
FHEM 5.5
2 x HMLAN
martinp876
Hi Nicola,
nein, habe noch keinen neuen Stand.
Habe auch noch nicht das  RegL_01 erhalten.
Wenn das register-lesen nicht funktioniert - dann sollte doch das Setzen noch funktionieren. Was ist dein Problem?
Welches Model hast du? ein HM-PB-4DIS-WM?
Gruss Martin
pwilms
#73
ich verzweifle. Ich habe das Display wie in einem Beispiel hier gepeert damit ich einfach nur verstehe wie es funktioniert.
Ich hatte zum Testen den 1 Chan mit meinem Rollo geleert das hat auch geklappt. Wenn ich den Schalter resette wie bekomme ich das Peering weg? Ich habe das Device resettet und das peering ist wieder da? Muss ich irgendwas noch am Rolladenaktor machen? Der ist Verbaut und ich kann den nicht in den Lernmodus versetzen...
Noch eine Frage wenn ich den Button als "dual" Peere habe 1-10 Devices oben und unten jeweils belegt. Alternativ kann ich die Auch als Single belegen so kann ich oben und unten jeweils einen virtuellen Aktor toggeln?
Mir ist aufgefallen das das DIS4 bei mir jedenfalls am Anfang nur Probleme gemacht hat und ich gerade wenn es um die Konfiguration ging einfach zu weit weg und die Verbingung zu schlecht war.
Vielleicht kann mir jemand helfen. Sollte ich es ans laufen bekommen schreibe ich auch gerne daraus das How-To für das Wiki :)
Viele Grüße,
Patric
martinp876
Hallo Patric,
ZitatWenn ich den Schalter resette wie bekomme ich das Peering weg?
set <taste> peerChan 0 <rollo> [single|double] unset
ZitatMuss ich irgendwas noch am Rolladenaktor machen?
das peering muss auf beiden Seiten entfernt werden, was peerChan per default macht. Siehe actor|remote|both
ZitatDer ist Verbaut und ich kann den nicht in den Lernmodus versetzen...
ist bei Blind-Aktoren nicht notwendig
Auf der Taster-seite  bedeuted dual das gleichzeitig (mit einem fhem-Kommando) 2 Buttons mit einem Aktor gepeert werden.
Auf der Aktor Seite wird bei dual ein anderes 'programm' initialisiert als bei single (oder 2-mal single). single baut i.a.ein toggle- programm, dual baut ein einschalt und ein ausschaltprogramm.
Die jeweiligen "Programme" sind nachträglich im Aktor komplett änderbar.
Du hast 20 buttons, die jeder lang und kurz können. Das sind genau genommen 40 Optionen, die du nutzen kannst.
bei schlechter Verbindung hilft nur, diese zu verbessern.
auch dir - hast du schon das einsteigerdoc - HM-anhang gesichtet?
Beim 4dis war noch etwas mit dem setzen der Texte offen - funktioniert dies bei dir?
Gruss Martin
