[gelöst] JsonMod bringt FHEM zum Absturz
Begonnen von FlatTV, 11 April 2023, 19:37:54
FlatTV
Erstmal vorweg, das Modul ist eigentlich super.
Ich mache bestimmt einen Fehler aber ich habe da ein Problem.
Folgende Quelle
https://api.weatherbit.io/v2.0/forecast/daily?lang=de&city=Bremerhaven&key=meiner
Liefert das Ergebnis
Zitat{"city_name":"Bremerhaven","country_code":"DE","data":[{"app_max_temp":10.4,"app_min_temp":3.4,"clouds":73,"clouds_hi":0,"clouds_low":62,"clouds_mid":60,"datetime":"2023-04-11","dewpt":4.5,"high_temp":8.6,"low_temp":4.7,"max_dhi":null,"max_temp":10.4,"min_temp":6.7,"moon_phase":0.621522,"moon_phase_lunation":0.72,"moonrise_ts":1681172354,"moonset_ts":1681198681,"ozone":392.3,"pop":75,"precip":5.5035644,"pres":1009.5,"rh":79,"slp":1009.6,"snow":0,"snow_depth":0,"sunrise_ts":1681187764,"sunset_ts":1681237269,"temp":8,"ts":1681196460,"uv":1.9,"valid_date":"2023-04-11","vis":20.32,"weather":{"code":500,"icon":"r01d","description":"Leichter Regen"},"wind_cdir":"WSW","wind_cdir_full":"West-Südwestlich","wind_dir":254,"wind_gust_spd":11.8,"wind_spd":5.9},{"app_max_temp":10,"app_min_temp":2.5,"clouds":81,"clouds_hi":18,"clouds_low":51,"clouds_mid":75,"datetime":"2023-04-12","dewpt":4,"high_temp":10,"low_temp":6.5,"max_dhi":null,"max_temp":10,"min_temp":6.1,"moon_phase":0.50275,"moon_phase_lunation":0.76,"moonrise_ts":1681263064,"moonset_ts":1681289577,"ozone":381.2,"pop":80,"precip":7.7000003,"pres":1000.9,"rh":76,"slp":1001,"snow":0,"snow_depth":0,"sunrise_ts":1681274023,"sunset_ts":1681323779,"temp":8,"ts":1681250460,"uv":1.6,"valid_date":"2023-04-12","vis":21.088,"weather":{"code":500,"icon":"r01d","description":"Leichter Regen"},"wind_cdir":"SSO","wind_cdir_full":"Süd-Südost","wind_dir":157,"wind_gust_spd":8.4,"wind_spd":5},{"app_max_temp":10.8,"app_min_temp":2.5,"clouds":69,"clouds_hi":3,"clouds_low":45,"clouds_mid":24,"datetime":"2023-04-13","dewpt":4.2,"high_temp":10.8,"low_temp":4.7,"max_dhi":null,"max_temp":10.8,"min_temp":6.5,"moon_phase":0.381368,"moon_phase_lunation":0.79,"moonrise_ts":1681352657,"moonset_ts":1681381284,"ozone":414.1,"pop":35,"precip":1,"pres":1002.6,"rh":75,"slp":1002.7,"snow":0,"snow_depth":0,"sunrise_ts":1681360283,"sunset_ts":1681410289,"temp":8.3,"ts":1681336860,"uv":5.3,"valid_date":"2023-04-13","vis":22.707,"weather":{"code":803,"icon":"c03d","description":"Aufgelockert Bewölkt"},"wind_cdir":"SSW","wind_cdir_full":"Süd-südwesten","wind_dir":204,"wind_gust_spd":9.4,"wind_spd":5.9},{"app_max_temp":12,"app_min_temp":2.5,"clouds":28,"clouds_hi":3,"clouds_low":6,"clouds_mid":9,"datetime":"2023-04-14","dewpt":2.9,"high_temp":12,"low_temp":6.5,"max_dhi":null,"max_temp":12,"min_temp":4.7,"moon_phase":0.26576,"moon_phase_lunation":0.82,"moonrise_ts":1681441195,"moonset_ts":1681473268,"ozone":403.7,"pop":0,"precip":0,"pres":1009.9,"rh":69,"slp":1010,"snow":0,"snow_depth":0,"sunrise_ts":1681446544,"sunset_ts":1681496798,"temp":8.5,"ts":1681423260,"uv":5.4,"valid_date":"2023-04-14","vis":24.128,"weather":{"code":802,"icon":"c02d","description":"Verstreute Wolken"},"wind_cdir":"OSO","wind_cdir_full":"Osten-Südöstlich","wind_dir":102,"wind_gust_spd":5.6,"wind_spd":3.1},{"app_max_temp":11.1,"app_min_temp":3.8,"clouds":75,"clouds_hi":4,"clouds_low":54,"clouds_mid":14,"datetime":"2023-04-15","dewpt":5.7,"high_temp":11.1,"low_temp":7.6,"max_dhi":null,"max_temp":11.1,"min_temp":6.5,"moon_phase":0.164094,"moon_phase_lunation":0.86,"moonrise_ts":1681529013,"moonset_ts":1681565202,"ozone":393,"pop":25,"precip":0.6,"pres":1013,"rh":81,"slp":1013.2,"snow":0,"snow_depth":0,"sunrise_ts":1681532805,"sunset_ts":1681583308,"temp":8.8,"ts":1681509660,"uv":2,"valid_date":"2023-04-15","vis":22.358,"weather":{"code":804,"icon":"c04d","description":"Bewölkt"},"wind_cdir":"NNO","wind_cdir_full":"Norden-Nordost","wind_dir":25,"wind_gust_spd":7.8,"wind_spd":4.9},{"app_max_temp":12.2,"app_min_temp":7.6,"clouds":69,"clouds_hi":41,"clouds_low":43,"clouds_mid":9,"datetime":"2023-04-16","dewpt":6.2,"high_temp":12.2,"low_temp":6.7,"max_dhi":null,"max_temp":12.2,"min_temp":7.6,"moon_phase":0.0833191,"moon_phase_lunation":0.89,"moonrise_ts":1681616408,"moonset_ts":1681656986,"ozone":366,"pop":0,"precip":0,"pres":1015.7,"rh":79,"slp":1015.9,"snow":0,"snow_depth":0,"sunrise_ts":1681619067,"sunset_ts":1681669818,"temp":9.7,"ts":1681596060,"uv":6,"valid_date":"2023-04-16","vis":24.128,"weather":{"code":803,"icon":"c03d","description":"Aufgelockert Bewölkt"},"wind_cdir":"NNO","wind_cdir_full":"Norden-Nordost","wind_dir":21,"wind_gust_spd":7.1,"wind_spd":4.2},{"app_max_temp":13.4,"app_min_temp":4,"clouds":46,"clouds_hi":14,"clouds_low":37,"clouds_mid":0,"datetime":"2023-04-17","dewpt":5.6,"high_temp":13.4,"low_temp":7.3,"max_dhi":null,"max_temp":13.4,"min_temp":6.7,"moon_phase":0.0284941,"moon_phase_lunation":0.93,"moonrise_ts":1681703571,"moonset_ts":1681748647,"ozone":334.5,"pop":0,"precip":0,"pres":1024.4,"rh":75,"slp":1024.4,"snow":0,"snow_depth":0,"sunrise_ts":1681705330,"sunset_ts":1681756327,"temp":10,"ts":1681682460,"uv":6,"valid_date":"2023-04-17","vis":22.805,"weather":{"code":803,"icon":"c03d","description":"Aufgelockert Bewölkt"},"wind_cdir":"ONO","wind_cdir_full":"Osten-Nordöstlich","wind_dir":59,"wind_gust_spd":6.9,"wind_spd":4.3}],"lat":"53.55021","lon":"8.57673","state_code":"03","timezone":"Europe/Berlin"}
Mit readingList ,,complete();" läuft alles stabil, nur bei der selektiven Ausgabe stürzt FHEM komplett ohne Meldung ab und startet neu.
Schon bei der Aktivierung der ersten beiden Ausgaben passiert das reproduzierbar (2 x auf reread).
#complete();
multi(jsonPath('$.data[*].weather'), concat('hfc', count(), '_iconAPI'), propertyf('icon', '', 'https://www.weatherbit.io/static/img/icons/%s.png'));
multi(jsonPath('$.data[*].weather'), concat('hfc', count(), '_condition'), property('description'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_day_of_week'), property('ts'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_pop'), propertyf('pop', '', '%s %%'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_cloudCover'), propertyf('clouds', '', '%s %%'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_temperature'), propertyf('temp', '', '%.0f°'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_feels_like'), propertyf('app_max_temp', '', '%.0f°'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_pressure'), propertyf('pres', '', '%s hPa'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_humidity'), propertyf('rh', '', '%s %%'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_wind_speed'), propertyf('wind_spd', '', '%.1f'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_wind_gust'), propertyf('wind_gust_spd', '', '%.1f'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_wind_deg'), property('wind_dir'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_precip'), propertyf('precip', '', '%.2f mm'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_tempLow'), propertyf('min_temp', '', '%.0f°'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_tempHigh'), propertyf('max_temp', '', '%.0f°'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_sunrise'), property('sunrise_ts'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_sunset'), property('sunset_ts'));
#multi(jsonPath('$.data[*]'), concat('hfc', count(), '_uv'), property('uv'));
Raspi4 - im wesentlichen mit Phoscon, HomeMatic ( aktuell über debmatic), CUL, BOSE-ST und Alexa (Connector)
herrmannj
Gibt es zum Absturz eine Fehlermeldung im log?
yersinia
Ich würde mal im Systemlog (journalctl) zum Zeitpunkt des FHEM Neustarts mal schauen, was da passiert sein könnte.
Mit JsonMod und größeren/komplexeren Abfragen kann es schon mal zu diesen Problemchen kommen. Allerdings konnte ich dies noch nicht verlässlig reproduzieren (siehe auch hier) - einige komplexe Abfragen funktionieren Problemfrei, andere wiederum nicht (zuletzt mit aponet).
viele Grüße, yersinia
FHEM 6.4 (SVN) on RPi 4B with RasPi OS Trixie (perl 5.40.1) | FTUI
Dein JsonMod funktioniert hier einwandfrei.
defmod test_json JsonMod file://tmp/test.json
attr test_json readingList multi(jsonPath('$.data[*].weather'), concat('hfc', count(), '_iconAPI'), propertyf('icon', '', 'https://www.weatherbit.io/static/img/icons/%s.png'));;\
multi(jsonPath('$.data[*].weather'), concat('hfc', count(), '_condition'), property('description'));;\
setstate test_json 2023-04-12 08:57:32 .computedReadings hfc3_condition,hfc0_iconAPI,hfc5_iconAPI,hfc5_condition,hfc0_condition,hfc3_iconAPI,hfc2_iconAPI,hfc2_condition,hfc6_condition,hfc4_condition,hfc4_iconAPI,hfc6_iconAPI,hfc1_iconAPI,hfc1_condition
setstate test_json 2023-04-12 08:57:32 hfc0_condition Leichter Regen
setstate test_json 2023-04-12 08:57:32 hfc0_iconAPI https://www.weatherbit.io/static/img/icons/r01d.png
setstate test_json 2023-04-12 08:57:32 hfc1_condition Leichter Regen
setstate test_json 2023-04-12 08:57:32 hfc1_iconAPI https://www.weatherbit.io/static/img/icons/r01d.png
setstate test_json 2023-04-12 08:57:32 hfc2_condition Aufgelockert Bewölkt
setstate test_json 2023-04-12 08:57:32 hfc2_iconAPI https://www.weatherbit.io/static/img/icons/c03d.png
setstate test_json 2023-04-12 08:57:32 hfc3_condition Verstreute Wolken
setstate test_json 2023-04-12 08:57:32 hfc3_iconAPI https://www.weatherbit.io/static/img/icons/c02d.png
setstate test_json 2023-04-12 08:57:32 hfc4_condition Bewölkt
setstate test_json 2023-04-12 08:57:32 hfc4_iconAPI https://www.weatherbit.io/static/img/icons/c04d.png
setstate test_json 2023-04-12 08:57:32 hfc5_condition Aufgelockert Bewölkt
setstate test_json 2023-04-12 08:57:32 hfc5_iconAPI https://www.weatherbit.io/static/img/icons/c03d.png
setstate test_json 2023-04-12 08:57:32 hfc6_condition Aufgelockert Bewölkt
setstate test_json 2023-04-12 08:57:32 hfc6_iconAPI https://www.weatherbit.io/static/img/icons/c03d.png
yersinia
Zitat von: betateilchen am 12 April 2023, 08:58:18Dein JsonMod funktioniert hier einwandfrei.
Ergänzend aus Erfahrung kann ich sagen, dass meine JsonMod-Devices auch funktioniert haben. Sogar teilweise mehrere Intervalle fehlerfrei. Aber dann und wann führte es immer wieder zu diesem Fehler mit Absturz & Neustart (imho Erzwungen von systemd) von FHEM. Bewusst provozieren konnte ich dies nie; auffallend war, dass die Zeiten des Intervals des JsonMod Devices mit dem Neustart korrelierten. Löscht/Deaktiviert man das JsonMod Device in FHEM, hat man keine Probleme.
Es war auch immer nur ein JsonMod Device betroffen (es liefen aber auch nie welche parallel).
Möglicherweise müsste man eine FHEM Testinstanz mit eben diesen JsonMod Code betreiben und schauen unter welchen Bedingungen es zu einem Absturz führt. Aber ob verbose=5 und stacktrace dann wirklich helfen würden?
Bisher hat es mir gereicht, das betreffende JsonMod Device zu löschen und nach Alternativen zu suchen. Generell fehlen mir aber die Möglichkeiten das tiefergehend zu debuggen - technisch und fachlich.
FlatTV
#5
Leider trotz verbose = 5 nichts im Log zu sehen.
Aber der Absturz ist da.
Apr 12 20:09:11 raspi3 systemd[1]: fhem.service: Main process exited, code=killed, status=11/SEGV
Apr 12 20:10:41 raspi3 systemd[1]: fhem.service: State 'stop-sigterm' timed out. Killing.
Apr 12 20:10:41 raspi3 systemd[1]: fhem.service: Killing process 14499 (perl) with signal SIGKILL.
Apr 12 20:10:41 raspi3 systemd[1]: fhem.service: Failed with result 'signal'.
Apr 12 20:10:41 raspi3 systemd[1]: fhem.service: Consumed 1min 52.072s CPU time.
Apr 12 20:10:42 raspi3 systemd[1]: fhem.service: Scheduled restart job, restart counter is at 1.
Apr 12 20:10:42 raspi3 systemd[1]: Stopped FHEM Home Automation.
Apr 12 20:10:42 raspi3 systemd[1]: fhem.service: Consumed 1min 52.072s CPU time.
Apr 12 20:10:42 raspi3 systemd[1]: Starting FHEM Home Automation...
Perl = v5.32.1
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 11 (bullseye)
Release:        11
Codename:       bullseye
Latest Revision: 27418
File                 Rev   Last Change
fhem.pl              27410 2023-04-07 19:59:43Z rudolfkoenig
39_alexa.pm          23820 2021-02-24 19:29:15Z justme1968
90_at.pm             25248 2021-11-21 10:29:01Z rudolfkoenig
98_autocreate.pm     23727 2021-02-12 20:31:37Z rudolfkoenig
98_BOSEST.pm         21773 2020-04-25 17:30:30Z dominik
98_cmdalias.pm       16300 2018-03-01 08:48:21Z rudolfkoenig
00_CUL.pm            24815 2021-08-01 16:14:02Z rudolfkoenig
14_CUL_REDIRECT.pm   18358 2019-01-20 20:21:05Z bjoernh
14_CUL_TCM97001.pm   26180 2022-06-29 15:00:03Z Ralf9
14_CUL_TX.pm         17102 2018-08-08 05:34:42Z rudolfkoenig
14_CUL_WS.pm         26674 2022-11-08 17:23:41Z rudolfkoenig
98_dewpoint.pm       18846 2019-03-10 11:45:58Z hotbso
98_DLNARenderer.pm   15836 2018-01-09 21:01:49Z dominik
98_DOIF.pm           27418 2023-04-09 21:23:46Z Damian
98_dummy.pm          25606 2022-02-01 10:43:57Z rudolfkoenig
70_ENIGMA2.pm        18995 2019-03-22 20:09:53Z loredo
91_eventTypes.pm     23471 2021-01-04 19:24:21Z rudolfkoenig
00_FBAHAHTTP.pm      25767 2022-03-03 18:52:56Z rudolfkoenig
10_FBDECT.pm         25069 2021-10-13 05:58:51Z rudolfkoenig
72_FB_CALLLIST.pm    25271 2021-11-28 09:40:15Z markusbloch
72_FB_CALLMONITOR.pm 27275 2023-02-27 07:05:39Z jowiemann
01_FHEMWEB.pm        27294 2023-03-03 14:34:59Z rudolfkoenig
92_FileLog.pm        26959 2023-01-04 12:56:01Z rudolfkoenig
72_FRITZBOX.pm       27403 2023-04-06 13:23:45Z jowiemann
37_harmony.pm        19170 2019-04-13 12:21:29Z justme1968
98_help.pm           25013 2021-09-23 21:07:00Z betateilchen
88_HMCCU.pm          26565 2022-10-20 12:24:12Z zap
88_HMCCUCHN.pm       26565 2022-10-20 12:24:12Z zap
88_HMCCURPCPROC.pm   26565 2022-10-20 12:24:12Z zap
98_HTTPMOD.pm        27065 2023-01-15 17:33:44Z StefanStrobel
30_HUEBridge.pm      26438 2022-09-22 06:40:39Z justme1968
31_HUEDevice.pm      26730 2022-11-21 17:28:03Z justme1968
10_IT.pm             20839 2019-12-28 09:41:47Z bjoernh
98_JsonList2.pm      26701 2022-11-14 09:51:02Z rudolfkoenig
98_JsonMod.pm        24783 2021-07-21 22:37:12Z herrmannj
70_NEUTRINO.pm       18461 2019-01-30 20:33:35Z michael.winkler
91_notify.pm         25888 2022-03-27 10:22:58Z rudolfkoenig
73_PRESENCE.pm       20782 2019-12-19 10:51:06Z markusbloch
33_readingsGroup.pm  23844 2021-02-27 19:43:24Z justme1968
10_RESIDENTS.pm      19533 2019-06-02 19:33:11Z loredo
20_ROOMMATE.pm       19533 2019-06-02 19:33:11Z loredo
70_SamsungAV.pm      19110 2019-04-04 10:37:59Z KoelnSolar
14_SD_WS07.pm        26981 2023-01-06 11:43:36Z Sidey
36_Shelly.pm         26017 2022-05-02 07:04:23Z phenning
99_SUNRISE_EL.pm     24249 2021-04-14 05:45:49Z rudolfkoenig
98_SVG.pm            27261 2023-02-21 09:34:09Z rudolfkoenig
50_TelegramBot.pm    27218 2023-02-13 22:45:48Z viegener
98_telnet.pm         25754 2022-02-27 16:49:52Z rudolfkoenig
99_Utils.pm          24128 2021-04-02 16:29:11Z rudolfkoenig
98_version.pm        26611 2022-10-28 16:32:29Z betateilchen
91_watchdog.pm       26108 2022-06-01 08:25:03Z rudolfkoenig
59_Weather.pm        27146 2023-01-29 15:27:02Z CoolTux
98_weblink.pm        26988 2023-01-07 09:18:42Z rudolfkoenig
98_WeekdayTimer.pm   27118 2023-01-25 19:32:47Z Beta-User
59_Wunderground.pm   18995 2019-03-22 20:09:53Z loredo
AttrTemplate.pm      27145 2023-01-29 11:48:19Z rudolfkoenig
Blocking.pm          23268 2020-12-01 11:48:48Z rudolfkoenig
Color.pm             20813 2019-12-22 18:42:10Z justme1968
Common.pm            10759 2016-02-07 20:00:12Z rleins
ControlPoint.pm      22400 2020-07-14 17:54:36Z Reinerlein
CoProcess.pm         24043 2021-03-21 16:21:46Z justme1968
DevIo.pm             27247 2023-02-18 21:22:32Z rudolfkoenig
FritzBoxUtils.pm     23727 2021-02-12 20:31:37Z rudolfkoenig
GPUtils.pm           19666 2019-06-20 11:17:29Z CoolTux
HMCCUConf.pm         26565 2022-10-20 12:24:12Z zap
HttpUtils.pm         27406 2023-04-07 16:52:19Z rudolfkoenig
Meta.pm              26889 2022-12-23 15:04:11Z CoolTux
myUtilsTemplate.pm    7570 2015-01-14 18:31:44Z rudolfkoenig
RESIDENTStk.pm       19788 2019-07-06 08:10:55Z loredo
RTypes.pm            10476 2016-01-12 21:03:33Z borisneubert
SetExtensions.pm     25286 2021-12-03 10:16:56Z rudolfkoenig
TcpServerUtils.pm    25866 2022-03-21 09:01:16Z rudolfkoenig
UConv.pm             21159 2020-02-09 14:04:27Z loredo
Unit.pm              19614 2019-06-13 23:11:25Z loredo
doif.js                    24438 2021-05-14 18:08:18Z Ellert
fhemweb.js                 27117 2023-01-25 09:13:32Z rudolfkoenig
fhemweb_readingsGroup.js   15189 2017-10-03 17:53:27Z justme1968
FlatTV
Das ist der Aufruf mit, mit dem fhem dann absemmelt im Log.
2023.04.12 20:09:11 4: https://api.weatherbit.io/v2.0/forecast/daily?lang=de&city=Bremerhaven&key=dee8bda83d9d49f1acf5b2072a15fee0: HTTP response code 200
2023.04.12 20:09:11 5: HttpUtils https://api.weatherbit.io/v2.0/forecast/daily?lang=de&city=Bremerhaven&key=meiner: Got data, length: 5011
2023.04.12 20:09:11 5: HttpUtils response header:
HTTP/1.1 200 OK
server: openresty/1.19.3.1
date: Wed, 12 Apr 2023 18:09:11 GMT
content-type: application/json; charset=utf-8
content-length: 5011
keep-alive: timeout=5
x-ratelimit-limit: 55
x-ratelimit-remaining: 35
x-ratelimit-reset: 1681343999
x-proxy-cache: MISS
access-control-allow-origin: *
access-control-allow-methods: GET, OPTIONS, POST
access-control-allow-headers: DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Content-Range,Range
access-control-expose-headers: DNT,X-CustomHeader,Keep-Alive,User-Agent,X-Requested-With,If-Modified-Since,Cache-Control,Content-Type,Content-Range,Range
connection: close
2023.04.12 20:09:11 4: [WeatherBit] api encoding is , designated encoder is utf-8-strict
2023.04.12 20:10:42 1: Including fhem.cfg
2023.04.12 20:10:43 3: WEB: port 8083 opened
FlatTV
Ja, so geht das hier auch - über http aber nicht
herrmannj
status=11/SEGV
Da ich nicht weiß wie gut Du im Thema bist, Seg fault ist in der Regel ein Problem von perl selbst. Yersinia hatte das segv spoaradisch ebenfalls. Soweit ich verstanden habe, ist es bei Dir aber sicher reproduzierbar. (richtig?)
Wenn Zeit, Lust und die Möglichkeit hast Testversionen des Moduls händisch einzuspielen, dann kann ich Dir anbieten diese zu erstellen. Im ersten Schritt baue ich mehr Logmeldungen ein, um die Stelle des Absturzes genauer einzugrenzen. Wenn das gelingt können wir vmtl einen work around finden.
FlatTV
Ich kann den Fehler reproduzieren und könnte Testversionen auch einspielen.
Wenn du magst, ich wäre bereit  ;)
herrmannj
Perfekt, dann tasten wir uns mal an die Stelle ran. Modul im Anhang, bitte verbose 5. Bitte schau auch ob folgende Meldung beim Start von fhem erscheint (verbos >3): "json [JsonMod::JSON::StreamWriter] is pure perl. Consider installing Cpanel::JSON::XS" Hintergrund: falls Cpanel::JSON::XS installiert ist, soll das zum decodieren verwendet werden, andernfalls ein eingebauter decoder.
Zitat von: herrmannj am 13 April 2023, 11:52:47Hintergrund: falls Cpanel::JSON::XS installiert ist, soll das zum decodieren verwendet werden, andernfalls ein eingebauter decoder.
Es gibt schon ein paar FHEM Module, die dieses Modul benötigen, insofern besteht die Wahrscheinlichkeit, dass es schon vorhanden ist.
Wer es mittels eins Debian-Paketes nachinstallieren muss/möchte:
sudo apt install libcpanel-json-xs-perl
herrmannj
@FlatTv: falls es bei dir jedoch noch nicht installiert war, bitte erstmal noch nicht installieren damit wir vorher den Fehler eingrenzen können ;)
Für die Unterstützung zur Fehlersuche: bei mir war das Modul bereits vorhanden und wird gemäß der zugehörigen Logmeldung (aus dem Testmodul) auch benutzt.
FlatTV
Also Verbose=5 ist ja überhaupt nicht wirklich zu nutzen.
Allein das Modul BOSEST schreibt mit seinem Polling ununterbrochen ins Log und man kann das Modul auch nicht deaktivieren (oder zumindest ich nicht).
Wenn ich im Log nach ,,JsonMod::" Suche, bekomme ich kein Ergebnis.
Der Absturz ist wieder hier im Log.
2023.04.13 19:18:53 4: https://api.weatherbit.io/v2.0/forecast/daily?lang=de&city=Bremerhaven&key=dee8bda83d9d49f1acf5b2072a15fee0: HTTP response code 200
2023.04.13 19:18:53 5: HttpUtils https://api.weatherbit.io/v2.0/forecast/daily?lang=de&city=Bremerhaven&key=dee8bda83d9d49f1acf5b2072a15fee0: Got data, length: 5033
2023.04.13 19:18:53 5: HttpUtils response header:
HTTP/1.1 200 OK
date: Thu, 13 Apr 2023 17:18:53 GMT
content-length: 5033
x-ratelimit-remaining: 20
x-ratelimit-reset: 1681430399
x-proxy-cache: HIT
connection: close
2023.04.13 19:18:53 4: [WeatherBit] api encoding is , designated encoder is utf-8-strict
2023.04.13 19:18:53 5: [WeatherBit] start json decoding
json decoded using Cpanel
2023.04.13 19:18:53 5: [WeatherBit] finished json decoding
2023.04.13 19:18:53 5: [WeatherBit] start do readings
