Endlose Bootschleife
Begonnen von VolkerGBenner, 10 Oktober 2022, 17:09:16
VolkerGBenner
Ich bin mir nicht bewußt, dass ich wesentliche Änderungen am System vorgenommen hätte, ausser ein paar überflüssige HMdevices zu löschen, aber seit ein paar Tagen hab ich nur noch die folgenden Zeilen in Endlosschleife (alle 10s) im LogFile:
2022.10.10 16:43:34 2: eventTypes: loaded 1440 lines from ./log/eventTypes.txt
2022.10.10 16:43:35 1: HMCCU [myCCU3] CCU port 48181 is reachable
2022.10.10 16:43:35 1: HMCCU [myCCU3] Initialized version 5.0 220431743
2022.10.10 16:43:35 1: HMCCU [myCCU3] Initializing device
2022.10.10 16:43:36 2: HMCCU [myCCU3] Deleting old CCU configuration data
2022.10.10 16:43:36 2: HMCCU [myCCU3] Updating device table
2022.10.10 16:43:36 1: HMCCU [myCCU3] Read 38 devices with 321 channels from CCU 192.168.2.60
2022.10.10 16:43:36 1: HMCCU [myCCU3] Read 10 programs from CCU 192.168.2.60
2022.10.10 16:43:36 1: HMCCU [myCCU3] Read 8 virtual groups from CCU 192.168.2.60
2022.10.10 16:43:36 1: PERL WARNING: Argument "str*" isn't numeric in numeric gt (>) at ./FHEM/88_HMCCU.pm line 664.
2022.10.10 16:43:37 1: Watchdog Client: systemd watchdog is not available. Module inactive.
2022.10.10 16:43:40 2: HMCCURPCPROC [d_rpc002060VirtualDevices] CCU interface VirtualDevices doesn't support RPC multicalls
2022.10.10 16:43:40 1: HMCCURPCPROC [d_rpc002060VirtualDevices] Initialized version 5.0 220431743 for interface VirtualDevices with I/O device myCCU3
2022.10.10 16:43:40 2: HMCCURPCPROC [d_rpc002060BidCos_RF] CCU interface BidCos-RF supports RPC multicalls
2022.10.10 16:43:40 1: HMCCURPCPROC [d_rpc002060BidCos_RF] Initialized version 5.0 220431743 for interface BidCos-RF with I/O device myCCU3
2022.10.10 16:43:40 2: HMCCURPCPROC [d_rpc002060HmIP_RF] CCU interface HmIP-RF doesn't support RPC multicalls
2022.10.10 16:43:40 1: HMCCURPCPROC [d_rpc002060HmIP_RF] Initialized version 5.0 220431743 for interface HmIP-RF with I/O device myCCU3
2022.10.10 16:43:40 2: ONKYO_AVR PioneerVSX1131: Registering ONKYO_AVR for webhook URI ?/ONKYO_AVR ...
/var/run/fhem/fhem.pid: No such file or directory
Wie fange ich mit der Fehlersuche an. Die Installation läuft mit configDB.
Fhem ist nicht zu erreichen, die piccu läuft fehlerfrei.
Hilfe!
1x  RasPiB3+  mit RPI-RF-MOD und debmatic,1x RasPiB2 mit HM-MOD-RPI-PCB und CUL433,
HM-LC-Sw4-DR, HM-WDS30-OT2-SM, HM-Dis-WM55,div HmIP-eTRV-B, HmIP-WTH-1, HmIP-SWDO-2, HmIP-SWSD-2, HmIP-SWD, LenovoThinkCenter als Hauptserver, 10kWp PV,10kWh/5kW Batterie, Wolf CHA10-400, Kostal Wallbox
Wernieman
Was ist es für eine Platform, auf dem FHEM läuft?
- Bitte um Input für Output
VolkerGBenner
ein Raspi 3 , mit RPI-RF-MOD, bullseye.
Weißt du zufällig, wie deine systemd_watchdog-Instanz heißt?
Dann deaktiviere die mal beim Start: https://forum.fhem.de/index.php/topic,86225.msg1236573.html#msg1236573
Wenn du den Namen nicht kennst, benennst du die Datei im Modulverzeichnis einfach mal um.
VolkerGBenner
#4
Habe die systemd-watchdog.pm mal unbenannt. Keine Auswirkung, ausser dass der entsprechende LogEintrag weg ist.
Ein Rescue-Start mit rescue => "1" in der configDB.config bringt nach dem Neustart das:
2022.10.10 18:02:14 0: configDB starting in rescue mode!
2022.10.10 18:02:14 3: telnetPort: port 7072 opened
2022.10.10 18:02:14 3: web: port 8083 opened
2022.10.10 18:02:15 0: configDB starting in rescue mode!
2022.10.10 18:02:15 3: telnetPort: port 7072 opened
2022.10.10 18:02:16 3: web: port 8083 opened
2022.10.10 18:02:56 0: configDB starting in rescue mode!
2022.10.10 18:02:56 3: telnetPort: port 7072 opened
2022.10.10 18:02:56 3: web: port 8083 opened
2022.10.10 18:02:57 0: configDB starting in rescue mode!
2022.10.10 18:02:58 3: telnetPort: port 7072 opened
2022.10.10 18:02:58 3: web: port 8083 opened
2022.10.10 18:02:59 0: configDB starting in rescue mode!
2022.10.10 18:02:59 3: telnetPort: port 7072 opened
2022.10.10 18:02:59 3: web: port 8083 opened
2022.10.10 18:03:01 0: configDB starting in rescue mode!
2022.10.10 18:03:01 3: telnetPort: port 7072 opened
2022.10.10 18:03:01 3: web: port 8083 opened
2022.10.10 18:03:02 0: configDB starting in rescue mode!
2022.10.10 18:03:02 3: telnetPort: port 7072 opened
2022.10.10 18:03:03 3: web: port 8083 opened
Hast du evtl. den systemd-timeout geändert?
VolkerGBenner
Das hätte ich dann in der fhem.service gemacht?
Die sieht so aus:
# $Id: fhem.service 19235 2019-04-21 13:26:17Z betateilchen $
[Unit]
Description=FHEM Home Automation
Wants=network.target
After=network.target
#Requires=postgresql.service
#After=postgresql.service
#Requires=mysql.service
#After=mysql.service
[Service]
Type=forking
User=fhem
Group=dialout
WorkingDirectory=/opt/fhem
#ExecStart=/usr/bin/perl fhem.pl fhem.cfg
ExecStart=/usr/bin/perl fhem.pl configDB
Restart=always
[Install]
WantedBy=multi-user.target
Ich hoffe ich stell mich gerade nicht zu dumm an :-( Ich bin immer froh wenn alles läuft, hab aber auch nicht die Zeit mich immer sofort um Fhem zu kümmern, wenns mal nicht läuft. Ist bei mir auch nur ganz oben aufgelegt, so dass auch ohne alles wichtige weiterläuft. Muss mich also ständig wieder neu einarbeiten und zwischendurch vergehen dann mal ein paar Wochen.
Hmm, bin auch nicht sicher, ob das aus systemd kommt, komisch ist auf alle Fälle, dass da jeweils als letztes ein Log-Eintrag drin ist, der mAn. nicht von fhem.pl geschrieben wird. Und das mit der pidfile klingt irgendwie nach systemd.
Könnte auch sein, dass du den globalen default geändert hast:
https://codybonney.com/change-default-timeouts-starting-stopping-systemd-units/
Ansonsten ist in https://www.freedesktop.org/software/systemd/man/systemd.service.html zu finden, dass es eigentlich bei Type=forking empfehlenswert wäre, eine pidfile anzugeben. So tief bin ich da aber auch nicht drin, kann auch sein, dass das ein Holzweg ist...
Was passiert denn, wenn Du FHEM direkt von der Linux Konsole aus manuell startest, anstatt über systemd?
VolkerGBenner
Ein manueller Start mit sudo /opt/fhem/fhem.pl configDB
gibt die Fehlermeldung:
2022.10.10 20:03:12 1: Can't locate configDB.pm in @INC (you may need to install the configDB module) (@INC contains: . /etc/perl /usr/local/lib/aarch64-linux-gnu/perl/5.32.1 /usr/local/share/perl/5.32.1 /usr/lib/aarch64-linux-gnu/perl5/5.32 /usr/share/perl5 /usr/lib/aarch64-linux-gnu/perl-base /usr/lib/aarch64-linux-gnu/perl/5.32 /usr/share/perl/5.32 /usr/local/lib/site_perl) at (eval 10) line 1.
BEGIN failed--compilation aborted at (eval 10) line 1.
Die Installation lief aber bis vor ein paar Tagen problemlos. Kann da durch ein update was zerwürfelt worden sein?
  • Du musst vorher in das Verzeichnis /opt/fhem wechseln
  • zum Testen solltest Du als root arbeiten, ob das mit sudo funktioniert, weiß ich nicht genau
VolkerGBenner
Start mit  root@raspberrypi:/opt/fhem# ./fhem.pl configDB geht ohne Fehlermeldung durch.
Das Log sieht dann wieder so aus
2022.10.10 20:23:12 0: configDB starting in rescue mode!
2022.10.10 20:23:12 3: telnetPort: port 7072 opened
2022.10.10 20:23:13 3: web: port 8083 opened
DetlefR
Sieh mal in deiner configDB nach ob da etwas von
attr global pidfilename
drin steht.
Wenn ja. Nimm das mal raus.
VolkerGBenner
 :-[ configDB editieren  :o
Mit dem Thema hatte ich mich mal vor einiger Zeit rein theoretisch beschäftigt, als ich feststellen musste, dass mein Backup zu alt war. Bin zu dem Schluss gekommen, dass das ausser meiner Reichweite liegt. Oder gibt es da auch einfache Wege?
PS: Bin jetzt bis erstmal in Nachtruhe. Vielen Dank für eure Denkarbeit schonmal.
Wernieman
Nur mal auf die schnelle. was steht denn im PID-Verzeichnis:
sudo ls -lha /var/run/fhem/
