peterboeckmann
Hallo Heiko,
hier meine Readings aus diesem Bereich für heute:
setstate SolarForecast 2025-03-08 09:00:04 pvCorrectionFactor_09 1.27 (automatic - old factor: 1.03, AI result used, Sun Alt range: 15, Cloud range: 15, Days in range: 2)
setstate SolarForecast 2025-03-08 10:00:00 pvCorrectionFactor_10 0.78 (automatic - old factor: 0.97, Sun Alt range: 20, Cloud range: 20, Days in range: 2)
setstate SolarForecast 2025-03-08 11:00:00 pvCorrectionFactor_11 0.85 (automatic - old factor: 0.83, Sun Alt range: 25, Cloud range: 15, Days in range: 3)
setstate SolarForecast 2025-03-08 12:00:05 pvCorrectionFactor_12 0.84 (automatic - old factor: 0.72, Sun Alt range: 30, Cloud range: 15, Days in range: 2)
setstate SolarForecast 2025-03-08 13:00:01 pvCorrectionFactor_13 0.83 (automatic - old factor: 0.72, Sun Alt range: 30, Cloud range: 15, Days in range: 2)
setstate SolarForecast 2025-03-08 14:00:00 pvCorrectionFactor_14 0.84 (automatic - old factor: 1.00, Sun Alt range: 30, Cloud range: 15, Days in range: 1)
setstate SolarForecast 2025-03-08 15:00:01 pvCorrectionFactor_15 0.92 (automatic - old factor: 1.04, Sun Alt range: 25, Cloud range: 15, Days in range: 2)
setstate SolarForecast 2025-03-08 16:00:01 pvCorrectionFactor_16 0.97 (automatic - old factor: 1.20, Sun Alt range: 20, Cloud range: 15, Days in range: 2)
setstate SolarForecast 2025-03-08 17:00:05 pvCorrectionFactor_17 0.92 (automatic - old factor: 1.00, Sun Alt range: 15, Cloud range: 15, Days in range: 1)
setstate SolarForecast 2025-03-08 18:00:03 pvCorrectionFactor_18 0.68 (automatic - old factor: 0.60, Sun Alt range: 5, Cloud range: 10, Days in range: 2)
Ich lasse die KI noch weiterhin aus und berichte morgen wieder.
Viele Grüße,
Peter
MQTT,Modbus,HTTPMod,DbLog,LaCrosse,SolarForecast,TelegramBot,Twilight,vitoconnect,withings
fhem,fhempy,debmatic
Debian
RaspberryPi5,HomeMatic,HomeMaticIP,Shelly,JeeLink,SignalDuino,ZWDongle,SONOS,alexa,Hue,tradfri,MobileAlerts,Siemens Home Connect,Roborock S50,Wallbox,Harmony,Tuya Smartlife
DS_Starter
Kannst du auch nochmal eine Debugausgabe posten bei Gelegenheit?
Ich möchte nur nochmal vergleichen wie sich meine kleine Anpassung bei zwei Ost/West Strings darstellt. Ich habe nur Südlage.
peterboeckmann
Zitat von: DS_Starter am 08 März 2025, 19:03:58Kannst du auch nochmal eine Debugausgabe posten bei Gelegenheit?
Mach ich morgen vormittag.
Debian
peterboeckmann
Hallo Heiko,
anbei die Debug-Ausgaben in einer Datei, weil es im Code-Block zu viel würde.
Außerdem ein Screenshot der heutigen Prognose. Die Wetter-Zeile zeigt zwar leichte Bewölkung (zwischen 38 und 50), bei WetterOnline ist davon nichts zu sehen.
Viele Grüße,
Peter
Debian
DS_Starter
Moin Peter,
vielen Dank für die Daten.
ZitatDie Wetter-Zeile zeigt zwar leichte Bewölkung (zwischen 38 und 50), bei WetterOnline ist davon nichts zu sehen.
Solche Unterschiede gibt es. Auch DWD_OpenData (API) und die ICON Modelle des DWD (OpenMeteoDWD) liefern u.U. andere Prognosedaten für die gleiche Umgebung.
Auch werden z.B. eine WetterID "0" (=wolkenloser Himmel) geliefert und Neff (die Bewölkung) hat einen Wert von ungleich "0", was ja eigentlich nicht zusammenpasst. Hier versuche ich aktuell ein Schema zu finden wie DWD an dieser Stelle agiert.
Wenn du tiefer einsteigen möchtest, ist diese Seite des DWD ein guter Startpunkt um zu weiteren Dokumenten zu verzweigen.
LG,
Heiko
peterboeckmann
Hallo Heiko,
den tieferen Einstieg lasse ich lieber weg.
Solange die Strahlungsprognose des DWD brauchbar ist, bin ich zufrieden.
Deswegen habe ich mich auch noch nicht mit Alternativen dazu befasst.
Ich stehe aber gerne für Tests und Debugausgaben zur Verfügung.
Viele Grüße,
Peter
Debian
tomcat.x
Für heute 12:00 Uhr habe ich in der Grafik eine Vorhersage, die 14% über der Kapazität (Sumne der Inverter capacity) liegt und das bei Cloud: 70.
Die Stunde ist generell der Ausreißer heute. Muss ich mich auf die Suche nach einem Konfiguratiosfehler machen?
FHEM: 6.4 auf Raspi 4B, Raspbian (noch Buster), Perl v5.28.1 mit Sender/Empfänger: 3 x CULv3, Duofern Stick
Gateways: FRITZ!Box 6591 (OS: 8.25), Trädfri, ConBee 2,  piVCCU (HM-MOD-RPI-PCB), OpenMQTTGateway
Sensoren/Aktoren: FRITZ!DECT, FS20, FHT, HMS, HomeMatic, Trädfri, DuoFern, NetAtmo, UNIRoll
DS_Starter
Shadow3561
#2258
Ich habe auch eine Frage.
Bei mir sind die Vorhersagewerte immer viel zu hoch.
Sie werden für den nächsten Tag angepasst, was am Ende der Grafik sieht.
Am nächstem morgen sind sie dann wieder viel zu hoch und werden erst nach dem Stundenwechsel, für die jeweils nächste Stunde, korrigiert.
Anbei ein Bild zu Verdeutlichung.
Mit freundlichen Grüßen
Edit:
   FUUID      67247ac1-f33f-d66d-4e77-94b6b4acd8c6944b
   FVERSION   76_SolarForecast.pm:v1.47.1-s29734/2025-03-07
   LCACHEFILE last write time: 11:15:41 whole Operating Memory
   MODE       Automatic / Event-controlled - next planned Cycletime: 11:29:33
   MODEL      DWD
   NAME       PV_forecast
   NOTIFYDEV  ShellyPro_3EM,Hyper2000,SE3500H
   NR         1538
   NTFY_ORDER 50-PV_forecast
   STATE      updated
   TYPE       SolarForecast
   WEATHERMODEL DWD
   eventCount 5694
   HELPER:
     FW         WEB
     PACKAGE    FHEM::SolarForecast
     SPGDETAIL
     SPGDEV     PV_forecast
     SPGROOM
     VERSION    1.47.1
     VERSION_API unused
     VERSION_CTZ 1.0.0
     VERSION_ErrCodes 1.3.9
     VERSION_SMUtils 1.28.3
     GMFRUNNING:
       abortFn    FHEM::SolarForecast::_abortGetMessageFile
       bc_pid     3878
       finishFn   FHEM::SolarForecast::_processMessageFile
       fn         FHEM::SolarForecast::_retrieveMessageFile
       loglevel   3
       pid        DEAD:214617
       telnet     telnetPort_127.0.0.1_54314
       terminated 1
       timeout    30
       abortArg:
       arg:
         block      1
         name       PV_forecast
         tsnext     1741518317.05364
   OLDREADINGS:
     2025-03-09 11:29:03   Battery_ChargeRecommended_01 1
     2025-03-09 11:29:03   Current_AutarkyRate 100 %
     2025-03-09 11:29:03   Current_BatCharge_01 99 %
     2025-03-09 11:29:03   Current_Consumption 434 W
     2025-03-09 11:29:03   Current_GridConsumption 0 W
     2025-03-09 11:29:03   Current_GridFeedIn 1012 W
     2025-03-09 11:29:03   Current_PV      1870 W
     2025-03-09 11:29:03   Current_PowerBatIn_01 424 W
     2025-02-02 07:46:16   Current_PowerBatIn_02 75 W
     2025-03-09 11:29:03   Current_PowerBatOut_01 0 W
     2025-02-02 07:46:16   Current_PowerBatOut_02 0 W
     2025-03-09 11:29:03   Current_SelfConsumption 434 W
     2025-03-09 11:29:03   Current_SelfConsumptionRate 23 %
     2025-03-09 11:29:03   Current_Surplus 1436 W
     2025-03-09 11:00:00   LastHourGridconsumptionReal 584 Wh
     2025-03-09 11:00:00   LastHourPVforecast 2752 Wh
     2025-03-09 11:00:00   LastHourPVreal  1000 Wh
     2025-03-09 11:29:03   NextHours_Sum01_PVforecast 3622 Wh
     2025-03-09 11:29:03   NextHours_Sum02_PVforecast 7174 Wh
     2025-03-09 11:29:03   NextHours_Sum03_PVforecast 10396 Wh
     2025-03-09 11:29:03   NextHours_Sum04_ConsumptionForecast 2590 Wh
     2025-03-09 11:29:03   NextHours_Sum04_PVforecast 12458 Wh
     2025-03-09 11:29:03   RestOfDayConsumptionForecast 4175 Wh
     2025-03-09 11:29:03   RestOfDayPVforecast 14497 Wh
     2025-03-09 00:59:49   Today_Hour01_BatIn_01 0 Wh
     2025-03-09 00:59:49   Today_Hour01_BatOut_01 0 Wh
     2025-03-09 00:59:49   Today_Hour01_GridConsumption 182 Wh
     2025-03-09 00:59:49   Today_Hour01_GridFeedIn 0 Wh
     2025-03-09 00:59:49   Today_Hour01_PVreal 10 Wh
     2025-03-09 01:59:49   Today_Hour02_BatIn_01 0 Wh
     2025-03-09 01:59:49   Today_Hour02_BatOut_01 0 Wh
     2025-03-09 01:59:49   Today_Hour02_GridConsumption 186 Wh
     2025-03-09 01:59:49   Today_Hour02_GridFeedIn 0 Wh
     2025-03-09 01:59:49   Today_Hour02_PVreal 0 Wh (WARNING invalid real PV occured - see Logfile)
     2025-03-09 02:59:50   Today_Hour03_BatIn_01 0 Wh
     2025-03-09 02:59:50   Today_Hour03_BatOut_01 0 Wh
     2025-03-09 02:59:50   Today_Hour03_GridConsumption 191 Wh
     2025-03-09 02:59:50   Today_Hour03_GridFeedIn 0 Wh
     2025-03-09 02:59:50   Today_Hour03_PVreal 0 Wh (WARNING invalid real PV occured - see Logfile)
     2025-03-09 03:59:49   Today_Hour04_BatIn_01 0 Wh
     2025-03-09 03:59:49   Today_Hour04_BatOut_01 0 Wh
     2025-03-09 03:59:49   Today_Hour04_GridConsumption 191 Wh
     2025-03-09 03:59:49   Today_Hour04_GridFeedIn 0 Wh
     2025-03-09 03:59:49   Today_Hour04_PVreal 0 Wh (WARNING invalid real PV occured - see Logfile)
     2025-03-09 04:59:49   Today_Hour05_BatIn_01 0 Wh
     2025-03-09 04:59:49   Today_Hour05_BatOut_01 0 Wh
     2025-03-09 04:59:49   Today_Hour05_GridConsumption 185 Wh
     2025-03-09 04:59:49   Today_Hour05_GridFeedIn 0 Wh
     2025-03-09 04:59:49   Today_Hour05_PVreal 0 Wh (WARNING invalid real PV occured - see Logfile)
     2025-03-09 05:59:49   Today_Hour06_BatIn_01 0 Wh
     2025-03-09 05:59:49   Today_Hour06_BatOut_01 0 Wh
     2025-03-09 05:59:49   Today_Hour06_GridConsumption 190 Wh
     2025-03-09 05:59:49   Today_Hour06_GridFeedIn 0 Wh
     2025-03-09 05:59:49   Today_Hour06_PVreal 0 Wh (WARNING invalid real PV occured - see Logfile)
     2025-03-09 06:59:49   Today_Hour07_BatIn_01 0 Wh
     2025-03-09 06:59:49   Today_Hour07_BatOut_01 0 Wh
     2025-03-09 06:59:49   Today_Hour07_GridConsumption 243 Wh
     2025-03-09 06:59:49   Today_Hour07_GridFeedIn 0 Wh
     2025-03-09 06:59:49   Today_Hour07_PVforecast 6 Wh
     2025-03-09 06:59:49   Today_Hour07_PVreal 0 Wh (WARNING invalid real PV occured - see Logfile)
     2025-03-09 07:59:49   Today_Hour08_BatIn_01 0 Wh
     2025-03-09 07:59:49   Today_Hour08_BatOut_01 0 Wh
     2025-03-09 07:59:49   Today_Hour08_GridConsumption 147 Wh
     2025-03-09 07:59:49   Today_Hour08_GridFeedIn 93 Wh
     2025-03-09 07:59:49   Today_Hour08_PVforecast 184 Wh
     2025-03-09 07:59:49   Today_Hour08_PVreal 420 Wh
     2025-03-09 08:59:59   Today_Hour09_BatIn_01 0 Wh
     2025-03-09 08:59:59   Today_Hour09_BatOut_01 0 Wh
     2025-03-09 08:59:59   Today_Hour09_GridConsumption 472 Wh
     2025-03-09 08:59:59   Today_Hour09_GridFeedIn 496 Wh
     2025-03-09 08:59:59   Today_Hour09_PVforecast 720 Wh
     2025-03-09 08:59:59   Today_Hour09_PVreal 820 Wh
     2025-03-09 09:59:49   Today_Hour10_BatIn_01 0 Wh
     2025-03-09 09:59:49   Today_Hour10_BatOut_01 0 Wh
     2025-03-09 09:59:49   Today_Hour10_GridConsumption 616 Wh
     2025-03-09 09:59:49   Today_Hour10_GridFeedIn 667 Wh
     2025-03-09 09:59:49   Today_Hour10_PVforecast 1959 Wh
     2025-03-09 09:59:49   Today_Hour10_PVreal 870 Wh
     2025-03-09 10:59:49   Today_Hour11_BatIn_01 0 Wh
     2025-03-09 10:59:49   Today_Hour11_BatOut_01 0 Wh
     2025-03-09 10:59:49   Today_Hour11_GridConsumption 584 Wh
     2025-03-09 10:59:49   Today_Hour11_GridFeedIn 902 Wh
     2025-03-09 10:59:49   Today_Hour11_PVforecast 2752 Wh
     2025-03-09 10:59:49   Today_Hour11_PVreal 1000 Wh
     2025-03-09 11:29:03   Today_Hour12_BatIn_01 0 Wh
     2025-03-09 11:29:03   Today_Hour12_BatOut_01 0 Wh
     2025-03-09 11:29:03   Today_Hour12_GridConsumption 122 Wh
     2025-03-09 11:29:03   Today_Hour12_GridFeedIn 581 Wh
     2025-03-09 11:29:03   Today_Hour12_PVforecast 3570 Wh
     2025-03-09 11:29:03   Today_Hour12_PVreal 680 Wh
     2025-03-09 11:29:03   Today_Hour13_PVforecast 3674 Wh
     2025-03-09 11:29:03   Today_Hour14_PVforecast 3431 Wh
     2025-03-09 11:29:03   Today_Hour15_PVforecast 3013 Wh
     2025-03-09 11:29:03   Today_Hour16_PVforecast 1110 Wh
     2025-03-09 11:29:03   Today_Hour17_PVforecast 1203 Wh
     2025-03-09 11:29:03   Today_Hour18_PVforecast 275 Wh
     2025-03-09 11:29:03   Today_Hour19_PVforecast 6 Wh
     2025-03-09 11:29:03   Today_MaxPVforecast 3674 Wh
     2025-03-09 11:29:03   Today_MaxPVforecastTime 2025-03-09 12:00:00
     2025-03-09 11:29:03   Today_PVdeviation 48.41 %
     2025-03-09 11:29:03   Today_PVforecast 21903 Wh
     2025-03-09 11:29:03   Today_PVreal    3800 Wh
     2025-03-09 11:29:03   Today_SunRise   06:51
     2025-03-09 11:29:03   Today_SunSet    18:13
     2025-03-09 11:29:03   Tomorrow_ConsumptionForecast 5036 Wh
     2025-03-09 11:29:03   Tomorrow_PVforecast 18293 Wh
     2025-03-09 11:29:03   Tomorrow_SunRise 06:48
     2025-03-09 11:29:03   Tomorrow_SunSet 18:14
     2024-11-01 08:16:36   currentInverterDev SE3500H pv=AC_current_W:W etotal=gesamtPV:kWh capacity=3600
     2024-11-01 07:59:28   currentRadiationAPI PV_forecast_weather
     2024-11-01 07:57:43   inverterStrings Vordach,Fahrradschuppen,Dach,Garten,Wintergarten
     2024-11-01 08:20:00   moduleAzimuth   Vordach=-90 Fahrradschuppen=0 Dach=0 Garten=-90 Wintergarten=90
     2024-11-01 08:22:24   moduleDeclination Vordach=40 Fahrradschuppen=25 Dach=45 Garten=15 Wintergarten=15
     2024-11-01 08:20:38   modulePeakString Vordach=0.6 Fahrradschuppen=0.66 Dach=0.88 Garten=1.2 Wintergarten=1.94
     2025-03-09 11:29:03   nextCycletime   11:29:33
     2025-03-09 08:00:03   pvCorrectionFactor_08 1.75 (automatic - old factor: 1.00, Sun Alt range: 5, Cloud range: 75, Days in range: 1)
     2025-03-09 09:00:03   pvCorrectionFactor_09 0.82 (automatic - old factor: 1.00, AI result used, Sun Alt range: 15, Cloud range: 50, Days in range: 1)
     2025-03-09 10:00:03   pvCorrectionFactor_10 0.44 (automatic - old factor: 1.00, Sun Alt range: 20, Cloud range: 40, Days in range: 1)
     2025-03-09 11:00:03   pvCorrectionFactor_11 0.36 (automatic - old factor: 1.00, Sun Alt range: 25, Cloud range: 35, Days in range: 1)
     2025-03-09 11:29:03   pvCorrectionFactor_Auto on_complex_ai
     2025-02-01 21:37:19   setupStringAzimuth Vordach=-90 Fahrradschuppen=0 Dach=0 Garten=-90 Wintergarten=90
     2025-02-01 21:37:20   setupStringDeclination Vordach=40 Fahrradschuppen=25 Dach=45 Garten=10 Wintergarten=15
     2025-03-09 11:29:03   special_runTimeTrainAI 0.34828 s
     2025-03-09 11:29:03   special_todayBatInSum 0.0  Wh
     2025-03-09 11:29:03   special_todayBatOutSum 0.0  Wh
     2025-03-09 11:29:03   special_todayConsumption 4367 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_01 184 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_02 188 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_03 187 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_04 186 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_05 188 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_06 190 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_07 229 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_08 308 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_09 491 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_10 466 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_11 782 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_12 1017 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_13 782 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_14 660 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_15 385 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_16 510 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_17 304 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_18 190 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_19 67 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_20 16 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_21 139 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_22 240 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_23 192 Wh
     2025-03-09 11:29:03   special_todayConsumptionForecast_24 182 Wh
     2025-03-09 11:29:04   state           updated
   DbLogExclude .*
   affectConsForecastIdentWeekdays 1
   affectConsForecastLastDays 31
   aiControl  aiTrainStart=6 aiStorageDuration=1825 aiTreesPV=5
   ctrlGenPVdeviation continuously
   ctrlInterval 30
   ctrlLanguage DE
   ctrlSpecialReadings runTimeTrainAI,todayBatInSum,todayBatOutSum,todayConsumption,todayConsumptionForecast
   event-on-change-reading .*
   graphicEnergyUnit Wh
   graphicHeaderOwnspec #Batterie
in heute:special_todayBatIn
out heute:special_todayBatOut
   graphicHistoryHour 23
   graphicHourCount 24
   graphicLayoutType double
   graphicShowDiff bottom
   graphicShowNight 0
   room       PV-Solar
   setupBatteryDev01 Hyper2000 pin=properties_report_properties_outputPackPower:W pout=properties_report_properties_packInputPower:W  cap=2000 charge=properties_report_properties_electricLevel show=1
   setupInverterDev01 SE3500H pv=AC_current_W:W etotal=AC_Lifetime_Energy_production_kWh:kWh capacity=3600
   setupInverterDev02 Hyper2000 pv=properties_report_properties_solarInputPower:W etotal=properties_report_packData_1_totalVol:Wh capacity=1200
   setupInverterStrings Vordach,Fahrradschuppen,Dach,Garten,Wintergarten
   setupMeterDev ShellyPro_3EM gcon=Active_Power_S:W contotal=Purchased_Energy_S:W gfeedin=-gcon feedtotal=Returned_Energy_S:W
   setupRadiationAPI PV_forecast_weather
   setupStringPeak Vordach=0.6 Fahrradschuppen=0.66 Dach=0.88 Garten=1.2 Wintergarten=1.93
   setupWeatherDev1 PV_forecast_weather
DS_Starter
ZitatBei mir sind die Vorhersagewerte immer viel zu hoch.
Für einen ersten Eindruck bräuchten wir mal ein List von deinem SF-Device.
tomcat.x
Zitat von: DS_Starter am 09 März 2025, 10:52:29Wie sieht denn dein(e) Attr setupInverterDevXX aus?
Kann jetzt gerade nicht mehr schauen, habe nur noch Internet, kein VPN.
Ist da etwas relevant außer "capacity"? Es sind 2 und die 14% bezogen sich auf die Summe der beiden Werte.
Shadow3561
Zitat von: DS_Starter am 09 März 2025, 11:23:32Für einen ersten Eindruck bräuchten wir mal ein List von deinem SF-Device.
Ist oben mit angehängt
DS_Starter
ZitatIst da etwas relevant außer "capacity"? Es sind 2 und die 14% bezogen sich auf die Summe der beiden Werte.
Nein. Achte darauf dass hier max. Leistung in Watt anzugeben ist.
Ansonsten ctrlDebug=radiationProcess anschalten, dann sieht man mehr.
DS_Starter
@Shadow3561,
du hast 5 Strings und 2 Inverter ohne den Invertern die ihnen zugehörigen Strings zugeordnet zu haben:
Dadurch verwenden beide Inverter alle Strings. Das ist wahrscheinlich so nicht korrekt. Überprüfe das mal.
Shadow3561
Danke,
Ich habe es geändert und werde weiter beobachten.
Ich wünsche dir und Alen mitlesenden einen schönen, sonnigen Sonntag
