DS_Starter
@Bison,
wird das Set-Kommando "on" eigentlich ausgeführt wenn du manuell im HM-Device ausführst?
Bison
Zitat von: DS_Starter am 17 April 2024, 23:12:39Was ich aktuelle sehe ist dass jede 1-2 Sekunden ein Schaltbefehl ausgeführt wird:
2024.04.16 10:38:27 2: SolarForecast - switching Consumer 'Entfeuchter' to 'on' (Automatic = 1)
2024.04.16 10:38:27 1: SolarForecast DEBUG> consumer "01" - current Context is >switch off< => swoffcond: 0, off-command: off
2024.04.16 10:38:27 1: SolarForecast DEBUG> consumer "01" - current planning state: starting
2024.04.16 10:38:29 1: SolarForecast DEBUG> ############### consumerSwitching consumer "01" ###############
2024.04.16 10:38:29 1: SolarForecast DEBUG> consumer "01" - general switching parameters => auto mode: 1, current Consumption: -100 W, nompower: 250, surplus: 331 W, planstate: switching on:, starttime: 16.04.2024 10:15:42
2024.04.16 10:38:29 1: SolarForecast DEBUG> consumer "01" - isInLocktime: 0
2024.04.16 10:38:29 1: SolarForecast DEBUG> consumer "01" - current Context is >switch on< => swoncond: 1, on-command: on
2024.04.16 10:38:29 1: SolarForecast DEBUG> consumer "01" - device >STD_AKT_1_Sw< is used as switching device
2024.04.16 10:38:29 2: SolarForecast - switching Consumer 'Entfeuchter' to 'on' (Automatic = 1)
2024.04.16 10:38:29 1: SolarForecast DEBUG> consumer "01" - current Context is >switch off< => swoffcond: 0, off-command: off
2024.04.16 10:38:29 1: SolarForecast DEBUG> consumer "01" - current planning state: starting
2024.04.16 10:38:30 1: SolarForecast DEBUG> ############### consumerSwitching consumer "01" ###############
2024.04.16 10:38:30 1: SolarForecast DEBUG> consumer "01" - general switching parameters => auto mode: 1, current Consumption: -100 W, nompower: 250, surplus: 331 W, planstate: switching on:, starttime: 16.04.2024 10:15:42
2024.04.16 10:38:30 1: SolarForecast DEBUG> consumer "01" - isInLocktime: 0
2024.04.16 10:38:30 1: SolarForecast DEBUG> consumer "01" - current Context is >switch on< => swoncond: 1, on-command: on
2024.04.16 10:38:30 1: SolarForecast DEBUG> consumer "01" - device >STD_AKT_1_Sw< is used as switching device
2024.04.16 10:38:30 2: SolarForecast - switching Consumer 'Entfeuchter' to 'on' (Automatic = 1)
Erkannt wird der Status nicht.
Wie steht dein Attribut ctrlInterval?
Hallo Heiko,
das Attribut ctrlInterval ist nicht gesetzt.
Raspberry, Homematic, CUL, 50 Device, 260 Entities
Bison
Ja es wird sogar ein und ausgeschaltet.
Der Consumer ist so definiert.
STD_AKT_1_Pwr type=heater power=250 switchdev=STD_AKT_1_Sw mode=can icon=Ventilator_wind on=on off=off swstate=state:.*on:*:.*off.* asynchron=1 notbefore=10 notafter=18 locktime=900:900 auto=1 pcurr=power:W:250 etotal=energy:Wh interruptable=1
TheTrumpeter
Zitat von: kask am 17 April 2024, 18:38:27Edit: Also mit den Shellys geht das auch Problemlos. Diese sind über MQTT angebunden. Keine Ahnung ob dadurch Unterschiede gibt.
Fakt ist das Tasmota und Shellys über MQTT ausschalten bei on-for-timer. Auch bei nicht mehr laufender Automation.
Der Auszug von oben ist aus der CommandRef zu den "set extensions". Da steht auch dabei, dass im Zweifelsfall die Modul-eigene Implementierung "gewinnt". Offensichtlich unterstützen die Shellys und Tasmota eine Art "Timer/Countdown" am Gerät selbst, d.h. beim Absetzen von "on-for-timer" wird dem Gerät direkt mitgegeben wie lange das Gerät eingeschaltet sein soll. (Ähnlich wie der "countdown" bei Tuya, aber möglicherweise sogar in einem einzigen Befehl?)
MQTT hat damit nix zu tun, das müsste egal sein wie Du mit den Dingern kommunizierst.
Meine Bewässerung wird von einem ESP32 mit ESPEasy angesteuert, da setze ich in FHEM auch die Befehle ab, die die Timer direkt am Gerät laufen lassen. (Zusätzlich habe ich dort noch eine interne und zwei externe Überwachungen eingebaut, die dafür sorgen, dass die Ventile bei einem Gerätereboot oder allerspätestens bei Sonnenaufgang geschlossen werden. Wird paar Minuten nach Sonnenaufgang immer noch Wasser verbraucht, dann wird die gesamte Steuerung über eine schaltbare Steckdose vom Netz genommen. Spätestens dann muss Ruhe sein.)
FHEM auf RPi3, THZ (LWZ404SOL), RPII2C & I2C_MCP342x (ADCPiZero), PowerMap, CustomReadings, RPI_GPIO, Twilight, nanoCUL (WMBus für Diehl Wasserzähler & Regenerationszähler für BWT AqaSmart), ESPEasy, TPLinkHS110
Prof. Dr. Peter Henning
Zitat von: TheTrumpeter am 18 April 2024, 06:54:28Offensichtlich unterstützen die Shellys und Tasmota eine Art "Timer/Countdown" am Gerät selbst, d.h. beim Absetzen von "on-for-timer" wird dem Gerät direkt mitgegeben wie lange das Gerät eingeschaltet sein soll. (Ähnlich wie der "countdown" bei Tuya, aber möglicherweise sogar in einem einzigen Befehl?)
Als "Erfinder" des Shelly-Moduls kann ich die Spekulation durch Klarheit ersetzen: Ja, Viele (nicht alle) Shelly-Devices erlauben das Setzen interner Timer mit einem einzigen REST-Call. Allerdings bitte nicht mit Tuya in einen Topf werfen.
pah
DS_Starter
@Bison,
Hier stimmt etwas nicht:
So wäre es richtig:
     swstate=state:.*on.*:.*off.*
Da du asynchron=1 gesetzt hast (was allerdings bei den Homematic Devices nicht nötig ist weil sie direkt schalten), wird bei einem Event von STD_AKT_1_Sw die Logik im SF angesprochen. Daher wahrscheinloch die hohe Frequenz der Logmeldungen. Das kannst du mit ctrlDebug=notifyHandling überprüfen.
Die grundlegende Sache ist allerdings das falsche Setting im Key swstate.
Reinschki
#501
Guten Morgen,
die zweite Nacht in Folge wird der Docker Container Fhem "unhealthy" und nichts geht mehr.
Einer der letzten Log-Einträge ist:
Illegal division by zero at ./FHEM/76_SolarForecast.pm line 10220.
Ich bin auf Version: 76_SolarForecast.pm:v1.17.9-s28804/2024-04-17
Ich habe vor, dass Device zu deinstallieren um die Gegenprobe zu machen und zu schauen, ob der Container durchläuft.
Schade  :(
DS_Starter
Morgen Reinschki,
nicht gleich die Flinte ins Korn werfen.  ;)
Da war die vorletzte Änderung bzgl. Abweichungsberechnung nicht so optimal. Das korrigiere ich heute noch.
Als schnellen Workaround stellst du das Attr ctrlGenPVdeviation auf daily.
DS_Starter
#503
@Reinschki,
ich habe das Problem gefixt und eingecheckt.
In meinem contrib liegt die gleiche Version zum sofortigen Download wenn du si schon einspielen magst.
LG,
Heiko
Reinschki
Hallo Heiko,
die 1.17.10 ist installiert -> ich werde berichten.
An dieser Stelle herzlichen Dank für das Modul und deine engagierte Supportleistung!
Reiner
oelidoc
ich wollte mal fragen, wie ihr das mit einer Batterie gelöst habt. Ich lese die BYD Batterie als currentBatteryDev über den SMA Sunny Tripower SE Wechselrichter aus und lasse sie bei SF anzeigen. Da ich gerne den Batterie Bezug auch nach Sonnenuntergang im SF Modul angezeigt bekommen möchte, habe ich beim 76_SMAInverter.pm attr suppressSleep 1 gesetzt. Jetzt wird mir aber der Bezug aus der Batterie (z.B. nach Sonnenuntergang) offensichtlich als Ertrag angerechnet, weswegen es zu hohen Abweichungen von der Modul Prognose kommt (gestern z.B. 36,8%).
Wie kann man das umgehen?
oelidoc
DS_Starter
Hat 76_SMAInverter keine getrennten Readings für PV Erzeugung und Batterie in/out?
oelidoc
Doch
define SunnyTripower8.0SE SMAInverter crypt:xxxxxxxxxxxxxxxxxx 192.xxx.xxx.xx
attr SunnyTripower8.0SE detail-level 1
attr SunnyTripower8.0SE mode automatic
attr SunnyTripower8.0SE readEnergyMeter-data 1
attr SunnyTripower8.0SE room Photovoltaik
attr SunnyTripower8.0SE stateFormat {sprintf("%.1f",ReadingsNum($name,"state",0))." W"}
attr SunnyTripower8.0SE suppressSleep 0
attr SunnyTripower8.0SE target-serial xxxxxxxxx
attr SunnyTripower8.0SE target-susyid 440
attr SunnyTripower8.0SE verbose 2
#   DEF        crypt:xxxxxxxxxxxxxxxxxxx 192.xxx.xxx.xx
#   FUUID      65e1bd9e-f33f-74ea-0abe-0570e6a936905ef0
#   FVERSION   76_SMAInverter.pm:v2.24.1-s28631/2024-03-10
#   HOST       192.xxx.xxx.xx
#   INTERVAL   60
#   INVCLASS   8009
#   INVFWMAIN  0
#   INVTYPE    19050
#   LASTUPDATE 19.04.2024 / 21:01:17
#   NAME       SunnyTripower8.0SE
#   NR         646
#   PASS       crypt:xxxxxxxxxxxxxxxxxxx
#   STATE      0.0 W
#   TYPE       SMAInverter
#   eventCount 157
#   HELPER:
#     AVERAGEBUF 0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0
#     DEFAULT_TARGET_SERIAL xxxxxxxxxx
#     DEFAULT_TARGET_SUSYID 65535
#     FAULTEDCYCLES 0
#     INTERVAL   60
#     MAXBYTES   300
#     MYSERIALNUMBER xxxxxxxxx
#     MYSUSYID   233
#     PACKAGE    main
#     PKT_ID     32769
#     VERSION    2.24.1
#     firtRunDay 0
#   READINGS:
#     2024-04-19 21:01:17   BAT_IDC         3185
#     2024-04-19 21:01:17   BAT_LOADTODAY   7307
#     2024-04-19 21:01:17   BAT_LOADTOTAL   518830
#     2024-04-19 21:01:17   BAT_P_CHARGE    0
#     2024-04-19 21:01:17   BAT_P_DISCHARGE 282
#     2024-04-19 21:01:17   BAT_UDC         20
#     2024-04-19 21:01:17   BAT_UNLOADTODAY 5629
#     2024-04-19 21:01:17   BAT_UNLOADTOTAL 357843
#     2024-04-19 21:01:17   ChargeStatus    68
#     2024-04-19 21:01:17   Meter_Grid_Consumation_PAC1 4
#     2024-04-19 21:01:17   Meter_Grid_Consumation_PAC2 0
#     2024-04-19 21:01:17   Meter_Grid_Consumation_PAC3 18
#     2024-04-19 21:01:17   Meter_Grid_FeedIn_PAC1 0
#     2024-04-19 21:01:17   Meter_Grid_FeedIn_PAC2 21
#     2024-04-19 21:01:17   Meter_Grid_FeedIn_PAC3 0
#     2024-04-19 21:01:17   Meter_Power_Grid_Consumation 1
#     2024-04-19 21:01:17   Meter_Power_Grid_FeedIn 0
#     2024-04-19 21:01:17   Meter_TOTAL_Consumation 2427492
#     2024-04-19 21:01:17   Meter_TOTAL_FeedIn 7738685
#     2024-04-19 21:01:17   Meter_TOTAL_Grid_Consumation 2427492
#     2024-04-19 21:01:17   Meter_TOTAL_Grid_FeedIn 7738685
#     2024-04-19 21:01:17   SPOT_Backup_IAC1 0.10
#     2024-04-19 21:01:17   SPOT_Backup_IAC2 0.00
#     2024-04-19 21:01:17   SPOT_Backup_IAC3 0.10
#     2024-04-19 21:01:17   SPOT_Backup_PAC1 23
#     2024-04-19 21:01:17   SPOT_Backup_PAC2 0
#     2024-04-19 21:01:17   SPOT_Backup_PAC3 23
#     2024-04-19 21:01:17   SPOT_CosPhi     0.000
#     2024-04-19 21:01:17   SPOT_EPVTODAY   13950
#     2024-04-19 21:01:17   SPOT_EPVTOTAL   1733347
#     2024-04-19 21:01:17   SPOT_ETODAY     11618
#     2024-04-19 21:01:17   SPOT_ETOTAL     1581481
#     2024-04-19 21:01:17   SPOT_IAC1       0.50
#     2024-04-19 21:01:17   SPOT_IAC2       0.60
#     2024-04-19 21:01:17   SPOT_IAC3       0.50
#     2024-04-19 21:01:17   SPOT_IDC1       0
#     2024-04-19 21:01:17   SPOT_IDC2       0
#     2024-04-19 21:01:17   SPOT_PAC1       90
#     2024-04-19 21:01:17   SPOT_PAC2       96
#     2024-04-19 21:01:17   SPOT_PAC3       95
#     2024-04-19 21:01:17   SPOT_PACTOT     281
#     2024-04-19 21:01:17   SPOT_PDC        0
#     2024-04-19 21:01:17   SPOT_PDC1       0
#     2024-04-19 21:01:17   SPOT_PDC2       0
#     2024-04-19 21:01:17   SPOT_UAC1       227.7
#     2024-04-19 21:01:17   SPOT_UAC1_2     394.300
#     2024-04-19 21:01:17   SPOT_UAC2       228.8
#     2024-04-19 21:01:17   SPOT_UAC2_3     396.200
#     2024-04-19 21:01:17   SPOT_UAC3       228.3
#     2024-04-19 21:01:17   SPOT_UAC3_1     395.400
#     2024-04-19 21:01:17   SPOT_UDC1       0
#     2024-04-19 21:01:17   SPOT_UDC2       0
#     2024-04-19 21:01:17   avg_power_lastminutes_05 0
#     2024-04-19 21:01:17   avg_power_lastminutes_10 0
#     2024-04-19 21:01:17   avg_power_lastminutes_15 0
#     2024-04-19 21:01:17   modulstate      normal
#     2024-04-19 21:01:17   opertime_start  19.04.2024 05:50:12
#     2024-04-19 21:01:17   opertime_stop   19.04.2024 21:13:09
#     2024-04-19 21:01:17   state           0
#   hmccu:
setstate SunnyTripower8.0SE 0.0 W
setstate SunnyTripower8.0SE 2024-04-19 00:00:20 .bat_loadtotal_yesterday 511523
setstate SunnyTripower8.0SE 2024-04-19 00:00:20 .bat_unloadtotal_yesterday 352214
setstate SunnyTripower8.0SE 2024-04-19 00:00:20 .epvtotal_yesterday 1719397
setstate SunnyTripower8.0SE 2024-04-19 00:00:20 .etotal_yesterday 1569187
setstate SunnyTripower8.0SE 2024-04-19 00:00:20 .yesterday 19
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 BAT_IDC 3185
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 BAT_LOADTODAY 7307
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 BAT_LOADTOTAL 518830
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 BAT_P_CHARGE 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 BAT_P_DISCHARGE 282
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 BAT_UDC 20
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 BAT_UNLOADTODAY 5629
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 BAT_UNLOADTOTAL 357843
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 ChargeStatus 68
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_Grid_Consumation_PAC1 4
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_Grid_Consumation_PAC2 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_Grid_Consumation_PAC3 18
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_Grid_FeedIn_PAC1 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_Grid_FeedIn_PAC2 21
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_Grid_FeedIn_PAC3 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_Power_Grid_Consumation 1
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_Power_Grid_FeedIn 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_TOTAL_Consumation 2427492
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_TOTAL_FeedIn 7738685
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_TOTAL_Grid_Consumation 2427492
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 Meter_TOTAL_Grid_FeedIn 7738685
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_Backup_IAC1 0.10
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_Backup_IAC2 0.00
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_Backup_IAC3 0.10
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_Backup_PAC1 23
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_Backup_PAC2 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_Backup_PAC3 23
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_CosPhi 0.000
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_EPVTODAY 13950
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_EPVTOTAL 1733347
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_ETODAY 11618
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_ETOTAL 1581481
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_IAC1 0.50
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_IAC2 0.60
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_IAC3 0.50
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_IDC1 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_IDC2 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_PAC1 90
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_PAC2 96
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_PAC3 95
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_PACTOT 281
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_PDC 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_PDC1 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_PDC2 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_UAC1 227.7
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_UAC1_2 394.300
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_UAC2 228.8
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_UAC2_3 396.200
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_UAC3 228.3
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_UAC3_1 395.400
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_UDC1 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 SPOT_UDC2 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 avg_power_lastminutes_05 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 avg_power_lastminutes_10 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 avg_power_lastminutes_15 0
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 modulstate normal
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 opertime_start 19.04.2024 05:50:12
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 opertime_stop 19.04.2024 21:13:09
setstate SunnyTripower8.0SE 2024-04-19 21:01:17 state 0
oelidoc
Hier die Definition des currentBatteryDevice
SunnyTripower8.0SE pin=BAT_P_CHARGE:W pout=BAT_P_DISCHARGE:W intotal=BAT_LOADTOTAL:W outtotal=BAT_UNLOADTOTAL:W charge=ChargeStatus cap=7700
DS_Starter
Das sieht ok aus. Und currentInverterDev?
Ein Screenshot mit der aktuellen FlowGrafik wäre auch gut.
